Hello, my Flash Professional CS6 keeps crashing when I use the Copy command! It crashes when I copy a vector or shape. If I restart the program, I can paste what I had copied that caused the crash, but it crashes again next time I use Copy. It doesn't always crash, and sometimes I can copy many times in a row, but it usually crashes the first time I Copy, each time I start Flash. It wont crash if what I'm copying is text. I'm on Mac Sierra, and this does not happen if I start the computer in safe mode. I've tried reinstalling Flash and cleaning out any purgeable memory including caches and PRAM and stuff. The problem is easily repeatable. Any advice would be awesome please, thanks for reading!
I'll differ to what John said! I'm already running High Sierra, and CS6 continues to work ok.
You could try reseting preferences, hold down Shift+Command+Option as you open CS6. If you have a Creative Cloud subscription you could reinstall CS6. Make sure your CS6 is up to date:
Adobe - Adobe Flash - Downloads
If you have your serial number you could do a new install from this page:
Download Adobe Creative Suite 6 applications
Here's the direct link to the old Java runtime John mentioned, though usu
...Copy link to clipboard
Owners of old programs simply have problems with Mac El Capitan/Sierra... none of which is Adobe's fault... Adobe did not change your old program to make it stop working... Apple changed their operating system and THAT is why your old programs won't work, not because of anything Adobe did... Also... every time Apple issues an update, there is the risk that an old program that HAS been working will STOP working... bottom line, old programs require a matching old operating system
https://forums.adobe.com/thread/2301916 includes a link to install the old Java runtime that is required
Here's the direct link to the old Java runtime John mentioned, though usually old programs don't even run if this is needed and is missing:
Download Java for OS X 2015-001
Does the crash happen when you copy anything at all? If it's just certain things, can you post an example somewhere for me to try in CS6, and also in Animate?
Thank you very much. I "solved" it, but this might come back to bite me later: Go to ~/Library/Caches/ and find the Adobe folder. Delete all the Adobe folder's contents. (Now the problem is fixed next time I open flash, but not two times in a row) Last, set the permissions for the Adobe folder to Read Only for my account. This stops the crashes.
If this causes further problems, then I'll try to track down the specific problematic files within ~/Library/Caches/Adobe and only make them empty and read-only.
That seems odd. That folder is read/write for me, and No Access for everyone. Also, neither Animate or Flash Pro seem to be using that folder.
I am having the same issue in regards to Adobe Flash CS6 crashing every time I try to copy something. If I use Cmd - C or Right Click - Copy, the result is still the same. The program crashes and I have to restart the application. I have already uninstalled and RE-installed the Suite several times and nothing has changed. I have deleted the system preferences as well, with no change. Any ideas would be greatly appreciated.
Here is the error log:
Process: | Adobe Flash CS6 [16088] |
Path: | /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6 |
Identifier: | com.adobe.flash |
Version: | 12.0.0.481 (12.0.0) |
Code Type: | X86 (Native) |
Parent Process: | ??? [1] |
Responsible: | Adobe Flash CS6 [16088] |
User ID: | 501 |
Date/Time: | 2018-01-18 01:07:58.196 -0600 |
OS Version: | Mac OS X 10.13.2 (17C205) |
Report Version: | 12 |
Anonymous UUID: | 80CB0877-7D5A-6F21-8493-CAE70DBE9D4C |
Sleep/Wake UUID: | 8AC31BA4-613A-4134-8EE1-88D4DB000412 |
Time Awake Since Boot: 23000 seconds
Time Since Wake: | 10000 seconds |
System Integrity Protection: enabled
Crashed Thread: | 0 Dispatch queue: com.apple.main-thread |
Exception Type: | EXC_CRASH (SIGABRT) |
Exception Codes: | 0x0000000000000000, 0x0000000000000000 |
Exception Note: | EXC_CORPSE_NOTIFY |
Application Specific Information:
terminating with uncaught exception of type CAIOutOfMemoryFault: std::exception
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib | 0xa76f6eae __pthread_kill + 10 | |
1 libsystem_pthread.dylib | 0xa78284c7 pthread_kill + 363 | |
2 libsystem_c.dylib | 0xa7646afe abort + 133 | |
3 libc++abi.dylib | 0xa5ad3ea7 abort_message + 134 | |
4 libc++abi.dylib | 0xa5ad406a default_terminate_handler() + 250 | |
5 libc++abi.dylib | 0xa5aed657 std::__terminate(void (*)()) + 14 | |
6 libc++abi.dylib | 0xa5aed0c1 __cxa_throw + 116 | |
7 com.adobe.AILib | 0x04242fc4 operator new[](unsigned long) + 116 | |
8 com.adobe.flash | 0x0085f844 SimpleStreamNS::ISimpleStream::~ISimpleStream() + 860 | |
9 com.adobe.flash | 0x0085f8ec SimpleStreamNS::ISimpleStream::~ISimpleStream() + 1028 | |
10 com.adobe.flash | 0x0119380d boost::exception_detail::clone_impl<boost::exception_detail::bad_alloc_>::rethrow() const + 95647 | |
11 com.adobe.flash | 0x011920ff boost::exception_detail::clone_impl<boost::exception_detail::bad_alloc_>::rethrow() const + 89745 | |
12 com.adobe.flash | 0x01192352 boost::exception_detail::clone_impl<boost::exception_detail::bad_alloc_>::rethrow() const + 90340 | |
13 com.adobe.flash | 0x00e0990e SimpleStreamNS::OFilterStream::OutputData(char const*) + 790 | |
14 com.adobe.flash | 0x003161a5 vc::BasicOperation::~BasicOperation() + 17105 | |
15 com.adobe.flash | 0x00316729 vc::BasicOperation::~BasicOperation() + 18517 | |
16 com.adobe.flash | 0x00f95347 CMiniFrameWnd::~CMiniFrameWnd() + 863 | |
17 com.adobe.flash | 0x00fc3fa4 CPropertyPage::GetRuntimeClass() const + 9792 | |
18 com.adobe.flash | 0x00f71b21 CButtonImplBase::~CButtonImplBase() + 8129 | |
19 com.adobe.flash | 0x00fd933a TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 17124 | |
20 com.adobe.flash | 0x00fda65e TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 22024 | |
21 com.adobe.flash | 0x00fd5bc6 TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 2928 | |
22 com.adobe.flash | 0x001feb01 CArray<CTimer*, CTimer*>::~CArray() + 11005 | |
23 com.adobe.flash | 0x0117277c CList<MMUI::DocumentFrame*, MMUI::DocumentFrame*>::RemoveAt(__POSITION*) + 3866 | |
24 com.adobe.flash | 0x00fda65e TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 22024 | |
25 com.adobe.flash | 0x0030ca19 CTemporaryMenu::~CTemporaryMenu() + 1117 | |
26 com.adobe.flash | 0x00fd5bc6 TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 2928 | |
27 com.adobe.flash | 0x001feb01 CArray<CTimer*, CTimer*>::~CArray() + 11005 | |
28 com.adobe.flash | 0x004de5a6 CToolsCommandScope::GetAcceleratorsHandle() + 1742 | |
29 com.adobe.flash | 0x0030cbe2 CTemporaryMenu::~CTemporaryMenu() + 1574 | |
30 com.adobe.flash | 0x00fe641e CRgn::~CRgn() + 5692 | |
31 com.adobe.flash | 0x00fc36b3 CPropertyPage::GetRuntimeClass() const + 7503 | |
32 com.adobe.flash | 0x010632b8 cf_bad_change::~cf_bad_change() + 3550 | |
33 com.apple.HIToolbox | 0x92f7c746 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 26 | |
34 com.apple.HIToolbox | 0x92f296b9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1948 | |
35 com.apple.HIToolbox | 0x92f2888a SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374 | |
36 com.apple.HIToolbox | 0x92f28702 SendEventToEventTargetWithOptions + 40 | |
37 com.apple.HIToolbox | 0x92f5eaa8 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1006 | |
38 com.apple.HIToolbox | 0x92f29b5c DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 3135 | |
39 com.apple.HIToolbox | 0x92f2888a SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374 | |
40 com.apple.HIToolbox | 0x92f39b1f SendEventToEventTarget + 33 | |
41 com.apple.HIToolbox | 0x930b7ff3 ToolboxEventDispatcher + 82 | |
42 com.apple.HIToolbox | 0x930b7ebe RunApplicationEventLoop + 192 | |
43 com.adobe.flash | 0x00fcc1fb CArray<MACFTYPES*, MACFTYPES*>::SetSize(int, int) + 5271 | |
44 com.adobe.flash | 0x00fa4c1d CTimerImpl::~CTimerImpl() + 1293 | |
45 com.adobe.flash | 0x00fa4e00 CTimerImpl::~CTimerImpl() + 1776 | |
46 com.adobe.flash | 0x0020fc4d std::vector<Symmetry*, std::allocator<Symmetry*> >::vector(std::allocator<Symmetry*> const&) + 6295 |
Thread 1:
0 libsystem_kernel.dylib | 0xa76f6d26 __psynch_cvwait + 10 | |
1 libsystem_pthread.dylib | 0xa78264db _pthread_cond_wait + 658 | |
2 libsystem_pthread.dylib | 0xa7828130 pthread_cond_wait$UNIX2003 + 51 |
3 com.apple.CoreServices.CarbonCore 0x9490e938 TSWaitOnCondition + 113
4 com.apple.CoreServices.CarbonCore 0x9490eb2a TSWaitOnConditionTimedRelative + 173
5 com.apple.CoreServices.CarbonCore 0x948e8e58 MPWaitOnQueue + 189
6 com.adobe.ACE | 0x06a2da69 0x69ee000 + 260713 | |
7 com.adobe.ACE | 0x06a2cd99 0x69ee000 + 257433 |
8 com.apple.CoreServices.CarbonCore 0x948e92a2 PrivateMPEntryPoint + 51
9 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
10 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
11 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
2 libsystem_pthread.dylib | 0xa7828130 pthread_cond_wait$UNIX2003 + 51 | |
3 com.adobe.AFlame | 0x0bc0d439 Flame_Terminate + 1281926 | |
4 com.adobe.AFlame | 0x0bc57950 Flame_Terminate + 1586333 | |
5 com.adobe.AFlame | 0x0bc0ba35 Flame_Terminate + 1275266 | |
6 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
7 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
8 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 9:
0 libsystem_kernel.dylib | 0xa76f6f9e __recvfrom + 10 | |
1 libsystem_c.dylib | 0xa7663f00 recv$UNIX2003 + 30 |
2 ServiceManager-Launcher.dylib 0x143c0733 Invoke + 47867
3 ServiceManager-Launcher.dylib 0x143bf846 Invoke + 44046
4 ServiceManager-Launcher.dylib 0x143be988 Invoke + 40272
5 ServiceManager-Launcher.dylib 0x143bea0f Invoke + 40407
