I have tried to blend two files one face into Another. Whenever I go to edit and click on "auto blend files" the window that appears is Blanck and White and not in colour like in other tutorials that I´ve seen.. I took a Picture with gyazo and here is the link: Gyazo - 4c054b670a2731355ba72d3c1951b9f4.png
Looks right to me, other than you should be using stack mode rather than pano. That's just the UI, and those change with different versions of Photoshop. What matters is the result you get.
I have tried both stack and pano and I get the same result, No Changes.
If you want to merge photos together with that tool and it's not working well, you can do that manually using the content aware tool & masks.
Check the below link:
Combine images with Auto-Blend Layers in Adobe Photoshop
Ahmed
Why is the windows that appears black and White? Why is not in colour like in this tutorial that there is in Youtube:
Photoshop cc- How to swap face - Auto Blend Layers - YouTube
Did you check your background color because as per the youtube tutorial its 2 layers only no background?
I have checked it but, it´s the same result
You are sharing the software not the ending result. We are here to help you so help us, Luis.
Try to take step by step screenshots so we can handle it.
Ahmed
Hi again. Here is a tutorial in which two Pictures are used. Take a look of the tones of the two people on the Pictures.: https://www.youtube.com/watch?v=t5SGw8izxMYhttps://www.youtube.com/watch?v=t5SGw8izxMY
Swap Faces In Photoshop - YouTube
Now my attempt trying to do the same thing.
https://gyazo.com/492d6619200e6dc83df995cd07d2dcc1
https://gyazo.com/9130dac019058f5d0da21c931a366b35
https://gyazo.com/ab4c33e5ce968970c9f5eb6f837350c5
https://gyazo.com/7e21f910c79745f777c2b23057109d43
https://gyazo.com/36d1ee93c904003b7400b141569eee4f
https://gyazo.com/fbd1dff4d03029a8a11b8dc63b5d0fee
https://gyazo.com/05017feb21b8fe5ab3a9ca4536c11ea7
https://gyazo.com/e56ad9cf6ced38f1adeffce1b6e66b41
https://gyazo.com/977b2995e5a7c4ad6fcd3f692ddd6361
https://gyazo.com/8dbfc3820e36f10e69af48c8a248795c
https://gyazo.com/b8cf7f1f428b16d6d99c435615f2c71e
https://gyazo.com/1b835961c4ef3e6335b2943b10c09a5c
https://gyazo.com/bf653935281665b9725c8a40d741df24
https://gyazo.com/d1db0b00fba3d4e0cc473214fdfb67a5
https://gyazo.com/1aad45c2c0fc393c6d5f6288d83a2472
They are in chronological order. Can you tell me how to Contact an expert in Photoshop? I mean somene of the staff?
Luis
Hello Luis,
I check every pic you have shared it looks good and should get a good result but now I just want you to do something else can you try another image without glasses. I hope it will work this time.
Hi Luis
Did you make sure that the top layer (the new face) is larger than the cutout on the old face - leaving a few pixels overlap round the edges. In the video that was the purpose of contracting the selection.
Then set auto-blend to panorama, these are effectively side by side images with a small overlap
Dave
Yesssssssss, now it worked. Thanks for your advice Davescn . Now I did it different. I make the new face a Little bit bigger that the old face and this time Everything was fine.
Luis
You're welcome - glad to help
Dave
