Hello.
I want to make a rollover button and when I click it to change the button's image to Image_SELECTED image.
I have 3 images for the button
Image_NORMAL
Image_MOUSEOVER
Image_SELECTED
How can I do to change the button's image with Image_SELECTED image and the button still work correctly on Mouse Rollover ?
I want to use Image Behavoirs for that purpose.
Thank You !
hi tomcat2900 ,
if you want to use behaviours
and not "external" DW technologies you can try a combo of classical swap/restore image via the "Behaviours" panel and mix it with a "Show-Hide Elements" for the "Image_SELECTED". But in this case you will need an element (a div with an image or an image) with absolute positioning matching the same position of your button (I assume its a button).
hope this can be of any help. Cheers.
You do not need complicated JavaScript behaviors for this. Use pure CSS instead.
CSS Button Sprite - http://alt-web.com/
Nancy
Hello Tom,
as an addition: I like to use this disjont technique, as you can it see there: DisjointTest ​
It might be of interest to you.
Hans-Günter
P.S.
It's Dreamweaver technique, you simply could use the source code adapted to your needs. The theory behind this is written in italosan's reference.
But I want to use only Dreamweaver Image Behavoirs...
Please tell me how can I do that.
Thank You !
Image behaviors alone won't do what you want. You still need some CSS.
hi tomcat2900 ,
Thank You All for your answers !
