Invert selection while file is rotated using Rotate View tool causes crash
Aug 24, 2017 Aug 24, 2017
Hello all,
A couple of months ago, I began experiencing a Photoshop bug that continues to drive me crazy. I participated in an earlier discussion that another user created to try and find a solution (Inverting a selection causes Photoshop to instantly crash & close, what could be causing this?, but in the hopes that a power user or someone from Adobe can weigh in, I wanted to start a new discussion.
Some specifics:
Photoshop crashes (not every time, but the majority of the time, usually after working for about 5 minutes) when I select a path and invert it. The program crashes just after I hit CMD+SHIFT+I (also while using the menu button) -- but *only* when my file is "rotated" using the "Rotate View Tool".
If I've reset the view so the file is not view rotated, the program does not crash when inverting the selection.
This occurs quite often, and I'd love to find a solution. I've already reset my Photoshop preferences and tried the usual troubleshooting, but it keeps happening.
Photoshop version: Photoshop CC 2017.0.1 (20161130.r.29. x64)
Computer: Mac Pro (Mid 2010), 2x2.66 Ghz 6-Core Intel Xeon, 64 GB 1333 MHz DDR3 ECC, NVIDIA GeForce GTX 980 TI 6144MB
Operating System: OS X El Capitan v10.11.6
Happy to answer all questions in the hopes that I can fix this -- thanks so much!
704
Adobe
If you are having problem with Photoshop Crashing on your Mac. You should try posting your Mac crash report here. Some Mac user here may be able too see what your problem is and tell you what you need to do to correct the problem.
JJMack
Sep 29, 2017 Sep 29, 2017
Thanks for the suggestion. Here is the crash report that is generated when I try to invert a selection while the file is "rotated" using the "Rotate View Tool":
Process:               Adobe Photoshop CC 2017 [734]
Path:                  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
Identifier:            com.adobe.Photoshop
Version:               18.0.1 (18.0.1.29)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Adobe Photoshop CC 2017 [734]
User ID:               501
Date/Time:             2017-09-29 14:15:09.011 -0700
OS Version:            Mac OS X 10.11.6 (15G1611)
Report Version:        11
Anonymous UUID:        056FB863-13B4-6410-D572-383FF35796D5
Time Awake Since Boot: 230000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGBUS)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x00000001230a1100
Exception Note:        EXC_CORPSE_NOTIFY
VM Regions Near 0x1230a1100:
    __DATA                 0000000123093000-0000000123095000 [    8K] rw-/rwx SM=PRV  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
--> __LINKEDIT             0000000123095000-00000001230a4000 [   60K] r--/rwx SM=COW  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
    MALLOC_LARGE           00000001230a4000-00000001240a4000 [ 16.0M] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   MMXCore                       0x00000001209fc506 0x1209df000 + 120070
1   com.adobe.Photoshop           0x000000010bfd3671 0x10b6a1000 + 9643633
2   com.adobe.Photoshop           0x000000010bfe66bf 0x10b6a1000 + 9721535
3   com.adobe.Photoshop           0x000000010be6e184 0x10b6a1000 + 8180100
4   com.adobe.Photoshop           0x000000010c30b0fa 0x10b6a1000 + 13017338
5   com.adobe.Photoshop           0x000000010b761c79 0x10b6a1000 + 789625
6   com.adobe.Photoshop           0x000000010b7406b0 0x10b6a1000 + 652976
7   com.adobe.Photoshop           0x000000010b740779 0x10b6a1000 + 653177
8   com.adobe.Photoshop           0x000000010d51d19d 0x10b6a1000 + 31965597
9   com.apple.Foundation           0x00007fff93a94e2c __NSFireTimer + 95
10  com.apple.CoreFoundation       0x00007fff97f46ae4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
11  com.apple.CoreFoundation       0x00007fff97f46773 __CFRunLoopDoTimer + 1075
12  com.apple.CoreFoundation       0x00007fff97f462ca __CFRunLoopDoTimers + 298
13  com.apple.CoreFoundation       0x00007fff97f3d7c1 __CFRunLoopRun + 1841
14  com.apple.CoreFoundation       0x00007fff97f3ce28 CFRunLoopRunSpecific + 296
15  com.apple.HIToolbox           0x00007fff983a2935 RunCurrentEventLoopInMode + 235
16  com.apple.HIToolbox           0x00007fff983a276f ReceiveNextEventCommon + 432
17  com.apple.HIToolbox           0x00007fff983a25af _BlockUntilNextEventMatchingListInModeWithFilter + 71
18  com.apple.AppKit               0x00007fff8de42df6 _DPSNextEvent + 1067
19  com.apple.AppKit               0x00007fff8de42226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
20  com.adobe.Photoshop           0x000000010d51be81 0x10b6a1000 + 31960705
21  com.apple.AppKit               0x00007fff8de36d80 -[NSApplication run] + 682
22  com.adobe.Photoshop           0x000000010d51cfb2 0x10b6a1000 + 31965106
23  com.adobe.Photoshop           0x000000010d51e3b3 0x10b6a1000 + 31970227
24  com.adobe.Photoshop           0x000000010b7421fd 0x10b6a1000 + 659965
25  com.adobe.Photoshop           0x000000010babc1db 0x10b6a1000 + 4305371
26  com.adobe.Photoshop           0x000000010babc529 0x10b6a1000 + 4306217
27  libdyld.dylib                 0x00007fff93e2e5ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib         0x00007fff91701efa kevent_qos + 10
1   libdispatch.dylib             0x00007fff8c57d165 _dispatch_mgr_invoke + 216
2   libdispatch.dylib             0x00007fff8c57cdcd _dispatch_mgr_thread + 52
Thread 2:: MPSupport Worker
0   libsystem_kernel.dylib         0x00007fff91700db6 __psynch_cvwait + 10
1   libsystem_pthread.dylib       0x00007fff93742728 _pthread_cond_wait + 767
2   MultiProcessor Support         0x0000000120b266db 0x120adf000 + 292571
3   MultiProcessor Support         0x0000000120b265fb 0x120adf000 + 292347
4   MultiProcessor Support         0x0000000120b48bcd 0x120adf000 + 433101
5   libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
6   libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
7   libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 3:: MPSupport Worker
Thread 4:: MPSupport Worker
Thread 5:: MPSupport Worker
Thread 6:: MPSupport Worker
Thread 7:: MPSupport Worker
Thread 8:: MPSupport Worker
Thread 9:: MPSupport Worker
Thread 10:: MPSupport Worker
Thread 11:: MPSupport Worker
Thread 12:: MPSupport Worker
Thread 13:: MPSupport Worker
Thread 14:: MPSupport Worker
Thread 15:: MPSupport Worker
Thread 16:: MPSupport Worker
Thread 17:: MPSupport Worker
Thread 18:: MPSupport Worker
Thread 19:: MPSupport Worker
Thread 20:: MPSupport Worker
Thread 21:: MPSupport Worker
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: VulcanMsgRecv
0   libsystem_kernel.dylib         0x00007fff91700fba __recvfrom + 10
1   VulcanMessage5.dylib           0x000000011712b308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2   VulcanMessage5.dylib           0x000000011712a6cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3   VulcanMessage5.dylib           0x00000001171299c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4   VulcanMessage5.dylib           0x0000000117129888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5   VulcanMessage5.dylib           0x00000001171244c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6   VulcanMessage5.dylib           0x0000000117124f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
7   VulcanMessage5.dylib           0x00000001171248ef vcfoundation::io::Serializer::Deserialize() + 9
8   VulcanMessage5.dylib           0x0000000117128974 vcfoundation::ncomm::Connection::ReadIn() + 22
9   VulcanMessage5.dylib           0x00000001171283cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10  VulcanMessage5.dylib           0x00000001171280ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11  VulcanMessage5.dylib           0x000000011712800d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12  VulcanMessage5.dylib           0x000000011711b848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13  VulcanMessage5.dylib           0x000000011711aa86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14  VulcanMessage5.dylib           0x000000011712920c vcfoundation::thread::AbstractThread::Run() + 72
15  VulcanMessage5.dylib           0x000000011712b109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16  libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
17  libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
18  libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 26:
0   libsystem_kernel.dylib         0x00007fff916fafae semaphore_wait_trap + 10
1   libtbb.dylib                   0x000000011307e100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
2   libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
3   libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
4   libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:: BridgeTalk
0   libsystem_kernel.dylib         0x00007fff9170110a __semwait_signal + 10
1   libsystem_c.dylib             0x00007fff9d126d0f nanosleep + 199
2   com.adobe.PSAutomate           0x000000011db85f48 0x11d9a9000 + 1953608
3   com.adobe.PSAutomate           0x000000011db67d0c 0x11d9a9000 + 1830156
4   com.adobe.PSAutomate           0x000000011db85ad1 0x11d9a9000 + 1952465
Thread 50:: Bristle Physics
2   com.adobe.Photoshop           0x000000010b6ab57b 0x10b6a1000 + 42363
3   com.adobe.Photoshop           0x000000010d3cc68b 0x10b6a1000 + 30586507
4   com.adobe.Photoshop           0x000000010d3c3ed3 0x10b6a1000 + 30551763
5   com.adobe.Photoshop           0x0000000110cf4e47 0x10b6a1000 + 90521159
Thread 51:: Font Initialization
2   com.adobe.Photoshop           0x000000010ba8a431 0x10b6a1000 + 4101169
3   com.adobe.Photoshop           0x000000010d8cade8 0x10b6a1000 + 35823080
4   com.adobe.Photoshop           0x000000010d8ca4fc 0x10b6a1000 + 35820796
5   com.adobe.Photoshop           0x000000010d8cbd96 0x10b6a1000 + 35827094
6   com.adobe.Photoshop           0x0000000110cf4e47 0x10b6a1000 + 90521159
7   libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
8   libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
9   libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 52:: DeepFont
Thread 53:: com.apple.NSEventThread
0   libsystem_kernel.dylib         0x00007fff916faf72 mach_msg_trap + 10
1   libsystem_kernel.dylib         0x00007fff916fa3b3 mach_msg + 55
2   com.apple.CoreFoundation       0x00007fff97f3e114 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation       0x00007fff97f3d5dc __CFRunLoopRun + 1356
5   com.apple.AppKit               0x00007fff8df98d95 _NSEventThread + 149
Thread 54:
2   com.adobe.headlights.LogSessionFramework 0x0000000116248ccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3   com.adobe.headlights.LogSessionFramework 0x00000001162475ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4   com.adobe.headlights.LogSessionFramework 0x00000001161f5059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5   com.adobe.headlights.LogSessionFramework 0x00000001161c3cfb RealTimeProcessor::WorkerThread(int, int) + 3633
6   com.adobe.headlights.LogSessionFramework 0x0000000116246969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 55:: com.apple.NSURLConnectionLoader
5   com.apple.CFNetwork           0x00007fff9a4aca6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6   com.apple.Foundation           0x00007fff93a20c84 __NSThread__start__ + 1351
Thread 56:
2   com.adobe.headlights.LogSessionFramework 0x00000001161f6152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3   com.adobe.headlights.LogSessionFramework 0x00000001161f50db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4   com.adobe.headlights.LogSessionFramework 0x00000001161f4bae IdleTimeLogger::IdleTimeWorkerThread() + 2804
5   com.adobe.headlights.LogSessionFramework 0x0000000116246969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 57:: General Background Service
Thread 58:: Update Activation Menu Items
2   com.adobe.Photoshop           0x000000010ba08b50 0x10b6a1000 + 3570512
3   com.adobe.Photoshop           0x0000000110cf4e47 0x10b6a1000 + 90521159
4   libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
5   libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
6   libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 59:
3   com.adobe.Photoshop           0x000000010b6a695e 0x10b6a1000 + 22878
4   com.adobe.Photoshop           0x000000010b6a7e36 0x10b6a1000 + 28214
Thread 60:
Thread 61:
Thread 62:
Thread 63:: com.apple.CFSocket.private
0   libsystem_kernel.dylib         0x00007fff9170107a __select + 10
1   com.apple.CoreFoundation       0x00007fff97f7b45a __CFSocketManager + 762
Thread 64:: NetworkConfigWatcher
5   com.apple.Foundation           0x00007fff93a0fcf9 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270
6   org.chromium.ContentShell.framework 0x000000018411c564 0x183fe5000 + 1275236
7   org.chromium.ContentShell.framework 0x000000018411bd64 0x183fe5000 + 1273188
8   org.chromium.ContentShell.framework 0x00000001841533d3 0x183fe5000 + 1500115
9   org.chromium.ContentShell.framework 0x00000001841421fd 0x183fe5000 + 1430013
10  org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
11  org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
12  libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
13  libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
14  libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 65:: DnsConfigService
0   libsystem_kernel.dylib         0x00007fff91701eca kevent + 10
1   org.chromium.ContentShell.framework 0x000000018419be97 0x183fe5000 + 1797783
2   org.chromium.ContentShell.framework 0x00000001841998ad 0x183fe5000 + 1788077
3   org.chromium.ContentShell.framework 0x000000018411afd1 0x183fe5000 + 1269713
4   org.chromium.ContentShell.framework 0x00000001841533d3 0x183fe5000 + 1500115
5   org.chromium.ContentShell.framework 0x00000001841421fd 0x183fe5000 + 1430013
6   org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
7   org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
8   libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
9   libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
10  libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 66:: Chrome_DBThread
5   org.chromium.ContentShell.framework 0x000000018411c2df 0x183fe5000 + 1274591
6   org.chromium.ContentShell.framework 0x000000018411bd64 0x183fe5000 + 1273188
7   org.chromium.ContentShell.framework 0x00000001841533d3 0x183fe5000 + 1500115
8   org.chromium.ContentShell.framework 0x00000001841421fd 0x183fe5000 + 1430013
9   org.chromium.ContentShell.framework 0x0000000186cf47a8 0x183fe5000 + 47249320
10  org.chromium.ContentShell.framework 0x0000000186cf4af6 0x183fe5000 + 47250166
11  org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
12  org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
13  libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
14  libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
15  libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 67:: Chrome_FileThread
6   org.chromium.ContentShell.framework 0x0000000186cf4828 0x183fe5000 + 47249448
7   org.chromium.ContentShell.framework 0x0000000186cf4b03 0x183fe5000 + 47250179
8   org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
9   org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
10  libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
11  libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
12  libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 68:: Chrome_FileUserBlockingThread
9   org.chromium.ContentShell.framework 0x0000000186cf48a8 0x183fe5000 + 47249576
10  org.chromium.ContentShell.framework 0x0000000186cf4b10 0x183fe5000 + 47250192
Thread 69:: Chrome_ProcessLauncherThread
9   org.chromium.ContentShell.framework 0x0000000186cf4928 0x183fe5000 + 47249704
10  org.chromium.ContentShell.framework 0x0000000186cf4b1d 0x183fe5000 + 47250205
Thread 70:: Chrome_CacheThread
3   org.chromium.ContentShell.framework 0x000000018411afb9 0x183fe5000 + 1269689
6   org.chromium.ContentShell.framework 0x0000000186cf49a8 0x183fe5000 + 47249832
7   org.chromium.ContentShell.framework 0x0000000186cf4b2a 0x183fe5000 + 47250218
Thread 71:: Chrome_IOThread
6   org.chromium.ContentShell.framework 0x0000000186cf4a28 0x183fe5000 + 47249960
7   org.chromium.ContentShell.framework 0x0000000186cf4b37 0x183fe5000 + 47250231
Thread 72:: IndexedDB
9   org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
10  org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
11  libsystem_pthread.dylib       0x00007fff9374199d _pthread_body + 131
12  libsystem_pthread.dylib       0x00007fff9374191a _pthread_start + 168
13  libsystem_pthread.dylib       0x00007fff9373f351 thread_start + 13
Thread 73:: CompositorTileWorker1/133635
2   org.chromium.ContentShell.framework 0x0000000185cf61f9 0x183fe5000 + 30478841
3   org.chromium.ContentShell.framework 0x0000000184173002 0x183fe5000 + 1630210
4   org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
Thread 74:: AudioThread
Thread 75:: BrowserBlockingWorker1/136467
2   org.chromium.ContentShell.framework 0x0000000184170bd6 0x183fe5000 + 1620950
3   org.chromium.ContentShell.framework 0x0000000184170243 0x183fe5000 + 1618499
4   org.chromium.ContentShell.framework 0x0000000184173002 0x183fe5000 + 1630210
5   org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
Thread 76:: NetworkConfigWatcher
Thread 77:: Chrome_DevToolsHandlerThread
Thread 78:: handle-watcher-thread
2   org.chromium.ContentShell.framework 0x00000001865a9738 0x183fe5000 + 39601976
3   org.chromium.ContentShell.framework 0x0000000186594498 0x183fe5000 + 39515288
4   org.chromium.ContentShell.framework 0x0000000186594776 0x183fe5000 + 39516022
5   org.chromium.ContentShell.framework 0x000000018658cc03 0x183fe5000 + 39484419
6   org.chromium.ContentShell.framework 0x00000001865875ab 0x183fe5000 + 39462315
7   org.chromium.ContentShell.framework 0x0000000186587363 0x183fe5000 + 39461731
8   org.chromium.ContentShell.framework 0x00000001865872ee 0x183fe5000 + 39461614
9   org.chromium.ContentShell.framework 0x00000001841533d3 0x183fe5000 + 1500115
10  org.chromium.ContentShell.framework 0x00000001841421fd 0x183fe5000 + 1430013
Thread 79:: BrowserBlockingWorker2/141575
Thread 80:: BrowserBlockingWorker3/140563
Thread 81:: CachePoolWorker1/141323
Thread 82:
5   com.apple.Foundation           0x00007fff93b27f99 -[NSConnection run] + 149
Thread 83:: CEPMonitorThread
5   com.apple.Foundation           0x00007fff93ab9dda -[NSConcreteTask waitUntilExit] + 205
6   com.adobe.PlugPlugOwl         0x0000000113807c4b -[HtmlEngineMonitor monitorThreadProc] + 160
7   com.apple.Foundation           0x00007fff93a20c84 __NSThread__start__ + 1351
Thread 84:: Generator
0   libsystem_kernel.dylib         0x00007fff91701582 __wait4 + 10
1   com.adobe.Photoshop           0x000000010da363b0 0x10b6a1000 + 37311408
2   com.adobe.Photoshop           0x000000010da34b9e 0x10b6a1000 + 37305246
Thread 85:: GeneratorReadPipe
0   libsystem_kernel.dylib         0x00007fff91702362 read + 10
1   com.adobe.Photoshop           0x000000010d614275 0x10b6a1000 + 32977525
2   com.adobe.Photoshop           0x0000000110cf4e47 0x10b6a1000 + 90521159
Thread 86:: GeneratorWritePipe
1   libtbb.dylib                   0x0000000113070cf4 tbb::internal::concurrent_queue_base_v3::internal_pop(void*) + 580
2   com.adobe.Photoshop           0x000000010d6144b5 0x10b6a1000 + 32978101
Thread 87:
Thread 88:: CEPMonitorThread
Thread 89:: Background Save
3   com.adobe.Photoshop           0x000000010d61016a 0x10b6a1000 + 32960874
4   com.adobe.Photoshop           0x000000010d60ddd9 0x10b6a1000 + 32951769
Thread 90:: cr_scratch
2   com.adobe.CameraRaw           0x0000000bcc48203c 0xbcba48000 + 10723388
3   com.adobe.CameraRaw           0x0000000bcc3f5d1b 0xbcba48000 + 10149147
4   com.adobe.CameraRaw           0x0000000bcc11fd41 0xbcba48000 + 7175489
Thread 91:: Transform Tile Locking
2   com.adobe.Photoshop           0x000000010c8e54c3 0x10b6a1000 + 19154115
Thread 92:
1   libsystem_pthread.dylib       0x00007fff9374275e _pthread_cond_wait + 821
2   com.apple.CoreServices.CarbonCore 0x00007fff9d217a93 TSWaitOnConditionTimedRelative + 147
3   com.apple.CoreServices.CarbonCore 0x00007fff9d21766e TSWaitOnSemaphoreCommon + 406
4   com.apple.CoreServices.CarbonCore 0x00007fff9d1de6ea AsyncFileThread(void*) + 275
Thread 93:
0   libsystem_kernel.dylib         0x00007fff917015e2 __workq_kernreturn + 10
1   libsystem_pthread.dylib       0x00007fff93741578 _pthread_wqthread + 1283
2   libsystem_pthread.dylib       0x00007fff9373f341 start_wqthread + 13
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
Thread 109:
Thread 110:: Dispatch queue: NSCGSDisableUpdates
2   com.apple.CoreGraphics         0x00007fff874aaa42 _CGSReenableUpdateForConnection + 92
3   com.apple.CoreGraphics         0x00007fff874aa70d CGSReenableUpdateToken + 469
4   libdispatch.dylib             0x00007fff8c58293d _dispatch_call_block_and_release + 12
5   libdispatch.dylib             0x00007fff8c57740b _dispatch_client_callout + 8
6   libdispatch.dylib             0x00007fff8c57c03b _dispatch_queue_drain + 754
7   libdispatch.dylib             0x00007fff8c582707 _dispatch_queue_invoke + 549
8   libdispatch.dylib             0x00007fff8c57740b _dispatch_client_callout + 8
9   libdispatch.dylib             0x00007fff8c57b29b _dispatch_root_queue_drain + 1890
10  libdispatch.dylib             0x00007fff8c57ab00 _dispatch_worker_thread3 + 91
11  libsystem_pthread.dylib       0x00007fff937414de _pthread_wqthread + 1129
12  libsystem_pthread.dylib       0x00007fff9373f341 start_wqthread + 13
Thread 111:
Thread 112:
Thread 113:
Thread 114:
Thread 115:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000001  rbx: 0x0000000000000000  rcx: 0xffffffffffffd100  rdx: 0x0000000000000001
  rdi: 0x00000001230a1100  rsi: 0x0000000000000aee  rbp: 0x0000000000000000  rsp: 0x00007fff5455b968
   r8: 0x0000000000000000   r9: 0x0000000000000001  r10: 0x0000000000000000  r11: 0x0000000000001000
  r12: 0x0000000000000001  r13: 0x00000001230a1100  r14: 0x00000000ffffd100  r15: 0xffffffffffffd0fe
  rip: 0x00000001209fc506  rfl: 0x0000000000010297  cr2: 0x00000001230a1100
Logical CPU:     20
Error Code:      0x00000006
Trap Number:     14
Binary Images:
       0x10b6a1000 -        0x111ee7f4f +com.adobe.Photoshop (18.0.1 - 18.0.1.29) <AE656ED1-6240-34A2-83CA-258C4A18157C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
       0x11306f000 -        0x1130a6fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
       0x1130e9000 -        0x11310cfe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
       0x113144000 -        0x113242ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
       0x113271000 -        0x1132e0ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <B1AD98B3-6ED3-34CE-90A3-F2D798BB0439> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
