Various animations in one page
Jul 20, 2017 Jul 20, 2017
Hello,
I have a question. I'm trying to create a presentation, just as created in Powerpoint.
I'm inserting a event the start the animation of the page after the click of the mouse, but all the animations show immediately.
What I want: Blank page; (click) the title appear; (click) a diagram appear; (click) next page....
As this presentation is a corporate one, it's not viable to add a button to start determined action.
I hope someone have a solution.
Thanks.
1.7K
Guru ,
If you open your animation panel, you can select any item in your design,  select a preset animation (appear, fade, and so on). below that is the event options, here you can select the "on click" option. see screenshot.
here are more detail instructions:
Animate InDesign objects in your documents
The thing is, if I insert the animation for all the objects of the page to "on click", all the objects will appear in the same time, after the first click.
Guru ,
Jul 21, 2017 Jul 21, 2017
Now open the timing panel. And use it to control the order of things
Advisor ,
Aug 04, 2017 Aug 04, 2017
Another way to possibly do this is to create invisible buttons that only you know the location of, and which trigger the appropriate animation. Since you only have three clicks, you could put them at the bottom of the page in roughly each third of the area.
Aug 17, 2017 Aug 17, 2017
Just for fun!
Animations on … only one page!
https://indd.adobe.com/view/d40c03d1-51fa-4d8d-b01f-a4e6b4e9d1cf
Advisor ,
Aug 30, 2017 Aug 30, 2017
@Obi-wan Kenobi, how have you set this up, please, in brief?
Aug 31, 2017 Aug 31, 2017
… "Un nouveau cas d'école"!  😉
I could share the ID file but without explanation!
Guru ,
Yes, please do share. i am interested in testing that animation with IN5, i could use something like that if i can get it work with that platform.
thanks
Advisor ,
Obi-wan Kenobi​ yes, please kindly make the Obi-wan Kenobi.indd file available. Thank you.
ID file (CC 2015).
Dropbox - One-Page-Animations_TestFile_Shared-2017-08-31.zip
… Enjoy!
Advisor ,
@Obi-wan Kenobi, thanks. I had suspected Show/Hide buttons and on first glance, this seems at least part of the technique. I'll look more closely later, but thanks for sharing the file!
Diane, it's really more complex! Good headaches!!
Guru ,
Sep 01, 2017 Sep 01, 2017
they however will not work on the ipad. most stuff does not work on acrobat for ipad for interactive .pdf section panel options. so if you are going to have people open things on the ipad. test first to see if its even worth the time to make...
"You talk to me?! …"  [from Taxi Driver]
Guru ,
No, yours works, I was talking interactive .pdf reader animations. I am going to see if it works to take your file and export to IN5. Ever use it?
Guide ,
Sep 02, 2017 Sep 02, 2017
Did it work?
P
Guru ,
Testing it on Tuesday. I will post a link and share.
Guru ,
Sep 05, 2017 Sep 05, 2017
check it out. looks just fine.. really nice. thanks. i will hold on to that. i will use that:
Hi Jonathan,
The ID animations construction I've used here is really too complex to work correctly! …
Guru ,
it did work fine on IN5 did you see the link. its good.
I saw it! …
My sample is an infinite loop with 5 steps!
See the original [in Publish Online]!
Guru ,
now i understand. yes, with IN5 it breaks at the end. Its the loop code, i am fine with what it can do. I am sure if you post to IN5 forums he would have the work around. it requires code for the work arounds. that is the only thing.
I think Diane will send it to Justin! [if not already done!]
