I am using the layer comps to file export function but when I check include ICC profile, it strips the file.
I am specifically talking about the PNG export. When I save a layer comp Manually going through FILE > Save > PNG the file saves with color profile.
When I use Layer Comps to File I select
PNG - 8 or PNG - 24 neither work
Check Include ICC profile
Check Transparency
any idea how to change this? Would make exporting a lot easier than setting it up so that it goes through the save as menu everytime.
Presumably the underlying script hasn't been properly updated or there is a bug. In the first case updating the script to include the dialog options would solve the issue.
Mylenium
Hello, what is the version of Photoshop that you are using? (to pinpoint which version might have a bug, if there is one)
photoshop CC
2015.1.2
20160113.r.355 x64
Hello, I wold first try and install PsCC 2017, to see if the bug has been squashed. You can select to keep the previous version installed.
Actually here is what I figured out.
I have updated to CC17 but the reason it wasn't working was because you need to go into save for web, and change the setting for PNGs in there. Once that is set, then you can use the batch or, layer comp to pngs...and they will adhere to the correct settings. If you set the settings in only the command prompts they will be over written by the save for web settings...
seems silly but thats the fix
