There is a lengthy post about some performance issues with 2017, that article seems to talk about myriad issues though the fixes are peppered throughout there and I don't have time to try every single fix inside it. Some of those fixes seem to look at type, admin profiles, library panels, CEPhtml issues, syncing, gpu issues and overclocking. To try and really diagnose my issue I have tried to consolidate my system info and symptoms. I expect to get linked to the article to search for help myself and figure it out alone so that is why I have tried to exhaust my current system and what I have troubleshooted already.
The interface is extremely sluggish during file opens in particular - 5 to 15 seconds take place while nothing happens
The interface will stick and jitter randomly and freeze the mouse, I can alt tab to another app and it's back to normal.
When this is happening, it happens from app start up and continues through the entirety of the session with photoshop.
I work with multiple 16-bit and 32-bit images open often and always.
I recently reduced my performance settings to 50% of ram and 41% of gpu ram in 3d settings.
I also turned off CC file syncing as I don't use it and really don't need it as a service.
My machine is water-cooled, and I work in a very hot environment, AC is employed but often the temp in my office can hover around 70F to 80F.
I have the Nvidia panel tuned to use the 4x980tis towards photoshop.
Here are my win 10 performance stats while opening files but no slowdown occured ~ right now i am not able to replicate the slowdown ( i will post that ss when it happens again - hopefully today).
Here is a system info dump as well.
I have a very high-end machine that is overclocked fro 2.99ghz to 3.99ghz. One odd line i see is " Free memory: 2mb". system has 128gb installed and has almost 100mb free.
Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967 x64
Number of Launches: 107
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:15, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 10
Logical processor count: 20
Processor speed: 2999 MHz
Built-in memory: 130995 MB
Free memory: 2 MB
Memory available to Photoshop: 119560 MB
Memory used by Photoshop: 85 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Disabled.
Image tile size: 1028K
Image cache levels: 6
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1440, right=2560
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=4
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=6144
glgpu[0].GLName="NVIDIA GeForce GTX 980 Ti"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="22.21.13.8528"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GTX 980 Ti/PCIe/SSE2"
glgpu[0].GLRendererID=6088
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9ab613610b40aa98\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9ab613610b40aa98\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9ab613610b40aa98\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9ab613610b40aa98\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9ab613610b40aa98\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9ab613610b40aa98\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9ab613610b40aa98\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9ab613610b40aa98\nvldumd.dll"
glgpu[0].GLDriverDate="20170809000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=6144
clgpu[0].CLName="GeForce GTX 980 Ti"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="385.28"
clgpu[0].CLBandwidth=2.42917e+11
clgpu[0].CLCompute=2728.16
clgpu[1].CLPlatformVersion="1.2"
clgpu[1].CLDeviceVersion="1.2 CUDA"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=6144
clgpu[1].CLName="GeForce GTX 980 Ti"
clgpu[1].CLVendor="NVIDIA Corporation"
clgpu[1].CLVendorID=4318
clgpu[1].CLDriverVersion="385.28"
clgpu[1].CLBandwidth=2.42928e+11
clgpu[1].CLCompute=2715.92
clgpu[2].CLPlatformVersion="1.2"
clgpu[2].CLDeviceVersion="1.2 CUDA"
clgpu[2].IsIntegratedCLGPU=0
clgpu[2].CLMemoryMB=6144
clgpu[2].CLName="GeForce GTX 980 Ti"
clgpu[2].CLVendor="NVIDIA Corporation"
clgpu[2].CLVendorID=4318
clgpu[2].CLDriverVersion="385.28"
clgpu[2].CLBandwidth=2.42754e+11
clgpu[2].CLCompute=2740.66
clgpu[3].CLPlatformVersion="1.2"
clgpu[3].CLDeviceVersion="1.2 CUDA"
clgpu[3].IsIntegratedCLGPU=0
clgpu[3].CLMemoryMB=6144
clgpu[3].CLName="GeForce GTX 980 Ti"
clgpu[3].CLVendor="NVIDIA Corporation"
clgpu[3].CLVendorID=4318
clgpu[3].CLDriverVersion="385.28"
clgpu[3].CLBandwidth=2.42883e+11
clgpu[3].CLCompute=2714.35