6 ServiceManager-Launcher.dylib 0x143b9baf Invoke + 20343
7 ServiceManager-Launcher.dylib 0x143b9ea7 Invoke + 21103
8 ServiceManager-Launcher.dylib 0x143ba685 Invoke + 23117
9 ServiceManager-Launcher.dylib 0x143ba8f9 Invoke + 23745
10 ServiceManager-Launcher.dylib 0x143bd2a0 Invoke + 34408
11 ServiceManager-Launcher.dylib 0x143bd3fd Invoke + 34757
12 ServiceManager-Launcher.dylib 0x143bdc91 Invoke + 36953
13 ServiceManager-Launcher.dylib 0x143bddb2 Invoke + 37242
14 ServiceManager-Launcher.dylib 0x143b0656 Login + 461
15 ServiceManager-Launcher.dylib 0x143b409a Login + 15377
16 ServiceManager-Launcher.dylib 0x143be165 Invoke + 38189
17 ServiceManager-Launcher.dylib 0x143c02eb Invoke + 46771
18 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
19 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
20 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 10:: Java: Exception Handler Thread
0 libsystem_kernel.dylib | 0xa76ed742 mach_msg_trap + 10 | |
1 libsystem_kernel.dylib | 0xa76ecd7f mach_msg + 47 | |
2 libsystem_kernel.dylib | 0xa76ed484 mach_msg_server + 300 | |
3 libjvm.dylib | 0x5665677a 0x56640000 + 92026 | |
4 libjvm.dylib | 0x56656603 0x56640000 + 91651 | |
5 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
Thread 11:: Java: Gang worker#0 (Parallel GC Threads)
2 libjvm.dylib | 0x566557e6 0x56640000 + 88038 | |
3 libjvm.dylib | 0x56655722 0x56640000 + 87842 | |
4 libjvm.dylib | 0x566555e8 0x56640000 + 87528 | |
5 libjvm.dylib | 0x5665512d 0x56640000 + 86317 | |
6 libjvm.dylib | 0x56654fb7 0x56640000 + 85943 | |
7 libjvm.dylib | 0x5666ca59 0x56640000 + 182873 | |
8 libjvm.dylib | 0x5666c943 0x56640000 + 182595 | |
9 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
10 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
11 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
12 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 12:: Java: Gang worker#1 (Parallel GC Threads)
Thread 13:: Java: Gang worker#2 (Parallel GC Threads)
Thread 14:: Java: Gang worker#3 (Parallel GC Threads)
Thread 15:: Java: Gang worker#4 (Parallel GC Threads)
Thread 16:: Java: Gang worker#5 (Parallel GC Threads)
Thread 17:: Java: Gang worker#6 (Parallel GC Threads)
Thread 18:: Java: Gang worker#7 (Parallel GC Threads)
Thread 19:: Java: Gang worker#0 (Parallel CMS Threads)
7 libjvm.dylib | 0x5695286e 0x56640000 + 3221614 | |
Thread 20:: Java: Gang worker#1 (Parallel CMS Threads)
Thread 21:: Java: Concurrent Mark-Sweep GC Thread
2 libjvm.dylib | 0x566558b6 0x56640000 + 88246 | |
3 libjvm.dylib | 0x566733ca 0x56640000 + 209866 | |
4 libjvm.dylib | 0x56655604 0x56640000 + 87556 | |
7 libjvm.dylib | 0x5677fed5 0x56640000 + 1310421 | |
8 libjvm.dylib | 0x5677fe43 0x56640000 + 1310275 | |
9 libjvm.dylib | 0x566731e5 0x56640000 + 209381 | |
10 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
11 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
12 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
13 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 22:: Java: VM Thread
7 libjvm.dylib | 0x566ee134 0x56640000 + 713012 | |
8 libjvm.dylib | 0x566eddd3 0x56640000 + 712147 | |
Thread 23:: Java: Reference Handler
4 libjvm.dylib | 0x566fd2a0 0x56640000 + 774816 | |
5 libjvm.dylib | 0x566fc7a2 0x56640000 + 772002 | |
6 libjvm.dylib | 0x566fc491 JVM_MonitorWait + 211 | |
7 libjvmlinkage.dylib | 0x1426add5 JVM_MonitorWait + 69 | |
8 ??? | 0xb0f339d9 0 + 2968730073 | |
9 ??? | 0xb0f2be31 0 + 2968698417 | |
10 ??? | 0xb0f2be31 0 + 2968698417 | |
11 ??? | 0xb0f29374 0 + 2968687476 | |
12 libjvm.dylib | 0x566ef4a3 0x56640000 + 717987 | |
13 libjvm.dylib | 0x566ef215 0x56640000 + 717333 | |
14 libjvm.dylib | 0x566fc139 0x56640000 + 770361 | |
15 libjvm.dylib | 0x566fbfc1 0x56640000 + 769985 | |
16 libjvm.dylib | 0x566fbf40 0x56640000 + 769856 | |
17 libjvm.dylib | 0x566fbd8d 0x56640000 + 769421 | |
18 libjvm.dylib | 0x566fbbc3 0x56640000 + 768963 | |
19 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
20 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
21 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
22 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 24:: Java: Finalizer
10 ??? | 0xb0f2bf97 0 + 2968698775 | |
11 ??? | 0xb0f2bf97 0 + 2968698775 | |
12 ??? | 0xb0f29374 0 + 2968687476 | |
13 libjvm.dylib | 0x566ef4a3 0x56640000 + 717987 | |
14 libjvm.dylib | 0x566ef215 0x56640000 + 717333 | |
15 libjvm.dylib | 0x566fc139 0x56640000 + 770361 | |
16 libjvm.dylib | 0x566fbfc1 0x56640000 + 769985 | |
17 libjvm.dylib | 0x566fbf40 0x56640000 + 769856 | |
18 libjvm.dylib | 0x566fbd8d 0x56640000 + 769421 | |
19 libjvm.dylib | 0x566fbbc3 0x56640000 + 768963 | |
20 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
21 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
22 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
23 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 25:: Java: Surrogate Locker Thread (Concurrent GC)
6 libjvm.dylib | 0x56654efa 0x56640000 + 85754 | |
7 libjvm.dylib | 0x5670d58c 0x56640000 + 841100 | |
8 libjvm.dylib | 0x5670d4d0 0x56640000 + 840912 | |
9 libjvm.dylib | 0x566fbd8d 0x56640000 + 769421 | |
10 libjvm.dylib | 0x566fbbc3 0x56640000 + 768963 | |
11 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
12 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
13 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
14 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 26:: Java: Signal Dispatcher
0 libsystem_kernel.dylib | 0xa76ed77e semaphore_wait_trap + 10 | |
1 libjvm.dylib | 0x5670de7a 0x56640000 + 843386 | |
2 libjvm.dylib | 0x5670d850 0x56640000 + 841808 | |
3 libjvm.dylib | 0x566fbd8d 0x56640000 + 769421 | |
4 libjvm.dylib | 0x566fbbc3 0x56640000 + 768963 | |
Thread 27:: Java: C1 CompilerThread0
7 libjvm.dylib | 0x5671590e 0x56640000 + 874766 | |
8 libjvm.dylib | 0x5670f060 0x56640000 + 847968 | |
9 libjvm.dylib | 0x5670ee0a 0x56640000 + 847370 | |
10 libjvm.dylib | 0x566fbd8d 0x56640000 + 769421 | |
11 libjvm.dylib | 0x566fbbc3 0x56640000 + 768963 | |
12 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
13 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
14 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
15 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 28:: Java: Low Memory Detector
7 libjvm.dylib | 0x5670fda0 0x56640000 + 851360 | |
Thread 29:: Java: VM Periodic Task Thread
4 libjvm.dylib | 0x56712951 0x56640000 + 862545 | |
Thread 30:: Java: FelixDispatchQueue
11 ??? | 0xb0f2be31 0 + 2968698417 | |
12 ??? | 0xb0f2be31 0 + 2968698417 | |
13 ??? | 0xb0f2c30d 0 + 2968699661 | |
14 ??? | 0xb0f29374 0 + 2968687476 | |
15 libjvm.dylib | 0x566ef4a3 0x56640000 + 717987 | |
16 libjvm.dylib | 0x566ef215 0x56640000 + 717333 | |
17 libjvm.dylib | 0x566fc139 0x56640000 + 770361 | |
18 libjvm.dylib | 0x566fbfc1 0x56640000 + 769985 | |
19 libjvm.dylib | 0x566fbf40 0x56640000 + 769856 | |
20 libjvm.dylib | 0x566fbd8d 0x56640000 + 769421 | |
21 libjvm.dylib | 0x566fbbc3 0x56640000 + 768963 | |
22 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
23 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
24 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
25 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 31:: Java: FelixStartLevel
11 ??? | 0xb0f2c30d 0 + 2968699661 | |
Thread 32:: Java: FelixPackageAdmin
Thread 33:: Java: Code Model Worker
3 libjvm.dylib | 0x568fbfa9 0x56640000 + 2867113 | |
4 libjvm.dylib | 0x5693d0c2 0x56640000 + 3133634 | |
5 ??? | 0xb0f339d9 0 + 2968730073 | |
6 ??? | 0xb0f2be31 0 + 2968698417 | |
7 ??? | 0xb0f2be31 0 + 2968698417 | |
8 ??? | 0xb0f2c30d 0 + 2968699661 | |
9 ??? | 0xb0f2c473 0 + 2968700019 | |
Thread 34:: Java: Code Model Worker
Thread 35:
0 libsystem_kernel.dylib | 0xa76f7126 __semwait_signal + 10 | |
1 libsystem_c.dylib | 0xa7663df7 nanosleep$UNIX2003 + 189 | |
2 com.adobe.flash.flbridge | 0x3afdf93b ScObjects::Thread::sleep(unsigned int) + 59 | |
3 com.adobe.flash.flbridge | 0x3afdb799 ScObjects::BridgeTalkThread::run() + 185 | |
4 com.adobe.flash.flbridge | 0x3afdfca8 ScObjects::Thread::go(void*) + 168 | |
5 libsystem_pthread.dylib | 0xa782550d _pthread_body + 347 | |
6 libsystem_pthread.dylib | 0xa78253b2 _pthread_start + 357 | |
7 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 36:
1 libsystem_pthread.dylib | 0xa7826525 _pthread_cond_wait + 732 | |
2 libsystem_pthread.dylib | 0xa7826244 pthread_cond_wait + 25 |
3 com.macromedia.Flash Player.authplaylib 0x1a80411f 0x1a3b4000 + 4522271
4 com.macromedia.Flash Player.authplaylib 0x1a3ce25f 0x1a3b4000 + 107103
5 com.macromedia.Flash Player.authplaylib 0x1a80420c 0x1a3b4000 + 4522508
6 com.macromedia.Flash Player.authplaylib 0x1a804250 0x1a3b4000 + 4522576
7 com.macromedia.Flash Player.authplaylib 0x1a804376 0x1a3b4000 + 4522870
10 libsystem_pthread.dylib | 0xa7824a8e thread_start + 34 |
Thread 37:
Thread 38:
Thread 39:
Thread 40:: com.apple.NSURLConnectionLoader
2 com.apple.CoreFoundation | 0x9394d3b8 __CFRunLoopServiceMachPort + 296 | |
3 com.apple.CoreFoundation | 0x9394c3a6 __CFRunLoopRun + 2262 | |
4 com.apple.CoreFoundation | 0x9394b7a1 CFRunLoopRunSpecific + 641 | |
5 com.apple.CoreFoundation | 0x9394b50a CFRunLoopRunInMode + 122 | |
6 com.apple.CFNetwork | 0x92dc1f55 -[__CoreSchedulingSetRunnable runForever] + 663 | |
7 com.apple.CFNetwork | 0x92dc2686 +[__CoreSchedulingSetRunnable _run:] + 129 | |
8 com.apple.Foundation | 0x9532afe8 -[NSThread main] + 39 | |
9 com.apple.Foundation | 0x9532ae6c __NSThread__start__ + 1269 | |
Thread 41:: com.apple.CFSocket.private
0 libsystem_kernel.dylib | 0xa76f707e __select + 10 | |
1 com.apple.CoreFoundation | 0x93985899 __CFSocketManager + 777 | |
Thread 42:
0 libsystem_kernel.dylib | 0xa76f76ee __workq_kernreturn + 10 | |
1 libsystem_pthread.dylib | 0xa7825090 _pthread_wqthread + 1536 | |
2 libsystem_pthread.dylib | 0xa7824a6a start_wqthread + 34 |
