Regular BSOD when working with the new titler
Aug 13, 2017 Aug 13, 2017
I just upgraded my computer to an i7 7820x to speed up editing and upgraded to the latest version of Premiere Pro.
Upon opening it for the first time, when the Adobe intro video starts, I get a BSOD right away with a general "WHEA_UNCORRECTABLE_ERROR" and the computer restarts.
When opening a project, everything seems to be working fine, except the tiltler: every single time I adjust the properties of a title (shadow, transparency, size, etc) I get a blue screen of death.
I tried everything: clean re-installation of windows, different drivers, older versions of GPU drivers. The computer always crashes on adjusting titles.
I also tried gaming like crazy (to put the system under intense stress) and everything works fine, so I think it's not a computer issue but a problem with Premiere Pro.
Now I'm stuck and I cannot proceed with my work.
My configuration is as follows:
Intel i7 7820x
Gigabyte X299 UD4
32Gb ram
1Tb M.2 SSD
Nvidia GTX 980 Ti
Latest version of Premiere Pro as of 13 august 2017
Thanks.
2.1K
Aug 14, 2017 Aug 14, 2017
BSOD most often is the result of a faulty driver or bad hardware.
As you are using new hardware...
Moved to hardware forum for expert advice.
You can still use the old titler.
File > new > legacy title.
Aug 16, 2017 Aug 16, 2017
Upon further testing, the situation has improved by reverting to BIOS version F3, instead of the newest provided by Gigabyte (I think it's called F4g or another letter at the end).
The titler still causes Premiere Pro to crash every now and then, but at least since it's a SW crash I am able to recover the latest modifications to my project.
Still very annoying but I can proceed with my work.
I do not recommend PPro users to upgrade to the latest BIOS if you have a new Gigabyte motherboard.
Yes, all hardware is brand new.
Aug 25, 2017 Aug 25, 2017
I work with a similar configuration and I'm also experiencing BSOD, not tried with the titler, but it crashes every time warp stabilizer starts to analyze a clip... and sometimes BSOD happens also randomly.
i7820x
Gigabyte X299 Gaming 7
64Gb RAM
512Gb M.2 SSD
MSI Nvidia 1080 8Gb
Latest driver, latest bios (I tried also an older one), latest WIN 10 Pro updates, latest Premiere CC (25th August).
Adobe problem with new Intel CPUs?
Aug 30, 2017 Aug 30, 2017
SAME PROBLEM HERE! Pls Adobe, help!
i7820x
ASUS TUF X299 Mark II
32Gb RAM
240Gb M.2 SSD
GTX1070 Turbo 8Gb
Mentor ,
Aug 31, 2017 Aug 31, 2017
does it crash if you set gfx card premiere render to software only?
Yes, there's no difference if I set "Software only". Same BSOD.
On Premiere 2015 everything works fine. When the Adobe 2017 intro video starts, I get a BSOD right away with a general "WHEA_UNCORRECTABLE_ERROR" and the computer restarts. I can't  even run PP 2017.   I tried everything: roll back GPU driver, reinstall Win10. Everything! Pls, help.
I had the same problem, I solved upgrading the bios of the motherboard (mine is a Gigabyte, but based on the same X299 platform).
And now everything's works fine? Without any problems? No crashes when you use warp stabilizer?
No, that only solved the BSOD at startup...
Then BSOD started to happen when applying warp stabilizer.
I'm not happy with that solution. Can it be up to Premiere? Win 10?
Sep 01, 2017 Sep 01, 2017
Same problem for me, a lot of BSOD also have a brand new MSI x299..
Sep 04, 2017 Sep 04, 2017
Is here anyone from Adobe who can help us?
In case it might be an Adobe fault, file a bug report here:
Feature Request/Bug Report Form
BSOD usually means hardware.
Yeah, It's an hardware error cause by the X299 and something from Adobe. I double check all my hardware, everything is working fine and un only get BSOD on AE ou Pre
Sep 07, 2017 Sep 07, 2017
Not always. 2015. version of Premiere works fine.
Contributor ,
Sep 08, 2017 Sep 08, 2017
It must be an anomaly with the x299 mobos because I'm using the gigabyte x99p-sli with the latest Premiere and having no issues.
Nov 16, 2017 Nov 16, 2017
One of my clever friend (the old overclocker)) advised me to do this:
Go to the BIOS and change the CPU voltage setting. (For Gigabit X299 UD4 motherboard) BIOS / M.I.T./Advanced Voltage Setting / CPU Core Voltage Control / Internal CPU Vcore - set 1.2v instead of "Auto". That's exactly what I did. While everything is working fine. After Effects CC2018 and Premiere CC2018. "Turbo Boost" I did not turn it off.
Try to change this parameter on motherboards of other manufacturers. Perhaps this will help solve the problem.
Attention! Do not forget to monitor the CPU temperature. And install a good CPU cooling.
(Most likely this is an Intel problem, but not Adobe problem.)
Configuration
MB Gigabyte X299 UD4
CPU Intel Core i7-7820X
RAM Corsair Vengeance LPX DDR4 2800Mhz 64Gb
SVGA Gigabyte GTX 1080Ti
SSD1 Kingston 240Gb
SSD2 Samsung 850Evo 2Tb
Guest
Jun 25, 2018 Jun 25, 2018
Has anyone gotten a fix for this problem? Adobe software was working fine until around mid April or so.
I'm having the same issue with Premiere Pro CC 2018. It randomly crashes the pc. But when I try to use the warp stabalizer... It crashes EVERY SINGLE TIME. I have contacted Adobe tech support but haven't heard anything back yet.
My System:
Intel i9 7920x
Asus x299 Prime Deluxe
Corsair Dominator Pro DDR4 64GB
NVidia GTX 1080
Samsung NVMe2 Pro 1TB HD
