A simple question but I cannot find an answer for. I have a photographers username/portfolio name from a previous image I viewed a while ago. How on earth do I find his portfolio from main adobe stock search. I type the portfolio name and it does not work work, I don't have the image file number as I know that works. But searching the photographer is proving futile for me. There must be something I am missing.
Hi Kiriako,
Unfortunately, the feature for searching for the portfolio of a photographer from the main Adobe Stock search is not available as of now. However, if you remember the image ID or the keywords of a particular image you have viewed, then you can click on the image and below you will get the photographer's/contributor's name, upon clicking on that you can view his portfolio.
Although I doubt if this helps and will pass on this as a feature request to the Adobe Stock team.
Twarita
Hy,
You can try it on Google. - Search for "AdobeStock, USERNAME"
Mario
I get login/password results when I search google. Thanks for response though.
Hi Kiriako,
Twarita
kiriktm500 schrieb
... I have a photographers username/portfolio name...
What is the username?
I found the portfolio I was looking for and it turns out one of the images was in my library belonged to it. But it would be nice to be able search via portfolio. To be able to give an unsubscribed Adobe client a portfolio name for them to choose a graphic from. I'll just have to use image file numbers as portfolio references.
Cheers.