License Type: Subscription
Serial number: 90970080495740409575
GUIDBucket:
bucket: 194
test: DocumentPanel
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\OUTERG~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
E:\, 16.3T, 15.2T free
C:\, 931.0G, 426.8G free
D:\, 931.3G, 437.0G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/01/26-01:10:02 79.579975 79.579975
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.579975 79.579975
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/01/26-01:10:02 79.579975 79.579975
ahclient.dll AdobeHelp Dynamic Link Library 2.2.0.1
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7) 1.000000
ARE.dll ARE 2017/01/26-01:10:02 79.579975 79.579975
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/01/26-01:10:02 79.579975 79.579975
BIBUtils.dll BIBUtils 2017/01/26-01:10:02 79.579975 79.579975
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/01/26-01:10:02 79.579975 79.579975
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/12/13-13:10:33 80.1089815 80.1089815
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.11
JP2KLib.dll JP2KLib 2017/04/05-14:24:38 79.266006 79.266006
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.1.1
Plugin.dll Adobe Photoshop CC 2017 18.1.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.1.1
PSViews.dll Adobe Photoshop CC 2017 18.1.1
SCCore.dll ScCore 2016/12/13-13:10:33 80.1089815 80.1089815
SVGRE.dll SVGRE 79.579975 79.579975
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Accented Edges 18.1.1 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 18.1.1 - from the file “Filter Gallery.8bf”
Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average.8bf”
Bas Relief 18.1.1 - from the file “Filter Gallery.8bf”
BMP 18.1.1 - from the file “Standard MultiPlugin.8bf”
Camera Raw 9.12 - from the file “Camera Raw.8bi”
Camera Raw Filter 9.12 - from the file “Camera Raw.8bi”
Chalk && Charcoal 18.1.1 - from the file “Filter Gallery.8bf”
Chrome 18.1.1 - from the file “Filter Gallery.8bf”
Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon.8bi”
Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Color Halftone 18.1.1 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 18.1.1 - from the file “Filter Gallery.8bf”
CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 18.1.1 - from the file “Filter Gallery.8bf”
Craquelure 18.1.1 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin.8bf”
Crosshatch 18.1.1 - from the file “Filter Gallery.8bf”
Crystallize 18.1.1 - from the file “Standard MultiPlugin.8bf”
Cutout 18.1.1 - from the file “Filter Gallery.8bf”
Dark Strokes 18.1.1 - from the file “Filter Gallery.8bf”
De-Interlace 18.1.1 - from the file “Standard MultiPlugin.8bf”
Dicom 18.1.1 - from the file “Dicom.8bi”
Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
Diffuse Glow 18.1.1 - from the file “Filter Gallery.8bf”
Displace 18.1.1 - from the file “Standard MultiPlugin.8bf”
Dry Brush 18.1.1 - from the file “Filter Gallery.8bf”
Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire.8ba”
Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
Extrude 18.1.1 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore.8bx”
Fibers 18.1.1 - from the file “Standard MultiPlugin.8bf”
Film Grain 18.1.1 - from the file “Filter Gallery.8bf”
Filter Gallery 18.1.1 - from the file “Filter Gallery.8bf”
Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Fresco 18.1.1 - from the file “Filter Gallery.8bf”
Glass 18.1.1 - from the file “Filter Gallery.8bf”
Glowing Edges 18.1.1 - from the file “Filter Gallery.8bf”
Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Graphic Pen 18.1.1 - from the file “Filter Gallery.8bf”
Halftone Pattern 18.1.1 - from the file “Filter Gallery.8bf”
HDRMergeUI 18.1.1 - from the file “HDRMergeUI.8bf”
HSB/HSL 18.1.1 - from the file “Standard MultiPlugin.8bf”
IFF Format 18.1.1 - from the file “Standard MultiPlugin.8bf”
IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Ink Outlines 18.1.1 - from the file “Filter Gallery.8bf”
JPEG 2000 18.1.1 - from the file “JPEG2000.8bi”
Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Lens Blur 18.1.1 - from the file “Lens Blur.8bf”
Lens Correction 18.1.1 - from the file “Lens Correction.8bf”
Lens Flare 18.1.1 - from the file “Standard MultiPlugin.8bf”
Liquify 18.1.1 - from the file “Liquify.8bf”
Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Mezzotint 18.1.1 - from the file “Standard MultiPlugin.8bf”
Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore.8bx”