       0x11336c000 -        0x1134f6fff +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <FED42048-AA7F-35D5-87AC-03BB1B9DB306> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
       0x113650000 -        0x113753fff +com.adobe.amtlib (10.0.0.47 - 10.0.0.47) <AD7B1E56-04A5-355A-AD70-DA2464879FC3> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
       0x11376e000 -        0x1139e4ff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
       0x113cb8000 -        0x113d57ff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.4) <A75C85DD-5C39-343D-91A1-B6601FF46C32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
       0x113da8000 -        0x113e51fff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.4) <1B9BAF47-DDB1-35DB-8CD1-7231566F3C88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
       0x113eb1000 -        0x113f27fff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37447) <4756E8D2-6541-3A34-9A40-FED989F1B05D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
       0x114013000 -        0x1140bcff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
       0x1140ec000 -        0x1140f1fff  org.twain.dsm (1.9.5 - 1.9.5) <F7AA3C5E-4FB0-379D-8F79-AD06669D087E> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
       0x1140fb000 -        0x114117fff +com.adobe.ahclientframework (2.0.0.1 - 2.0.0.1) <075BD455-9D2E-3B8A-8C83-8B40D3059A55> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
       0x114124000 -        0x114128fff  com.apple.agl (3.3.1 - AGL-3.3.1) <2FC3E30C-5370-3369-B8D1-1C7050A4A85A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x114130000 -        0x114131fff  libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
       0x114136000 -        0x1142c9ff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <C849EDD6-B535-3200-A418-817EB0D29B0C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
       0x114315000 -        0x11467bff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
       0x1146f0000 -        0x114714fff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
       0x114740000 -        0x114a07ff7 +com.adobe.AGM (AdobeAGM 4.30.60.37447 - 4.30.60.37447) <71B74E67-BF19-3C2A-A843-8FC82C183138> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
       0x114a79000 -        0x114d76ff7 +com.adobe.CoolType (AdobeCoolType 5.15.00.37447 - 5.15.00.37447) <7BAD2049-203D-3A5F-B7CE-4F11C7361100> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
       0x114dc6000 -        0x114de9ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
       0x114df6000 -        0x114e1aff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
       0x114e40000 -        0x114f6aff7 +com.winsoft.wrservices (WRServices 12.0.0 - 12.0.0) <DC848A40-2FD7-3C18-8653-242100970FF6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
       0x114fbe000 -        0x115107ffb +com.adobe.ACE (AdobeACE 2.20.02.37447 - 2.20.02.37447) <A8CFE20B-3A58-3337-9BDC-1B623999BFFC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
       0x115121000 -        0x11513dffb +com.adobe.BIB (AdobeBIB 1.2.03.37447 - 1.2.03.37447) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
       0x115149000 -        0x115209ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.36529) <578A7A58-7F7D-3727-9D9A-4748CA20C1B2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
       0x115253000 -        0x1153cdfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
       0x115525000 -        0x115a7dfef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
       0x1160f0000 -        0x11628afff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
       0x116362000 -        0x1170a7fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
       0x1170bb000 -        0x1170e4ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
       0x1170fe000 -        0x117101fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
       0x11710d000 -        0x117148ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
       0x117194000 -        0x117290fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
       0x11733f000 -        0x1174a3ff7 +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <F35C19E3-EADE-3DCD-A487-394A474895CE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
       0x1174f7000 -        0x1175f1ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
       0x117608000 -        0x11770bff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
       0x11775b000 -        0x1178a2fef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
       0x1179fe000 -        0x117a19fff +CITThreading (???) <36EB8576-8BCB-3E23-8191-D1CA3E2DC6C5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
       0x117a5a000 -        0x117c7cff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
       0x117cd6000 -        0x117eb3ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
       0x117f9d000 -        0x11822fffb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <B5655C08-3BF8-3F17-A990-54E52F392CB3> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
       0x1182b5000 -        0x1183e9fff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
       0x118685000 -        0x118687ff7  com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x11d6ed000 -        0x11d8e0fff  com.nvidia.web.GeForceMTLDriverWeb (10.11.14 - 10.1.1) <293ED998-72BF-33D0-AC42-282B8122F6A1> /System/Library/Extensions/GeForceMTLDriverWeb.bundle/Contents/MacOS/GeForceMTLDriverWeb
       0x11d9a9000 -        0x11dde6ff7 +com.adobe.PSAutomate (18.0.1 - 18.0.1) <CB76414A-5F97-3773-88A0-E2AFCA58AEDC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
       0x11e0d8000 -        0x11e1d8ff3 +com.adobe.ps.spaces (18.0.1 - 18.0.1) <57CC47E2-045B-38B6-AD41-A431AE4DAD09> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
       0x11e207000 -        0x11e23efff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x11e267000 -        0x11e280fff  libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
       0x11ee2c000 -        0x11ee47fff  com.apple.security.csparser (3.0 - 57337.60.3) <1E3D798B-2878-3486-84EE-14D609B88A36> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
       0x11fc24000 -        0x11fc40ff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
       0x11fc46000 -        0x11fc68ff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
       0x11fc6d000 -        0x11fc7cff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
       0x11fc81000 -        0x11fc93fff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
       0x120481000 -        0x120485fff  libFontRegistryUI.dylib (155.2) <8346E80E-5832-3944-A750-FBB9D328C2FE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x120782000 -        0x1207c5ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
       0x1207e1000 -        0x1207e9fff +FastCore (18.0.1 - 18.0.1) <323940C3-8650-399F-838E-DEDABD28C89E> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
       0x1209df000 -        0x120a5bfe7 +MMXCore (18.0.1 - 18.0.1) <BF90AFD4-7412-3D3D-B3CE-3B9F9D02B340> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
       0x120adf000 -        0x120b56ff7 +MultiProcessor Support (18.0.1 - 18.0.1) <C655E4E8-B03F-3CBA-9CC3-8F213B73C1EE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
       0x122f34000 -        0x123083fff +IMSLib.dylib (10.0.0.1 - 10.0.0.1) <65AFDE5C-E1BB-3EC0-B59E-2F73453AA996> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
       0x128608000 -        0x1286adfff  ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
       0x18160f000 -        0x181621ff7 +MeasurementCore (18.0.1 - 18.0.1) <6DE40DF3-1951-3226-BAFB-F5C751520A64> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
       0x181b31000 -        0x181babff7  com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
       0x183fe5000 -        0x188812fb7 +org.chromium.ContentShell.framework (47.0.2526.16 - 2526.16) <7B368F04-4BDD-3D3C-9BF7-F015293D4368> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
       0x18906a000 -        0x1899d7fff  com.nvidia.web.GeForceGLDriverWeb (10.11.14 - 10.1.1) <0D0C682E-CE22-3724-B251-05A6736FC883> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/GeForceGLDriverWeb
       0x18a4dd000 -        0x18afeaff7  libclhWeb.dylib (0) <4FB1DBC0-6E02-3B9A-A6B4-F225B0CDCD75> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/libclhWeb.dylib
       0x18b7c8000 -        0x18b7faff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
       0x18b806000 -        0x18b82ffff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
       0x18d443000 -        0x18d443ff7 +cl_kernels (???) <EA673946-537D-49E6-9B7C-D8DBDEEB2D06> cl_kernels
       0xbcba48000 -        0xbcf00ffe7 +com.adobe.CameraRaw (9.12 [784] - 9.12f784) <03C19329-CEF8-3314-84E3-DDD76A674910> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
       0xbd3e43000 -        0xbd46e7ff7  com.nvidia.web.GeForceAIRPluginWeb (10.11.14 - 10.1.1) <C932D9E8-289A-30BD-AB3B-C54948201D3E> /System/Library/Extensions/GeForceAIRPluginWeb.bundle/Contents/MacOS/GeForceAIRPluginWeb
       0xbda200000 -        0xbda8f8ffb  libairptxasWeb.dylib (0) <DED23148-9DF7-30AC-8D64-9FB4676C9D40> /System/Library/Extensions/GeForceAIRPluginWeb.bundle/Contents/MacOS/libairptxasWeb.dylib
       0xbdbd4f000 -        0xbdbe3702f + (???) <2E1BD5A6-F029-3BA0-8966-2467A20C855F>
    0x7fff66e6a000 -     0x7fff66ea1a47  dyld (360.22) <C8E77F6D-CE86-3C5B-8576-2584A799B51E> /usr/lib/dyld
    0x7fff8722e000 -     0x7fff8723afff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff8723b000 -     0x7fff87448fff  libicucore.A.dylib (551.51.5) <2D3634CA-A87A-37A9-A3F4-C3E3106C2A33> /usr/lib/libicucore.A.dylib
    0x7fff87449000 -     0x7fff886affff  com.apple.CoreGraphics (1.600.0 - 960.7) <82D77440-30B2-3DCF-9414-88EC57CAD6CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff886de000 -     0x7fff88785fff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff88786000 -     0x7fff88798fff  libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
    0x7fff888f1000 -     0x7fff8894ffff  com.apple.SystemConfiguration (1.14 - 1.14) <ACAEDA14-FAA0-3F14-B476-DE492A52D383> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff88a79000 -     0x7fff88ab3ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff88b11000 -     0x7fff88d32ff7  com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff88d92000 -     0x7fff88d95ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff88ea0000 -     0x7fff88fcdfff  com.apple.CoreText (352.0 - 494.14) <93E0D8C3-D5DD-3EBB-9CC1-831C46572133> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff8902f000 -     0x7fff8904aff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
    0x7fff8904b000 -     0x7fff890dafff  com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff8916b000 -     0x7fff8916bfff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff893bc000 -     0x7fff8940efff  com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff89414000 -     0x7fff89464ff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff89467000 -     0x7fff894c5fff  com.apple.CoreServices.OSServices (728.13 - 728.13) <477EA3F9-D13E-3D83-ABAD-4DC7DB134CF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff894f2000 -     0x7fff89500fff  com.apple.IntlPreferences (2.0 - 192) <388C5784-7713-36B0-B08B-5163E6B04002> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fff89501000 -     0x7fff89503ff7  libquarantine.dylib (80) <B3B7B630-9012-3DA3-9458-5C009625E606> /usr/lib/system/libquarantine.dylib
    0x7fff89538000 -     0x7fff898abfff  com.apple.FinderKit (1.4.4 - 1.4.4) <76E52C7F-CA82-337E-BF8E-9961F11C4B8D> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
    0x7fff8994a000 -     0x7fff8aa33ff3  com.apple.WebCore (11601 - 11601.7.5) <9153DA7E-1625-382A-8257-8D4293F06F7F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff8aa34000 -     0x7fff8ae0cfef  com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff8ae0d000 -     0x7fff8ae5cff7  com.apple.opencl (2.7.0 - 2.7.0) <DAEC71D4-E0E7-3E24-BB44-C977A798C575> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff8ae5d000 -     0x7fff8aea9ff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff8aeaa000 -     0x7fff8aeb4fff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff8aeb6000 -     0x7fff8aec1fff  com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff8aef0000 -     0x7fff8aef0fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff8aef1000 -     0x7fff8af58fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff8af6c000 -     0x7fff8af6dfff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
    0x7fff8af6e000 -     0x7fff8af71ff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff8af72000 -     0x7fff8af80ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
    0x7fff8afaf000 -     0x7fff8b44affb  com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff8b44b000 -     0x7fff8b53dff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
    0x7fff8b599000 -     0x7fff8b599ff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
    0x7fff8b5a2000 -     0x7fff8b5a9ff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fff8b667000 -     0x7fff8b9d2657  libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
    0x7fff8b9d3000 -     0x7fff8b9e9fff  com.apple.CoreMediaAuthoring (2.2 - 953) <A8F1B6EE-8ABE-3DC2-9829-A268D016648E> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fff8baec000 -     0x7fff8bd7effb  com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff8bd7f000 -     0x7fff8bd81fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff8bd82000 -     0x7fff8bd84fff  libCVMSPluginSupport.dylib (12.1) <20BA72AF-C7C5-3551-8F59-E1AED5FC69F0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff8be08000 -     0x7fff8be2afff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff8be2b000 -     0x7fff8be4dff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff8c18a000 -     0x7fff8c2cffff  com.apple.QTKit (7.7.3 - 2943.13) <3E3DB3DD-8D7E-3478-B020-F975CCAAE522> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fff8c2d4000 -     0x7fff8c2dfff7  libkxld.dylib (3248.70.3) <BAD04BB1-5BFE-3D88-ADDE-23FED2DD2942> /usr/lib/system/libkxld.dylib
    0x7fff8c2e0000 -     0x7fff8c2e4fff  libGIF.dylib (1463) <3F84E60B-18E5-3897-8494-DFB1ACE76829> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff8c54a000 -     0x7fff8c54aff7  liblaunch.dylib (765.70.1) <96D7C3EE-82E2-39AB-870F-B317A030E86D> /usr/lib/system/liblaunch.dylib
    0x7fff8c54b000 -     0x7fff8c567ff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
    0x7fff8c575000 -     0x7fff8c5a2fff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
    0x7fff8c5a3000 -     0x7fff8c5b1fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
    0x7fff8c5c8000 -     0x7fff8c5e4fff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff8c5e5000 -     0x7fff8c626ff7  libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff8c77e000 -     0x7fff8d0b2f5f  libLLVMContainer.dylib (119.5) <09A35A20-7CDD-3E5A-94B4-5F1E5CFBC3D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libLLVMContainer.dylib
    0x7fff8d0b3000 -     0x7fff8d106ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
    0x7fff8d107000 -     0x7fff8d219fef  libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff8d21a000 -     0x7fff8d220ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff8d2f4000 -     0x7fff8d2f8fff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff8d302000 -     0x7fff8d303ff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff8d340000 -     0x7fff8d4befff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff8d5f2000 -     0x7fff8d661fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff8d662000 -     0x7fff8d77ffff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
    0x7fff8d7b0000 -     0x7fff8dcd2fff  com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff8dcd3000 -     0x7fff8dcd8fff  com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff8dd55000 -     0x7fff8dda7fff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <4F5F5CD6-631F-3C97-AA62-7DF19BD5EC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff8dda8000 -     0x7fff8ddf9fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff8ddfa000 -     0x7fff8ea23ff7  com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff8ea24000 -     0x7fff8ea25ff7  libodfde.dylib (23) <F84CB160-D638-3190-B6F5-A262E9AF09F6> /usr/lib/libodfde.dylib
    0x7fff8ea26000 -     0x7fff8eadfff7  libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff8eb78000 -     0x7fff8eba6ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff8ed58000 -     0x7fff8ed95ff3  com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff8ed96000 -     0x7fff8ee41fff  com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff8eea4000 -     0x7fff8eec3ff7  com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff8eec4000 -     0x7fff8eeedff7  libxpc.dylib (765.70.1) <4FB1311F-4032-3F56-BF0B-CFF45D78FB01> /usr/lib/system/libxpc.dylib
    0x7fff8eeee000 -     0x7fff8efceff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
    0x7fff8efcf000 -     0x7fff8f0beff7  libxml2.2.dylib (29.14) <02077D26-0AB0-347A-8AF2-FADE3CFC296C> /usr/lib/libxml2.2.dylib
    0x7fff8f0bf000 -     0x7fff8f0f2ff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff8f128000 -     0x7fff8f130fff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff8f134000 -     0x7fff8f13cfff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
    0x7fff8f140000 -     0x7fff8f146fff  com.apple.IOAccelerator (205.11 - 205.11) <3E86AB1B-C1CF-307D-900F-385C8D8C534A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff8f147000 -     0x7fff8f15cff3  libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff8f15d000 -     0x7fff8f177ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
    0x7fff8f17a000 -     0x7fff8f17cfff  libCGXType.A.dylib (970) <A931200A-B248-39EF-8A8B-311D881BE372> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff8f18e000 -     0x7fff8f19cfff  com.apple.opengl (12.1.0 - 12.1.0) <12EBDE6A-2F44-3429-8337-2BB36870BFD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff8f1ae000 -     0x7fff8f4ecff7  com.apple.WebKit (11601 - 11601.7.8) <58A8B070-2AE4-3909-AE1D-7A7DF34AA268> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff8f51e000 -     0x7fff8f56afff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff8f56b000 -     0x7fff8f7d8fff  com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff8f7d9000 -     0x7fff8f7eaff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
    0x7fff8f7eb000 -     0x7fff8f7ebfff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff8f7ec000 -     0x7fff8f81eff7  libTrueTypeScaler.dylib (158.7) <020536E5-C032-30B5-864C-920D5F7DB6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff8f81f000 -     0x7fff8f836ff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
    0x7fff8fad3000 -     0x7fff8ff01fff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff8ff02000 -     0x7fff8ff33ff7  libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
    0x7fff8ff6b000 -     0x7fff8ff6cfff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
    0x7fff8ff6d000 -     0x7fff8ff78fff  libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff90078000 -     0x7fff9007dfff  com.apple.DiskArbitration (2.7 - 2.7) <8CB47F4A-0FD2-343A-93C8-965174F6F24F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff9007e000 -     0x7fff90093fff  com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
    0x7fff90094000 -     0x7fff900faff7  libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
    0x7fff900fb000 -     0x7fff900fbfff  com.apple.CoreServices (728.13 - 728.13) <CFE3EE73-A3F5-3824-9210-0790C07120F3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff900fc000 -     0x7fff9010bfe7  com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff9010f000 -     0x7fff90118fff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
    0x7fff90131000 -     0x7fff901c7fff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff907bc000 -     0x7fff90860fff  com.apple.Bluetooth (4.4.6 - 4.4.6f1) <D8ED953B-AD7D-3FE2-8631-E9CBCF6EBAB9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff90861000 -     0x7fff90861fff  libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fff90862000 -     0x7fff90868fff  com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fff908b4000 -     0x7fff90a7dff7  com.apple.ImageIO.framework (3.3.0 - 1462) <1D8FF28C-5DBB-3D23-8CF0-75269C1CE84D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff90a7e000 -     0x7fff90a9aff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
    0x7fff90add000 -     0x7fff90adefff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
    0x7fff90adf000 -     0x7fff90ae4fff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff90b53000 -     0x7fff90b7ffff  com.apple.framework.SystemAdministration (1.0 - 1.0) <1318B6A5-FFC3-3615-914D-95CBFE5BA727> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fff90b80000 -     0x7fff90b8cfff  com.apple.CacheDelete (1.0 - 1) <678B521D-5B50-3137-A972-33F2DF1D7A5A> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
    0x7fff90ba6000 -     0x7fff90babff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
    0x7fff90c33000 -     0x7fff90c8eff7  libTIFF.dylib (1463) <5C02D055-02D3-37FE-AABC-487301080941> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff90c9e000 -     0x7fff90ca7ff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
    0x7fff90d48000 -     0x7fff90d50fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff90d51000 -     0x7fff90da3fff  com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff90da4000 -     0x7fff90dacfef  libcldcpuengine.dylib (2.7.3) <745C41A3-CEC0-3BF5-91DC-FCB140A3DACE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff90dad000 -     0x7fff90dafff7  libRadiance.dylib (1463) <11392BBE-6DAC-3ADD-A0C0-CD653B9AEDE3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff90db0000 -     0x7fff90dc0fff  libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff90df2000 -     0x7fff90e20ff7  libsandbox.1.dylib (460.60.3) <C8B9F633-EA0C-35CF-9207-1AFDF694EEAD> /usr/lib/libsandbox.1.dylib
    0x7fff90e86000 -     0x7fff90ea3ff7  com.apple.pluginkit.framework (1.0 - 1) <0BA96479-0451-3DA9-A2AC-FE1D86D383AB> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
    0x7fff90ea8000 -     0x7fff90ec3fff  com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff91134000 -     0x7fff9113cfff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff91181000 -     0x7fff91186ff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
    0x7fff91187000 -     0x7fff911b0ff7  libxslt.1.dylib (14.5) <8E03110E-1529-3BE8-B5F4-052A47A1674C> /usr/lib/libxslt.1.dylib
