Immer wenn ich Photoshop benutze und mit meinem Wacom-Tablett zeichne hängt z.B. der Pinselstrich hinterher. In anderen Anwendungen wie Animate ist das nicht der Fall. Wenn ich normal mit der Maus in Photoshop zeichne ist es auch ganz normal und der Pinselstrich ist sofort da. Muss ich irgendwo etwas in den Einstellungen ändern?
Vielen Dank im Voraus!
Could you please post a meaningful screenshot taken at View > 100% and with the pertinent Panels (Layers, Brush, Brush Presets, Options Bar, …) visible?
http://imgur.com/a/XuULM I don't know if that's what you meant but thanks anyways. Should i maybe make a short video that shows the problem or show you one from the internet if I find one?
Are there multiple Pen Pressure sensitive settings in the indicated Brush Panel?
Does the delay also happen with Brushes without any Pen Pressure settings?
https://youtu.be/BhB6XdHqE_c?t=3m35s Thats basically my problem but it only occurs when i use my tablet and only in Photoshop, as I said every other application is fine.
Do you have the latest Wacom driver installed?
Yes I did it recently. It's weird that it is only happening in Photoshop. Are there any options that i could change to make it work?