Thread 43:
1 libsystem_pthread.dylib | 0xa7824e9b _pthread_wqthread + 1035 | |
Thread 44:
Thread 45:
1 libsystem_pthread.dylib | 0xa7824e70 _pthread_wqthread + 992 | |
Thread 46:
Thread 47:
2 com.adobe.flash | 0x00f4767b void std::sort<__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)>(__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, __gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)) + 101302 | |
3 com.adobe.flash | 0x00f442b9 void std::sort<__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)>(__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, __gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)) + 88052 | |
4 com.adobe.flash | 0x00f479e8 void std::sort<__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)>(__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, __gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)) + 102179 | |
Thread 48:: Java: Thread-4
3 libjvm.dylib | 0x5678ad05 0x56640000 + 1355013 | |
4 libjvm.dylib | 0x5678e23a JVM_Sleep + 254 | |
5 libjvmlinkage.dylib | 0x1426b9c8 JVM_Sleep + 72 | |
6 ??? | 0xb0f339d9 0 + 2968730073 | |
9 ??? | 0xb0f29374 0 + 2968687476 | |
10 libjvm.dylib | 0x566ef4a3 0x56640000 + 717987 | |
11 libjvm.dylib | 0x566ef215 0x56640000 + 717333 | |
12 libjvm.dylib | 0x566fc139 0x56640000 + 770361 | |
13 libjvm.dylib | 0x566fbfc1 0x56640000 + 769985 | |
14 libjvm.dylib | 0x566fbf40 0x56640000 + 769856 | |
15 libjvm.dylib | 0x566fbd8d 0x56640000 + 769421 | |
16 libjvm.dylib | 0x566fbbc3 0x56640000 + 768963 | |
17 libjvm.dylib | 0x5665508c 0x56640000 + 86156 | |
Thread 49:
2 libsystem_pthread.dylib | 0xa7827872 pthread_cond_timedwait_relative_np + 27 |
3 com.macromedia.Flash Player.authplaylib 0x1a8040e7 0x1a3b4000 + 4522215
4 com.macromedia.Flash Player.authplaylib 0x1a5949de 0x1a3b4000 + 1968606
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0xa9b301c0 ecx: 0xbfffe27c edx: 0x00000000
edi: 0xa782836a esi: 0x0000002d ebp: 0xbfffe2a8 esp: 0xbfffe27c
ss: 0x00000023 efl: 0x00000206 eip: 0xa76f6eae cs: 0x0000000b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0xa9b15330
Logical CPU: | 0 |
Error Code: | 0x00080148 |
Trap Number: | 132 |
Binary Images:
0x1000 - 0x1b81fe7 +com.adobe.flash (12.0.0.481 - 12.0.0) <CFAB9248-6011-0498-4D7A-985E1FB68592> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6 |
0x272a000 - 0x2735ff7 +libChar16.dylib (1) <5E278E11-8234-CB11-AAC9-090FBD037DB7> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/libChar16.dylib
0x273e000 - 0x2760fff +libCoreTypes.dylib (1) <5799BD8C-B334-518F-3F6F-EAA503B43831> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/libCoreTypes.dylib
0x2778000 - 0x2778ffb +com.adobe.SPBasic (SPBasic version 16.0.0 - 16.0.0.646) <936C3F3E-8DDD-50EC-D247-C1F242633914> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
0x277d000 - 0x27c2fdf dyld (519.2.2) <7B7B05B7-204A-38FF-BD32-4CBB51752DD4> /usr/lib/dyld
0x2806000 - 0x299afff +com.adobe.PlugPlug (3.0.0.383 - 3.0.0.383) <2205B6E1-7C9E-1892-EC68-C1B326C727A8> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x2a42000 - 0x2b2afe3 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <2540764B-C2F2-61D7-EFBA-6663171FD19A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x2bbb000 - 0x2c59fe3 +libicucnv.40.0.dylib (40) <D11DC46F-D58E-B17C-9356-46F593D5A7CF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
0x2c7b000 - 0x2db0fe7 +libicui18n.40.0.dylib (40) <8BE3FE71-0CE6-2B93-B5F2-B4F0DD274B91> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/libicui18n.40.0.dylib
0x2e24000 - 0x2f15fef +libicuuc.40.0.dylib (40) <4CF7066A-6E82-FF80-93E6-6849149FBB98> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
0x2f52000 - 0x3c97ff7 +libicudata.40.0.dylib (40) <015E6351-4F42-00C1-2096-BEE385B275B1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
0x3caa000 - 0x3ed8fff com.apple.carbonframeworktemplate (1.0 - 1.0) <9F3FE9F2-8834-4654-C0D0-F4F356E6A906> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/Xerces.framework/Versions/A/Xerces
0x418f000 - 0x57f9fff +com.adobe.AILib (AILib version 16.0.0 - 16.0.0.646) <317A871E-E0A5-8C5E-B60F-7448ADEBEDBD> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
0x6872000 - 0x68cdfff +com.adobe.aiport (aiport version 16.0.0 - 16.0.0.646) <59612576-B2F2-BF25-B09D-6120A3B1462C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AIPort.framework/Versions/A/aiport
0x690d000 - 0x696dfff +com.adobe.filterport (filterport version 16.0.0 - 16.0.0.646) <AF193FFA-F555-2379-81B3-7DA07698E466> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FilterPort.framework/Versions/A/filterport
0x69b8000 - 0x69d4ff9 +AdobePDFSettings (1) /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x69ee000 - 0x6b6aff3 +com.adobe.ACE (AdobeACE 2.19.18.19822 - 2.19.18.19822) <2EC89B0E-6B51-4F7F-314A-FB6E18BFC36D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x6b79000 - 0x7114fef +com.adobe.AGM (AdobeAGM 4.26.20.19822 - 4.26.20.19822) <F394945E-943B-B99F-9B45-07E96C293C05> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x7184000 - 0x71befef +com.adobe.ARE (AdobeARE 1.5.02.19822 - 1.5.02.19822) <2A3CBF43-F63E-B5B6-19EA-A2C392CA92F4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x71c4000 - 0x71dffff +com.adobe.BIB (AdobeBIB 1.2.02.19822 - 1.2.02.19822) <CD35337B-CA58-50D9-5AAE-74E720CCE415> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x71e5000 - 0x720bfff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <606DA5E0-CCB3-90B2-3971-A48349DA046A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x7211000 - 0x7538ffb +com.adobe.CoolType (AdobeCoolType 5.10.31.19822 - 5.10.31.19822) <A5344CC0-BD71-A071-A001-EDB3A28B9A8D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x7570000 - 0x796bfe7 +com.adobe.MPS (AdobeMPS 5.8.0.19673 - 5.8.0.19673) <D65ABA15-80D2-3F1C-2500-EEF873019149> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x79c8000 - 0x7accfef +com.adobe.PDFPort (AdobePDFPort 2.1.0.19734 - 2.1.0.19734) <71232DFD-06FB-837B-8246-BD20F862B5E3> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
0x7ae5000 - 0x82ddffb +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 10.0.1.18562) <F24575DF-1B4D-B13E-1525-3C7F5CB88B3E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
0x8368000 - 0x8390feb +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636) <C38ACBCE-04AA-DF40-FF79-29377F25CDAF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x83af000 - 0x83d7ff3 +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.7.101.18636 - 3.7.101.18636) <AD333DEF-C5AC-1F75-0486-DF86F89433CD> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedExpat
0x83f6000 - 0x8452fef +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <123A0829-A85B-6E67-0E48-4F37B08E4C03> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x845b000 - 0x84d3fe3 +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 66.145433) <EF13921E-1CC6-2891-0EEC-D8D8C68D5D87> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x84e2000 - 0x86c1ffb +com.adobe.owl (AdobeOwl version 4.0.93 - 4.0.93) <D102FCD2-496D-5322-AEC0-7A5091CAA2CA> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x86ee000 - 0x979aff3 +com.adobe.psl (AdobePSL 13.0.0.19655 - 13.0.0.19655) <47A9AAEC-43CD-17C9-6E58-6312315FC15D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x9913000 - 0x9b3dffb +com.adobe.linguistic.LinguisticManager (6.0.0 - 17018) <DE928A0E-AE8F-4FB7-6B6C-C52E4FD366A1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x9baf000 - 0x9bb2ffb +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <6CE1936E-6AC7-6900-769B-876CBB68B5BC> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x9bba000 - 0x9fedffb +com.adobe.dvaui.framework (5.0.0 - 5.0.0.0) <EAD7D965-79BB-EA89-AB42-692578840BA8> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0xa426000 - 0xa5dbff3 +com.adobe.dvacore.framework (5.0.0 - 5.0.0.0) <EDDA1DA8-726A-0F1E-8733-CF6A482F307C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0xa729000 - 0xab3cfe7 +com.adobe.dvaadameve.framework (5.0.0 - 5.0.0.0) <E717BB78-EC59-A9C3-B02B-91A7D46DDBB3> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0xb14d000 - 0xb22fff3 +com.adobe.amtlib (amtlib 6.0.0.93 - 6.0.0.93) <2218F05B-09B7-AE0E-5EF7-98FBA5DF9C86> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0xb23e000 - 0xb2abffb +com.adobe.headlights.LogSessionFramework (2.1.2.1652) <82DA9279-45D2-AD40-C86C-F5A94B9DAAFF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0xb2fa000 - 0xb32eff7 +com.adobe.pip (6.0.0.1654) <21A87289-747E-A0BD-2692-F9E844932E26> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
0xb33a000 - 0xb47afeb +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <6D085279-1185-E7F0-B0D8-FBADBA062516> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0xb4ec000 - 0xb4f4ff7 +com.adobe.boost_date_time.framework (5.0.0 - 5.0.0.0) <6397AF50-419F-3030-C6D6-A28D34CF3412> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0xb50c000 - 0xb524ff3 +com.adobe.boost_filesystem.framework (5.0.0 - 5.0.0.0) <8DC64C9A-155F-DE79-3521-8869C4A2661D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0xb545000 - 0xb5efffb +com.adobe.boost_regex.framework (5.0.0 - 5.0.0.0) <F143073E-6033-B137-7633-9601D846FC1A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0xb674000 - 0xb67fff7 +com.adobe.boost_signals.framework (5.0.0 - 5.0.0.0) <5F9FB957-8AC2-A2FD-1518-9F9D978B0C58> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0xb693000 - 0xb695ff3 +com.adobe.boost_system.framework (5.0.0 - 5.0.0.0) <5641DBC5-37C4-7349-4BB4-FC19F46EEFFC> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0xb69b000 - 0xb6a7ff7 +com.adobe.boost_threads.framework (5.0.0 - 5.0.0.0) <6F6A3465-894D-2E05-9FDE-16A15486E583> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0xb6c3000 - 0xb876fe3 +com.adobe.AFlamingo (AFlamingo 2.3.102.19287 - 2.3.102.19287) <A04AE11D-8128-3324-295F-504CBAD447E1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