    0x7fff91325000 -     0x7fff9144cfff  com.apple.LaunchServices (728.13 - 728.13) <91147A89-9D0D-3272-AD05-48E2835BD8D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff9144d000 -     0x7fff9144efff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff9144f000 -     0x7fff916e9ff3  com.apple.security (7.0 - 57337.60.3) <4BF5CF26-6E34-35EC-8D41-58ED65F9BFB8> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff916ea000 -     0x7fff91708ff7  libsystem_kernel.dylib (3248.70.3) <69D68230-7793-3D11-B49E-BA3A6D5137B8> /usr/lib/system/libsystem_kernel.dylib
    0x7fff918ca000 -     0x7fff918f5ff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fff918f6000 -     0x7fff91901ff7  libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
    0x7fff91908000 -     0x7fff91937ffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
    0x7fff91c5b000 -     0x7fff91e1bffb  libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff91e48000 -     0x7fff91e53ff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
    0x7fff91e54000 -     0x7fff91ec2ff7  com.apple.ApplicationServices.ATS (377 - 394.4) <CB64C2B7-828A-3C4C-8F3C-72B78630CD94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff91ec3000 -     0x7fff91eeeffb  libarchive.2.dylib (33.20.2.1.1) <BC764A1E-573A-3D95-A3CC-1758935ADC56> /usr/lib/libarchive.2.dylib
    0x7fff91eef000 -     0x7fff91f00ff7  libsystem_trace.dylib (201.10.3) <4F626911-011B-3E9C-8D61-C5EBA79013F0> /usr/lib/system/libsystem_trace.dylib
    0x7fff91f0a000 -     0x7fff91f20ff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff91f21000 -     0x7fff91f23ff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
    0x7fff91f24000 -     0x7fff91f27fff  libspindump.dylib (197.1) <B86EE257-4429-32E9-B98D-B12BFF2A373B> /usr/lib/libspindump.dylib
    0x7fff91f28000 -     0x7fff91f76fff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
    0x7fff91f77000 -     0x7fff91f79fff  com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff91f7a000 -     0x7fff91fa4ff7  GLRendererFloat (12.1) <0412B850-BB25-33B1-AF0D-8E6297D4620E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff91fe7000 -     0x7fff9200cff7  libPng.dylib (1463) <17F67BF3-4A78-3587-AAE4-E50A71BDD4CB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff9200d000 -     0x7fff9200ffff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff92010000 -     0x7fff92037fff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff92064000 -     0x7fff9206cfef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
    0x7fff9206d000 -     0x7fff92084ff7  libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
    0x7fff92127000 -     0x7fff924a5ff3  com.apple.VideoToolbox (1.0 - 1731.15.207) <6C7C261F-CB65-3AF1-92E7-16ACAD371EF4> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff9250a000 -     0x7fff9251bfff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
    0x7fff92524000 -     0x7fff92541ff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <707C6ED6-B8C0-38D4-B45A-7F2F689BD157> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff92813000 -     0x7fff9296eff3  com.apple.WebKitLegacy (11601 - 11601.7.8) <F41E6CAF-1157-3868-9FAC-D074FCE74BB9> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
    0x7fff9330e000 -     0x7fff93353ff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff93354000 -     0x7fff933cbfeb  libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
    0x7fff933cc000 -     0x7fff933ccfff  com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff933cd000 -     0x7fff933d8fff  libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
    0x7fff933d9000 -     0x7fff93523ff7  com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff93529000 -     0x7fff9361bff7  libJP2.dylib (1463) <D107FF52-7FD6-3A5E-B40E-F3D0F1FF651D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff9361c000 -     0x7fff9361cfff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff9361d000 -     0x7fff93630fff  com.apple.SafariServices.framework (11604 - 11604.1.38.1.7) <5B649F4B-09D3-3AAC-9801-B6084B91E7D7> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fff9373e000 -     0x7fff93747ff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
    0x7fff93748000 -     0x7fff939defff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
    0x7fff939eb000 -     0x7fff93d3fff7  com.apple.Foundation (6.9 - 1259.31) <EBB5BE3F-1FE9-3231-B53B-149CDEE8BCA9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff93d8e000 -     0x7fff93e16fff  com.apple.CoreSymbolication (3.1 - 58048.1) <C1A1A8DB-8A51-3A21-865A-3CEF22A0E67A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff93e2b000 -     0x7fff93e2effb  libdyld.dylib (360.22) <7C1BBC59-FA8A-3BDF-B209-02167832E7D1> /usr/lib/system/libdyld.dylib
    0x7fff93e2f000 -     0x7fff93fbbff7  libGLProgrammability.dylib (12.1) <6D4C193C-5F7B-3E82-81D9-D14D25BBD962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff93fe4000 -     0x7fff93fedff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff93fee000 -     0x7fff94001fff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fff94002000 -     0x7fff9401bfe7  libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
    0x7fff9401c000 -     0x7fff94027fff  com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff94832000 -     0x7fff94835ffb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
    0x7fff94836000 -     0x7fff9483efff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
    0x7fff94840000 -     0x7fff94919fff  com.apple.CoreMedia (1.0 - 1731.15.207) <70CAD4A7-3F8B-3767-A420-98BE1062C230> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff95179000 -     0x7fff951c7ff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
    0x7fff95422000 -     0x7fff95960ff7  com.apple.MediaToolbox (1.0 - 1731.15.207) <63AD3FB7-BAD3-3040-8A99-843033F24CF6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff95983000 -     0x7fff95b2fff7  com.apple.avfoundation (2.0 - 1046.9.12) <41BDD03F-5545-3B9F-8DD7-7106485BAE8B> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff95b35000 -     0x7fff95b59ff7  libJPEG.dylib (1463) <11227D36-EA80-3D5B-A7D3-F2AC6C7497EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff95cc7000 -     0x7fff95dadff7  libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff95dae000 -     0x7fff95e0efff  com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff96029000 -     0x7fff96042fff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff96049000 -     0x7fff96095ffb  com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff96096000 -     0x7fff960b0fff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff960b1000 -     0x7fff960d8fff  com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fff9610d000 -     0x7fff96122fff  com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff96123000 -     0x7fff961dcff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff9623d000 -     0x7fff962ccff7  libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
    0x7fff96337000 -     0x7fff9637cff3  libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff9638a000 -     0x7fff967b4fff  com.apple.ModelIO (1.0 - 1) <8838E0E1-ACB3-3CE8-ABDC-C787D8B3F247> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
    0x7fff967b7000 -     0x7fff967cefff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
    0x7fff967d4000 -     0x7fff96884fff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff968c1000 -     0x7fff968e0ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fff968ec000 -     0x7fff96af7fff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
    0x7fff96af8000 -     0x7fff96b21fff  com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff96c6c000 -     0x7fff96c70fff  com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fff96c96000 -     0x7fff96cc7fff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff96cc8000 -     0x7fff96cd4fff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff96cd7000 -     0x7fff96e82ffb  GLEngine (12.1) <278B3208-B0D0-3FAE-AC23-A4FA06837311> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff96e83000 -     0x7fff96e83fff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff96e84000 -     0x7fff96e92fff  com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fff96ea1000 -     0x7fff96ed1ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff97893000 -     0x7fff978d1ff7  libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff978d2000 -     0x7fff97947fff  com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff9794b000 -     0x7fff979ebfff  com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff97c05000 -     0x7fff97c07fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff97c08000 -     0x7fff97c11ff7  com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff97c12000 -     0x7fff97c63ff7  libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
    0x7fff97c64000 -     0x7fff97c64fff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
    0x7fff97c7f000 -     0x7fff97cb3ff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff97cb4000 -     0x7fff97cb6ff7  com.apple.xpc.ServiceManagement (1.0 - 1) <B4181284-D588-3A20-93F3-B4FA882BC9A8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff97cb7000 -     0x7fff97d0cfff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff97d0d000 -     0x7fff97d4fff7  com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff97d50000 -     0x7fff97d51ffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
    0x7fff97d76000 -     0x7fff97d78ffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
    0x7fff97d86000 -     0x7fff97d88fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
    0x7fff97d89000 -     0x7fff97de5fff  com.apple.Suggestions (5.0 - 180) <450BCB58-786F-37DC-9AC7-2E3D13198032> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
    0x7fff97de6000 -     0x7fff97deafff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
    0x7fff97eb4000 -     0x7fff9832afff  com.apple.CoreFoundation (6.9 - 1259.11) <B8056BE3-151B-3003-91C9-6720CF04937B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff9832b000 -     0x7fff9832eff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff9832f000 -     0x7fff98343fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
    0x7fff98371000 -     0x7fff98371fff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff98372000 -     0x7fff98667fff  com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff98668000 -     0x7fff98670ffb  libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff98671000 -     0x7fff98747ffb  com.apple.DiskImagesFramework (10.11.4 - 417.4) <FB30D069-648F-3FB2-AA55-FC603606C49E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff98748000 -     0x7fff98757ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff98e47000 -     0x7fff98e52fff  com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff98e6c000 -     0x7fff98e6ffff  com.apple.IOSurface (108.2.4 - 108.2.4) <E7A63C0D-2FDA-3BC6-947D-07E3C4A13110> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff9907a000 -     0x7fff9908dfff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff99095000 -     0x7fff9909dfff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff9909e000 -     0x7fff99127ff7  com.apple.PerformanceAnalysis (1.0 - 1) <9C57BB91-46D6-3FB6-A5A2-8DB1CFE86B72> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff99128000 -     0x7fff99224fff  libFontParser.dylib (158.7) <393EFEA3-42B7-38DA-99DA-D01DEAA734CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff993c4000 -     0x7fff9943bff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fff9943c000 -     0x7fff99adbffb  com.apple.JavaScriptCore (11601 - 11601.7.8) <38585ADC-1AD4-3BD2-8972-B90344CE57C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff99adc000 -     0x7fff99aecff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff99b16000 -     0x7fff99b50fff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff99f74000 -     0x7fff99f79fff  com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff99f7a000 -     0x7fff99fa4ff7  libc++abi.dylib (307.4) <D24E06BF-6522-3C4A-BD0C-11C42BA4D8E8> /usr/lib/libc++abi.dylib
    0x7fff99fb5000 -     0x7fff99fe4fff  com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fff99ff4000 -     0x7fff9a081dd7  com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff9a082000 -     0x7fff9a190ff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff9a191000 -     0x7fff9a196ff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fff9a197000 -     0x7fff9a1a3fff  com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff9a1a4000 -     0x7fff9a372ff3  com.apple.QuartzCore (1.11 - 410.14) <06A2BE20-38CB-3A89-9629-A782829DF977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff9a373000 -     0x7fff9a3e7ff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff9a3e8000 -     0x7fff9a3ebfff  libsystem_sandbox.dylib (460.60.3) <2DDCB4AF-3037-34E5-A451-6846AFB9B85C> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff9a3ec000 -     0x7fff9a432ff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
    0x7fff9a4a5000 -     0x7fff9a72cfff  com.apple.CFNetwork (760.6.5 - 760.6.5) <8A36BBA6-F100-3F39-9711-2FA49D412987> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff9a740000 -     0x7fff9a744fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
    0x7fff9a74e000 -     0x7fff9a834fef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
    0x7fff9a835000 -     0x7fff9a8a0ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff9a9ac000 -     0x7fff9adaefff  libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff9adaf000 -     0x7fff9ae67ff7  com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
    0x7fff9ae68000 -     0x7fff9ae8cfff  com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff9aec2000 -     0x7fff9afadff7  com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff9afae000 -     0x7fff9afaffff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff9afb0000 -     0x7fff9afccff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
    0x7fff9b02d000 -     0x7fff9b064ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff9b0d0000 -     0x7fff9b0d3fff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff9b0d4000 -     0x7fff9b592fcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff9b597000 -     0x7fff9b5c6ff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff9b64a000 -     0x7fff9b65afff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
    0x7fff9b65b000 -     0x7fff9b6cfff3  com.apple.securityfoundation (6.0 - 55126) <3FF6D6E0-0C5D-385A-A97E-441D3947EFAB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff9b6d0000 -     0x7fff9b6f4fff  com.apple.MultitouchSupport.framework (304.12 - 304.12) <598A8689-E97E-3C8D-AACD-8A0EB1956CA6> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff9b6f5000 -     0x7fff9b72dff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff9b730000 -     0x7fff9b73cff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff9b760000 -     0x7fff9b789ffb  libRIP.A.dylib (970) <BA17C96B-83CC-3835-8AFD-CB5A69D3D26F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff9b7c6000 -     0x7fff9b7c6fff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff9b7c7000 -     0x7fff9c6cff67  libLLVMContainer.dylib (4) <61555A24-0AF4-30F6-B3A2-B3A5FF6D1847> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/A/Libraries/libLLVMContainer.dylib
    0x7fff9c6d0000 -     0x7fff9c6d8fff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff9c6d9000 -     0x7fff9c925ff7  com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x7fff9c947000 -     0x7fff9c976ffb  com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
    0x7fff9c977000 -     0x7fff9c977ff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
    0x7fff9c978000 -     0x7fff9ca0dfff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff9cb72000 -     0x7fff9cb9bfff  libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
    0x7fff9ce3c000 -     0x7fff9cef6fff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff9cef7000 -     0x7fff9d09dff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff9d09e000 -     0x7fff9d0a6fff  libGFXShared.dylib (12.1) <22F78420-D92E-3B5F-BA86-918A34289FCD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff9d0a7000 -     0x7fff9d134fef  libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
    0x7fff9d172000 -     0x7fff9d457ffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff9d4bc000 -     0x7fff9d507ff7  com.apple.CoreMediaIO (703.0 - 4791) <E49D0C36-295A-311A-9470-706455EA6F80> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff9d508000 -     0x7fff9d50dff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
    0x7fff9d514000 -     0x7fff9d7baff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff9d7d9000 -     0x7fff9d879fff  com.apple.Metadata (10.7.0 - 972.34) <B0137597-158A-3503-85C8-F55DB5D21BE1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff9d8e7000 -     0x7fff9d8e8ffb  libSystem.B.dylib (1226.10.1) <160608FD-B79D-3B49-AFEA-53A10C0C86B3> /usr/lib/libSystem.B.dylib
    0x7fff9d8e9000 -     0x7fff9d8f0ff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
    0x7fff9d906000 -     0x7fff9d975fff  com.apple.datadetectorscore (7.0 - 460) <233A8FBF-B22F-3177-A328-781588D95D69> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff9d9db000 -     0x7fff9da3efff  libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
    0x7fff9da99000 -     0x7fff9daa4fff  libGPUSupportMercury.dylib (12.1) <97C7C8A3-234B-3C7C-8777-611E3D3EE63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff9daa5000 -     0x7fff9daa7ff7  com.apple.securityhi (9.0 - 55006) <AC151C58-A7AD-3ECF-B15D-5E09FF94FC23> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff9daa8000 -     0x7fff9dac1fff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff9db3a000 -     0x7fff9db62fff  com.apple.GLKit (1.0 - 56) <820F61C9-B74D-3604-BA6E-F20235E2E5B4> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
    0x7fff9db95000 -     0x7fff9db98fff  com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 426
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 127896
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=694.2M resident=0K(0%) swapped_out_or_unallocated=694.2M(100%)
Writable regions: Total=43.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=43.1G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
ATS (font support)                32.3M        7
ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
Accelerate.framework               256K        3
Activity Tracing                  2048K        2
CG backing stores                 39.3M       20
CG image                         196.8M      153
CG shared images                  1008K       21
CoreAnimation                      756K      151
CoreUI image data                 2940K       34
CoreUI image file                  320K        5
Dispatch continuations            48.0M        2
Foundation                          24K        3
Image IO                          1336K      111
Kernel Alloc Once                    8K        3
MALLOC                             1.1G     3586
MALLOC guard page                   32K        7
MALLOC_LARGE (reserved)           1080K        4         reserved VM address space (unallocated)
Memory Tag 242                      12K        2
Memory Tag 251                      12K        2
OpenCL                               8K        2
OpenGL GLSL                        256K        4
Process Corpse Info               2048K        2
STACK GUARD                       56.4M      117
Stack                            281.5M      127
VM_ALLOCATE                       41.4G       45
__DATA                            86.3M      394
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       120.4M       79
__TEXT                           573.8M      364
__TEXT0                            800K        2
__UNICODE                          552K        2
mapped file                      234.0M       98
shared memory                     16.4M       12
TOTAL                             44.2G     5337
TOTAL, minus reserved VM space    44.2G     5337
Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 64 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX 980 TI, NVIDIA GeForce GTX 980 TI, PCIe, 6144 MB
Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 4, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 5, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 6, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 7, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 8, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce GTX 980 TI, Display Controller, Slot-1
PCI Card: NVIDIA GeForce GTX 980 TI, NVDA,Parent, Slot-1
PCI Card: pci10b5,8609, Slot-2
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@11,0,0
PCI Card: pci1b4b,9230, AHCI Controller, Slot-3
PCI Card: pci1b4b,9230, AHCI Controller, Slot-4
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@8,0,0
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@8,0,1
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@9,0,0
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@10,0,0
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@9,0,1
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: HL-DT-ST BD-RE  WH16NS40
Serial ATA Device: Samsung SSD 850 PRO 2TB, 2.05 TB
Serial ATA Device: Samsung SSD 840 EVO 1TB, 1 TB
Serial ATA Device: ElitePro Qx2, 9 TB
Serial ATA Device: 2.74 TB HD Glyph, 3 TB
Serial ATA Device: OWC Mercury Accelsior PCIe SSD, 960.04 GB
Serial ATA Device: MARVELL VIRTUAL
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: USB Bus
USB Device: Intuos5 touch L
USB Device: USB Bus
USB Device: USB 2.0 Bus
USB Device: HZD
USB Device: USB2.0 Hub
USB Device: Apple Watch Magnetic Charging Cable
USB Device: GL3220
USB Device: SoundSticks
USB Device: Hub
USB Device: Keyboard Hub
USB Device: USB Flash Memory
USB Device: Apple Keyboard
USB Device: Apple LED Cinema Display
USB Device: Display iSight
USB Device: Display Audio
USB Device: USB 3.0 Bus
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
Sep 29, 2017 Sep 29, 2017
I'm not a mac  user but it looks like you may be missing thes second cc 2017 update or it failed to install.  It lie like Photoshop is avr version 18.0.1.29. On my system I see CC 2017 is at  version 18.1.1  and CC 2017 system info shows many of the plugins are also a version 18.1.1
Capture.jpg]
JJMack
Sep 30, 2017 Sep 30, 2017
Hi JJMack,
Thanks so much for the suggestion. For some reason, my Adobe Creative Cloud was not updating Photoshop, so I uninstalled 18.0.1.29 and installed the latest version available to me (18.1.1.252).
Sadly, Photoshop is still crashing when I invert the selection and hit "delete" while the view is rotated. The behavior is the same every time -- I can invert the selection and delete while the view is rotated for the first 5-10 minutes when the program is open, but after 5-10 minutes, hitting "delete" crashes the software. It's baffling.
