Printing crashes my Photoshop CS5 app...Help??
Aug 23, 2017 Aug 23, 2017
For several months, I have been having issues with Photoshop crashing every time I try to print from the regular “print” option pull-down. I am able to print using the “print one copy” option, but not through the regular process (which allows for color and print options). I have tried to update though the Adobe Application Manager several times, but the 12.0.4 update for Photoshop CS5 always comes back with an error message saying “There was an error downloading this update. Please quit and try again later.” - which I have done many times. Any ideas on what’s going on?? Any help available?
I'm running Photoshop CS5 extended version 12.0 on a MacBook Pro running Sierra 10.12.6
Thanks for any thoughts/advice you may have!
Kristin
2.2K
Adobe
You can install the photoshop cs5 12.0.4 update by following the Creative Suite 5.5, 5, and 4
install instructions on the following link:
https://helpx.adobe.com/creative-cloud/kb/install-creative-suite-mac-os-sierra.html
Photoshop cs5 12.0.4 update download:
Adobe - Photoshop : For Macintosh : Adobe Photoshop 12.0.4 update for Adobe Photoshop CS5
Aug 24, 2017 Aug 24, 2017
Thank you so much! I will look forward to finding some time again to try this and solve my printing problem. I really appreciate your suggestion.
Best,
Kristin
Aug 27, 2017 Aug 27, 2017
Hmmm...can't get this to load on my computer. I get the following message:
“AdobePatchInstaller” can’t be opened. You should eject the disk image."
Maybe I'm not downloading it correctly??
Right-click on the installer, choose "Open" from the context menu and confirm when asked if you want to open it.
If that does not work, we can try another thing.
Gene
Can't get anything to right click on my Mac - either with the bluetooth mouse or the mouse trackpad...
Try Ctrl + click
Yes! Got the menu to pop up this way. Unfortunately I still get the same error message: “AdobePatchInstaller” can’t be opened. You should eject the disk image.
I really appreciate all your help! If this is just going to be what it is, I understand...
Ok next step will involve "Terminal", a command line utility on your Mac. Search for Terminal.app and run it.
Follow these steps to show "Open Package Contents" in the Patch Installer.app and open the MacOS folder inside. Drag the Install executable inside that folder into the Terminal window and press Enter to start it.
The steps and screenshots are here:
Installing Creative Suite on macOS 10.12 (Sierra)
Seem as though this worked! Thank you SO much. I will have to play with Photoshop a bit later to make sure all is well, but everything seemed to go as described. Thank you, thank you!!
Kristin
You're welcome. I want to warn you that whether you install or patch CS5 in Sierra, this is what you will have to do from now on.
CS5 will never be upgraded and sooner or later will not run at all on newer MacOS versions.
Aug 28, 2017 Aug 28, 2017
Ugh! Thanks for the heads-up and for all the help!
Best,
Kristin
The Adobe Application Manager is out of date. Once you update it, the Help > Updates process should work normally.
Adobe - Adobe Application Manager : For Macintosh : Adobe Application Manager
Not only will it update Photoshop, but also Bridge and Camera Raw.
Best,
Kristin
