I've reviewed similar questions but still cannot resolve my specific issue. I have a button that on click goes to a certain point in the timeline and plays. The issue is that while the timeline is playing, this button is still enabled- and if you click it it takes the user back to the first frame. I want to just disable this while it plays, and then reenable once completed.
this.button_4.addEventListener("click", fl_ClickToGoToAndPlayFromFrame_6.bind(this));
function fl_ClickToGoToAndPlayFromFrame_6()
this.gotoAndPlay(2);
and then on the first frame of the animation, I have created a keyframe and added
button_4.enabled=false;
But this does not work.
Please advise?
Well this is fun... in CreateJS, buttons are created by attaching the ButtonHelper class to a movieclip instance. But in the Animate generated code the class is attached anonymously, like this:
new cjs.ButtonHelper(this.btn, 0, 1, 1);
So all the properties of ButtonHelper (like enabled) are completely inaccessible. Good job guys.
Anyway, the simplest way to disable the button would be to just hide it... this.button_4.visible = false; ... Can't click something that's not there.
A more elegant soluti
...Copy link to clipboard
Did you forget to add "this." before "button_4.enabled=false;" ?
I tried that. still no dice.
It should actually be: this.button_4.mouseEnabled = false;
A more elegant solution would be to fade the button out, indicating it's temporarily not available. For this you could do something like this.button_4.alpha = 0.5; then modify your event code like so...
function fl_ClickToGoToAndPlayFromFrame_6(evt) {
if (evt.currentTarget.alpha === 1) {
Alternatively, you could leave the event code alone and disable with this:
Then enable with this:
this.button_4.alpha = 1;
this.button_4.mouseEnabled = true;
There's lots of ways to do this sort of thing.