Here is the crash report:
Process:               Adobe Photoshop CC 2017 [960]
Path:                  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
Identifier:            com.adobe.Photoshop
Version:               18.1.1 (18.1.1.252)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Adobe Photoshop CC 2017 [960]
User ID:               501
Date/Time:             2017-09-30 11:36:23.625 -0700
OS Version:            Mac OS X 10.11.6 (15G1611)
Report Version:        11
Anonymous UUID:        056FB863-13B4-6410-D572-383FF35796D5
Time Awake Since Boot: 2000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGBUS)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x000000012196ad80
Exception Note:        EXC_CORPSE_NOTIFY
VM Regions Near 0x12196ad80:
    CG backing stores      00000001218d4000-000000012190b000 [  220K] rw-/rw- SM=PRV
--> mapped file            000000012190b000-0000000121c1e000 [ 3148K] r--/rwx SM=COW
    CoreUI image file      0000000121c1e000-0000000121c3e000 [  128K] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   MMXCore                       0x000000011eac8431 0x11eaab000 + 119857
1   com.adobe.Photoshop           0x000000010a2e74f7 0x1099b1000 + 9659639
2   com.adobe.Photoshop           0x000000010a2fb1ff 0x1099b1000 + 9740799
3   com.adobe.Photoshop           0x000000010a1787ed 0x1099b1000 + 8157165
4   com.adobe.Photoshop           0x000000010a63303a 0x1099b1000 + 13115450
5   com.adobe.Photoshop           0x0000000109a7679a 0x1099b1000 + 808858
6   com.adobe.Photoshop           0x0000000109a4eb70 0x1099b1000 + 646000
7   com.adobe.Photoshop           0x0000000109a4ec39 0x1099b1000 + 646201
8   com.adobe.Photoshop           0x000000010b8f278d 0x1099b1000 + 32774029
9   com.apple.Foundation          0x00007fff9783ce2c __NSFireTimer + 95
10  com.apple.CoreFoundation      0x00007fff9bceeae4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
11  com.apple.CoreFoundation      0x00007fff9bcee773 __CFRunLoopDoTimer + 1075
12  com.apple.CoreFoundation      0x00007fff9bcee2ca __CFRunLoopDoTimers + 298
13  com.apple.CoreFoundation      0x00007fff9bce57c1 __CFRunLoopRun + 1841
14  com.apple.CoreFoundation      0x00007fff9bce4e28 CFRunLoopRunSpecific + 296
15  com.apple.HIToolbox           0x00007fff9c14a935 RunCurrentEventLoopInMode + 235
16  com.apple.HIToolbox           0x00007fff9c14a76f ReceiveNextEventCommon + 432
17  com.apple.HIToolbox           0x00007fff9c14a5af _BlockUntilNextEventMatchingListInModeWithFilter + 71
18  com.apple.AppKit              0x00007fff91beadf6 _DPSNextEvent + 1067
19  com.apple.AppKit              0x00007fff91bea226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
20  com.adobe.Photoshop           0x000000010b8f1441 0x1099b1000 + 32769089
21  com.apple.AppKit              0x00007fff91bded80 -[NSApplication run] + 682
22  com.adobe.Photoshop           0x000000010b8f25a2 0x1099b1000 + 32773538
23  com.adobe.Photoshop           0x000000010b8f3928 0x1099b1000 + 32778536
24  com.adobe.Photoshop           0x0000000109a5068d 0x1099b1000 + 652941
25  com.adobe.Photoshop           0x0000000109dc87df 0x1099b1000 + 4290527
26  com.adobe.Photoshop           0x0000000109dc8a69 0x1099b1000 + 4291177
27  libdyld.dylib                 0x00007fff97bd65ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib        0x00007fff954a9efa kevent_qos + 10
1   libdispatch.dylib             0x00007fff90325165 _dispatch_mgr_invoke + 216
2   libdispatch.dylib             0x00007fff90324dcd _dispatch_mgr_thread + 52
Thread 2:: MPSupport Worker
0   libsystem_kernel.dylib        0x00007fff954a8db6 __psynch_cvwait + 10
1   libsystem_pthread.dylib       0x00007fff974ea728 _pthread_cond_wait + 767
2   MultiProcessor Support        0x000000011ebf50fb 0x11ebab000 + 303355
3   MultiProcessor Support        0x000000011ebf501b 0x11ebab000 + 303131
4   MultiProcessor Support        0x000000011ec167a6 0x11ebab000 + 440230
5   libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
6   libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
7   libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 3:: MPSupport Worker
Thread 4:: MPSupport Worker
Thread 5:: MPSupport Worker
Thread 6:: MPSupport Worker
Thread 7:: MPSupport Worker
Thread 8:: MPSupport Worker
Thread 9:: MPSupport Worker
Thread 10:: MPSupport Worker
Thread 11:: MPSupport Worker
Thread 12:: MPSupport Worker
Thread 13:: MPSupport Worker
Thread 14:: MPSupport Worker
Thread 15:: MPSupport Worker
Thread 16:: MPSupport Worker
Thread 17:: MPSupport Worker
Thread 18:: MPSupport Worker
Thread 19:: MPSupport Worker
Thread 20:: MPSupport Worker
Thread 21:: MPSupport Worker
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: VulcanMsgRecv
0   libsystem_kernel.dylib        0x00007fff954a8fba __recvfrom + 10
1   VulcanMessage5.dylib          0x00000001152b7308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2   VulcanMessage5.dylib          0x00000001152b66cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3   VulcanMessage5.dylib          0x00000001152b59c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4   VulcanMessage5.dylib          0x00000001152b5888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5   VulcanMessage5.dylib          0x00000001152b04c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6   VulcanMessage5.dylib          0x00000001152b0f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
7   VulcanMessage5.dylib          0x00000001152b08ef vcfoundation::io::Serializer::Deserialize() + 9
8   VulcanMessage5.dylib          0x00000001152b4974 vcfoundation::ncomm::Connection::ReadIn() + 22
9   VulcanMessage5.dylib          0x00000001152b43cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10  VulcanMessage5.dylib          0x00000001152b40ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11  VulcanMessage5.dylib          0x00000001152b400d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12  VulcanMessage5.dylib          0x00000001152a7848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13  VulcanMessage5.dylib          0x00000001152a6a86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14  VulcanMessage5.dylib          0x00000001152b520c vcfoundation::thread::AbstractThread::Run() + 72
15  VulcanMessage5.dylib          0x00000001152b7109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16  libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
17  libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
18  libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 26:
0   libsystem_kernel.dylib        0x00007fff954a2fae semaphore_wait_trap + 10
1   libtbb.dylib                  0x000000011118f100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
2   libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
3   libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
4   libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:: BridgeTalk
0   libsystem_kernel.dylib        0x00007fff954a910a __semwait_signal + 10
1   libsystem_c.dylib             0x00007fffa0eced0f nanosleep + 199
2   com.adobe.PSAutomate          0x000000015429ece8 0x1540cb000 + 1916136
3   com.adobe.PSAutomate          0x0000000154280b5c 0x1540cb000 + 1792860
4   com.adobe.PSAutomate          0x000000015429e871 0x1540cb000 + 1914993
Thread 50:: com.apple.NSEventThread
0   libsystem_kernel.dylib        0x00007fff954a2f72 mach_msg_trap + 10
1   libsystem_kernel.dylib        0x00007fff954a23b3 mach_msg + 55
2   com.apple.CoreFoundation      0x00007fff9bce6114 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      0x00007fff9bce55dc __CFRunLoopRun + 1356
5   com.apple.AppKit              0x00007fff91d40d95 _NSEventThread + 149
Thread 51:
2   com.adobe.headlights.LogSessionFramework 0x00000001143cbccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3   com.adobe.headlights.LogSessionFramework 0x00000001143ca5ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4   com.adobe.headlights.LogSessionFramework 0x0000000114378059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5   com.adobe.headlights.LogSessionFramework 0x0000000114346cfb RealTimeProcessor::WorkerThread(int, int) + 3633
6   com.adobe.headlights.LogSessionFramework 0x00000001143c9969 boost::(anonymous namespace)::thread_proxy(void*) + 185
7   libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
8   libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
9   libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 52:: com.apple.NSURLConnectionLoader
5   com.apple.CFNetwork           0x00007fff9e254a6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6   com.apple.Foundation          0x00007fff977c8c84 __NSThread__start__ + 1351
Thread 53:
2   com.adobe.headlights.LogSessionFramework 0x0000000114379152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3   com.adobe.headlights.LogSessionFramework 0x00000001143780db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4   com.adobe.headlights.LogSessionFramework 0x0000000114377bae IdleTimeLogger::IdleTimeWorkerThread() + 2804
5   com.adobe.headlights.LogSessionFramework 0x00000001143c9969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 54:: Update Activation Menu Items
2   com.adobe.Photoshop           0x0000000109d143a2 0x1099b1000 + 3552162
3   CITThreading                  0x000000011183c05e boost::(anonymous namespace)::thread_proxy(void*) + 130
4   libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
5   libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
6   libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 55:
2   libc++.1.dylib                0x00007fff90e6268f std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3   com.adobe.Photoshop           0x00000001099b62fd 0x1099b1000 + 21245
4   com.adobe.Photoshop           0x00000001099b6f5b 0x1099b1000 + 24411
5   com.adobe.Photoshop           0x00000001099b6d4e 0x1099b1000 + 23886
Thread 56:
Thread 57:
Thread 58:
Thread 59:: com.apple.CFSocket.private
0   libsystem_kernel.dylib        0x00007fff954a907a __select + 10
1   com.apple.CoreFoundation      0x00007fff9bd2345a __CFSocketManager + 762
Thread 60:: NetworkConfigWatcher
5   com.apple.Foundation          0x00007fff977b7cf9 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270
6   org.chromium.ContentShell.framework 0x0000000155e95eee 0x1548f5000 + 22679278
7   org.chromium.ContentShell.framework 0x0000000155e9572c 0x1548f5000 + 22677292
8   org.chromium.ContentShell.framework 0x0000000155eae113 0x1548f5000 + 22778131
9   org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
10  org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
11  libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
12  libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
13  libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 61:: DnsConfigService
0   libsystem_kernel.dylib        0x00007fff954a9eca kevent + 10
1   org.chromium.ContentShell.framework 0x0000000155f053e7 0x1548f5000 + 23135207
2   org.chromium.ContentShell.framework 0x0000000155f02ebd 0x1548f5000 + 23125693
3   org.chromium.ContentShell.framework 0x0000000155e94e2f 0x1548f5000 + 22674991
4   org.chromium.ContentShell.framework 0x0000000155eae113 0x1548f5000 + 22778131
5   org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
6   org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
Thread 62:: Chrome_DBThread
5   org.chromium.ContentShell.framework 0x0000000155e95c4f 0x1548f5000 + 22678607
6   org.chromium.ContentShell.framework 0x0000000155e9572c 0x1548f5000 + 22677292
7   org.chromium.ContentShell.framework 0x0000000155eae113 0x1548f5000 + 22778131
8   org.chromium.ContentShell.framework 0x00000001555cb354 0x1548f5000 + 13460308
9   org.chromium.ContentShell.framework 0x00000001555cb4c3 0x1548f5000 + 13460675
10  org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
11  org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
12  libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
13  libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
14  libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 63:: Chrome_FileThread
5   org.chromium.ContentShell.framework 0x00000001555cb384 0x1548f5000 + 13460356
6   org.chromium.ContentShell.framework 0x00000001555cb4d0 0x1548f5000 + 13460688
7   org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
8   org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
9   libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
10  libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
11  libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 64:: Chrome_FileUserBlockingThread
8   org.chromium.ContentShell.framework 0x00000001555cb3b4 0x1548f5000 + 13460404
9   org.chromium.ContentShell.framework 0x00000001555cb4dd 0x1548f5000 + 13460701
Thread 65:: Chrome_ProcessLauncherThread
8   org.chromium.ContentShell.framework 0x00000001555cb3e4 0x1548f5000 + 13460452
9   org.chromium.ContentShell.framework 0x00000001555cb4ea 0x1548f5000 + 13460714
Thread 66:: Chrome_CacheThread
8   org.chromium.ContentShell.framework 0x00000001555cb414 0x1548f5000 + 13460500
9   org.chromium.ContentShell.framework 0x00000001555cb4f7 0x1548f5000 + 13460727
Thread 67:: Chrome_IOThread
5   org.chromium.ContentShell.framework 0x00000001555cb444 0x1548f5000 + 13460548
6   org.chromium.ContentShell.framework 0x00000001555cb504 0x1548f5000 + 13460740
Thread 68:: BrowserBlockingWorker1/152579
2   org.chromium.ContentShell.framework 0x0000000155ece2cf 0x1548f5000 + 22909647
3   org.chromium.ContentShell.framework 0x0000000155ecd976 0x1548f5000 + 22907254
4   org.chromium.ContentShell.framework 0x0000000155ed0c5d 0x1548f5000 + 22920285
5   org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
Thread 69:: IndexedDB
8   org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
9   org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
10  libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
11  libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
12  libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 70:: CompositorTileWorker1/154371
2   org.chromium.ContentShell.framework 0x0000000155f84698 0x1548f5000 + 23656088
3   org.chromium.ContentShell.framework 0x0000000155ed0c5d 0x1548f5000 + 22920285
4   org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
Thread 71:: AudioThread
Thread 72:: BrowserBlockingWorker2/158979
Thread 73:: NetworkConfigWatcher
Thread 74:: Chrome_DevToolsHandlerThread
Thread 75:
5   com.apple.Foundation          0x00007fff978cff99 -[NSConnection run] + 149
Thread 76:: CEPMonitorThread
5   com.apple.Foundation          0x00007fff97861dda -[NSConcreteTask waitUntilExit] + 205
6   com.adobe.PlugPlugOwl         0x0000000111b66c4b -[HtmlEngineMonitor monitorThreadProc] + 160
7   com.apple.Foundation          0x00007fff977c8c84 __NSThread__start__ + 1351
8   libsystem_pthread.dylib       0x00007fff974e999d _pthread_body + 131
9   libsystem_pthread.dylib       0x00007fff974e991a _pthread_start + 168
10  libsystem_pthread.dylib       0x00007fff974e7351 thread_start + 13
Thread 77:: General Background Service
2   com.adobe.Photoshop           0x0000000109d93fb1 0x1099b1000 + 4075441
3   com.adobe.Photoshop           0x000000010bc9d81c 0x1099b1000 + 36620316
4   com.adobe.Photoshop           0x000000010bc9ccac 0x1099b1000 + 36617388
5   com.adobe.Photoshop           0x000000010bc9eba6 0x1099b1000 + 36625318
6   CITThreading                  0x000000011183c05e boost::(anonymous namespace)::thread_proxy(void*) + 130
Thread 78:
Thread 79:: CEPMonitorThread
Thread 80:: BrowserBlockingWorker3/202047
Thread 81:: CachePoolWorker1/202595
Thread 82:
Thread 83:: CEPMonitorThread
Thread 84:: Bristle Physics
2   com.adobe.Photoshop           0x000000010a3f648b 0x1099b1000 + 10769547
3   com.adobe.Photoshop           0x000000010b78cc65 0x1099b1000 + 31308901
4   com.adobe.Photoshop           0x000000010b784583 0x1099b1000 + 31274371
5   CITThreading                  0x000000011183c05e boost::(anonymous namespace)::thread_proxy(void*) + 130
Thread 85:: Font Initialization
Thread 86:: DeepFont
Thread 87:: Background Save
3   com.adobe.Photoshop           0x000000010b9db98c 0x1099b1000 + 33728908
4   com.adobe.Photoshop           0x000000010b9d96a9 0x1099b1000 + 33719977
Thread 88:
0   libsystem_kernel.dylib        0x00007fff954a95e2 __workq_kernreturn + 10
1   libsystem_pthread.dylib       0x00007fff974e9578 _pthread_wqthread + 1283
2   libsystem_pthread.dylib       0x00007fff974e7341 start_wqthread + 13
Thread 89:
Thread 90:
Thread 91:
Thread 92:
Thread 93:
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
Thread 109:
Thread 110:
1   libsystem_pthread.dylib       0x00007fff974ea75e _pthread_cond_wait + 821
2   com.apple.CoreServices.CarbonCore 0x00007fffa0fbfa93 TSWaitOnConditionTimedRelative + 147
3   com.apple.CoreServices.CarbonCore 0x00007fffa0fbf66e TSWaitOnSemaphoreCommon + 406
4   com.apple.CoreServices.CarbonCore 0x00007fffa0f866ea AsyncFileThread(void*) + 275
Thread 111:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x000000000000099d  rbx: 0x0000000000000000  rcx: 0x00000000000009a0  rdx: 0x0000000000000000
  rdi: 0x000000012196ad80  rsi: 0x0000000000000001  rbp: 0x0000000000000001  rsp: 0x00007fff5624b928
   r8: 0x0000000000000990   r9: 0x000000000000099d  r10: 0x0000000000000001  r11: 0x000000000000000d
  r12: 0x000000000000099d  r13: 0x000000012196ad80  r14: 0x000000000000004c  r15: 0x0000000000000000
  rip: 0x000000011eac8431  rfl: 0x0000000000010202  cr2: 0x000000012196ad80
Logical CPU:     12
Error Code:      0x00000006
Trap Number:     14
Binary Images:
       0x1099b1000 -        0x11019ef87 +com.adobe.Photoshop (18.1.1 - 18.1.1.252) <B684F32F-915C-3BEA-B7EC-8B5F5820FAAC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
       0x111180000 -        0x1111b7fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
       0x1111f9000 -        0x11121cfe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
       0x111255000 -        0x1112fdfff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.5) <0AE6FE3B-AD77-3C9E-AD1B-CEE881FEF5C2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
       0x11135d000 -        0x1113fbfff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.5) <678BE576-32AB-3958-9C04-2504856330E5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
       0x11144b000 -        0x1115ceff7 +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <EB941620-7550-301A-98C4-69CDB0577834> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
       0x111729000 -        0x111798ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <48E3C4F3-461F-3F9F-B83A-11BC5D103508> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
       0x11182c000 -        0x111845fff +CITThreading (???) <F6746740-68D1-3F47-9714-94B42B132BD9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
       0x111886000 -        0x111984ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
       0x1119b3000 -        0x111ab9fff +com.adobe.amtlib (10.0.0.119 - 10.0.0.119) <53139645-73AD-3787-AEE6-579FABE39250> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
       0x111acd000 -        0x111d43ff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
       0x112019000 -        0x11208ffff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37848) <387CF9B9-B873-35B7-8D5E-7ACB4EA61AE7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
       0x11217b000 -        0x112224ff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
       0x11224d000 -        0x112252fff  org.twain.dsm (1.9.5 - 1.9.5) <F7AA3C5E-4FB0-379D-8F79-AD06669D087E> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
       0x11225a000 -        0x112278fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
       0x112291000 -        0x112295fff  com.apple.agl (3.3.1 - AGL-3.3.1) <2FC3E30C-5370-3369-B8D1-1C7050A4A85A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x1122a2000 -        0x112434ff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <CDF9E325-6035-3EF9-8E03-980CD33D6582> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
       0x112485000 -        0x1127ebff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
       0x112863000 -        0x112887fff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
       0x1128b3000 -        0x112b7cffb +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <7DAE22B9-2F91-385B-B4EA-9EC75CBEE0EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
       0x112bee000 -        0x112eebffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <46381E3C-77F9-3842-8A13-33BDEFA6E1D7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
       0x112f3d000 -        0x112f60ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
       0x112f69000 -        0x112f6afff  libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
       0x112f70000 -        0x112f94ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
       0x112fbd000 -        0x1130e7ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
       0x11313c000 -        0x113286ff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <3236E6F5-C286-3C46-AD03-9838AFE1D751> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
       0x1132a1000 -        0x1132bdffb +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
       0x1132c6000 -        0x113386ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.38234) <FA7EDCFB-62E7-33C2-89C9-8D745921518F> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
       0x1133d2000 -        0x11354cfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
       0x1136a1000 -        0x1136a1ff7 +cl_kernels (???) <EA673946-537D-49E6-9B7C-D8DBDEEB2D06> cl_kernels
       0x1136a6000 -        0x113bfefef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
       0x114273000 -        0x11440dfff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
       0x1144e5000 -        0x11522afff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
       0x11523f000 -        0x115268ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
       0x115287000 -        0x11528afff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
       0x115299000 -        0x1152d4ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
       0x11531d000 -        0x115419fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
       0x1154c4000 -        0x115613ff3 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <CEC41C30-5517-3C8E-9998-A2F72308D548> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
       0x11566a000 -        0x115764ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
       0x115778000 -        0x11587bff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
       0x1158ca000 -        0x115a11fef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
       0x115b6e000 -        0x115d90ff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
       0x115dea000 -        0x115fc7ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
       0x1160b1000 -        0x116343ffb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <6A2AF438-1448-33BB-81F2-7058E8E3E1F2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
       0x1163c7000 -        0x1164fbfff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
       0x116797000 -        0x116799ff7  com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x11dd28000 -        0x11dd44ff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
       0x11dd4a000 -        0x11dd6cff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
       0x11dd71000 -        0x11dd80ff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
       0x11dd85000 -        0x11dd97fff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
       0x11dea0000 -        0x11dee3ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
       0x11deff000 -        0x11df07fff +FastCore (18.1.1 - 18.1.1) <F20E2338-3B28-3C34-BB07-CE946978B58B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
       0x11e6fc000 -        0x11e700fff  libFontRegistryUI.dylib (155.2) <8346E80E-5832-3944-A750-FBB9D328C2FE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x11eaab000 -        0x11eb27fef +MMXCore (18.1.1 - 18.1.1) <A6B54ABB-D74E-39C7-A606-35B8F3FCDAF4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
       0x11ebab000 -        0x11ec24ff7 +MultiProcessor Support (18.1.1 - 18.1.1) <A53DC4D5-BB48-3608-94A6-6C839B409A51> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
       0x120f31000 -        0x12107cfff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
       0x1215f9000 -        0x1217ecfff  com.nvidia.web.GeForceMTLDriverWeb (10.11.14 - 10.1.1) <293ED998-72BF-33D0-AC42-282B8122F6A1> /System/Library/Extensions/GeForceMTLDriverWeb.bundle/Contents/MacOS/GeForceMTLDriverWeb
       0x1276b5000 -        0x12775afff  ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