0xb892000 - 0xb899ffb +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <B711CAA7-29D6-D5CF-CE1B-A611896C8D87> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0xb8a1000 - 0xb96afeb +FlashIK Framework (1.0) <A8AFFB46-F2F7-FBFF-CF77-6BC999E1D266> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
0xb9f3000 - 0xba27ff7 +com.adobe.pff.framework (1.0 - 1.0) <E053457E-4AA0-D931-14AF-37BFE91AA1E4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
0xba50000 - 0xc3f3fef +com.adobe.AFlame (AFlame 2.03.54.19287 - 2.03.54.19287) <21495560-EA23-BCA2-8E91-9F0C1EF440EB> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
0xc467000 - 0xc496fff +com.adobe.contextui.framework (5.0.0 - 5.0.0.0) <109B01C7-7CB9-D3CA-2CBB-B8D4ADC7AE3E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/contextui.framework/Versions/A/contextui
0xc4dd000 - 0xc501fe7 +com.adobe.dvaunittesting.framework (5.0.0 - 5.0.0.0) <B32EF0E4-EBCF-6A17-56B2-FC5F2A969F45> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
0xc539000 - 0xc558fff +libtbb.dylib (0) <6EA19434-60D6-505D-CB6F-5CA562A0F2A7> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/libtbb.dylib
0xc56f000 - 0xc577fef +libtbbmalloc.dylib (0) <7A79ED70-A4AC-737A-2FAA-63B6FB29D4ED> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/libtbbmalloc.dylib
0xc586000 - 0xc641fef +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.4 -f 49 - 66.145661) <B8855D3A-C827-D9EB-040E-F808043458DA> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
0xc670000 - 0xc673ffb +com.adobe.dvaflashview.framework (5.0.0 - 5.0.0.0) <F06AF987-2A15-A8B9-11C9-2368422D061E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
0xc682000 - 0xc754fff +com.adobe.dvaworkspace.framework (5.0.0 - 5.0.0.0) <2B746397-82F4-3C89-28C1-1EC7EE317435> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0xc8c3000 - 0xc8c4fff com.apple.textencoding.unicode (4.0 - 4.0) <A4BE917A-9F3D-34B6-B086-C1B86D325BB3> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0xf7f3000 - 0xf7f4ff3 +com.macromedia.Flash.flastoragelib (9.0 - 9.0) <AB678254-543D-CC50-3CF8-EC0AA01D99D4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
0x12345000 - 0x12347ff7 +com.macromedia.Flash.FLfile (12.0.0.481 - 12.0.0) <639D8AF3-69A7-4D91-5826-F54C86AB1BD1> /Applications/Adobe Flash CS6/*/FLfile.bundle/Contents/MacOS/FLfile
0x140d3000 - 0x140e6ff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.18561 - 1.1.0.18561) <5A153C87-DD7A-CE28-2E93-7DC120D4244F> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
0x14256000 - 0x1425affb com.apple.audio.AppleHDAHALPlugIn (280.12 - 280.12) <687E756D-6AAB-32A7-917F-6CC8E2CCBAE0> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1426a000 - 0x14271ffb +libjvmlinkage.dylib (1) <D9427B46-8FEB-3FA9-AC0C-3E0FA4824320> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
0x14284000 - 0x1428bfff +libverify.dylib (1.0 - 1.0) <683BCE2E-6200-3734-A926-10129E43A284> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
0x14290000 - 0x142adfff +libjava.jnilib (1) <FCA2018B-641E-32C8-8978-1935FF8F8544> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
0x142cb000 - 0x142d7fff +libzip.jnilib (1) <788F148B-73D1-30C5-8310-DE41C9206221> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
0x143ab000 - 0x143d2ffb +ServiceManager-Launcher.dylib (389) <4EEAF886-0B48-9FF4-BE65-41E222123A50> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
0x143dc000 - 0x143ebfff +com.yourcompany.PointGrid (1.0) <2CB987CD-6752-D333-7F4F-A6713A901947> /Applications/Adobe Flash CS6/*/PointGrid.bundle/Contents/MacOS/PointGrid
0x14600000 - 0x14622ff7 +com.adobe.flash.cs6.airAndroid (12.0.0.0 - 12.0.0) <48421B0A-923E-5940-9F04-B00DA3A75C11> /Applications/Adobe Flash CS6/*/Air_Android.bundle/Contents/MacOS/Air_Android
0x14636000 - 0x1465eff7 +com.adobe.flash.cs6.air (12.0.0.0 - 12.0.0) <871E06CB-E151-DD97-46AB-A8B2E9D75665> /Applications/Adobe Flash CS6/*/Air_Desktop_iOS.bundle/Contents/MacOS/Air_Desktop_iOS
0x15800000 - 0x15d3efff com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.30.12 - 10.3.0) <3A85569D-C753-365C-AEF0-67704DB7CB96> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
0x197b1000 - 0x197c0fff libSimplifiedChineseConverter.dylib (70) <7F4EA439-FF06-3CF8-9FD0-6B69059104E6> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x197c5000 - 0x197d7fff libTraditionalChineseConverter.dylib (70) <A421E237-655C-304A-A73E-E31B0713F46C> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x1a3b4000 - 0x1ada6ff3 +com.macromedia.Flash Player.authplaylib (10.2.153.2 - 10.2.153.2) <3CFE191B-E5E1-6C47-46DB-FE24C06872B7> /Applications/Adobe Flash CS6/*/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
0x1b048000 - 0x1b3b2fff com.apple.RawCamera.bundle (8.02.0 - 1017.2.2) <2BA977FD-99E8-3614-B754-535CDF1776D2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x1b40a000 - 0x1b47cfef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <E4ADECD5-05B4-E78B-09D8-E45FD640E84D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0x1bbd9000 - 0x1bc2dfe7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <0B80F7A7-EC10-A7C7-5E6E-787953553C55> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
0x1bd04000 - 0x1bd47ff3 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <4B40551F-5306-C836-02AD-109826BD580C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x3afbe000 - 0x3b005fff +com.adobe.flash.flbridge (12.0.0.481 - 12.0.0) <9301CA9F-DABA-0BB4-84D3-B9DAE690711D> /Applications/Adobe Flash CS6/*/FLBridge.bundle/Contents/MacOS/FLBridge
0x40000000 - 0x400c4fe3 +com.adobe.JP2K (2.0.0 - 2.0.0.18562) <FFA540EA-6CEB-F4D1-E0EF-A844A536D499> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x45811000 - 0x4586efef +com.yourcompany.Brush (1.0) <2136D27E-974D-81F0-6078-492B233E16FC> /Applications/Adobe Flash CS6/*/Brush.bundle/Contents/MacOS/Brush
0x50611000 - 0x50694ffb +com.yourcompany.Collision (1.0) <F0E00160-1946-C591-89EC-FBD99ACCC449> /Applications/Adobe Flash CS6/*/Collision.bundle/Contents/MacOS/Collision
0x55000000 - 0x55101fff +com.yourcompany.Stroke (1.0) <B1BDF135-128A-A5D9-3EC0-E0EBEC447500> /Applications/Adobe Flash CS6/*/Stroke.bundle/Contents/MacOS/Stroke
0x56640000 - 0x569a8fe6 +libjvm.dylib (1) <FD52FA39-2545-3053-AB1C-354995E08DDD> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm.dylib
0x869aa000 - 0x87558ff3 +com.adobe.flash.createjs (1.1.0.0 - 1.1.0) <D9B1E8C1-68E2-3A8E-91BC-7B2807F535F9> /Users/USER/Library/Application Support/Adobe/*/FLCreateJS.bundle/Contents/MacOS/FLCreateJS
0x90015000 - 0x9001cfff com.apple.agl (3.3.1 - AGL-3.3.1) <DE1399CF-739C-3AAC-AAFC-766D4AAFD282> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9001d000 - 0x901d8ff7 com.apple.avfoundation (2.0 - 1528.24) <1A334EEE-99A1-3F7A-A14B-0D987EE1F193> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x901d9000 - 0x90296ff7 com.apple.audio.AVFAudio (1.0 - ???) <5658CF45-3305-3112-9394-510CF049EF6C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x90298000 - 0x90298fff com.apple.Accelerate (1.11 - Accelerate 1.11) <F4A138F5-290D-3413-AD17-ECD395935FF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x90299000 - 0x902afffb libCGInterfaces.dylib (417) <92B03F58-1974-35E7-BC7F-28B6B285A860> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x902b0000 - 0x909f1fdf com.apple.vImage (8.1 - ???) <591C941E-6475-347E-89DA-F541E88F949A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x909f2000 - 0x90b2dff7 libBLAS.dylib (1211.30.1) <A850E0E2-3A72-3916-9907-AF1E7ECC95F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x90b2e000 - 0x90b5bffb libBNNS.dylib (37) <C29094A0-5C89-3C5E-AB37-510C28588E2E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x90b5c000 - 0x90ecffff libLAPACK.dylib (1211.30.1) <2DDDE838-0FF1-3679-8E62-9C09923ECB7E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90ed0000 - 0x90ee6ffb libLinearAlgebra.dylib (1211.30.1) <8A120E75-CAF4-3CAE-BBE6-E2F5FAE44DB8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x90ee7000 - 0x90f00ff7 libSparseBLAS.dylib (1211.30.1) <0C5E0EF4-E9A5-3FC4-B7A3-1FE59DB4A2AA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x90f01000 - 0x9105ffc7 libvDSP.dylib (622.20.8) <C5F16300-061F-3DF0-B91E-8BD0D2173351> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91060000 - 0x9113effb libvMisc.dylib (622.20.8) <1C8D5D80-F32C-3853-8309-57C8A82B7DA5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9113f000 - 0x9113ffff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7A0D5DD6-C302-390D-9178-0B2EA94BB5ED> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91333000 - 0x920f4ffb com.apple.AppKit (6.9 - 1561.20.106) <5EC573DC-BD5D-3901-AC06-65690425A1B1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x92146000 - 0x92146fff com.apple.ApplicationServices (48 - 50) <BFE7FB45-365B-341F-A8FC-B9483AE87709> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x92147000 - 0x921adff3 com.apple.ApplicationServices.ATS (377 - 445) <CD3D5685-2BB9-3A7B-AC97-2A74A81CB7CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x921ae000 - 0x921affff ATSHI.dylib (445) <A8BA760D-02EE-3EB5-B39C-1C67A2699275> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x921b0000 - 0x922d4ff3 libFontParser.dylib (222.1.2) <8F7D388A-299C-3C6D-9864-40EC0914A96B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x922d5000 - 0x92321ffb libFontRegistry.dylib (221) <8D81FDCF-F05D-3556-AB6D-090F9508C25E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x92370000 - 0x923a3ff3 libTrueTypeScaler.dylib (222.1.2) <CFBA5950-79C1-32F9-9DB4-902A31A72EFE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x923a4000 - 0x9240eff7 libType1Scaler.dylib (136) <260982B2-CA75-36CB-89F5-27008AD3CBFC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x9240f000 - 0x92414fff