I recently took multiple bracketed pictures of the eclipse. Obviously, as the sun moves, the sun is not in the same place in all these pictures. So I created multiple layers and put each one of these 7 exposures in separate layers. Then I aligned them two at a time using Difference. So far, so good. But then, I would like to create an HDR image with these 7 layers. Is there a way of doing this? I had to save each layer as a Tiff file and then open them in the HDR program. Is there an easier way?
thanks
Luis
Another method would be to run an action on your working document on top of your existing layers.
Here's a link to a free HDR action - HDR Tools by forfie on DeviantArt
Another, but time consuming method would be to duplicate each layer three times. On the bottom layer change your exposure to a negative number, underexposing the image. Leave the middle layer as is and set the top layer to a positive exposure making it over exposed. Play with the blending modes of each layer until you get an effe
...Copy link to clipboard
crop and save each layer as a jpg to keep the images aligned. Then file> automate > Merge to HDR
That's exactly what I did, only I saved Tiff files, not JPEG. I know how to do an HDR. The question is, "can it be directly from layers?"
Another, but time consuming method would be to duplicate each layer three times. On the bottom layer change your exposure to a negative number, underexposing the image. Leave the middle layer as is and set the top layer to a positive exposure making it over exposed. Play with the blending modes of each layer until you get an effect you like.
below is a screen shot of the above method
I suspect that the best you can do is use Export > Layers to Files and then then import to HDR
Just stumbled over this old topic... Another method would be to select all the layers and then convert to a smart object, then use Layer > Smart Objects > Stack Mode: Mean to create an average, then use adjustments like Shadow/Highlight, curves, USM etc. Or use HDR toning etc.