       0x153e80000 -        0x153e91ff7 +MeasurementCore (18.1.1 - 18.1.1) <E5DCB5F1-79E2-3B56-B4A9-6A650EE8B6B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
       0x1540cb000 -        0x154500fff +com.adobe.PSAutomate (18.1.1 - 18.1.1) <54B32ED4-0367-3E12-837F-06413A5FF034> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
       0x1547ed000 -        0x1548cdff7 +com.adobe.ps.spaces (18.1.1 - 18.1.1) <976B6154-C2DD-39C4-BF65-9A8AA2EAEB34> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
       0x1548f5000 -        0x15a377faf +org.chromium.ContentShell.framework (99.77.34.5 - 34.5) <42663479-0F87-37B7-8694-E2701B2A59B6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
       0x15aa77000 -        0x15aaaefff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x15aad7000 -        0x15aaeaff7  com.apple.GameController (1.0 - 1) <5B98EABB-D27C-3381-9487-21B1C91BF9E8> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
       0x15aafc000 -        0x15ab15fff  libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
       0x15ade2000 -        0x15adedfff  com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <B46E04B4-EB85-3436-82C4-158DF1A2AB36> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
       0x15cb9f000 -        0x15cbd1ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
       0x15cbdd000 -        0x15cc06fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
       0x15cc20000 -        0x15cc9aff7  com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
       0x15ea19000 -        0x15f386fff  com.nvidia.web.GeForceGLDriverWeb (10.11.14 - 10.1.1) <0D0C682E-CE22-3724-B251-05A6736FC883> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/GeForceGLDriverWeb
       0x15fe8c000 -        0x160999ff7  libclhWeb.dylib (0) <4FB1DBC0-6E02-3B9A-A6B4-F225B0CDCD75> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/libclhWeb.dylib
    0x7fff63b22000 -     0x7fff63b59a47  dyld (360.22) <C8E77F6D-CE86-3C5B-8576-2584A799B51E> /usr/lib/dyld
    0x7fff8afd6000 -     0x7fff8afe2fff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff8afe3000 -     0x7fff8b1f0fff  libicucore.A.dylib (551.51.5) <2D3634CA-A87A-37A9-A3F4-C3E3106C2A33> /usr/lib/libicucore.A.dylib
    0x7fff8b1f1000 -     0x7fff8c457fff  com.apple.CoreGraphics (1.600.0 - 960.7) <82D77440-30B2-3DCF-9414-88EC57CAD6CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff8c486000 -     0x7fff8c52dfff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff8c52e000 -     0x7fff8c540fff  libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
    0x7fff8c699000 -     0x7fff8c6f7fff  com.apple.SystemConfiguration (1.14 - 1.14) <ACAEDA14-FAA0-3F14-B476-DE492A52D383> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff8c821000 -     0x7fff8c85bff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff8c8b9000 -     0x7fff8cadaff7  com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff8cb3a000 -     0x7fff8cb3dff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff8cc48000 -     0x7fff8cd75fff  com.apple.CoreText (352.0 - 494.14) <93E0D8C3-D5DD-3EBB-9CC1-831C46572133> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff8cdd7000 -     0x7fff8cdf2ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
    0x7fff8cdf3000 -     0x7fff8ce82fff  com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff8cf13000 -     0x7fff8cf13fff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff8d164000 -     0x7fff8d1b6fff  com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff8d1bc000 -     0x7fff8d20cff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff8d20f000 -     0x7fff8d26dfff  com.apple.CoreServices.OSServices (728.13 - 728.13) <477EA3F9-D13E-3D83-ABAD-4DC7DB134CF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff8d29a000 -     0x7fff8d2a8fff  com.apple.IntlPreferences (2.0 - 192) <388C5784-7713-36B0-B08B-5163E6B04002> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fff8d2a9000 -     0x7fff8d2abff7  libquarantine.dylib (80) <B3B7B630-9012-3DA3-9458-5C009625E606> /usr/lib/system/libquarantine.dylib
    0x7fff8d6f2000 -     0x7fff8e7dbff3  com.apple.WebCore (11601 - 11601.7.5) <9153DA7E-1625-382A-8257-8D4293F06F7F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff8e7dc000 -     0x7fff8ebb4fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff8ebb5000 -     0x7fff8ec04ff7  com.apple.opencl (2.7.0 - 2.7.0) <DAEC71D4-E0E7-3E24-BB44-C977A798C575> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff8ec05000 -     0x7fff8ec51ff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff8ec52000 -     0x7fff8ec5cfff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff8ec5e000 -     0x7fff8ec69fff  com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff8ec98000 -     0x7fff8ec98fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff8ec99000 -     0x7fff8ed00fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff8ed14000 -     0x7fff8ed15fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
    0x7fff8ed16000 -     0x7fff8ed19ff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff8ed1a000 -     0x7fff8ed28ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
    0x7fff8ed57000 -     0x7fff8f1f2ffb  com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff8f1f3000 -     0x7fff8f2e5ff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
    0x7fff8f341000 -     0x7fff8f341ff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
    0x7fff8f34a000 -     0x7fff8f351ff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fff8f40f000 -     0x7fff8f77a657  libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
    0x7fff8f77b000 -     0x7fff8f791fff  com.apple.CoreMediaAuthoring (2.2 - 953) <A8F1B6EE-8ABE-3DC2-9829-A268D016648E> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fff8f894000 -     0x7fff8fb26ffb  com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff8fb27000 -     0x7fff8fb29fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff8fb2a000 -     0x7fff8fb2cfff  libCVMSPluginSupport.dylib (12.1) <20BA72AF-C7C5-3551-8F59-E1AED5FC69F0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff8fbb0000 -     0x7fff8fbd2fff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff8fbd3000 -     0x7fff8fbf5ff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff8ff32000 -     0x7fff90077fff  com.apple.QTKit (7.7.3 - 2943.13) <3E3DB3DD-8D7E-3478-B020-F975CCAAE522> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fff9007c000 -     0x7fff90087ff7  libkxld.dylib (3248.70.3) <BAD04BB1-5BFE-3D88-ADDE-23FED2DD2942> /usr/lib/system/libkxld.dylib
    0x7fff90088000 -     0x7fff9008cfff  libGIF.dylib (1463) <3F84E60B-18E5-3897-8494-DFB1ACE76829> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff902f2000 -     0x7fff902f2ff7  liblaunch.dylib (765.70.1) <96D7C3EE-82E2-39AB-870F-B317A030E86D> /usr/lib/system/liblaunch.dylib
    0x7fff902f3000 -     0x7fff9030fff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
    0x7fff9031d000 -     0x7fff9034afff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
    0x7fff9034b000 -     0x7fff90359fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
    0x7fff90370000 -     0x7fff9038cfff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff9038d000 -     0x7fff903ceff7  libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff90526000 -     0x7fff90e5af5f  libLLVMContainer.dylib (119.5) <09A35A20-7CDD-3E5A-94B4-5F1E5CFBC3D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libLLVMContainer.dylib
    0x7fff90e5b000 -     0x7fff90eaeff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
    0x7fff90eaf000 -     0x7fff90fc1fef  libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff90fc2000 -     0x7fff90fc8ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff9109c000 -     0x7fff910a0fff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff910aa000 -     0x7fff910abff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff910e8000 -     0x7fff91266fff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff9139a000 -     0x7fff91409fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff9140a000 -     0x7fff91527fff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
    0x7fff91558000 -     0x7fff91a7afff  com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff91a7b000 -     0x7fff91a80fff  com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff91afd000 -     0x7fff91b4ffff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <4F5F5CD6-631F-3C97-AA62-7DF19BD5EC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff91b50000 -     0x7fff91ba1fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff91ba2000 -     0x7fff927cbff7  com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff927ce000 -     0x7fff92887ff7  libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff92920000 -     0x7fff9294eff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff92b3e000 -     0x7fff92be9fff  com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff92c4c000 -     0x7fff92c6bff7  com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff92c6c000 -     0x7fff92c95ff7  libxpc.dylib (765.70.1) <4FB1311F-4032-3F56-BF0B-CFF45D78FB01> /usr/lib/system/libxpc.dylib
    0x7fff92c96000 -     0x7fff92d76ff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
    0x7fff92d77000 -     0x7fff92e66ff7  libxml2.2.dylib (29.14) <02077D26-0AB0-347A-8AF2-FADE3CFC296C> /usr/lib/libxml2.2.dylib
    0x7fff92e67000 -     0x7fff92e9aff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff92ed0000 -     0x7fff92ed8fff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff92edc000 -     0x7fff92ee4fff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
    0x7fff92ee8000 -     0x7fff92eeefff  com.apple.IOAccelerator (205.11 - 205.11) <3E86AB1B-C1CF-307D-900F-385C8D8C534A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff92eef000 -     0x7fff92f04ff3  libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff92f05000 -     0x7fff92f1fff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
    0x7fff92f22000 -     0x7fff92f24fff  libCGXType.A.dylib (970) <A931200A-B248-39EF-8A8B-311D881BE372> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff92f36000 -     0x7fff92f44fff  com.apple.opengl (12.1.0 - 12.1.0) <12EBDE6A-2F44-3429-8337-2BB36870BFD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff92f56000 -     0x7fff93294ff7  com.apple.WebKit (11601 - 11601.7.8) <58A8B070-2AE4-3909-AE1D-7A7DF34AA268> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff932c6000 -     0x7fff93312fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff93313000 -     0x7fff93580fff  com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff93581000 -     0x7fff93592ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
    0x7fff93593000 -     0x7fff93593fff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff93594000 -     0x7fff935c6ff7  libTrueTypeScaler.dylib (158.7) <020536E5-C032-30B5-864C-920D5F7DB6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff935c7000 -     0x7fff935deff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
    0x7fff9387b000 -     0x7fff93ca9fff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff93caa000 -     0x7fff93cdbff7  libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
    0x7fff93d13000 -     0x7fff93d14fff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
    0x7fff93d15000 -     0x7fff93d20fff  libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff93e20000 -     0x7fff93e25fff  com.apple.DiskArbitration (2.7 - 2.7) <8CB47F4A-0FD2-343A-93C8-965174F6F24F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff93e26000 -     0x7fff93e3bfff  com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
    0x7fff93e3c000 -     0x7fff93ea2ff7  libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
    0x7fff93ea3000 -     0x7fff93ea3fff  com.apple.CoreServices (728.13 - 728.13) <CFE3EE73-A3F5-3824-9210-0790C07120F3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff93eb7000 -     0x7fff93ec0fff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
    0x7fff93ed9000 -     0x7fff93f6ffff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff94564000 -     0x7fff94608fff  com.apple.Bluetooth (4.4.6 - 4.4.6f1) <D8ED953B-AD7D-3FE2-8631-E9CBCF6EBAB9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff94609000 -     0x7fff94609fff  libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fff9460a000 -     0x7fff94610fff  com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fff9465c000 -     0x7fff94825ff7  com.apple.ImageIO.framework (3.3.0 - 1462) <1D8FF28C-5DBB-3D23-8CF0-75269C1CE84D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff94826000 -     0x7fff94842ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
    0x7fff94885000 -     0x7fff94886fff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
    0x7fff94887000 -     0x7fff9488cfff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff9494e000 -     0x7fff94953ff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
    0x7fff949db000 -     0x7fff94a36ff7  libTIFF.dylib (1463) <5C02D055-02D3-37FE-AABC-487301080941> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff94a46000 -     0x7fff94a4fff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
    0x7fff94af0000 -     0x7fff94af8fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff94af9000 -     0x7fff94b4bfff  com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff94b4c000 -     0x7fff94b54fef  libcldcpuengine.dylib (2.7.3) <745C41A3-CEC0-3BF5-91DC-FCB140A3DACE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff94b55000 -     0x7fff94b57ff7  libRadiance.dylib (1463) <11392BBE-6DAC-3ADD-A0C0-CD653B9AEDE3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff94b58000 -     0x7fff94b68fff  libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff94b9a000 -     0x7fff94bc8ff7  libsandbox.1.dylib (460.60.3) <C8B9F633-EA0C-35CF-9207-1AFDF694EEAD> /usr/lib/libsandbox.1.dylib
    0x7fff94c50000 -     0x7fff94c6bfff  com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff94edc000 -     0x7fff94ee4fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff94f29000 -     0x7fff94f2eff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
    0x7fff94f2f000 -     0x7fff94f58ff7  libxslt.1.dylib (14.5) <8E03110E-1529-3BE8-B5F4-052A47A1674C> /usr/lib/libxslt.1.dylib
    0x7fff950cd000 -     0x7fff951f4fff  com.apple.LaunchServices (728.13 - 728.13) <91147A89-9D0D-3272-AD05-48E2835BD8D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff951f5000 -     0x7fff951f6fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff951f7000 -     0x7fff95491ff3  com.apple.security (7.0 - 57337.60.3) <4BF5CF26-6E34-35EC-8D41-58ED65F9BFB8> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff95492000 -     0x7fff954b0ff7  libsystem_kernel.dylib (3248.70.3) <69D68230-7793-3D11-B49E-BA3A6D5137B8> /usr/lib/system/libsystem_kernel.dylib
    0x7fff95672000 -     0x7fff9569dff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fff9569e000 -     0x7fff956a9ff7  libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
    0x7fff956b0000 -     0x7fff956dfffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
    0x7fff95a03000 -     0x7fff95bc3ffb  libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff95bf0000 -     0x7fff95bfbff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
    0x7fff95bfc000 -     0x7fff95c6aff7  com.apple.ApplicationServices.ATS (377 - 394.4) <CB64C2B7-828A-3C4C-8F3C-72B78630CD94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff95c6b000 -     0x7fff95c96ffb  libarchive.2.dylib (33.20.2.1.1) <BC764A1E-573A-3D95-A3CC-1758935ADC56> /usr/lib/libarchive.2.dylib
    0x7fff95c97000 -     0x7fff95ca8ff7  libsystem_trace.dylib (201.10.3) <4F626911-011B-3E9C-8D61-C5EBA79013F0> /usr/lib/system/libsystem_trace.dylib
    0x7fff95cb2000 -     0x7fff95cc8ff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff95cc9000 -     0x7fff95ccbff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
    0x7fff95ccc000 -     0x7fff95ccffff  libspindump.dylib (197.1) <B86EE257-4429-32E9-B98D-B12BFF2A373B> /usr/lib/libspindump.dylib
    0x7fff95cd0000 -     0x7fff95d1efff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
    0x7fff95d1f000 -     0x7fff95d21fff  com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff95d22000 -     0x7fff95d4cff7  GLRendererFloat (12.1) <0412B850-BB25-33B1-AF0D-8E6297D4620E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff95d8f000 -     0x7fff95db4ff7  libPng.dylib (1463) <17F67BF3-4A78-3587-AAE4-E50A71BDD4CB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff95db5000 -     0x7fff95db7fff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff95db8000 -     0x7fff95ddffff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff95e0c000 -     0x7fff95e14fef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
    0x7fff95e15000 -     0x7fff95e2cff7  libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
    0x7fff95ecf000 -     0x7fff9624dff3  com.apple.VideoToolbox (1.0 - 1731.15.207) <6C7C261F-CB65-3AF1-92E7-16ACAD371EF4> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff962b2000 -     0x7fff962c3fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
    0x7fff962cc000 -     0x7fff962e9ff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <707C6ED6-B8C0-38D4-B45A-7F2F689BD157> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff965bb000 -     0x7fff96716ff3  com.apple.WebKitLegacy (11601 - 11601.7.8) <F41E6CAF-1157-3868-9FAC-D074FCE74BB9> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
    0x7fff970b6000 -     0x7fff970fbff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff970fc000 -     0x7fff97173feb  libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
    0x7fff97174000 -     0x7fff97174fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff97175000 -     0x7fff97180fff  libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
    0x7fff97181000 -     0x7fff972cbff7  com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff972d1000 -     0x7fff973c3ff7  libJP2.dylib (1463) <D107FF52-7FD6-3A5E-B40E-F3D0F1FF651D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff973c4000 -     0x7fff973c4fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff973c5000 -     0x7fff973d8fff  com.apple.SafariServices.framework (11604 - 11604.1.38.1.7) <5B649F4B-09D3-3AAC-9801-B6084B91E7D7> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fff974e6000 -     0x7fff974efff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
    0x7fff974f0000 -     0x7fff97786fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
    0x7fff97793000 -     0x7fff97ae7ff7  com.apple.Foundation (6.9 - 1259.31) <EBB5BE3F-1FE9-3231-B53B-149CDEE8BCA9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff97b36000 -     0x7fff97bbefff  com.apple.CoreSymbolication (3.1 - 58048.1) <C1A1A8DB-8A51-3A21-865A-3CEF22A0E67A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff97bd3000 -     0x7fff97bd6ffb  libdyld.dylib (360.22) <7C1BBC59-FA8A-3BDF-B209-02167832E7D1> /usr/lib/system/libdyld.dylib
    0x7fff97bd7000 -     0x7fff97d63ff7  libGLProgrammability.dylib (12.1) <6D4C193C-5F7B-3E82-81D9-D14D25BBD962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff97d8c000 -     0x7fff97d95ff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff97d96000 -     0x7fff97da9fff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fff97daa000 -     0x7fff97dc3fe7  libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
    0x7fff97dc4000 -     0x7fff97dcffff  com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff985da000 -     0x7fff985ddffb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
    0x7fff985de000 -     0x7fff985e6fff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
    0x7fff985e8000 -     0x7fff986c1fff  com.apple.CoreMedia (1.0 - 1731.15.207) <70CAD4A7-3F8B-3767-A420-98BE1062C230> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff98f21000 -     0x7fff98f6fff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
    0x7fff991ca000 -     0x7fff99708ff7  com.apple.MediaToolbox (1.0 - 1731.15.207) <63AD3FB7-BAD3-3040-8A99-843033F24CF6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff9972b000 -     0x7fff998d7ff7  com.apple.avfoundation (2.0 - 1046.9.12) <41BDD03F-5545-3B9F-8DD7-7106485BAE8B> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff998dd000 -     0x7fff99901ff7  libJPEG.dylib (1463) <11227D36-EA80-3D5B-A7D3-F2AC6C7497EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff99a6f000 -     0x7fff99b55ff7  libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff99b56000 -     0x7fff99bb6fff  com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff99dd1000 -     0x7fff99deafff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff99df1000 -     0x7fff99e3dffb  com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff99e3e000 -     0x7fff99e58fff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff99e59000 -     0x7fff99e80fff  com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fff99eb5000 -     0x7fff99ecafff  com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff99ecb000 -     0x7fff99f84ff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff99fe5000 -     0x7fff9a074ff7  libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
    0x7fff9a0df000 -     0x7fff9a124ff3  libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff9a132000 -     0x7fff9a55cfff  com.apple.ModelIO (1.0 - 1) <8838E0E1-ACB3-3CE8-ABDC-C787D8B3F247> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
    0x7fff9a55f000 -     0x7fff9a576fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
    0x7fff9a57c000 -     0x7fff9a62cfff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff9a669000 -     0x7fff9a688ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fff9a694000 -     0x7fff9a89ffff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
    0x7fff9a8a0000 -     0x7fff9a8c9fff  com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff9aa3e000 -     0x7fff9aa6ffff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff9aa70000 -     0x7fff9aa7cfff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff9aa7f000 -     0x7fff9ac2affb  GLEngine (12.1) <278B3208-B0D0-3FAE-AC23-A4FA06837311> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff9ac2b000 -     0x7fff9ac2bfff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff9ac2c000 -     0x7fff9ac3afff  com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fff9ac49000 -     0x7fff9ac79ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff9b63b000 -     0x7fff9b679ff7  libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff9b67a000 -     0x7fff9b6effff  com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff9b6f3000 -     0x7fff9b793fff  com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff9b9ad000 -     0x7fff9b9affff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff9b9b0000 -     0x7fff9b9b9ff7  com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff9b9ba000 -     0x7fff9ba0bff7  libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
    0x7fff9ba0c000 -     0x7fff9ba0cfff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
    0x7fff9ba27000 -     0x7fff9ba5bff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff9ba5c000 -     0x7fff9ba5eff7  com.apple.xpc.ServiceManagement (1.0 - 1) <B4181284-D588-3A20-93F3-B4FA882BC9A8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff9ba5f000 -     0x7fff9bab4fff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff9bab5000 -     0x7fff9baf7ff7  com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff9baf8000 -     0x7fff9baf9ffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
    0x7fff9bb1e000 -     0x7fff9bb20ffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
    0x7fff9bb2e000 -     0x7fff9bb30fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
    0x7fff9bb8e000 -     0x7fff9bb92fff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
    0x7fff9bc5c000 -     0x7fff9c0d2fff  com.apple.CoreFoundation (6.9 - 1259.11) <B8056BE3-151B-3003-91C9-6720CF04937B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff9c0d3000 -     0x7fff9c0d6ff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff9c0d7000 -     0x7fff9c0ebfff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
