I am using Adobe Acrobat DC Pro (Windows 10). Whenever I attempt a 'Save As,' Acrobat will exhibit a lag/delayed response. I have just enough time to type a few characters and it freezes up for about 10-15 seconds. It will continue to register keystrokes, but they don't display until the lag period ends. It does this with small and large files alike. Using 'Save' or 'Save A Copy' results in normal behavior.
Any ideas on how to resolve this?
there are three ways to solve this issue, check out this video
Hi Captain_Deadpool,
As per the issue description, the Acrobat DC Pro is freezing while using the "Save As" option, Is that correct?
Please try the troubleshooting steps from the link: Troubleshoot errors, freezes | Adobe Reader | Windows
* Check for latest update of Acrobat Pro DC from Help>Check for updates.
* You can also repair the installation file of Acrobat Pro DC from Help>Repiar Installation.
Keep us posted with the results.
Anand Sri.
I'm having the same issue and this did not resolve the issue for me.
Hi there
We are sorry for the trouble and the delay in response
What is the version of the Adobe Acrobat/Reader DC you are using? To check the version go to Help > About Adobe Acrobat DC
Please try to update the application to the new version 20.009.20065 Go to Help > Check for Update and see if that works for you
Regards
Amal
Just updated to 20.009.20067 and have same problem -
Fill & Sign - modify fields
Save or Save As causes screen to blink and then mouse becomes inactive. I can move mouse around screen but clicking on anything does nothing. Tab, space or any other key also does nothing. I must use Task Manager to cancel task. Win 10 18363.836
Tried repair but it finds no problems
Hi there
We are sorry to keep you waiting.
Please try to turn off the ptotected mode for testing. Go to Edit > Prefernces > Enhanced Security > Turn Off the Protected Mode and Uncheck the Enhanced Security > Click Ok
Note: Please turn on the security after testing
if it still doesnt work, please create a new test user profile with full admin rights on Windows and try using the application there and check.
Regards
Amal
Third solution here is a winner.
Thank you very much for the feed bqck
Thank you very much for the video 2nd solution worked for me 🙂
Thanks again
The third step worked for me ( online storage uncheck) Thank you!
Thank you very much for your feed back
Solution 3 worked.
Good to hear that, thank you for the feed back
Solution #3 worked for me also. Thank you so much. I fixed this once before with Adobe Support directing me to do something much more convoluted and difficult, which worked, but lasted only a few days.
