stack overflow limit
Participant ,
Sep 05, 2017 Sep 05, 2017
Hello all
having a problem.
I have recursive script that runs through a groupitem of groupitems and seelets the left half of the group. Groups with in groups with in groups with in . . .
This works on simpler illustrations but some of the groupitems recursively call the function so many times that i get a stack overflow. Obviouly designed to protect your computer etc, however in my case i simply need more recursion then is allowed.
How can i change the stack limit. or any kind of workaround for overflow limits.
Many thanks in advance.
Dane
Scripting
708
Enthusiast , Sep 05, 2017 Sep 05, 2017
Another way:
Deselect all, select the groupItem, then loop through activeDocument.pageItems, if pageItems.selected == true, it belongs to the groupItem, then check it's groupItem or not, is not, go ahead to see it's left half or not.
Adobe
Valorous Hero ,
Hello, sounds like an interesting and frustrating problem. Can you post the recursive function?
Participant ,
below is the recursive bit.
I may not be so tidy. Sorry about that.
Ain't no profi.
thanks for taking a look.
function leftgroupcontent(a2,lateralCounter, preGroup,more){
    var y= 0
    var x = 0
    while (this.more != false){
        for (x = (aSelectItems.length -1); x > -1 ; x--){
            var a1 = aSelectItems
            if (a2 == ""){
                var curGroup = aGroup[a1]
            else {
                 var curGroup = a2[a1]
            if (curGroup.length>0){
                for (y = 0; y < curGroup.length; y++){
                    var abc = curGroup
                    if (back == false ){
                        if (curGroup.controlBounds[2] > aHalfWidth && x != 0) {
                            curGroup.selected = false
                        else if (curGroup.controlBounds[0] > aHalfWidth) {
                        else if (a2 == "" && x == 0) {
                            var preGroup = [[curGroup], [curGroup.length], [curGroup.length]]
                            a2 = curGroup
                            aaa = leftgroupcontent (a2, 0, preGroup)
                        else if (a2 != "" && x == 0) {
                            if (curGroup.length != 0) {
                            preGroup[0].push(curGroup)
                            preGroup[1].push(curGroup.length)
                            preGroup[2].push(curGroup.length)
                            a2 = curGroup
                    else{
                          if (curGroup.controlBounds[2] < aHalfWidth && x != 0) {
                        else if (curGroup.controlBounds[2] < aHalfWidth) {
                            a2 = curGroup
                            a2 = curGroup
            if (a2 != "" && x == 0){
                            var lateralCounter = lateralCounter+1
                             if ( preGroup[1][(preGroup[1].length - 1)] > 0 && lateralCounter <  preGroup[1][(preGroup[1].length - 1)]  && preGroup[2][(preGroup[1].length - 1)] > 0){
                                a2 = preGroup[0][(preGroup[0].length -1)]
                                var aab=a2[lateralCounter]
                                var preLeftOver = lateralCounter
                                preGroup[2][(preGroup[1].length - 1)] = preGroup[2][(preGroup[1].length - 1)] - 1
                                aaa = leftgroupcontent (a2[lateralCounter],lateralCounter, preGroup, more)
                            else if (preGroup[1].length - 1 == 0) {
                                this.more = false
                            else{
                                preGroup[2].pop()
                                preGroup[1].pop()
                                preGroup[0].pop()
                                var lateralCounter = 0
Enthusiast ,
Another way:
Participant ,
interesting idea.
I find the groupitems structure very difficult to work with.
maybe page items are easier.
People's Champ ,
Probably possible to lighten your code. Nested loops are always not a good idea.
Feel free to share a sample document and a capture of what you want to achieve.
Valorous Hero ,
I think there's probably some bug which prevents "this.more != false" from being false some some situations.
What I'd do is use approach of moluapple, if selections are allowed, or capture all needed items in one linear array which can be processed for deciding what's on the right/left.
Participant ,
well "this.more != false" actually seemed to work.
The code did work just fine for simpler groups.
but you are right. moluapple was the way to go.
very simple.
Participant ,
just fine meaning 10x slower than moluapple's solution.
Participant ,
Amazing.
This solution is so simple and light and slick.
Thank you very much.
the new code:
var aiApp = app.activeDocument;
var aSelection = aiApp.selection;
var aGroup = app.activeDocument.groupItems.add();
var aPages = aiApp.pageItems
aGroup.name = "NewStyle"
for (i=0; i < aSelection.length; i++){
aSelection.move( aGroup, ElementPlacement.INSIDE);
aSelection.move( aGroup, ElementPlacement.PLACEATEND);
aGroup.translate(0,700)
aGroup.resize(200, 200, true , true, true, true, 200)
var aHalfWidth= aGroup.controlBounds[2] - ((aGroup.controlBounds[2] - aGroup.controlBounds[0]) / 2)
for (x = 0; x < aPages.length ; x++){
     var a = aPages
     if (a.typename == "GroupItem" && a.controlBounds[0] > aHalfWidth) {
        a.selected = false
    else if (a.typename != "GroupItem" && a.controlBounds[2] > aHalfWidth){
        a.selected = false