    0x7fff9c119000 -     0x7fff9c119fff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff9c11a000 -     0x7fff9c40ffff  com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff9c410000 -     0x7fff9c418ffb  libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff9c419000 -     0x7fff9c4efffb  com.apple.DiskImagesFramework (10.11.4 - 417.4) <FB30D069-648F-3FB2-AA55-FC603606C49E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff9c4f0000 -     0x7fff9c4ffffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff9cbef000 -     0x7fff9cbfafff  com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff9cc14000 -     0x7fff9cc17fff  com.apple.IOSurface (108.2.4 - 108.2.4) <E7A63C0D-2FDA-3BC6-947D-07E3C4A13110> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff9ce22000 -     0x7fff9ce35fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff9ce3d000 -     0x7fff9ce45fff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff9ce46000 -     0x7fff9cecfff7  com.apple.PerformanceAnalysis (1.0 - 1) <9C57BB91-46D6-3FB6-A5A2-8DB1CFE86B72> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff9ced0000 -     0x7fff9cfccfff  libFontParser.dylib (158.7) <393EFEA3-42B7-38DA-99DA-D01DEAA734CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff9d16c000 -     0x7fff9d1e3ff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fff9d1e4000 -     0x7fff9d883ffb  com.apple.JavaScriptCore (11601 - 11601.7.8) <38585ADC-1AD4-3BD2-8972-B90344CE57C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff9d884000 -     0x7fff9d894ff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff9d8be000 -     0x7fff9d8f8fff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff9dd1c000 -     0x7fff9dd21fff  com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff9dd22000 -     0x7fff9dd4cff7  libc++abi.dylib (307.4) <D24E06BF-6522-3C4A-BD0C-11C42BA4D8E8> /usr/lib/libc++abi.dylib
    0x7fff9dd5d000 -     0x7fff9dd8cfff  com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fff9dd9c000 -     0x7fff9de29dd7  com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff9de2a000 -     0x7fff9df38ff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff9df39000 -     0x7fff9df3eff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fff9df3f000 -     0x7fff9df4bfff  com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff9df4c000 -     0x7fff9e11aff3  com.apple.QuartzCore (1.11 - 410.14) <06A2BE20-38CB-3A89-9629-A782829DF977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff9e11b000 -     0x7fff9e18fff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff9e190000 -     0x7fff9e193fff  libsystem_sandbox.dylib (460.60.3) <2DDCB4AF-3037-34E5-A451-6846AFB9B85C> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff9e194000 -     0x7fff9e1daff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
    0x7fff9e24d000 -     0x7fff9e4d4fff  com.apple.CFNetwork (760.6.5 - 760.6.5) <8A36BBA6-F100-3F39-9711-2FA49D412987> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff9e4e8000 -     0x7fff9e4ecfff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
    0x7fff9e4f6000 -     0x7fff9e5dcfef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
    0x7fff9e5dd000 -     0x7fff9e648ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff9e754000 -     0x7fff9eb56fff  libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff9eb57000 -     0x7fff9ec0fff7  com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
    0x7fff9ec10000 -     0x7fff9ec34fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff9ec6a000 -     0x7fff9ed55ff7  com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff9ed56000 -     0x7fff9ed57fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff9ed58000 -     0x7fff9ed74ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
    0x7fff9edd5000 -     0x7fff9ee0cff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff9ee78000 -     0x7fff9ee7bfff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff9ee7c000 -     0x7fff9f33afcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff9f33f000 -     0x7fff9f36eff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff9f3f2000 -     0x7fff9f402fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
    0x7fff9f403000 -     0x7fff9f477ff3  com.apple.securityfoundation (6.0 - 55126) <3FF6D6E0-0C5D-385A-A97E-441D3947EFAB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff9f478000 -     0x7fff9f49cfff  com.apple.MultitouchSupport.framework (304.12 - 304.12) <598A8689-E97E-3C8D-AACD-8A0EB1956CA6> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff9f49d000 -     0x7fff9f4d5ff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff9f4d8000 -     0x7fff9f4e4ff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff9f508000 -     0x7fff9f531ffb  libRIP.A.dylib (970) <BA17C96B-83CC-3835-8AFD-CB5A69D3D26F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff9f56e000 -     0x7fff9f56efff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fffa0478000 -     0x7fffa0480fff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fffa0481000 -     0x7fffa06cdff7  com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x7fffa06ef000 -     0x7fffa071effb  com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
    0x7fffa071f000 -     0x7fffa071fff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
    0x7fffa0720000 -     0x7fffa07b5fff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fffa091a000 -     0x7fffa0943fff  libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
    0x7fffa0be4000 -     0x7fffa0c9efff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fffa0c9f000 -     0x7fffa0e45ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fffa0e46000 -     0x7fffa0e4efff  libGFXShared.dylib (12.1) <22F78420-D92E-3B5F-BA86-918A34289FCD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fffa0e4f000 -     0x7fffa0edcfef  libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
    0x7fffa0f1a000 -     0x7fffa11ffffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fffa1264000 -     0x7fffa12afff7  com.apple.CoreMediaIO (703.0 - 4791) <E49D0C36-295A-311A-9470-706455EA6F80> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fffa12b0000 -     0x7fffa12b5ff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
    0x7fffa12bc000 -     0x7fffa1562ff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fffa1581000 -     0x7fffa1621fff  com.apple.Metadata (10.7.0 - 972.34) <B0137597-158A-3503-85C8-F55DB5D21BE1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fffa168f000 -     0x7fffa1690ffb  libSystem.B.dylib (1226.10.1) <160608FD-B79D-3B49-AFEA-53A10C0C86B3> /usr/lib/libSystem.B.dylib
    0x7fffa1691000 -     0x7fffa1698ff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
    0x7fffa16ae000 -     0x7fffa171dfff  com.apple.datadetectorscore (7.0 - 460) <233A8FBF-B22F-3177-A328-781588D95D69> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fffa1783000 -     0x7fffa17e6fff  libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
    0x7fffa1841000 -     0x7fffa184cfff  libGPUSupportMercury.dylib (12.1) <97C7C8A3-234B-3C7C-8777-611E3D3EE63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffa184d000 -     0x7fffa184fff7  com.apple.securityhi (9.0 - 55006) <AC151C58-A7AD-3ECF-B15D-5E09FF94FC23> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fffa1850000 -     0x7fffa1869fff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fffa18e2000 -     0x7fffa190afff  com.apple.GLKit (1.0 - 56) <820F61C9-B74D-3604-BA6E-F20235E2E5B4> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
    0x7fffa193d000 -     0x7fffa1940fff  com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 3
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 2043
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=618.8M resident=0K(0%) swapped_out_or_unallocated=618.8M(100%)
Writable regions: Total=9.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9.7G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
ATS (font support)                32.3M        8
ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
Accelerate.framework               256K        3
Activity Tracing                  2048K        2
CG backing stores                 38.1M       16
CG image                         195.7M       60
CG shared images                  1040K       21
CoreAnimation                      224K       43
CoreUI image data                 2084K       20
CoreUI image file                  320K        5
Dispatch continuations            48.0M        2
Foundation                          24K        3
Image IO                           584K       48
Kernel Alloc Once                    8K        3
MALLOC                           876.9M      868
MALLOC guard page                   48K       11
MALLOC_LARGE (reserved)           5432K       38         reserved VM address space (unallocated)
Memory Tag 242                      12K        2
OpenCL                               8K        2
OpenGL GLSL                        256K        4
Process Corpse Info               2048K        2
STACK GUARD                       56.4M      113
Stack                            272.0M      121
VM_ALLOCATE                        8.2G       57
__DATA                            70.9M      379
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       116.9M       76
__TEXT                           501.9M      351
__UNICODE                          552K        2
mapped file                      220.7M       59
shared memory                     16.4M       12
TOTAL                             10.6G     2306
TOTAL, minus reserved VM space    10.6G     2306
Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 64 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX 980 TI, NVIDIA GeForce GTX 980 TI, PCIe, 6144 MB
Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 4, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 5, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 6, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 7, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 8, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce GTX 980 TI, Display Controller, Slot-1
PCI Card: NVIDIA GeForce GTX 980 TI, NVDA,Parent, Slot-1
PCI Card: pci10b5,8609, Slot-2
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@11,0,0
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@10,0,0
PCI Card: pci1b4b,9230, AHCI Controller, Slot-3
PCI Card: pci1b4b,9230, AHCI Controller, Slot-4
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@9,0,0
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@8,0,0
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@9,0,1
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@8,0,1
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: HL-DT-ST BD-RE  WH16NS40
Serial ATA Device: Samsung SSD 850 PRO 2TB, 2.05 TB
Serial ATA Device: Samsung SSD 840 EVO 1TB, 1 TB
Serial ATA Device: ElitePro Qx2, 9 TB
Serial ATA Device: 2.74 TB HD Glyph, 3 TB
Serial ATA Device: OWC Mercury Accelsior PCIe SSD, 960.04 GB
Serial ATA Device: MARVELL VIRTUAL
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: Intuos5 touch L
USB Device: USB 2.0 Bus
USB Device: HZD
USB Device: USB2.0 Hub
USB Device: Apple Watch Magnetic Charging Cable
USB Device: GL3220
USB Device: SoundSticks
USB Device: Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Apple LED Cinema Display
USB Device: Display iSight
USB Device: Display Audio
USB Device: USB 3.0 Bus
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
Sep 30, 2017 Sep 30, 2017
Hi
I am not a Mac user so could only test on Windows and could not get the problem to occur. However I do notice that you are not using the latest version of Photoshop which is CC2017.1.1 r252.
You may want to update to that latest version and see if the problem still occurs
Dave
Hi davescm,
Thanks for the reply. In the first crash report I posted, I was using an older version of Photoshop, and a different user suggested I update.
I updated to CC2017.1.1 r252 and sadly, the problem still occurred (I posted the 2nd crash report above).
Oops -sorry my mistake - I missed the second crash report . Hopefully a Mac user will come along soon to offer advice.
Dave
Oct 02, 2017 Oct 02, 2017
Another user on a different forum recommended that I disable GPU acceleration (I will try that next and see if it helps).
And another user mentioned that they were able to replicate the error on their machine, but that they're beta testing a new version of Photoshop and the problem has been fixed. I'm not sure when this version will get released, though, so still hoping that there's something I can adjust on my end to resolve the issue. Hopefully Adobe (or a Mac user) can check out the crash report(s) I've posted -- can anything be learned from them?
Really appreciate any advice anyone has to offer.
Went to Preferences/Performace/Advanced Settings and unchecked "Use Graphics Processor to Accelerate Computation" and restarted.
Just like in the previous instances, I was able to rotate the view, make a selection, and invert and delete the selection without any problems for the first 5 or so minutes of my session.
Then the software crashed again. The only difference was, I was able to invert the selection, hit "delete", and the program didn't instantly crash -- it took maybe 2 full seconds for the program to crash. (But the cause was still the same -- making a selection with the view rotated, inverting it, and then hitting "delete".
Here is the latest crash report:
Process:               Adobe Photoshop CC 2017 [894]
Path:                  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
Identifier:            com.adobe.Photoshop
Version:               18.1.1 (18.1.1.252)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Adobe Photoshop CC 2017 [894]
User ID:               501
Date/Time:             2017-10-02 16:10:06.307 -0700
OS Version:            Mac OS X 10.11.6 (15G1611)
Report Version:        11
Anonymous UUID:        056FB863-13B4-6410-D572-383FF35796D5
Time Awake Since Boot: 7400 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGBUS)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x0000000125593bd8
Exception Note:        EXC_CORPSE_NOTIFY
VM Regions Near 0x125593bd8:
    mapped file            000000012540e000-00000001254ed000 [  892K] r--/rwx SM=COW
--> __TEXT                 00000001254ed000-0000000125639000 [ 1328K] r-x/rwx SM=COW  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
    __DATA                 0000000125639000-0000000125648000 [   60K] rw-/rwx SM=COW  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   MMXCore                       0x00000001230843cd 0x123067000 + 119757
1   com.adobe.Photoshop           0x000000010e8744f7 0x10df3e000 + 9659639
2   com.adobe.Photoshop           0x000000010e8881ff 0x10df3e000 + 9740799
3   com.adobe.Photoshop           0x000000010e7057ed 0x10df3e000 + 8157165
4   com.adobe.Photoshop           0x000000010ebc003a 0x10df3e000 + 13115450
5   com.adobe.Photoshop           0x000000010e00379a 0x10df3e000 + 808858
6   com.adobe.Photoshop           0x000000010dfdbb70 0x10df3e000 + 646000
7   com.adobe.Photoshop           0x000000010dfdbc39 0x10df3e000 + 646201
8   com.adobe.Photoshop           0x000000010fe7f78d 0x10df3e000 + 32774029
9   com.apple.Foundation          0x00007fff90c3ae2c __NSFireTimer + 95
10  com.apple.CoreFoundation      0x00007fff950ecae4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
11  com.apple.CoreFoundation      0x00007fff950ec773 __CFRunLoopDoTimer + 1075
12  com.apple.CoreFoundation      0x00007fff950ec2ca __CFRunLoopDoTimers + 298
13  com.apple.CoreFoundation      0x00007fff950e37c1 __CFRunLoopRun + 1841
14  com.apple.CoreFoundation      0x00007fff950e2e28 CFRunLoopRunSpecific + 296
15  com.apple.HIToolbox           0x00007fff95548935 RunCurrentEventLoopInMode + 235
16  com.apple.HIToolbox           0x00007fff9554876f ReceiveNextEventCommon + 432
17  com.apple.HIToolbox           0x00007fff955485af _BlockUntilNextEventMatchingListInModeWithFilter + 71
18  com.apple.AppKit              0x00007fff8afe8df6 _DPSNextEvent + 1067
19  com.apple.AppKit              0x00007fff8afe8226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
20  com.adobe.Photoshop           0x000000010fe7e441 0x10df3e000 + 32769089
21  com.apple.AppKit              0x00007fff8afdcd80 -[NSApplication run] + 682
22  com.adobe.Photoshop           0x000000010fe7f5a2 0x10df3e000 + 32773538
23  com.adobe.Photoshop           0x000000010fe80928 0x10df3e000 + 32778536
24  com.adobe.Photoshop           0x000000010dfdd68d 0x10df3e000 + 652941
25  com.adobe.Photoshop           0x000000010e3557df 0x10df3e000 + 4290527
26  com.adobe.Photoshop           0x000000010e355a69 0x10df3e000 + 4291177
27  libdyld.dylib                 0x00007fff90fd45ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib        0x00007fff8e8a7efa kevent_qos + 10
1   libdispatch.dylib             0x00007fff89723165 _dispatch_mgr_invoke + 216
2   libdispatch.dylib             0x00007fff89722dcd _dispatch_mgr_thread + 52
Thread 2:: MPSupport Worker
0   libsystem_kernel.dylib        0x00007fff8e8a6db6 __psynch_cvwait + 10
1   libsystem_pthread.dylib       0x00007fff908e8728 _pthread_cond_wait + 767
2   MultiProcessor Support        0x00000001231b10fb 0x123167000 + 303355
3   MultiProcessor Support        0x00000001231b101b 0x123167000 + 303131
4   MultiProcessor Support        0x00000001231d27a6 0x123167000 + 440230
5   libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
6   libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
7   libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 3:: MPSupport Worker
Thread 4:: MPSupport Worker
Thread 5:: MPSupport Worker
Thread 6:: MPSupport Worker
Thread 7:: MPSupport Worker
Thread 8:: MPSupport Worker
Thread 9:: MPSupport Worker
Thread 10:: MPSupport Worker
Thread 11:: MPSupport Worker
Thread 12:: MPSupport Worker
Thread 13:: MPSupport Worker
Thread 14:: MPSupport Worker
Thread 15:: MPSupport Worker
Thread 16:: MPSupport Worker
Thread 17:: MPSupport Worker
Thread 18:: MPSupport Worker
Thread 19:: MPSupport Worker
Thread 20:: MPSupport Worker
Thread 21:: MPSupport Worker
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: VulcanMsgRecv
0   libsystem_kernel.dylib        0x00007fff8e8a6fba __recvfrom + 10
1   VulcanMessage5.dylib          0x000000011982f308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2   VulcanMessage5.dylib          0x000000011982e6cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3   VulcanMessage5.dylib          0x000000011982d9c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4   VulcanMessage5.dylib          0x000000011982d888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5   VulcanMessage5.dylib          0x00000001198284c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6   VulcanMessage5.dylib          0x0000000119828f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
7   VulcanMessage5.dylib          0x00000001198288ef vcfoundation::io::Serializer::Deserialize() + 9
8   VulcanMessage5.dylib          0x000000011982c974 vcfoundation::ncomm::Connection::ReadIn() + 22
9   VulcanMessage5.dylib          0x000000011982c3cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10  VulcanMessage5.dylib          0x000000011982c0ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11  VulcanMessage5.dylib          0x000000011982c00d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12  VulcanMessage5.dylib          0x000000011981f848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13  VulcanMessage5.dylib          0x000000011981ea86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14  VulcanMessage5.dylib          0x000000011982d20c vcfoundation::thread::AbstractThread::Run() + 72
15  VulcanMessage5.dylib          0x000000011982f109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16  libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
17  libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
18  libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 26:
0   libsystem_kernel.dylib        0x00007fff8e8a0fae semaphore_wait_trap + 10
1   libtbb.dylib                  0x000000011571c100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
2   libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
3   libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
4   libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:: BridgeTalk
0   libsystem_kernel.dylib        0x00007fff8e8a710a __semwait_signal + 10
1   libsystem_c.dylib             0x00007fff9a2ccd0f nanosleep + 199
2   com.adobe.PSAutomate          0x0000000158000ce8 0x157e2d000 + 1916136
3   com.adobe.PSAutomate          0x0000000157fe2b5c 0x157e2d000 + 1792860
4   com.adobe.PSAutomate          0x0000000158000871 0x157e2d000 + 1914993
Thread 50:: Bristle Physics
2   com.adobe.Photoshop           0x000000010e98348b 0x10df3e000 + 10769547
3   com.adobe.Photoshop           0x000000010fd19c65 0x10df3e000 + 31308901
4   com.adobe.Photoshop           0x000000010fd11583 0x10df3e000 + 31274371
5   CITThreading                  0x0000000115dca05e boost::(anonymous namespace)::thread_proxy(void*) + 130
Thread 51:: Font Initialization
2   com.adobe.Photoshop           0x000000010e320fb1 0x10df3e000 + 4075441
3   com.adobe.Photoshop           0x000000011022a81c 0x10df3e000 + 36620316
4   com.adobe.Photoshop           0x0000000110229cac 0x10df3e000 + 36617388
5   com.adobe.Photoshop           0x000000011022bba6 0x10df3e000 + 36625318
6   CITThreading                  0x0000000115dca05e boost::(anonymous namespace)::thread_proxy(void*) + 130
7   libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
8   libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
9   libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 52:: DeepFont
Thread 53:: com.apple.NSEventThread
0   libsystem_kernel.dylib        0x00007fff8e8a0f72 mach_msg_trap + 10
1   libsystem_kernel.dylib        0x00007fff8e8a03b3 mach_msg + 55
2   com.apple.CoreFoundation      0x00007fff950e4114 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      0x00007fff950e35dc __CFRunLoopRun + 1356
5   com.apple.AppKit              0x00007fff8b13ed95 _NSEventThread + 149
Thread 54:
2   com.adobe.headlights.LogSessionFramework 0x0000000118944ccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3   com.adobe.headlights.LogSessionFramework 0x00000001189435ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4   com.adobe.headlights.LogSessionFramework 0x00000001188f1059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5   com.adobe.headlights.LogSessionFramework 0x00000001188bfcfb RealTimeProcessor::WorkerThread(int, int) + 3633
6   com.adobe.headlights.LogSessionFramework 0x0000000118942969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 55:: com.apple.NSURLConnectionLoader
5   com.apple.CFNetwork           0x00007fff97652a6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6   com.apple.Foundation          0x00007fff90bc6c84 __NSThread__start__ + 1351
Thread 56:
2   com.adobe.headlights.LogSessionFramework 0x00000001188f2152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3   com.adobe.headlights.LogSessionFramework 0x00000001188f10db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4   com.adobe.headlights.LogSessionFramework 0x00000001188f0bae IdleTimeLogger::IdleTimeWorkerThread() + 2804
5   com.adobe.headlights.LogSessionFramework 0x0000000118942969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 57:: General Background Service
Thread 58:: Update Activation Menu Items
2   com.adobe.Photoshop           0x000000010e2a13a2 0x10df3e000 + 3552162
3   CITThreading                  0x0000000115dca05e boost::(anonymous namespace)::thread_proxy(void*) + 130
4   libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
5   libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
6   libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 59:
2   libc++.1.dylib                0x00007fff8a26068f std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3   com.adobe.Photoshop           0x000000010df432fd 0x10df3e000 + 21245
4   com.adobe.Photoshop           0x000000010df43f5b 0x10df3e000 + 24411
5   com.adobe.Photoshop           0x000000010df43d4e 0x10df3e000 + 23886
Thread 60:
Thread 61:
Thread 62:
Thread 63:: com.apple.CFSocket.private
0   libsystem_kernel.dylib        0x00007fff8e8a707a __select + 10
1   com.apple.CoreFoundation      0x00007fff9512145a __CFSocketManager + 762
Thread 64:: NetworkConfigWatcher
5   com.apple.Foundation          0x00007fff90bb5cf9 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270
6   org.chromium.ContentShell.framework 0x0000000159bf7eee 0x158657000 + 22679278
7   org.chromium.ContentShell.framework 0x0000000159bf772c 0x158657000 + 22677292
8   org.chromium.ContentShell.framework 0x0000000159c10113 0x158657000 + 22778131
9   org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
10  org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
11  libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
12  libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
13  libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 65:: DnsConfigService
0   libsystem_kernel.dylib        0x00007fff8e8a7eca kevent + 10
1   org.chromium.ContentShell.framework 0x0000000159c673e7 0x158657000 + 23135207
2   org.chromium.ContentShell.framework 0x0000000159c64ebd 0x158657000 + 23125693
3   org.chromium.ContentShell.framework 0x0000000159bf6e2f 0x158657000 + 22674991
