Hi All,
Good day. I am trying to remove the empty layers. The script tags master page elements as unused and therefore deletes all of them resulting to a blank file.
My code:
function mylayer()
var flag=0;
wasteLayers=[];
wastename=[];
var myDoc = app.activeDocument;
var layers = app.activeDocument.layers;
for(var i=0;i<layers.length;i++){
if (layers.locked){
layers.locked=false;
if(layers.length>1){
for(var i=layers.length-1;i>=0;i--){
if((layers.pageItems.length==0)){
wasteLayers.push(layers);
wastename.push(layers.name)
layers.remove();
flag=1;
if(flag==1){
alert(wasteLayers.length + " unused layers deleted"+"\n");
else
alert("No Unused layers Present in the document")
mylayer();
I found the interesting solution (Thanks to Jump_Over) from the below link. But it removes the item if it presents in pasteboard. How to ignore this?
IDCS6 MACOSX JS: "remove unused layer" script doesn't see masters based on masters
K
Interesting! Never ran into this problem.
I tested this out in AppleScript as sometimes the language can make a difference. Not. Working from a list of layers and checking for no page items, ignores a layer created in a master page based on a master page. So here is what I came up with in AppleScript (gets list of item layer for all page items then compares with list of all layers).
set layerList to {}
tell application "Adobe InDesign CC 2017"
tell document 1
set allItems to all page items
set allLayers to id of layers
repeat with i from 1 to length of allItems
set thisLayer to item layer of item i of allItems
if id of thisLayer is not in layerList then
set end of layerList to id of item layer of item i of allItems
end if
end repeat
repeat with i from 1 to length of allLayers
if item i of allLayers is not in layerList then
delete layer id (item i of allLayers)
end if
end repeat
end tell
end tell
{layerList, allLayers}
Note: It also deleted the layer even when it was locked.
Hi S Hopkins,
Thank you so much for your script. Unfortunately I dont have Mac right now to text this script. I will check and let you know.
Thanks again.
K
Hi S Hopkins,
It is working fine. But I wonder how to use this script for all version in Indesign. It is directing to cc 2017. I have no idea how the applescript working.
Also I have to include this applescript into my core javascript. Because this a part of the script.
K
Try this:
tell application id "com.adobe.indesign"
When I switched from CS6 to CC 2017 I didn't have to change this at all.
