Problem during importation
Guest
Aug 28, 2017 Aug 28, 2017
Hey,
I wanted to import pictures, but I have this message "Can not perform this operation in the reason for the analysis of the jpeg data" (translated in french...)
It's the same message in Photoshop or Photoshop elements, try few pictures.
Any solutions ? Thanks
250
Community Expert , Aug 29, 2017 Aug 29, 2017
Extensions should be turned on in Windows.  Here's how: http://www.thewindowsclub.com/show-file-extensions-in-windows
That way you know whether Image is really Image.jpg  A wrong or missing extension can cause these problems.
But your error seems to be a "parse" error. Photoshop cannot read it as a jpeg. Might be a bit of file corruption going on.
Let's try this:
Open the file that doesn't work in the standard windows picture viewer, rotate the image, close, rotate back and close again.This should r
Adobe
We'll need some details:
Photoshop version, OS version, screenshot of the error message.
Was this File > Open?
Guest
Photoshop Elements 15 / Photoshop CC 2017.
Windows 10.
"File > import" and "drag and drop", same message
Let's try this:
Open the file that doesn't work in the standard windows picture viewer, rotate the image, close, rotate back and close again.This should resave the file.
Then see if it opens.
Also make good use of Windows 10 File History to preserve backups of your files. If a file gets damaged and you do not have copies anywhere else, your work is gone.
Gene
Guest
Aug 30, 2017 Aug 30, 2017
Okay, so this works.
Thanks.
Guest
But how to do it with multiples pictures ?
I don't have any good ideas for this. I hope someone can suggest something here. You can also check Windows and Photography forums for answers on a batch resave.