4   org.chromium.ContentShell.framework 0x0000000159c10113 0x158657000 + 22778131
5   org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
6   org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
Thread 66:: Chrome_DBThread
5   org.chromium.ContentShell.framework 0x0000000159bf7c4f 0x158657000 + 22678607
6   org.chromium.ContentShell.framework 0x0000000159bf772c 0x158657000 + 22677292
7   org.chromium.ContentShell.framework 0x0000000159c10113 0x158657000 + 22778131
8   org.chromium.ContentShell.framework 0x000000015932d354 0x158657000 + 13460308
9   org.chromium.ContentShell.framework 0x000000015932d4c3 0x158657000 + 13460675
10  org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
11  org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
12  libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
13  libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
14  libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 67:: Chrome_FileThread
5   org.chromium.ContentShell.framework 0x000000015932d384 0x158657000 + 13460356
6   org.chromium.ContentShell.framework 0x000000015932d4d0 0x158657000 + 13460688
7   org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
8   org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
9   libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
10  libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
11  libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 68:: Chrome_FileUserBlockingThread
8   org.chromium.ContentShell.framework 0x000000015932d3b4 0x158657000 + 13460404
9   org.chromium.ContentShell.framework 0x000000015932d4dd 0x158657000 + 13460701
Thread 69:: Chrome_ProcessLauncherThread
8   org.chromium.ContentShell.framework 0x000000015932d3e4 0x158657000 + 13460452
9   org.chromium.ContentShell.framework 0x000000015932d4ea 0x158657000 + 13460714
Thread 70:: Chrome_CacheThread
8   org.chromium.ContentShell.framework 0x000000015932d414 0x158657000 + 13460500
9   org.chromium.ContentShell.framework 0x000000015932d4f7 0x158657000 + 13460727
Thread 71:: Chrome_IOThread
5   org.chromium.ContentShell.framework 0x000000015932d444 0x158657000 + 13460548
6   org.chromium.ContentShell.framework 0x000000015932d504 0x158657000 + 13460740
Thread 72:: BrowserBlockingWorker1/168707
2   org.chromium.ContentShell.framework 0x0000000159c302cf 0x158657000 + 22909647
3   org.chromium.ContentShell.framework 0x0000000159c2f976 0x158657000 + 22907254
4   org.chromium.ContentShell.framework 0x0000000159c32c5d 0x158657000 + 22920285
5   org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
Thread 73:: IndexedDB
8   org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
9   org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
10  libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
11  libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
12  libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 74:: CompositorTileWorker1/171523
2   org.chromium.ContentShell.framework 0x0000000159ce6698 0x158657000 + 23656088
3   org.chromium.ContentShell.framework 0x0000000159c32c5d 0x158657000 + 22920285
4   org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
Thread 75:: AudioThread
Thread 76:: NetworkConfigWatcher
Thread 77:: Chrome_DevToolsHandlerThread
Thread 78:: BrowserBlockingWorker2/180239
Thread 79:: BrowserBlockingWorker3/181043
Thread 80:
5   com.apple.Foundation          0x00007fff90ccdf99 -[NSConnection run] + 149
Thread 81:: CEPMonitorThread
5   com.apple.Foundation          0x00007fff90c5fdda -[NSConcreteTask waitUntilExit] + 205
6   com.adobe.PlugPlugOwl         0x00000001160f4c4b -[HtmlEngineMonitor monitorThreadProc] + 160
7   com.apple.Foundation          0x00007fff90bc6c84 __NSThread__start__ + 1351
8   libsystem_pthread.dylib       0x00007fff908e799d _pthread_body + 131
9   libsystem_pthread.dylib       0x00007fff908e791a _pthread_start + 168
10  libsystem_pthread.dylib       0x00007fff908e5351 thread_start + 13
Thread 82:: CachePoolWorker1/191235
Thread 83:
Thread 84:: CEPMonitorThread
Thread 85:: Background Save
3   com.adobe.Photoshop           0x000000010ff6898c 0x10df3e000 + 33728908
4   com.adobe.Photoshop           0x000000010ff666a9 0x10df3e000 + 33719977
Thread 86:
0   libsystem_kernel.dylib        0x00007fff8e8a75e2 __workq_kernreturn + 10
1   libsystem_pthread.dylib       0x00007fff908e7578 _pthread_wqthread + 1283
2   libsystem_pthread.dylib       0x00007fff908e5341 start_wqthread + 13
Thread 87:
Thread 88:
Thread 89:
Thread 90:
Thread 91:
Thread 92:
Thread 93:
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
1   libsystem_pthread.dylib       0x00007fff908e875e _pthread_cond_wait + 821
2   com.apple.CoreServices.CarbonCore 0x00007fff9a3bda93 TSWaitOnConditionTimedRelative + 147
3   com.apple.CoreServices.CarbonCore 0x00007fff9a3bd66e TSWaitOnSemaphoreCommon + 406
4   com.apple.CoreServices.CarbonCore 0x00007fff9a3846ea AsyncFileThread(void*) + 275
Thread 109:: Dispatch queue: NSCGSDisableUpdates
2   com.apple.CoreGraphics        0x00007fff84650a42 _CGSReenableUpdateForConnection + 92
3   com.apple.CoreGraphics        0x00007fff8465070d CGSReenableUpdateToken + 469
4   libdispatch.dylib             0x00007fff8972893d _dispatch_call_block_and_release + 12
5   libdispatch.dylib             0x00007fff8971d40b _dispatch_client_callout + 8
6   libdispatch.dylib             0x00007fff8972203b _dispatch_queue_drain + 754
7   libdispatch.dylib             0x00007fff89728707 _dispatch_queue_invoke + 549
8   libdispatch.dylib             0x00007fff8971d40b _dispatch_client_callout + 8
9   libdispatch.dylib             0x00007fff8972129b _dispatch_root_queue_drain + 1890
10  libdispatch.dylib             0x00007fff89720b00 _dispatch_worker_thread3 + 91
11  libsystem_pthread.dylib       0x00007fff908e74de _pthread_wqthread + 1129
12  libsystem_pthread.dylib       0x00007fff908e5341 start_wqthread + 13
Thread 110:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x00000000000006e6  rbx: 0x0000000000000008  rcx: 0x00000000000006e8  rdx: 0x0000000000000000
  rdi: 0x0000000125593bd8  rsi: 0x0000000000000001  rbp: 0x00007fff51cbebd0  rsp: 0x00007fff51cbe928
   r8: 0x0000000000000000   r9: 0x00000000000006e6  r10: 0x0000000000000000  r11: 0x0000000000000006
  r12: 0x00000000000006e6  r13: 0x0000000000000008  r14: 0x00000000000006e8  r15: 0x00000000000006e6
  rip: 0x00000001230843cd  rfl: 0x0000000000010203  cr2: 0x0000000125593bd8
Logical CPU:     10
Error Code:      0x00000007
Trap Number:     14
Binary Images:
       0x10df3e000 -        0x11472bf87 +com.adobe.Photoshop (18.1.1 - 18.1.1.252) <B684F32F-915C-3BEA-B7EC-8B5F5820FAAC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
       0x11570d000 -        0x115744fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
       0x115785000 -        0x1157a8fe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
       0x1157e2000 -        0x11588afff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.5) <0AE6FE3B-AD77-3C9E-AD1B-CEE881FEF5C2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
       0x1158e9000 -        0x115987fff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.5) <678BE576-32AB-3958-9C04-2504856330E5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
       0x1159d7000 -        0x115b5aff7 +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <EB941620-7550-301A-98C4-69CDB0577834> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
       0x115cb9000 -        0x115d28ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <48E3C4F3-461F-3F9F-B83A-11BC5D103508> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
       0x115dba000 -        0x115dd3fff +CITThreading (???) <F6746740-68D1-3F47-9714-94B42B132BD9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
       0x115e11000 -        0x115f0fff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
       0x115f40000 -        0x116046fff +com.adobe.amtlib (10.0.0.119 - 10.0.0.119) <53139645-73AD-3787-AEE6-579FABE39250> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
       0x11605b000 -        0x1162d1ff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
       0x1165a1000 -        0x116617fff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37848) <387CF9B9-B873-35B7-8D5E-7ACB4EA61AE7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
       0x116701000 -        0x1167aaff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
       0x1167d9000 -        0x1167defff  org.twain.dsm (1.9.5 - 1.9.5) <F7AA3C5E-4FB0-379D-8F79-AD06669D087E> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
       0x1167e7000 -        0x116805fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
       0x11681a000 -        0x11681efff  com.apple.agl (3.3.1 - AGL-3.3.1) <2FC3E30C-5370-3369-B8D1-1C7050A4A85A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x11682c000 -        0x1169beff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <CDF9E325-6035-3EF9-8E03-980CD33D6582> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
       0x116a0e000 -        0x116d74ff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
       0x116deb000 -        0x116e0ffff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
       0x116e3c000 -        0x117105ffb +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <7DAE22B9-2F91-385B-B4EA-9EC75CBEE0EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
       0x117175000 -        0x117472ffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <46381E3C-77F9-3842-8A13-33BDEFA6E1D7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
       0x1174c0000 -        0x1174e3ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
       0x1174f1000 -        0x117515ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
       0x11753d000 -        0x117667ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
       0x1176bc000 -        0x117806ff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <3236E6F5-C286-3C46-AD03-9838AFE1D751> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
       0x11781c000 -        0x117838ffb +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
       0x117846000 -        0x117906ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.38234) <FA7EDCFB-62E7-33C2-89C9-8D745921518F> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
       0x117951000 -        0x117acbfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
       0x117c1f000 -        0x118177fef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
       0x1187e5000 -        0x1187e6fff  libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
       0x1187ec000 -        0x118986fff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
       0x118a60000 -        0x1197a5fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
       0x1197bb000 -        0x1197e4ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
       0x119801000 -        0x119804fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
       0x119811000 -        0x11984cff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
       0x11989b000 -        0x119997fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
       0x119a41000 -        0x119b90ff3 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <CEC41C30-5517-3C8E-9998-A2F72308D548> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
       0x119beb000 -        0x119ce5ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
       0x119cfb000 -        0x119dfeff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
       0x119e4e000 -        0x119f95fef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
       0x11a0f3000 -        0x11a315ff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
       0x11a36a000 -        0x11a547ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
       0x11a62e000 -        0x11a8c0ffb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <6A2AF438-1448-33BB-81F2-7058E8E3E1F2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
       0x11a940000 -        0x11aa74fff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
       0x11ad10000 -        0x11ad12ff7  com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x11ade3000 -        0x11adf2ff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
       0x1222c0000 -        0x1222dcff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
       0x1222e2000 -        0x122304ff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
       0x122309000 -        0x12231bfff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
       0x12245c000 -        0x12249fff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
       0x1224bb000 -        0x1224c3fff +FastCore (18.1.1 - 18.1.1) <F20E2338-3B28-3C34-BB07-CE946978B58B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
       0x123067000 -        0x1230e3fef +MMXCore (18.1.1 - 18.1.1) <A6B54ABB-D74E-39C7-A606-35B8F3FCDAF4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
       0x123167000 -        0x1231e0ff7 +MultiProcessor Support (18.1.1 - 18.1.1) <A53DC4D5-BB48-3608-94A6-6C839B409A51> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
       0x1254ed000 -        0x125638fff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
       0x12ad93000 -        0x12ad97fff  libFontRegistryUI.dylib (155.2) <8346E80E-5832-3944-A750-FBB9D328C2FE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x12add2000 -        0x12ae77fff  ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
       0x12b2c7000 -        0x12b2d2fff  com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <B46E04B4-EB85-3436-82C4-158DF1A2AB36> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
       0x14740f000 -        0x147414fff  libgermantok.dylib (17) <B230A9A9-EC4C-306C-8C65-7143285DA142> /usr/lib/libgermantok.dylib
       0x157687000 -        0x157698ff7 +MeasurementCore (18.1.1 - 18.1.1) <E5DCB5F1-79E2-3B56-B4A9-6A650EE8B6B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
       0x157832000 -        0x157864ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
       0x157870000 -        0x157899fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
       0x157b74000 -        0x157d67fff  com.nvidia.web.GeForceMTLDriverWeb (10.11.14 - 10.1.1) <293ED998-72BF-33D0-AC42-282B8122F6A1> /System/Library/Extensions/GeForceMTLDriverWeb.bundle/Contents/MacOS/GeForceMTLDriverWeb
       0x157e2d000 -        0x158262fff +com.adobe.PSAutomate (18.1.1 - 18.1.1) <54B32ED4-0367-3E12-837F-06413A5FF034> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
       0x15854f000 -        0x15862fff7 +com.adobe.ps.spaces (18.1.1 - 18.1.1) <976B6154-C2DD-39C4-BF65-9A8AA2EAEB34> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
       0x158657000 -        0x15e0d9faf +org.chromium.ContentShell.framework (99.77.34.5 - 34.5) <42663479-0F87-37B7-8694-E2701B2A59B6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
       0x15e7d9000 -        0x15e810fff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x15e839000 -        0x15e84cff7  com.apple.GameController (1.0 - 1) <5B98EABB-D27C-3381-9487-21B1C91BF9E8> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
       0x15e85e000 -        0x15e877fff  libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
       0x160a72000 -        0x1613dffff  com.nvidia.web.GeForceGLDriverWeb (10.11.14 - 10.1.1) <0D0C682E-CE22-3724-B251-05A6736FC883> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/GeForceGLDriverWeb
       0x161ee5000 -        0x1629f2ff7  libclhWeb.dylib (0) <4FB1DBC0-6E02-3B9A-A6B4-F225B0CDCD75> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/libclhWeb.dylib
       0x1669aa000 -        0x166a24ff7  com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
       0x16b730000 -        0x16b730ff7 +cl_kernels (???) <EA673946-537D-49E6-9B7C-D8DBDEEB2D06> cl_kernels
    0x7fff6943c000 -     0x7fff69473a47  dyld (360.22) <C8E77F6D-CE86-3C5B-8576-2584A799B51E> /usr/lib/dyld
    0x7fff843d4000 -     0x7fff843e0fff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff843e1000 -     0x7fff845eefff  libicucore.A.dylib (551.51.5) <2D3634CA-A87A-37A9-A3F4-C3E3106C2A33> /usr/lib/libicucore.A.dylib
    0x7fff845ef000 -     0x7fff85855fff  com.apple.CoreGraphics (1.600.0 - 960.7) <82D77440-30B2-3DCF-9414-88EC57CAD6CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff85884000 -     0x7fff8592bfff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff8592c000 -     0x7fff8593efff  libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
    0x7fff85a97000 -     0x7fff85af5fff  com.apple.SystemConfiguration (1.14 - 1.14) <ACAEDA14-FAA0-3F14-B476-DE492A52D383> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff85c1f000 -     0x7fff85c59ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff85cb7000 -     0x7fff85ed8ff7  com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff85f38000 -     0x7fff85f3bff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff86046000 -     0x7fff86173fff  com.apple.CoreText (352.0 - 494.14) <93E0D8C3-D5DD-3EBB-9CC1-831C46572133> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff861d5000 -     0x7fff861f0ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
    0x7fff861f1000 -     0x7fff86280fff  com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff86311000 -     0x7fff86311fff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff86562000 -     0x7fff865b4fff  com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff865ba000 -     0x7fff8660aff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff8660d000 -     0x7fff8666bfff  com.apple.CoreServices.OSServices (728.13 - 728.13) <477EA3F9-D13E-3D83-ABAD-4DC7DB134CF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff86698000 -     0x7fff866a6fff  com.apple.IntlPreferences (2.0 - 192) <388C5784-7713-36B0-B08B-5163E6B04002> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fff866a7000 -     0x7fff866a9ff7  libquarantine.dylib (80) <B3B7B630-9012-3DA3-9458-5C009625E606> /usr/lib/system/libquarantine.dylib
    0x7fff86af0000 -     0x7fff87bd9ff3  com.apple.WebCore (11601 - 11601.7.5) <9153DA7E-1625-382A-8257-8D4293F06F7F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff87bda000 -     0x7fff87fb2fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff87fb3000 -     0x7fff88002ff7  com.apple.opencl (2.7.0 - 2.7.0) <DAEC71D4-E0E7-3E24-BB44-C977A798C575> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff88003000 -     0x7fff8804fff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff88050000 -     0x7fff8805afff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff8805c000 -     0x7fff88067fff  com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff88096000 -     0x7fff88096fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff88097000 -     0x7fff880fefff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff88112000 -     0x7fff88113fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
    0x7fff88114000 -     0x7fff88117ff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff88118000 -     0x7fff88126ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
    0x7fff88155000 -     0x7fff885f0ffb  com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff885f1000 -     0x7fff886e3ff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
    0x7fff8873f000 -     0x7fff8873fff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
    0x7fff88748000 -     0x7fff8874fff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fff8880d000 -     0x7fff88b78657  libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
    0x7fff88b79000 -     0x7fff88b8ffff  com.apple.CoreMediaAuthoring (2.2 - 953) <A8F1B6EE-8ABE-3DC2-9829-A268D016648E> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fff88c92000 -     0x7fff88f24ffb  com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff88f25000 -     0x7fff88f27fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff88f28000 -     0x7fff88f2afff  libCVMSPluginSupport.dylib (12.1) <20BA72AF-C7C5-3551-8F59-E1AED5FC69F0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff88fae000 -     0x7fff88fd0fff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff88fd1000 -     0x7fff88ff3ff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff89330000 -     0x7fff89475fff  com.apple.QTKit (7.7.3 - 2943.13) <3E3DB3DD-8D7E-3478-B020-F975CCAAE522> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fff8947a000 -     0x7fff89485ff7  libkxld.dylib (3248.70.3) <BAD04BB1-5BFE-3D88-ADDE-23FED2DD2942> /usr/lib/system/libkxld.dylib
    0x7fff89486000 -     0x7fff8948afff  libGIF.dylib (1463) <3F84E60B-18E5-3897-8494-DFB1ACE76829> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff896f0000 -     0x7fff896f0ff7  liblaunch.dylib (765.70.1) <96D7C3EE-82E2-39AB-870F-B317A030E86D> /usr/lib/system/liblaunch.dylib
    0x7fff896f1000 -     0x7fff8970dff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
    0x7fff8971b000 -     0x7fff89748fff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
    0x7fff89749000 -     0x7fff89757fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
    0x7fff8976e000 -     0x7fff8978afff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff8978b000 -     0x7fff897ccff7  libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff89924000 -     0x7fff8a258f5f  libLLVMContainer.dylib (119.5) <09A35A20-7CDD-3E5A-94B4-5F1E5CFBC3D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libLLVMContainer.dylib
    0x7fff8a259000 -     0x7fff8a2acff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
    0x7fff8a2ad000 -     0x7fff8a3bffef  libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff8a3c0000 -     0x7fff8a3c6ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff8a49a000 -     0x7fff8a49efff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff8a4a8000 -     0x7fff8a4a9ff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff8a4e6000 -     0x7fff8a664fff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff8a798000 -     0x7fff8a807fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff8a808000 -     0x7fff8a925fff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
    0x7fff8a956000 -     0x7fff8ae78fff  com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff8ae79000 -     0x7fff8ae7efff  com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff8aefb000 -     0x7fff8af4dfff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <4F5F5CD6-631F-3C97-AA62-7DF19BD5EC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff8af4e000 -     0x7fff8af9ffff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff8afa0000 -     0x7fff8bbc9ff7  com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff8bbcc000 -     0x7fff8bc85ff7  libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff8bd1e000 -     0x7fff8bd4cff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff8bf3c000 -     0x7fff8bfe7fff  com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff8c04a000 -     0x7fff8c069ff7  com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff8c06a000 -     0x7fff8c093ff7  libxpc.dylib (765.70.1) <4FB1311F-4032-3F56-BF0B-CFF45D78FB01> /usr/lib/system/libxpc.dylib
    0x7fff8c094000 -     0x7fff8c174ff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
    0x7fff8c175000 -     0x7fff8c264ff7  libxml2.2.dylib (29.14) <02077D26-0AB0-347A-8AF2-FADE3CFC296C> /usr/lib/libxml2.2.dylib
    0x7fff8c265000 -     0x7fff8c298ff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff8c2ce000 -     0x7fff8c2d6fff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff8c2da000 -     0x7fff8c2e2fff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
    0x7fff8c2e6000 -     0x7fff8c2ecfff  com.apple.IOAccelerator (205.11 - 205.11) <3E86AB1B-C1CF-307D-900F-385C8D8C534A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff8c2ed000 -     0x7fff8c302ff3  libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff8c303000 -     0x7fff8c31dff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
    0x7fff8c320000 -     0x7fff8c322fff  libCGXType.A.dylib (970) <A931200A-B248-39EF-8A8B-311D881BE372> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff8c334000 -     0x7fff8c342fff  com.apple.opengl (12.1.0 - 12.1.0) <12EBDE6A-2F44-3429-8337-2BB36870BFD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff8c354000 -     0x7fff8c692ff7  com.apple.WebKit (11601 - 11601.7.8) <58A8B070-2AE4-3909-AE1D-7A7DF34AA268> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff8c6c4000 -     0x7fff8c710fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff8c711000 -     0x7fff8c97efff  com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff8c97f000 -     0x7fff8c990ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
    0x7fff8c991000 -     0x7fff8c991fff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff8c992000 -     0x7fff8c9c4ff7  libTrueTypeScaler.dylib (158.7) <020536E5-C032-30B5-864C-920D5F7DB6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff8c9c5000 -     0x7fff8c9dcff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