com.apple.ColorSyncLegacy (4.13.0 - 1) <AB5CE7D2-8BE5-35C8-A9D5-ED0FB5BAB7D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x924be000 - 0x92515ff7 com.apple.HIServices (1.22 - 622) <8544026A-17BE-301D-BA2A-782F3AD864DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x92516000 - 0x92525ff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <E3245701-039B-353F-923D-F81B2242842C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x92526000 - 0x9257effb com.apple.print.framework.PrintCore (13 - 503) <FD0F7A18-6F78-34C9-B067-B3AB76C3D4C8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9257f000 - 0x92615ffb com.apple.QD (3.12 - 403) <372AFF26-17D1-3C6F-9E47-17C955C2045B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x92616000 - 0x92622ff3 com.apple.speech.synthesis.framework (7.2.1 - 7.2.1) <A0201575-0BFF-3C43-99C6-9DB3861F8A07> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x92623000 - 0x9286fff3 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <489BC806-28CC-3340-BB52-D37A65CADEC9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x92871000 - 0x92871fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <3CF15BE4-B8D9-3D92-AB17-B613CD0BFBFE> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92b8f000 - 0x92efcffb com.apple.CFNetwork (893.13.1 - 893.13.1) <960BA636-F94A-3DF7-B587-3165654BF020> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x92f11000 - 0x92f11fff com.apple.Carbon (158 - 158) <1545E2E8-F562-33D6-8DA7-5FD34045B314> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92f12000 - 0x92f1bff3 com.apple.audio.SoundManager (4.2 - 4.2) <83AE7AA9-8661-3449-99F4-291A42640692> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92f1c000 - 0x92f20fff com.apple.CommonPanels (1.2.6 - 98) <DA1D99A4-53F6-31AF-964D-86739FA74B52> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92f21000 - 0x932b7ffb com.apple.HIToolbox (2.1.1 - 910.4) <16D13C1E-B4A1-3AF0-A7A3-B3AC344D25F6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x932b8000 - 0x9330cffb com.apple.htmlrendering (77 - 1.1.4) <BAF5C846-FF50-3C80-97F5-71F1399CA85C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9330d000 - 0x93310fff com.apple.help (1.3.8 - 64) <1E913488-5D7B-388E-904D-64EF8C99E704> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x93311000 - 0x93316ffb com.apple.ImageCapture (9.0 - 9.0) <1887749B-D641-3057-B91F-3C2D8E990115> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x93317000 - 0x933b1ffb com.apple.ink.framework (10.9 - 220) <5340E055-BD3D-35AD-9797-F22E1ECEDAC6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x933b2000 - 0x933ecfff com.apple.NavigationServices (3.8 - 227) <6B1000C3-9C00-33F5-88D5-62F6BD5DD7F8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x933ed000 - 0x93408ffb com.apple.openscripting (1.7 - 174) <CD281A8D-54C8-3201-B9F7-DE2439088302> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93409000 - 0x9340efff com.apple.print.framework.Print (12 - 267) <F7BEF8BA-7D1F-34A2-97B8-D49F20886644> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9340f000 - 0x93411fff com.apple.securityhi (9.0 - 55006) <E9FF8254-B8E1-312A-8FC3-2B4EA8CE9AEA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93412000 - 0x93418fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C27FB7B-A467-3171-A73B-8C9B403028E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93419000 - 0x93419fff com.apple.Cocoa (6.11 - 22) <299860CC-316E-3580-B0A3-3BF73B6E80E8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93426000 - 0x934e5ff7 com.apple.ColorSync (4.13.0 - 546) <DACC5623-8E37-3134-9562-4E8601127F67> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x934e6000 - 0x93581fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <D0803409-87D1-3794-8A6C-C06AE7CA94AD> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x935df000 - 0x935e4fff com.apple.CoreBluetooth (1.0 - 1) <E0F40A70-9E04-31FE-A4C8-BE05F6432BAD> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x935e5000 - 0x938c5fff com.apple.CoreData (120 - 849.2) <E17C36CB-6DED-36F4-930C-AD056F0F5953> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x938c6000 - 0x938ccff3 com.apple.CoreDisplay (1.0 - 81.7) <CF8FEFA1-D61A-30D9-A79F-342A55C71133> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x938cd000 - 0x93d57ff3 com.apple.CoreFoundation (6.9 - 1450.16) <5FAD88AF-D901-3D54-9480-BFD8BBB95A09> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93d59000 - 0x94388ffb com.apple.CoreGraphics (2.0 - 1129.5) <20752785-E9DA-3CC6-ACDD-5A82AD344209> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9438a000 - 0x94600ffb com.apple.CoreImage (13.0.0 - 579.2.9) <D91C42B6-CBEE-39AE-A4EA-22D3DE1C96B7> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x946bc000 - 0x9479dfff com.apple.CoreMedia (1.0 - 2267.40.5) <7D2BE382-4A76-3A7A-978C-0C8CD9B84B2E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9479e000 - 0x947f0fff com.apple.CoreMediaIO (812.0 - 4993) <78FA5884-4BE4-366F-AAAD-8831A8978C0F> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x947f1000 - 0x947f1fff com.apple.CoreServices (822.19 - 822.19) <5BEC50B1-0B38-3237-8D48-7858156721F5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x947f2000 - 0x94864ff3 com.apple.AE (735.1 - 735.1) <3E1B0CED-0AC3-3252-AEDD-5D8F91E3AAA7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x94865000 - 0x94b43ffb com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <E61EA71D-294F-3C8B-95BD-0CDBA0FFC907> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94b44000 - 0x94b78ff3 com.apple.DictionaryServices (1.2 - 284) <56BEF6B8-50D2-38A0-9EF2-D7093E9AAB56> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x94b79000 - 0x94b81fff com.apple.CoreServices.FSEvents (1239 - 1239) <CABC21F7-E3AB-3954-ACBE-B8066A37516A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x94b82000 - 0x94ce0fff com.apple.LaunchServices (822.19 - 822.19) <44D623FB-2F50-3322-BEEC-A6A2DD3CD9E6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x94ce1000 - 0x94d8dff7 com.apple.Metadata (10.7.0 - 1191.2.6) <6CE69880-6AF3-3A1A-A8E0-F89FC750EE4C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x94d8e000 - 0x94decff7 com.apple.CoreServices.OSServices (822.19 - 822.19) <CA9178CA-70B1-3BDC-B61B-A176DD7CE7F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x94ded000 - 0x94e5eff3 com.apple.SearchKit (1.4.0 - 1.4.0) <FAD60011-970B-3889-B6BD-3715CCF599CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94e5f000 - 0x94e82fff com.apple.coreservices.SharedFileList (71.4 - 71.4) <CD97E31D-0354-36AB-9997-C4FAF3221D30> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x94e83000 - 0x94fceffb com.apple.CoreText (352.0 - 578.12) <6389222B-6B26-3F46-93C2-ABE07168227F> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x94fcf000 - 0x95009ff3 com.apple.CoreVideo (1.8 - 279.2) <0D75C395-3C86-3539-9206-C7A330BE3551> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9500a000 - 0x95090ff3 com.apple.framework.CoreWLAN (13.0 - 1339) <F2109362-0F47-3D05-A67F-D9752B03EB6B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x951f4000 - 0x951fefff com.apple.DirectoryService.Framework (10.13 - 207) <250D0788-9C38-3D6C-8761-E2BCF924EFB6> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x951ff000 - 0x952befff com.apple.DiscRecording (9.0.3 - 9030.4.5) <80DF1650-3C57-352F-B0DC-6CBA11B5CAB1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x952e4000 - 0x952edff7 com.apple.DiskArbitration (2.7 - 2.7) <E3552A79-57A4-36AE-8B54-5FE2EB5193DA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x952fe000 - 0x9566dffb com.apple.Foundation (6.9 - 1450.16) <3838D116-6432-30EE-8C80-68FE79D28DE5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x956ae000 - 0x956ddff3 com.apple.GSS (4.0 - 2.0) <78C94D11-21DF-34C6-B4E8-88564551D67E> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9570a000 - 0x95822ff3 com.apple.Bluetooth (6.0.2 - 6.0.2f2) <48DCB862-4D56-3D7A-83BF-F182D238090A> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x95888000 - 0x95929ffb com.apple.framework.IOKit (2.0.2 - 1445.31.1) <22A82C10-B391-3359-B23A-053108AE9EB1> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9592b000 - 0x95932fff com.apple.IOSurface (209.2.2 - 209.2.2) <0CCA9904-FCBB-3278-96A1-714BDB961D8A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x95933000 - 0x95986fff com.apple.ImageCaptureCore (7.0 - 7.0) <9E9ADEDE-0C33-37E7-9179-957B8CA121E3> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x95987000 - 0x95b0bff3 com.apple.ImageIO.framework (3.3.0 - 1713) <3A5C1E33-7CCC-3537-819B-53F39F70F034> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95b0c000 - 0x95b10ffb libGIF.dylib (1713) <47A6BFCC-6651-3AAE-A70C-7BA3717B13BB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x95b11000 - 0x95c02fff libJP2.dylib (1713) <AC278AEA-560B-30E6-BA69-C1A2416F0849> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x95c03000 - 0x95c25ff7 libJPEG.dylib (1713) <EFD86068-C17E-32AD-B4A5-79C20BC93411> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x95f06000 - 0x95f2cff7 libPng.dylib (1713) <A10259A1-2581-3642-946D-5B3F101615EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x95f2d000 - 0x95f2fffb libRadiance.dylib (1713) <EE872547-4C9F-397B-B41B-C79FEEE68267> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x95f30000 - 0x95f7afff libTIFF.dylib (1713) <7A56E3C4-9965-3471-8E98-5F6B28D68FBF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x96029000 - 0x9687fffb com.apple.JavaScriptCore (13604 - 13604.4.7.1.6) <51BA4256-D385-3CB7-AE66-83716754432C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x96880000 - 0x96887fff JavaNativeFoundation (74) <6E1A3FCA-E162-3267-BD93-8CAAE66C1E3C> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x96888000 - 0x96890ff3 com.apple.java.JavaRuntimeSupport (15.0.1 - 15.0.1) <6166BC97-12D2-3D11-8DBE-73A340478724> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x96891000 - 0x96895fff com.apple.JavaVM (15.0.2 - 15.0.2) <18FAFCBC-D27E-35CD-B071-E6743BC0DA51> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x96897000 - 0x968affff com.apple.Kerberos (3.0 - 1) <8A399DB7-5440-3EC0-A241-3DD10E82DDB2> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x968b0000 - 0x968e3ffb com.apple.LDAPFramework (2.4.28 - 194.5) <7A129625-1C7A-34A3-AD2F-0D55D33BE623> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x96907000 - 0x9690ffff com.apple.MediaAccessibility (1.0 - 114) <087BD9A6-6E5E-3884-B4F7-8F0A6B662B8D> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x96910000 - 0x96f23ff3 com.apple.MediaToolbox (1.0 - 2267.40.5) <EF94A3D5-D37B-3AEF-85CE-85F3DBA504B4> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x96f25000 - 0x96f9bfff com.apple.Metal (124.7 - 124.7) <30F249EE-27E6-3C0F-AD33-792A2E77D75B> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x96f9d000 - 0x96fa9fff com.apple.NetFS (6.0 - 4.0) <F37A4DA0-AAB6-3F0B-BA18-E322BFA52CC4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x99c6d000 - 0x99c75ff7 libcldcpuengine.dylib (2.8.7) <E3B50B98-E1E4-396C-BB05-935AACC6FD80> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x99c76000 - 0x99cc1fff com.apple.opencl (2.8.12 - 2.8.12) <EC1CCEC3-19B3-3EC8-AEF5-2E1360E0B950> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x99cc2000 - 0x99cdefff com.apple.CFOpenDirectory (10.13 - 207) <F0632A8B-7F3D-3E73-B96E-2843058A3728> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x99cdf000 - 0x99ceafff com.apple.OpenDirectory (10.13 - 207) <86931646-B3A1-3200-A3CB-35005468F987> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9aef4000 - 0x9aef5fff libCVMSPluginSupport.dylib (16.4.2) <909D788E-692E-3FF1-AFF0-2AB4609C53D7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9aef6000 - 0x9aefafff libCoreFSCache.dylib (162.4) <D53B0D41-0774-3C6A-BB59-8BA7DB8A8374> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x9aefb000 - 0x9aefffff libCoreVMClient.dylib (162.4) <19767FEB-6A89-3892-8F18-1F9E73463050> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9af00000 - 0x9af08ff7 libGFXShared.dylib (16.4.2) <F62281F1-9495-3589-A576-75D84880D42D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9af09000 - 0x9af15fff libGL.dylib (16.4.2) <028B909B-DD19-388B-8113-1850DFAD3DCA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9af16000 - 0x9af51ffb libGLImage.dylib (16.4.2) <AE5E3974-656A-3F88-956E-F28192BA98C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9af52000 - 0x9b0caffb libGLProgrammability.dylib (16.4.2) <141160DE-8DB1-3A9C-95CA-0167D90B0A5A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9b0cb000 - 0x9b10dff7 libGLU.dylib (16.4.2) <9E1283AA-A7E0-37BA-BDEB-EE5256D677C7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9bab4000 - 0x9bac2fff com.apple.opengl (16.4.2 - 16.4.2) <40645026-52DC-3CFC-8308-EFA2FA79D5A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9bac3000 - 0x9bc50ffb GLEngine (16.4.2) <C8DAFD05-BBC9-3CE5-8940-114DA2E0147B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x9bc51000 - 0x9bc7bfff GLRendererFloat (16.4.2) <C50B4E84-163D-32E3-9643-290308B11918> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x9bd99000 - 0x9beeaffb com.apple.QTKit (7.7.3 - 3014) <9DB2668A-3F68-32F0-BF51-C7F791FEE8EE> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x9beeb000 - 0x9c136ff3 com.apple.imageKit (3.0 - 1040) <50E40E4F-2865-35B1-9FA3-A516921FBB8A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x9c137000 - 0x9c20affb com.apple.PDFKit (1.0 - 677.4) <1245217B-ADBE-3C64-B0B6-B8E795391421> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x9c20b000 - 0x9c71dff3 com.apple.QuartzComposer (5.1 - 364) <16A5F426-C732-30B0-B141-6AC3DAB4E86A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x9c71e000 - 0x9c73fff7 com.apple.quartzfilters (1.10.0 - 1.10.0) <C29EBE6F-03A5-3EAF-9155-6A224E671432> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x9c740000 - 0x9c825ff7 com.apple.QuickLookUIFramework (5.0 - 743.7) <57F8FF70-DD07-3808-A563-E96F8A56C0C2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x9c826000 - 0x9c826fff com.apple.quartzframework (1.5 - 21) <AFDC52CF-3DDF-3100-9D60-9DEFAE551CD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x9c827000 - 0x9ca5dff7 com.apple.QuartzCore (1.11 - 584.8.94) <FF9C6423-5220-3BCC-9D9A-1B90BF4BD95C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9ca5e000 - 0x9cab2ffb com.apple.QuickLookFramework (5.0 - 743.7) <EED11263-0CE3-3C40-953E-49F4E800FE74> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x9cab3000 - 0x9cd0bfeb com.apple.QuickTime (7.7.3 - 3014) <A38CF029-378C-3D67-9359-7DC15452B0E4> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9ceb9000 - 0x9cebafff com.apple.SafariServices.framework (13604 - 13604.4.7.1.6) <4D49864F-E3B4-32EE-AB9E-94917DB9D6E7> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x9cef6000 - 0x9d222ff3 com.apple.security (7.0 - 58286.31.2) <BF1FF3A9-0DA4-307D-84EE-B58EF2C98815> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9d223000 - 0x9d2aaff3 com.apple.securityfoundation (6.0 - 55185.30.4) <54362CD6-89D0-3328-9915-EC2F74748529> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9d2d6000 - 0x9d2dafff com.apple.xpc.ServiceManagement (1.0 - 1) <B09C1309-46A2-3081-B489-DCE549A8BA46> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x9d405000 - 0x9d475ff3 com.apple.SystemConfiguration (1.17 - 1.17) <318C287A-BB41-3F72-9095-9DFF0382CB77> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9d61f000 - 0x9d9acfff com.apple.VideoToolbox (1.0 - 2267.40.5) <F85F21A8-2F27-3903-BA62-DA7689F13C43> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x9d9ad000 - 0x9ed84ff7 com.apple.WebCore (13604 - 13604.4.7.1.6) <AC17FBCF-F35B-3CF5-B477-200F515EAEE6> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x9ed85000 - 0x9ef18ffb com.apple.WebKitLegacy (13604 - 13604.4.7.1.6) <E3D7EB10-BAE8-3A37-836C-14DC6FD030B7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x9ef19000 - 0x9f259ff7 com.apple.WebKit (13604 - 13604.4.7.1.6) <4A1C5262-7691-3E89-8DAC-E7626FA955E6> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9f26b000 - 0x9f302ff7 com.apple.APFS (1.0 - 1) <DC1D47F4-3D45-35F4-9D86-14B5946CEFA1> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x9f916000 - 0x9f941ff3 com.apple.framework.Apple80211 (13.0 - 1345) <6805C16F-21E5-3758-B77C-29870A7C6627> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x9f943000 - 0x9f94dfff com.apple.AppleFSCompression (96.30.2 - 1.0) <BEA6D735-9BF0-3146-9D45-32A3D9433602> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x9fa46000 - 0x9fa83ff3 com.apple.AppleJPEG (1.0 - 1) <E87393BB-6140-389C-BF53-36B3985A56D3> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x9faa2000 - 0x9faaafff com.apple.AppleSRP (5.0 - 1) <0C288A20-01A0-3C3C-8091-B8672B1F0CC6> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x9fb79000 - 0x9fb7cfff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <E0ACE999-E0DF-3227-BBF5-A04ECB3F6ECF> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x9fb7d000 - 0x9fbccffb com.apple.AppleVAFramework (5.0.39 - 5.0.39) <9EC588A6-D942-3B7C-88B4-59044051465A> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9fbd6000 - 0x9fbddfff com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <71FD5EA2-8D0B-3E21-94E4-6D5BD45005E7> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x9fbde000 - 0x9fc69ff7 com.apple.backup.framework (1.9.2 - 1.9.2) <19BE4138-61BB-33C8-80C5-0309B58CA16A> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9fdad000 - 0x9fdb6ffb com.apple.CommonAuth (4.0 - 2.0) <424B8D39-396A-3A78-84C1-5161B54A8F5B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9fe60000 - 0xa0178fef com.apple.CoreAUC (249.0.0 - 249.0.0) <77A27B7D-9EB4-39E0-9411-C9B7BDF0B1A8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0xa0179000 - 0xa01aafff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <EC1E91A7-CFD3-31E4-AE53-1D57BC7F852A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0xa021f000 - 0xa0227fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <20358A6F-D9AD-350F-B3D5-9D0988BAB017> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0xa0228000 - 0xa0238ff7 com.apple.CoreEmoji (1.0 - 69.3) <165A133F-DED4-3B24-A9BF-6EA6F3F7A152> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0xa0239000 - 0xa024fff7 com.apple.CoreMediaAuthoring (2.2 - 956) <7FB86A4B-5DC0-3267-AC40-3A99436D3FF1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0xa0303000 - 0xa039cfff com.apple.CorePDF (4.0 - 414) <4A8D560F-DBD3-37B7-B296-8123A03C81AF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0xa03c0000 - 0xa03f3ff7 com.apple.CoreServicesInternal (309.1 - 309.1) <1F73ECC7-F09F-3730-A290-472B89788807> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0xa03f4000 - 0xa048aff3 com.apple.CoreSymbolication (63075) <6223068D-FCD8-39C1-841D-834EF0AC6445> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0xa048b000 - 0xa05b1fe3 com.apple.coreui (2.1 - 492.2) <4B915963-6D32-3D89-B585-94094ACCF2E8> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0xa05b2000 - 0xa064dff3 com.apple.CoreUtils (5.3 - 530.57) <21D34447-A1FC-31C4-BE73-F61577ABB2F5> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0xa069e000 - 0xa06fbff3 com.apple.framework.CoreWiFi (13.0 - 1339) <5434C7AB-A80A-3DD3-B0F1-4EFEA912B16B> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0xa06fc000 - 0xa070cfff com.apple.CrashReporterSupport (10.13 - 1) <86DA5C7B-BA5E-3182-A787-28B6F580FF38> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0xa077a000 - 0xa0787fff com.apple.framework.DFRFoundation (1.0 - 191.1) <8EF25CE9-3ED3-3E20-A4A2-20743EA32265> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0xa07d3000 - 0xa0844fff com.apple.datadetectorscore (7.0 - 590.3) <2210A987-9208-3E20-8425-90180C57DE8C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0xa0845000 - 0xa0885ffb com.apple.DebugSymbols (141 - 141) <96BB879B-1A83-3622-BB02-1DDA5C4FD939> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0xa0886000 - 0xa09c5ff7 com.apple.desktopservices (1.12.2 - 1.12.2) <DC51DB71-E241-3715-8EEF-BA1166B551DD> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0xa09fb000 - 0xa0addff7 com.apple.DiskImagesFramework (480.30.2 - 480.30.2) <461AEBC8-5A57-3F1C-B845-E9EAB23490FF> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0xa0ade000 - 0xa0b54ffb com.apple.DiskManagement (11.2 - 1339) <BD5D176C-418C-3DB9-921E-C009402C692E> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0xa0b55000 - 0xa0b5ffff com.apple.DisplayServicesFW (3.1 - 380) <8940F718-0E7D-3805-80F9-C971E5DC9E30> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0xa0b95000 - 0xa0b97fff com.apple.EFILogin (2.0 - 2) <71E8BCE8-33B4-3F07-AD0E-847393177410> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0xa0c91000 - 0xa10c1ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <B2288C3D-E67F-3AAE-A652-E920CD19F267> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0xa2e6d000 - 0xa2e77fff libGPUSupportMercury.dylib (16.4.2) <AAAAF228-51D8-3425-9D15-4D34F41EA791> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0xa3108000 - 0xa312effb com.apple.GenerationalStorage (2.0 - 285) <430145ED-153B-3548-A6D4-6850752A9E6A> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0xa3a65000 - 0xa3ad8ff3 com.apple.Heimdal (4.0 - 2.0) <560C8A98-E261-39C9-9862-3340EC6ABC9C> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0xa3d8a000 - 0xa3d90fff com.apple.IOAccelerator (376.6 - 376.6) <4EFED596-8863-35F6-8EA3-CB11C5D9D157> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0xa3d91000 - 0xa3da9ffb com.apple.IOPresentment (1.0 - 32.1) <EBD4DB8D-03D3-3136-B431-969A2E5E1B91> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0xa3e06000 - 0xa3e25ff3 com.apple.IconServices (97.4 - 97.4) <3F593C33-E45D-3D77-B82C-F811428C4901> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0xa3e2e000 - 0xa3e3dfff com.apple.IntlPreferences (2.0 - 227) <A3DB41BE-6754-3A0D-8AE0-4177CFEF5413> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0xa3e4a000 - 0xa3e4efff JavaLaunching (42) <4CC877B4-CE5A-3DC7-AB58-45ABCB558F37> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0xa3e5d000 - 0xa3f51ff7 com.apple.LanguageModeling (1.0 - 159.3.1) <AA880B14-031D-33FB-9B48-0A8AAB7342C6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0xa3f52000 - 0xa3f93ff7 com.apple.Lexicon-framework (1.0 - 33.2) <13FAB8A2-507A-3AEA-A571-27BDDFD96B31> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0xa3f97000 - 0xa3f9dff3 com.apple.LinguisticData (1.0 - 238.3) <C47B3EB0-0463-3613-8A09-344F1639EE92> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0xa3fad000 - 0xa3fb2ff3 com.apple.LoginUICore (4.0 - 4.0) <811AE2E4-4487-36F5-94CF-334E4FFEB7AB> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0xa4107000 - 0xa413dffb com.apple.MediaKit (16 - 871) <3677518D-3972-38C9-8DBE-BDA83F5A19CF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0xa434b000 - 0xa4374ffb com.apple.MultitouchSupport.framework (1204.13 - 1204.13) <01BDF9A5-8C83-3611-A999-F43F9121A173> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0xa4493000 - 0xa449dfff com.apple.NetAuth (6.2 - 6.2) <52F67DC1-8C96-3944-8E54-C02DD51FD9FC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0xa4545000 - 0xa4581fff com.apple.PerformanceAnalysis (1.183.1 - 183.1) <FFE20C99-7FE3-3722-AD6C-C6ECF2C2D103> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0xa45da000 - 0xa461fffb com.apple.ProtectedCloudStorage (1.0 - 1) <ED5DB3B0-4CCE-3698-93BE-CAC3AD7F4F88> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0xa4620000 - 0xa463cff7 com.apple.ProtocolBuffer (1 - 259) <BBB59E09-0B06-3262-9C81-C126DF34667C> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0xa4713000 - 0xa4727fff com.apple.QuickLookThumbnailing (1.0 - 1) <5DB01EC5-14D5-3E51-9FF1-E034E62354D3> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0xa4728000 - 0xa474afff com.apple.RemoteViewServices (2.0 - 125) <5720B413-E761-3368-964F-7FEAC5535669> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0xa4800000 - 0xa482dffb com.apple.Sharing (972.6 - 972.6) <94426AD7-4302-3870-9D7B-F5ED6900BBCE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0xa484c000 - 0xa484dfff com.apple.performance.SignpostNotification (1.0 - 1) <9AD547F6-ED5A-3AC8-BF4C-811C69801CDF> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0xa484e000 - 0xa48d3ffb com.apple.SkyLight (1.600.0 - 312.23.4) <A78C5D21-4D37-358A-8C18-EADA8084BFCA> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0xa4903000 - 0xa4910ffb com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <BACA23B0-AF15-3B7F-8933-15DDEE48318B> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0xa4bdd000 - 0xa4c5eff3 com.apple.Symbolication (9.0 - 63079.1) <97DA4973-352E-3CBA-9B4A-BC22C3AFD597> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0xa4c7a000 - 0xa4ca5fff com.apple.framework.SystemAdministration (1.0 - 1.0) <46AB55C6-5CAF-38BA-9EA9-1640C7D060D8> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0xa4cb1000 - 0xa4cb8fff com.apple.TCC (1.0 - 1) <4B76752A-36A0-3175-87C7-CB42E33CCB5A> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0xa4cb9000 - 0xa4cd0ff3 com.apple.TextureIO (3.7 - 3.7) <B46FD025-BC89-3A84-B2E1-5E744E2F9C33> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0xa4cf8000 - 0xa4cf9fff com.apple.TrustEvaluationAgent (2.0 - 31) <185BD5A9-5A2D-3317-B7FE-9B67F14C4D2C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0xa4cfa000 - 0xa4e84fff com.apple.UIFoundation (1.0 - 546.1.1) <DB0AE684-9FD6-3EFC-BAA0-BD6F5D27D24C> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0xa521b000 - 0xa52dffff com.apple.ViewBridge (343.2 - 343.2) <E35AE410-455E-33FC-AD7B-C067EA0850CE> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0xa5452000 - 0xa5454fff com.apple.loginsupport (1.0 - 1) <086FAE1B-87E2-324A-AE76-E6EC0B5F1517> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0xa5455000 - 0xa5466fff com.apple.login (3.0 - 3.0) <A77D7047-2994-3696-8E3D-9922F2659A26> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0xa54a6000 - 0xa54befff com.apple.vmutils (4.2.1 - 110) <E0F135E6-103C-34C2-B4F3-C986B716A665> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
0xa54df000 - 0xa5512ff7 libclosured.dylib (519.2.2) <E0E52FC3-51A9-385F-953D-23A7CA8D5666> /usr/lib/closure/libclosured.dylib
0xa5562000 - 0xa5599ff3 libCRFSuite.dylib (41) <7F584902-74F1-3362-935D-95F5E735F5E7> /usr/lib/libCRFSuite.dylib
0xa559a000 - 0xa55a4ffb libChineseTokenizer.dylib (28) <1FF5A32D-E012-3E76-B738-FAC26AD2A39B> /usr/lib/libChineseTokenizer.dylib
0xa55a5000 - 0xa563fffb libCoreStorage.dylib (546) <CAD02BFA-05C3-3AA4-853F-956DF4CD93B3> /usr/lib/libCoreStorage.dylib
0xa5640000 - 0xa5641fff libDiagnosticMessagesClient.dylib (104) <6829B180-2556-3A7E-A2E6-BD4859DF30A7> /usr/lib/libDiagnosticMessagesClient.dylib
0xa5673000 - 0xa585dff7 libFosl_dynamic.dylib (17.7) <DBE4D720-8A46-3879-AD2D-F9A8CE3E7476> /usr/lib/libFosl_dynamic.dylib
0xa5865000 - 0xa5865fff libOpenScriptingUtil.dylib (174) <B7CEDC30-2D17-3896-9EFC-64DB3D11DF00> /usr/lib/libOpenScriptingUtil.dylib
0xa58af000 - 0xa58b3fff libScreenReader.dylib (562.13) <F1DB780F-86F0-32D9-B2BA-73AF91F59393> /usr/lib/libScreenReader.dylib
0xa58b4000 - 0xa58b5fff libSystem.B.dylib (1252) <334D9E12-F209-3C28-875B-77E0FD623AD7> /usr/lib/libSystem.B.dylib
0xa58c4000 - 0xa58d9ff7 libapple_nghttp2.dylib (1.24) <480C0C04-2533-3D44-8232-006B6CBA7758> /usr/lib/libapple_nghttp2.dylib
0xa58da000 - 0xa5905fff libarchive.2.dylib (54) <D55C5F86-251D-3C33-A617-0C623D4F512E> /usr/lib/libarchive.2.dylib
0xa5906000 - 0xa5a55ffb libate.dylib (1.13.1) <E109CCBF-357D-3C87-9CE5-D53AE03609A2> /usr/lib/libate.dylib
0xa5a59000 - 0xa5a59ff3 libauto.dylib (187) <CE2A78CC-670F-3E07-9539-822DCD2F6084> /usr/lib/libauto.dylib
0xa5a5a000 - 0xa5a6afff libbsm.0.dylib (39) <067E9003-0673-32A3-9B40-492323182C5C> /usr/lib/libbsm.0.dylib
0xa5a6b000 - 0xa5a77ff7 libbz2.1.0.dylib (38) <77C24A36-BE84-3702-A786-935C597A0A86> /usr/lib/libbz2.1.0.dylib
0xa5a78000 - 0xa5ad1ffb libc++.1.dylib (400.9) <AD612EEF-6CE3-315D-82C2-58248BE13431> /usr/lib/libc++.1.dylib
0xa5ad2000 - 0xa5af3fff libc++abi.dylib (400.7) <41323E53-C7EA-3E9A-BD30-38E82399F843> /usr/lib/libc++abi.dylib
0xa5af5000 - 0xa5b06ff7 libcmph.dylib (6) <EC7664F1-B5A1-37F4-B7DC-F6AC10587E35> /usr/lib/libcmph.dylib
0xa5b07000 - 0xa5b1aff7 libcompression.dylib (47) <F80DDFC1-F96A-3BAD-967D-C1E24253273A> /usr/lib/libcompression.dylib
0xa5b1b000 - 0xa5b32ffb libcoretls.dylib (155) <F66FAEBC-4B6E-31E0-ACA8-C8ACBC7689DD> /usr/lib/libcoretls.dylib
0xa5b33000 - 0xa5b34fff libcoretls_cfhelpers.dylib (155) <8B8ABC2C-F251-3C80-9747-88C05A2CBE64> /usr/lib/libcoretls_cfhelpers.dylib
0xa5bd6000 - 0xa5cb4fff libcrypto.0.9.8.dylib (76.30.1) <AE86D3F1-E7D3-32B5-983B-D436AAA191A2> /usr/lib/libcrypto.0.9.8.dylib
0xa5cb5000 - 0xa5e5cfff libcrypto.35.dylib (22) <EE1BA2F7-F2F4-387B-8866-5B4A7023D29F> /usr/lib/libcrypto.35.dylib
0xa6010000 - 0xa601bff7 libcsfde.dylib (546) <F4322188-F1FF-31A3-8245-C9D62F795D4A> /usr/lib/libcsfde.dylib
0xa601c000 - 0xa6073fff libcups.2.dylib (462.1) <0180AE97-A19F-3D49-9838-06995E73F572> /usr/lib/libcups.2.dylib
0xa609f000 - 0xa60f1fff libcurl.4.dylib (105.30.2) <9BE04599-41D6-36F3-B46F-9FEA218E70F0> /usr/lib/libcurl.4.dylib
0xa6189000 - 0xa6189fff libenergytrace.dylib (16) <34FC43C7-D9B6-3C01-8B65-E49059D31279> /usr/lib/libenergytrace.dylib
0xa61bd000 - 0xa61c1fff libheimdal-asn1.dylib (520.30.1) <DEA7E913-118F-333E-BE08-5B4F19B33B9A> /usr/lib/libheimdal-asn1.dylib
0xa61ed000 - 0xa62ddff3 libiconv.2.dylib (51) <FE6D05A5-18DB-3FD8-A52F-B7BADB232C78> /usr/lib/libiconv.2.dylib
0xa62de000 - 0xa6500ff7 libicucore.A.dylib (59152.0.1) <1048B064-30DD-30CA-BB7D-41F0F3159DA9> /usr/lib/libicucore.A.dylib
