Using CC2017 PS, Windows 10, and a Wacom Intuos CTL 490 Draw
I would like to disable the pen pressure settings and have the pen work as if pressed
down all the way all of the time. I use this in Layer Masks deleting objects and it takes
full pressure to remove all.
The pen pressure icon in the brush tool bar doesn't disable the pen pressure effect.
Are there brushes available that don't respond to pen pressure or is there another
way to disable?
I have solved the problem, but it's not by clicking the icon in the tool bar that you
have highlighted in red.
It's that other icon - the one between Opacity and Flow percentages - that needs to be turned off.
It's the Opacity that needs to be changed. The icon you have marked is for Size. I had been
clicking that to no avail.
Once the Opacity icon is clicked, there's no pen pressure requirement. Just what I want.
Thanks for your reply, though.
You can do that with a brush setting also make sure you do nor overritd the setting the the brush tool cotrol icon,
All three Icon there are for pen support Opacity Size and Airbrush I showed what is involved with size (Shape Dynamics). You Address Opacity (Transfer) settings.