    0x7fff8cc79000 -     0x7fff8d0a7fff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff8d0a8000 -     0x7fff8d0d9ff7  libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
    0x7fff8d111000 -     0x7fff8d112fff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
    0x7fff8d113000 -     0x7fff8d11efff  libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff8d21e000 -     0x7fff8d223fff  com.apple.DiskArbitration (2.7 - 2.7) <8CB47F4A-0FD2-343A-93C8-965174F6F24F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff8d224000 -     0x7fff8d239fff  com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
    0x7fff8d23a000 -     0x7fff8d2a0ff7  libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
    0x7fff8d2a1000 -     0x7fff8d2a1fff  com.apple.CoreServices (728.13 - 728.13) <CFE3EE73-A3F5-3824-9210-0790C07120F3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff8d2b5000 -     0x7fff8d2befff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
    0x7fff8d2d7000 -     0x7fff8d36dfff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff8d962000 -     0x7fff8da06fff  com.apple.Bluetooth (4.4.6 - 4.4.6f1) <D8ED953B-AD7D-3FE2-8631-E9CBCF6EBAB9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff8da07000 -     0x7fff8da07fff  libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fff8da08000 -     0x7fff8da0efff  com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fff8da5a000 -     0x7fff8dc23ff7  com.apple.ImageIO.framework (3.3.0 - 1462) <1D8FF28C-5DBB-3D23-8CF0-75269C1CE84D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff8dc24000 -     0x7fff8dc40ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
    0x7fff8dc83000 -     0x7fff8dc84fff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
    0x7fff8dc85000 -     0x7fff8dc8afff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff8dd4c000 -     0x7fff8dd51ff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
    0x7fff8ddd9000 -     0x7fff8de34ff7  libTIFF.dylib (1463) <5C02D055-02D3-37FE-AABC-487301080941> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff8de44000 -     0x7fff8de4dff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
    0x7fff8deee000 -     0x7fff8def6fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff8def7000 -     0x7fff8df49fff  com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff8df4a000 -     0x7fff8df52fef  libcldcpuengine.dylib (2.7.3) <745C41A3-CEC0-3BF5-91DC-FCB140A3DACE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff8df53000 -     0x7fff8df55ff7  libRadiance.dylib (1463) <11392BBE-6DAC-3ADD-A0C0-CD653B9AEDE3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff8df56000 -     0x7fff8df66fff  libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff8df98000 -     0x7fff8dfc6ff7  libsandbox.1.dylib (460.60.3) <C8B9F633-EA0C-35CF-9207-1AFDF694EEAD> /usr/lib/libsandbox.1.dylib
    0x7fff8e04e000 -     0x7fff8e069fff  com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff8e2da000 -     0x7fff8e2e2fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff8e327000 -     0x7fff8e32cff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
    0x7fff8e32d000 -     0x7fff8e356ff7  libxslt.1.dylib (14.5) <8E03110E-1529-3BE8-B5F4-052A47A1674C> /usr/lib/libxslt.1.dylib
    0x7fff8e4cb000 -     0x7fff8e5f2fff  com.apple.LaunchServices (728.13 - 728.13) <91147A89-9D0D-3272-AD05-48E2835BD8D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff8e5f3000 -     0x7fff8e5f4fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff8e5f5000 -     0x7fff8e88fff3  com.apple.security (7.0 - 57337.60.3) <4BF5CF26-6E34-35EC-8D41-58ED65F9BFB8> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff8e890000 -     0x7fff8e8aeff7  libsystem_kernel.dylib (3248.70.3) <69D68230-7793-3D11-B49E-BA3A6D5137B8> /usr/lib/system/libsystem_kernel.dylib
    0x7fff8ea70000 -     0x7fff8ea9bff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fff8ea9c000 -     0x7fff8eaa7ff7  libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
    0x7fff8eaae000 -     0x7fff8eaddffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
    0x7fff8ee01000 -     0x7fff8efc1ffb  libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff8efee000 -     0x7fff8eff9ff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
    0x7fff8effa000 -     0x7fff8f068ff7  com.apple.ApplicationServices.ATS (377 - 394.4) <CB64C2B7-828A-3C4C-8F3C-72B78630CD94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff8f069000 -     0x7fff8f094ffb  libarchive.2.dylib (33.20.2.1.1) <BC764A1E-573A-3D95-A3CC-1758935ADC56> /usr/lib/libarchive.2.dylib
    0x7fff8f095000 -     0x7fff8f0a6ff7  libsystem_trace.dylib (201.10.3) <4F626911-011B-3E9C-8D61-C5EBA79013F0> /usr/lib/system/libsystem_trace.dylib
    0x7fff8f0b0000 -     0x7fff8f0c6ff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff8f0c7000 -     0x7fff8f0c9ff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
    0x7fff8f0ca000 -     0x7fff8f0cdfff  libspindump.dylib (197.1) <B86EE257-4429-32E9-B98D-B12BFF2A373B> /usr/lib/libspindump.dylib
    0x7fff8f0ce000 -     0x7fff8f11cfff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
    0x7fff8f11d000 -     0x7fff8f11ffff  com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff8f120000 -     0x7fff8f14aff7  GLRendererFloat (12.1) <0412B850-BB25-33B1-AF0D-8E6297D4620E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff8f18d000 -     0x7fff8f1b2ff7  libPng.dylib (1463) <17F67BF3-4A78-3587-AAE4-E50A71BDD4CB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff8f1b3000 -     0x7fff8f1b5fff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff8f1b6000 -     0x7fff8f1ddfff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff8f20a000 -     0x7fff8f212fef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
    0x7fff8f213000 -     0x7fff8f22aff7  libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
    0x7fff8f2cd000 -     0x7fff8f64bff3  com.apple.VideoToolbox (1.0 - 1731.15.207) <6C7C261F-CB65-3AF1-92E7-16ACAD371EF4> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff8f6b0000 -     0x7fff8f6c1fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
    0x7fff8f6ca000 -     0x7fff8f6e7ff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <707C6ED6-B8C0-38D4-B45A-7F2F689BD157> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff8f9b9000 -     0x7fff8fb14ff3  com.apple.WebKitLegacy (11601 - 11601.7.8) <F41E6CAF-1157-3868-9FAC-D074FCE74BB9> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
    0x7fff904b4000 -     0x7fff904f9ff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff904fa000 -     0x7fff90571feb  libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
    0x7fff90572000 -     0x7fff90572fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff90573000 -     0x7fff9057efff  libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
    0x7fff9057f000 -     0x7fff906c9ff7  com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff906cf000 -     0x7fff907c1ff7  libJP2.dylib (1463) <D107FF52-7FD6-3A5E-B40E-F3D0F1FF651D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff907c2000 -     0x7fff907c2fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff907c3000 -     0x7fff907d6fff  com.apple.SafariServices.framework (11604 - 11604.1.38.1.7) <5B649F4B-09D3-3AAC-9801-B6084B91E7D7> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fff908e4000 -     0x7fff908edff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
    0x7fff908ee000 -     0x7fff90b84fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
    0x7fff90b91000 -     0x7fff90ee5ff7  com.apple.Foundation (6.9 - 1259.31) <EBB5BE3F-1FE9-3231-B53B-149CDEE8BCA9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff90f34000 -     0x7fff90fbcfff  com.apple.CoreSymbolication (3.1 - 58048.1) <C1A1A8DB-8A51-3A21-865A-3CEF22A0E67A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff90fd1000 -     0x7fff90fd4ffb  libdyld.dylib (360.22) <7C1BBC59-FA8A-3BDF-B209-02167832E7D1> /usr/lib/system/libdyld.dylib
    0x7fff90fd5000 -     0x7fff91161ff7  libGLProgrammability.dylib (12.1) <6D4C193C-5F7B-3E82-81D9-D14D25BBD962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff9118a000 -     0x7fff91193ff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff91194000 -     0x7fff911a7fff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fff911a8000 -     0x7fff911c1fe7  libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
    0x7fff911c2000 -     0x7fff911cdfff  com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff919d8000 -     0x7fff919dbffb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
    0x7fff919dc000 -     0x7fff919e4fff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
    0x7fff919e6000 -     0x7fff91abffff  com.apple.CoreMedia (1.0 - 1731.15.207) <70CAD4A7-3F8B-3767-A420-98BE1062C230> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff9231f000 -     0x7fff9236dff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
    0x7fff925c8000 -     0x7fff92b06ff7  com.apple.MediaToolbox (1.0 - 1731.15.207) <63AD3FB7-BAD3-3040-8A99-843033F24CF6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff92b29000 -     0x7fff92cd5ff7  com.apple.avfoundation (2.0 - 1046.9.12) <41BDD03F-5545-3B9F-8DD7-7106485BAE8B> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff92cdb000 -     0x7fff92cffff7  libJPEG.dylib (1463) <11227D36-EA80-3D5B-A7D3-F2AC6C7497EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff92e6d000 -     0x7fff92f53ff7  libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff92f54000 -     0x7fff92fb4fff  com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff931cf000 -     0x7fff931e8fff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff931ef000 -     0x7fff9323bffb  com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff9323c000 -     0x7fff93256fff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff93257000 -     0x7fff9327efff  com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fff932b3000 -     0x7fff932c8fff  com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff932c9000 -     0x7fff93382ff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff933e3000 -     0x7fff93472ff7  libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
    0x7fff934dd000 -     0x7fff93522ff3  libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff93530000 -     0x7fff9395afff  com.apple.ModelIO (1.0 - 1) <8838E0E1-ACB3-3CE8-ABDC-C787D8B3F247> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
    0x7fff9395d000 -     0x7fff93974fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
    0x7fff9397a000 -     0x7fff93a2afff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff93a67000 -     0x7fff93a86ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fff93a92000 -     0x7fff93c9dfff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
    0x7fff93c9e000 -     0x7fff93cc7fff  com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff93e3c000 -     0x7fff93e6dfff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff93e6e000 -     0x7fff93e7afff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff93e7d000 -     0x7fff94028ffb  GLEngine (12.1) <278B3208-B0D0-3FAE-AC23-A4FA06837311> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff94029000 -     0x7fff94029fff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff9402a000 -     0x7fff94038fff  com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fff94047000 -     0x7fff94077ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff94a39000 -     0x7fff94a77ff7  libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff94a78000 -     0x7fff94aedfff  com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff94af1000 -     0x7fff94b91fff  com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff94dab000 -     0x7fff94dadfff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff94dae000 -     0x7fff94db7ff7  com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff94db8000 -     0x7fff94e09ff7  libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
    0x7fff94e0a000 -     0x7fff94e0afff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
    0x7fff94e25000 -     0x7fff94e59ff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff94e5a000 -     0x7fff94e5cff7  com.apple.xpc.ServiceManagement (1.0 - 1) <B4181284-D588-3A20-93F3-B4FA882BC9A8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff94e5d000 -     0x7fff94eb2fff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff94eb3000 -     0x7fff94ef5ff7  com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff94ef6000 -     0x7fff94ef7ffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
    0x7fff94f1c000 -     0x7fff94f1effb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
    0x7fff94f2c000 -     0x7fff94f2efff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
    0x7fff94f8c000 -     0x7fff94f90fff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
    0x7fff9505a000 -     0x7fff954d0fff  com.apple.CoreFoundation (6.9 - 1259.11) <B8056BE3-151B-3003-91C9-6720CF04937B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff954d1000 -     0x7fff954d4ff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff954d5000 -     0x7fff954e9fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
    0x7fff95517000 -     0x7fff95517fff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff95518000 -     0x7fff9580dfff  com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff9580e000 -     0x7fff95816ffb  libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff95817000 -     0x7fff958edffb  com.apple.DiskImagesFramework (10.11.4 - 417.4) <FB30D069-648F-3FB2-AA55-FC603606C49E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff958ee000 -     0x7fff958fdffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff95fed000 -     0x7fff95ff8fff  com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff96012000 -     0x7fff96015fff  com.apple.IOSurface (108.2.4 - 108.2.4) <E7A63C0D-2FDA-3BC6-947D-07E3C4A13110> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff96220000 -     0x7fff96233fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff9623b000 -     0x7fff96243fff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff96244000 -     0x7fff962cdff7  com.apple.PerformanceAnalysis (1.0 - 1) <9C57BB91-46D6-3FB6-A5A2-8DB1CFE86B72> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff962ce000 -     0x7fff963cafff  libFontParser.dylib (158.7) <393EFEA3-42B7-38DA-99DA-D01DEAA734CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff9656a000 -     0x7fff965e1ff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fff965e2000 -     0x7fff96c81ffb  com.apple.JavaScriptCore (11601 - 11601.7.8) <38585ADC-1AD4-3BD2-8972-B90344CE57C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff96c82000 -     0x7fff96c92ff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff96cbc000 -     0x7fff96cf6fff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff9711a000 -     0x7fff9711ffff  com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff97120000 -     0x7fff9714aff7  libc++abi.dylib (307.4) <D24E06BF-6522-3C4A-BD0C-11C42BA4D8E8> /usr/lib/libc++abi.dylib
    0x7fff9715b000 -     0x7fff9718afff  com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fff9719a000 -     0x7fff97227dd7  com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff97228000 -     0x7fff97336ff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff97337000 -     0x7fff9733cff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fff9733d000 -     0x7fff97349fff  com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff9734a000 -     0x7fff97518ff3  com.apple.QuartzCore (1.11 - 410.14) <06A2BE20-38CB-3A89-9629-A782829DF977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff97519000 -     0x7fff9758dff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff9758e000 -     0x7fff97591fff  libsystem_sandbox.dylib (460.60.3) <2DDCB4AF-3037-34E5-A451-6846AFB9B85C> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff97592000 -     0x7fff975d8ff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
    0x7fff9764b000 -     0x7fff978d2fff  com.apple.CFNetwork (760.6.5 - 760.6.5) <8A36BBA6-F100-3F39-9711-2FA49D412987> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff978e6000 -     0x7fff978eafff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
    0x7fff978f4000 -     0x7fff979dafef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
    0x7fff979db000 -     0x7fff97a46ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff97b52000 -     0x7fff97f54fff  libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff97f55000 -     0x7fff9800dff7  com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
    0x7fff9800e000 -     0x7fff98032fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff98068000 -     0x7fff98153ff7  com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff98154000 -     0x7fff98155fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff98156000 -     0x7fff98172ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
    0x7fff981d3000 -     0x7fff9820aff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff98276000 -     0x7fff98279fff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff9827a000 -     0x7fff98738fcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff9873d000 -     0x7fff9876cff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff987f0000 -     0x7fff98800fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
    0x7fff98801000 -     0x7fff98875ff3  com.apple.securityfoundation (6.0 - 55126) <3FF6D6E0-0C5D-385A-A97E-441D3947EFAB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff98876000 -     0x7fff9889afff  com.apple.MultitouchSupport.framework (304.12 - 304.12) <598A8689-E97E-3C8D-AACD-8A0EB1956CA6> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff9889b000 -     0x7fff988d3ff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff988d6000 -     0x7fff988e2ff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff98906000 -     0x7fff9892fffb  libRIP.A.dylib (970) <BA17C96B-83CC-3835-8AFD-CB5A69D3D26F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff9896c000 -     0x7fff9896cfff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff99876000 -     0x7fff9987efff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff9987f000 -     0x7fff99acbff7  com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x7fff99aed000 -     0x7fff99b1cffb  com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
    0x7fff99b1d000 -     0x7fff99b1dff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
    0x7fff99b1e000 -     0x7fff99bb3fff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff99d18000 -     0x7fff99d41fff  libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
    0x7fff99fe2000 -     0x7fff9a09cfff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff9a09d000 -     0x7fff9a243ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff9a244000 -     0x7fff9a24cfff  libGFXShared.dylib (12.1) <22F78420-D92E-3B5F-BA86-918A34289FCD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff9a24d000 -     0x7fff9a2dafef  libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
    0x7fff9a318000 -     0x7fff9a5fdffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff9a662000 -     0x7fff9a6adff7  com.apple.CoreMediaIO (703.0 - 4791) <E49D0C36-295A-311A-9470-706455EA6F80> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff9a6ae000 -     0x7fff9a6b3ff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
    0x7fff9a6ba000 -     0x7fff9a960ff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff9a97f000 -     0x7fff9aa1ffff  com.apple.Metadata (10.7.0 - 972.34) <B0137597-158A-3503-85C8-F55DB5D21BE1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff9aa8d000 -     0x7fff9aa8effb  libSystem.B.dylib (1226.10.1) <160608FD-B79D-3B49-AFEA-53A10C0C86B3> /usr/lib/libSystem.B.dylib
    0x7fff9aa8f000 -     0x7fff9aa96ff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
    0x7fff9aaac000 -     0x7fff9ab1bfff  com.apple.datadetectorscore (7.0 - 460) <233A8FBF-B22F-3177-A328-781588D95D69> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff9ab81000 -     0x7fff9abe4fff  libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
    0x7fff9ac3f000 -     0x7fff9ac4afff  libGPUSupportMercury.dylib (12.1) <97C7C8A3-234B-3C7C-8777-611E3D3EE63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff9ac4b000 -     0x7fff9ac4dff7  com.apple.securityhi (9.0 - 55006) <AC151C58-A7AD-3ECF-B15D-5E09FF94FC23> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff9ac4e000 -     0x7fff9ac67fff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff9ace0000 -     0x7fff9ad08fff  com.apple.GLKit (1.0 - 56) <820F61C9-B74D-3604-BA6E-F20235E2E5B4> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
    0x7fff9ad3b000 -     0x7fff9ad3efff  com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 18
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 5383
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=618.8M resident=0K(0%) swapped_out_or_unallocated=618.8M(100%)
Writable regions: Total=15.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=15.6G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
ATS (font support)                32.3M        9
ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
Accelerate.framework               256K        3
Activity Tracing                  2048K        2
CG backing stores                 40.0M       16
CG image                         196.5M      115
CG shared images                  1008K       21
CoreAnimation                      256K       46
CoreUI image data                 2236K       26
CoreUI image file                  320K        5
Dispatch continuations            48.0M        2
Foundation                          24K        3
Image IO                          1208K      101
Kernel Alloc Once                    8K        3
MALLOC                           937.5M     1017
MALLOC guard page                   48K       11
MALLOC_LARGE (reserved)           5176K       36         reserved VM address space (unallocated)
Memory Tag 242                      12K        2
OpenCL                               8K        2
OpenGL GLSL                        256K        4
Process Corpse Info               2048K        2
STACK GUARD                       56.4M      112
Stack                            271.5M      118
VM_ALLOCATE                       14.1G       79
__DATA                            70.9M      380
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       116.9M       77
__TEXT                           501.9M      352
__UNICODE                          552K        2
mapped file                      227.2M       64
shared memory                     16.4M       13
TOTAL                             16.6G     2598
TOTAL, minus reserved VM space    16.6G     2598
Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 64 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX 980 TI, NVIDIA GeForce GTX 980 TI, PCIe, 6144 MB
Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 4, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 5, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 6, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 7, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 8, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce GTX 980 TI, Display Controller, Slot-1
PCI Card: pci10b5,8609, Slot-2
PCI Card: NVIDIA GeForce GTX 980 TI, NVDA,Parent, Slot-1
PCI Card: pci1b4b,9230, AHCI Controller, Slot-3
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@10,0,0
PCI Card: pci1b4b,9230, AHCI Controller, Slot-4
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@8,0,0
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@9,0,0
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@11,0,0
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@9,0,1
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@8,0,1
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: HL-DT-ST BD-RE  WH16NS40
Serial ATA Device: Samsung SSD 850 PRO 2TB, 2.05 TB
Serial ATA Device: Samsung SSD 840 EVO 1TB, 1 TB
Serial ATA Device: 2.74 TB HD Glyph, 3 TB
Serial ATA Device: ElitePro Qx2, 9 TB
Serial ATA Device: OWC Mercury Accelsior PCIe SSD, 960.04 GB
Serial ATA Device: MARVELL VIRTUAL
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: Intuos5 touch L
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB 2.0 Bus
USB Device: HZD
USB Device: USB2.0 Hub
USB Device: Apple Watch Magnetic Charging Cable
USB Device: GL3220
USB Device: SoundSticks
USB Device: Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Apple LED Cinema Display
USB Device: Display iSight
USB Device: Display Audio
USB Device: USB 3.0 Bus
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
