My full composition is 45 seconds, but I cannot even render a 3 second clip of it. 3 seconds takes 20 minutes. 45seconds took over 3 hours.
Earlier I did a 10 second clip that only took about 2 seconds and then after that it just shut down and stopped, I have no idea why but I have a DEADLINE TONIGHT and I haven't been able to make any progress. I do a lot of work in AE and this is the first time I've had this problem. PLEASE HELP.
Computer:
OS X El Capitan
Macbook Pro 15-in
2.8GHz Intel Core i&
16GB 1600 MHz DDR3
AMD Radeon R9 M370X 2048 MB
512 GB available storage
My composition settings:
HDTV 1080 29.97
1920x1080
Export Settings:
Quicktime
RGB + Alpha (i need transparency)
Duplicate thread here: Composition WON'T RENDER -- I HAVE A DEADLINE
Locked. Thanks!
Kevin
You could try the command line render for AE... But I think its your system... Your on a laptop in AE
The HD frame size and frame rate will make a bit of difference but the main thing that will slow up rendering is the codec that your compressing to and how many layers and effects you have going...
You might try exporting to animation then to h.264 if you are going for a compressed delivery.
Hello,
Did you try to change the Render Settings to make the rendering faster like this? The window opens when you click Render Settings on Render Queue.
Proxy Use: Use All Proxies
Working with footage items in After Effects
It would be another tip that CapsLock is set on during rendering.
Rick Gerard suggests the following:
Start by purging everything.
If you have a crash then render an image sequence because you can pick things up on the frame where it fails. If I'm under a tight deadline on something that I think will take a long time to render or may have rendering problems I always render an image sequence. It's really easy to drop the image sequence in Pro and put the audio track back in and quickly render a deliverable and everybody can use an image sequence.
Without details and a screenshot of your comp with all the modified properties of all the layers in the comp revealed (press the u key twice) it's impossible to guess what may be going on other than running out of resources.
Kevin
Hi Leslie C,
Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
Kevin
