when i use lasso tool to remove unwanted object, then go to content aware...it fills unwanted area with part of original photo
Could you please post screenshots to illustrate the issue?
That is what content aware fill does. It generates content based on the rest of the image. How successful it will be is very image dependant.
Dave
You will need content within the selection that you want to replace the unwanted item.
Expand selection
Shift + F5 for content aware
Content Aware Fill references nearby surrounding area to create the replacement content. As seen in the top row, it included the boy. In the bottom row, the girl and sky were placed on a separate layer so that the only surrounding reference was the sky. Then Layers > Merge Down