Mosaic Tiles 18.1.1 - from the file “Filter Gallery.8bf”
Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support.8bx”
Neon Glow 18.1.1 - from the file “Filter Gallery.8bf”
Note Paper 18.1.1 - from the file “Filter Gallery.8bf”
NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors.8bf”
Ocean Ripple 18.1.1 - from the file “Filter Gallery.8bf”
OpenEXR 18.1.1 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 18.1.1 - from the file “Filter Gallery.8bf”
Palette Knife 18.1.1 - from the file “Filter Gallery.8bf”
Patchwork 18.1.1 - from the file “Filter Gallery.8bf”
Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin.8bf”
PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX.8bi”
Photocopy 18.1.1 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 14.0 - from the file “PSDX.8bi”
Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
Pinch 18.1.1 - from the file “Standard MultiPlugin.8bf”
Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar.8bi”
Plaster 18.1.1 - from the file “Filter Gallery.8bf”
Plastic Wrap 18.1.1 - from the file “Filter Gallery.8bf”
PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
PNG 18.1.1 - from the file “Standard MultiPlugin.8bf”
Pointillize 18.1.1 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM.8bi”
Poster Edges 18.1.1 - from the file “Filter Gallery.8bf”
PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Radial Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance.8bi”
Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
Reticulation 18.1.1 - from the file “Filter Gallery.8bf”
Ripple 18.1.1 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 18.1.1 - from the file “Filter Gallery.8bf”
Save for Web 18.1.1 - from the file “Save for Web.8be”
ScriptingSupport 18.1.1 - from the file “ScriptingSupport.8li”
Shake Reduction 18.1.1 - from the file “Shake Reduction.8bf”
Shear 18.1.1 - from the file “Standard MultiPlugin.8bf”
Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Smart Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 18.1.1 - from the file “Filter Gallery.8bf”
Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize.8bf”
Spaces 18.1.1 - from the file “Spaces.8li”
Spatter 18.1.1 - from the file “Filter Gallery.8bf”
Spherize 18.1.1 - from the file “Standard MultiPlugin.8bf”
Sponge 18.1.1 - from the file “Filter Gallery.8bf”
Sprayed Strokes 18.1.1 - from the file “Filter Gallery.8bf”
Stained Glass 18.1.1 - from the file “Filter Gallery.8bf”
Stamp 18.1.1 - from the file “Filter Gallery.8bf”
Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Sumi-e 18.1.1 - from the file “Filter Gallery.8bf”
Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Targa 18.1.1 - from the file “Standard MultiPlugin.8bf”
Texturizer 18.1.1 - from the file “Filter Gallery.8bf”
Tiles 18.1.1 - from the file “Standard MultiPlugin.8bf”
Torn Edges 18.1.1 - from the file “Filter Gallery.8bf”
Twirl 18.1.1 - from the file “Standard MultiPlugin.8bf”
U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Underpainting 18.1.1 - from the file “Filter Gallery.8bf”
Vanishing Point 18.1.1 - from the file “VanishingPoint.8bf”
Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Water Paper 18.1.1 - from the file “Filter Gallery.8bf”
Watercolor 18.1.1 - from the file “Filter Gallery.8bf”
Wave 18.1.1 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport.8li”
Wind 18.1.1 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP.8bi”
ZigZag 18.1.1 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins:
GoZPlugIn NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\GoZ\GoZPlugIn64.8li”
Load OctaneRender Compositing Project 14.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Automate\OctaneCompositingFormat.8bi”
OTOY EXR 14.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Format\OtoyEXRFormat.8bi”
Setup OctaneRender Render Layers 14.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Automate\OctaneLayersSetup.8ba”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
Recent Files 1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
com.adobe.inapp.purchase 2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
New Document 1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
Libraries 2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
Start 1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Device Preview 1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
And about 2 hours into my workload today It has returned to the extremely slow and sluggish responsiveness.