0xa6548000 - 0xa6549fff liblangid.dylib (128) <120FE992-47E4-3A73-A039-1B401F5696DC> /usr/lib/liblangid.dylib
0xa654a000 - 0xa6562ff7 liblzma.5.dylib (10) <8A5C9679-430A-3A19-AF68-9D21BAC442C7> /usr/lib/liblzma.5.dylib
0xa6563000 - 0xa6578fff libmarisa.dylib (9) <805453EE-B829-3DA5-8DF3-5132D03D5B74> /usr/lib/libmarisa.dylib
0xa662d000 - 0xa684afff libmecabra.dylib (779.7.6) <08A39874-BF80-3A92-A088-C494C518218A> /usr/lib/libmecabra.dylib
0xa6a11000 - 0xa6ae5fff libnetwork.dylib (1229.30.11) <86111B18-D03B-3F4F-ACD8-9D9C510058F3> /usr/lib/libnetwork.dylib
0xa6ae6000 - 0xa6ec60fb libobjc.A.dylib (723) <4AF346B8-C1A8-3199-B1BB-ADEDD64D5C1A> /usr/lib/libobjc.A.dylib
0xa6ec7000 - 0xa6ec7fff libodfde.dylib (24) <C546D8F4-92DA-35F2-B166-10DCC67EB4CE> /usr/lib/libodfde.dylib
0xa6eca000 - 0xa6ecdfff libpam.2.dylib (22) <7106F43C-84DD-3F26-905A-B52780AFEB3E> /usr/lib/libpam.2.dylib
0xa6ed0000 - 0xa6f01fff libpcap.A.dylib (79.20.1) <154889CF-5F83-3012-953E-0FC8FEE50FF8> /usr/lib/libpcap.A.dylib
0xa6f3f000 - 0xa6f5affb libresolv.9.dylib (65) <65A43F5B-CF88-3948-AE5C-D7CA02D814A1> /usr/lib/libresolv.9.dylib
0xa6f93000 - 0xa6fa4ff7 libsasl2.2.dylib (211) <31BFF961-171E-331A-BA3A-F79E69C6E63B> /usr/lib/libsasl2.2.dylib
0xa6fa5000 - 0xa712fff7 libsqlite3.dylib (274.5) <B09AF63F-4F1A-3481-9B61-6EBB64D12EB9> /usr/lib/libsqlite3.dylib
0xa7187000 - 0xa71e5ff7 libssl.35.dylib (22) <F96B7886-D3AA-39F3-A23D-3C2822678E13> /usr/lib/libssl.35.dylib
0xa723f000 - 0xa728fffb libstdc++.6.0.9.dylib (104.1) <74744B76-524A-3052-A4CF-3C47446A32C0> /usr/lib/libstdc++.6.0.9.dylib
0xa72d3000 - 0xa730dffb libusrtcp.dylib (1229.30.11) <39D76669-A48B-3BAC-8F45-1D6CA87E9B4B> /usr/lib/libusrtcp.dylib
0xa730e000 - 0xa7311ff7 libutil.dylib (51.20.1) <86BD9675-16A2-345D-9B8D-E8A3397F2365> /usr/lib/libutil.dylib
0xa7312000 - 0xa7320ff7 libxar.1.dylib (400) <4B664A7E-EC05-34AD-ACC6-C879B69DBA7C> /usr/lib/libxar.1.dylib
0xa7321000 - 0xa73ffff7 libxml2.2.dylib (31.7) <3E1F9E3D-6C44-3437-AB2B-E5ACE1927F81> /usr/lib/libxml2.2.dylib
0xa7400000 - 0xa7428ff3 libxslt.1.dylib (15.10) <1A3DC7B8-7C92-3D73-BF82-D60E64BC3DF0> /usr/lib/libxslt.1.dylib
0xa7429000 - 0xa7438ff7 libz.1.dylib (70) <588F445F-0065-3D77-8002-BA9411DA1D70> /usr/lib/libz.1.dylib
0xa7472000 - 0xa7476fff libcache.dylib (80) <5D011637-CADA-38A1-A695-CE049657FD9D> /usr/lib/system/libcache.dylib
0xa7477000 - 0xa7481fff libcommonCrypto.dylib (60118.30.2) <38B2C15B-D27F-3106-A337-F72F29844825> /usr/lib/system/libcommonCrypto.dylib
0xa7482000 - 0xa7487fff libcompiler_rt.dylib (62) <FA07FEE2-CEFE-3CC0-A82F-E601AA2CCB36> /usr/lib/system/libcompiler_rt.dylib
0xa7488000 - 0xa7491ff3 libcopyfile.dylib (146.30.2) <F3A05833-AD1C-3E3A-8100-847297C882FC> /usr/lib/system/libcopyfile.dylib
0xa7492000 - 0xa74faff7 libcorecrypto.dylib (562.30.10) <0D8A61F8-2D7D-31F1-93AB-0597D80CCA85> /usr/lib/system/libcorecrypto.dylib
0xa7565000 - 0xa759afff libdispatch.dylib (913.30.4) <D1812254-DE85-3A5B-AD7B-5CE23BB8C9E1> /usr/lib/system/libdispatch.dylib
0xa759b000 - 0xa75b8fff libdyld.dylib (519.2.2) <A79B6A65-DDAA-31C5-B66B-95FB343125BE> /usr/lib/system/libdyld.dylib
0xa75b9000 - 0xa75b9fff libkeymgr.dylib (28) <C448ACFC-DD1B-3F08-B4C3-D2B69D1210B1> /usr/lib/system/libkeymgr.dylib
0xa75ba000 - 0xa75c6ff7 libkxld.dylib (4570.31.3) <17609EC4-47F0-39C9-8F90-5F07FF52F217> /usr/lib/system/libkxld.dylib
0xa75c7000 - 0xa75c7fff liblaunch.dylib (1205.30.29) <0F3BF17D-FCFA-3692-8A6E-FDE5C58DB3B7> /usr/lib/system/liblaunch.dylib
0xa75c8000 - 0xa75cdfff libmacho.dylib (900.0.1) <F1F0BC1D-A2D9-39F9-9A11-263F8392CB3B> /usr/lib/system/libmacho.dylib
0xa75ce000 - 0xa75d0fff libquarantine.dylib (86) <68DE2EB2-7911-304D-89D6-1517CA689001> /usr/lib/system/libquarantine.dylib
0xa75d1000 - 0xa75d2fff libremovefile.dylib (45) <BEF76B44-53EA-3970-AB50-2296DC7F097F> /usr/lib/system/libremovefile.dylib
0xa75d3000 - 0xa75eaff7 libsystem_asl.dylib (356.1.1) <F96973B5-C36B-3037-8AEC-3BF7147D79E2> /usr/lib/system/libsystem_asl.dylib
0xa75eb000 - 0xa75ebfff libsystem_blocks.dylib (67) <32CE9BB7-E047-3568-981E-4EA94D3DCBB5> /usr/lib/system/libsystem_blocks.dylib
0xa75ec000 - 0xa7678fff libsystem_c.dylib (1244.30.3) <8BCBF89D-5CE7-3950-884A-86E37DBF2660> /usr/lib/system/libsystem_c.dylib
0xa7679000 - 0xa767cfff libsystem_configuration.dylib (963.30.1) <0F30DC5A-F39F-32C9-BA01-05AAC699713A> /usr/lib/system/libsystem_configuration.dylib
0xa767d000 - 0xa7680fff libsystem_coreservices.dylib (51) <C3D75760-EED5-3C5C-8245-FBD3D9FD60FD> /usr/lib/system/libsystem_coreservices.dylib
0xa7681000 - 0xa7682fff libsystem_darwin.dylib (1244.30.3) <83B1D06A-9FA5-3F0B-A223-0659F4248E51> /usr/lib/system/libsystem_darwin.dylib
0xa7683000 - 0xa7689ff3 libsystem_dnssd.dylib (878.30.4) <3C4400C4-C531-3653-872B-E22892D7B29A> /usr/lib/system/libsystem_dnssd.dylib
0xa768a000 - 0xa76d9ffb libsystem_info.dylib (517.30.1) <A8E62937-32F9-373C-8150-B6B442227226> /usr/lib/system/libsystem_info.dylib
0xa76da000 - 0xa76fdff7 libsystem_kernel.dylib (4570.31.3) <FBC48404-D7AD-31FA-BDE2-5B6A1D8EFC7A> /usr/lib/system/libsystem_kernel.dylib
0xa76fe000 - 0xa774dfdb libsystem_m.dylib (3146) <DBE0AACD-3665-3EEB-BADA-A435E591C54B> /usr/lib/system/libsystem_m.dylib
0xa774e000 - 0xa7768fff libsystem_malloc.dylib (140.1.1) <DFE0206A-865E-359D-B2F9-FE9DBB3B5B32> /usr/lib/system/libsystem_malloc.dylib
0xa7769000 - 0xa7806ffb libsystem_network.dylib (1229.30.11) <84B584A7-7583-31E7-8A39-64B4A5AD643B> /usr/lib/system/libsystem_network.dylib
0xa7807000 - 0xa7811fff libsystem_networkextension.dylib (767.30.7) <E88F13BB-D751-3FF9-A136-2C1158129BAA> /usr/lib/system/libsystem_networkextension.dylib
0xa7812000 - 0xa781aff3 libsystem_notify.dylib (172) <63E3CF8C-4F15-3D45-84A6-1218352031E9> /usr/lib/system/libsystem_notify.dylib
0xa781b000 - 0xa7821ffb libsystem_platform.dylib (161.20.1) <82782E0E-7264-3CB4-AE69-571EDB5E7A24> /usr/lib/system/libsystem_platform.dylib
0xa7822000 - 0xa782cff3 libsystem_pthread.dylib (301.30.1) <7409C1E5-F3BA-3AB3-ADC1-9DCD356C6C13> /usr/lib/system/libsystem_pthread.dylib
0xa782d000 - 0xa7830ff3 libsystem_sandbox.dylib (765.30.4) <8226258C-47FE-30A9-AE91-C13DE173E368> /usr/lib/system/libsystem_sandbox.dylib
0xa7831000 - 0xa7833fff libsystem_secinit.dylib (30) <CE2C90DE-27A4-3546-8A05-96B743861DD0> /usr/lib/system/libsystem_secinit.dylib
0xa7834000 - 0xa783cff7 libsystem_symptoms.dylib (820.30.7) <0283BDB3-16A2-371E-A25C-A26F076C24A5> /usr/lib/system/libsystem_symptoms.dylib
0xa783d000 - 0xa784ffff libsystem_trace.dylib (829.30.14) <79446DE0-89F6-3979-B14C-7B463AD70351> /usr/lib/system/libsystem_trace.dylib
0xa7851000 - 0xa7857fff libunwind.dylib (35.3) <642BBA03-0411-3FAA-A421-D79A9156AB1C> /usr/lib/system/libunwind.dylib
0xa7858000 - 0xa7880ff7 libxpc.dylib (1205.30.29) <CD44097B-4B65-3F75-AB7F-52228229FFB5> /usr/lib/system/libxpc.dylib
0xb0000000 - 0xb001afe3 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <928D8FAD-DEE7-F1D0-FE17-FA7F4E4C1E48> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xba900000 - 0xba91cfff libJapaneseConverter.dylib (70) <EB2076FC-9416-3130-A0B0-0DF885D1FFDC> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fff libKoreanConverter.dylib (70) <11280CD6-08A2-3300-8BDB-8D04B67B3C79> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 16 | |
thread_create: 0 | |
thread_set_state: 0 |
Calls made by this process:
task_for_pid: 0 | |
Calls made by all processes on this machine:
task_for_pid: 656888 | |
VM Region Summary:
ReadOnly portion of Libraries: Total=518.5M resident=0K(0%) swapped_out_or_unallocated=518.5M(100%)
Writable regions: Total=682.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=682.4M(100%)
VIRTUAL REGION | |||
REGION TYPE | SIZE | COUNT (non-coalesced) | |
ATS (font support) | 33.3M | 12 | |
Accelerate framework | 256K | 3 | |
Activity Tracing | 256K | 2 | |
CG backing stores | 43.3M | 15 | |
CoreGraphics | 8K | 2 | |
CoreImage | 8K | 3 | |
CoreUI image data | 852K | 11 | |
CoreUI image file | 180K | 4 | |
Foundation | 16K | 2 | |
Image IO | 16K | 2 | |
Java | 225.2M | 8 | |
Java (reserved) | 9908K | 5 | reserved VM address space (unallocated) |
Kernel Alloc Once | 8K | 2 | |
MALLOC | 290.5M | 94 | |
MALLOC guard page | 64K | 17 | |
MALLOC_LARGE (reserved) | 1024K | 2 | reserved VM address space (unallocated) |
Mach message (reserved) | 8K | 2 | reserved VM address space (unallocated) |
Memory Tag 240 | 31.0M | 121 | |
Memory Tag 240 (reserved) | 4K | 2 | reserved VM address space (unallocated) |
Memory Tag 242 | 12K | 2 | |
Memory Tag 249 | 156K | 3 | |
OpenGL GLSL | 128K | 3 | |
Stack | 45.5M | 52 | |
Stack Guard | 56.3M | 64 | |
VM_ALLOCATE | 4288K | 188 | |
__DATA | 21.6M | 394 | |
__FONT_DATA | 4K | 2 | |
__GLSLBUILTINS | 2588K | 2 | |
__IMPORT | 32K | 7 | |
__LINKEDIT | 132.9M | 91 | |
__OBJC | 4864K | 139 | |
__TEXT | 385.6M | 368 | |
__UNICODE | 560K | 2 | |
mapped file | 2.4G | 658 | |
shared memory | 768K | 27 | |
TOTAL | 3.7G | 2276 | |
TOTAL, minus reserved VM space | 3.6G | 2276 |
Model: Macmini6,2, BootROM MM61.010B.B00, 4 processors, Intel Core i7, 2.3 GHz, 16 GB, SMC 2.8f0
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x01BA, 0x202020202020202020202020202020202020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x01BA, 0x202020202020202020202020202020202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x10E), Broadcom BCM43xx 1.0 (7.21.190.16.1a2)
Bluetooth: Version 6.0.2f2, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS541010A9E662, 1 TB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: Hub
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Cintiq 24HD HUB
USB Device: Cintiq 24HD Tablet
USB Device: USB 3.0 Bus
USB Device: Yeti Stereo Microphone
USB Device: USB Receiver
USB Device: Apple USB SuperDrive
Thunderbolt Bus: Mac mini, Apple Inc., 23.4