I have opened about 25 16bit images that are 121mb each when open as .PSD's
Here are performance ss of when I try to open a file - the program slows down to a halt and 10 seconds pass before the UI resolves the file open dialogue box.
[Moved from the non-technical Lounge Forum to the specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
Photoshop is still borderline unusable, I'm losing about half the time I'm working to opens and saves and generic interface slowdowns. The tools have a little lag when I switch around between them as well. Also, there are a second or two pauses when I cycle through screen states ( f button )
Why 4 GPUs? How many displays do you have connected?
Generally, multiple GPUs are not recommended. Photoshop can only take advantage of one, and even so, this isn't a GPU-intensive application. The basic requirement is simply a card that works.
If you must have them all running, try to uncheck GPU altogether from PS preferences.
I also do GPU rendering for CGI - I will focus Nvidias settings down to one gpu for photoshop
Same day, end of the day - Photoshop is early unresponsive and is taking 20 seconds between most operations now. The cursor and all dialogues are extremely slow to display, building up in parts slowly.
Here are the screenshots of the task manager during some of these extreme slow downs
I see no real evidence of overloaded systems resources. I am at a loss for what is going wrong.
Here are details of the same period from the task manager
I am running Gdata antivirus, which has an extremely low overhead.
So a whole week has passed, and no answers or comments have really cropped up to help fix Photoshop 2017. I moved back to Photoshop 2015 and it's instantly blazing fast. Whatever was put into Photoshop 2017 is a major problem, like very very major, it makes Photoshop unusable. So I will be using that deprecated version until 2018 comes out and referring all other friends and contacts I have to that as well.
I have been a Photoshop user since version 4, I wish it was easier to get some feedback as a loyal customer.
Bonjour underarock,
Je suis nouveau sur le forum, mais pas nouveau avec PhotoShop que j'ai commencé à utiliser avec la version 3.0 en 1995.
Avec Photoshop CC 2017, résolution écran 1200, il y a un paramètre de Windows 10 que j'ai utilisé et qui permet d'améliorer un peu l'affichage de l'interface de Photoshop, afin que les polices de caractères soient plus lisibles et un peu plus grosses.
La manipulation est la suivante:
1.- rechercher le fichier exécutif de Photoshop CC 2017 "Photoshop.exe", dont le chemin sous Windows 10 est le suivant: "C:\Program Files\Adobe\Adobe Photoshop CC 2017"
2.- effectuer un clic droit sur ce fichier "Photoshop.exe"...
3.- ... cliquez sur le 2e onglet "Compatibilité" et dans la section \Paramètres \Remplacez le comportement de mise à l'échelle PPP élevée... Utiliser l'option "Système".
IMPORTANT: IL NE FAUT PAS UTILISER L'OPTION "Système améliorée" CAR ELLE EST MAL SUPPORTÉE PAR CAMERA RAW et par LIGHTROOM.
Les résultats de cette manipulation peuvent dépendent des caractéristiques de la carte-graphique et de l'écran utilisés avec le système.
À mon humble avis, il serait souhaitable que les développeurs de Photoshop nous offrent une interface adaptée aux écrans et cartes graphiques d'aujourd'hui.
