5
How to get embroidery effect satin stitch in photoshop or illustrator
Participant ,
Sep 07, 2017 Sep 07, 2017
Example:-
65.0K
Adobe
Hi Sara
I've used the method in the tutorial below to good effect (it uses Illustrator initially but then brings it into Photoshop for finishing)
Embroidery Effect with Illustrator and Photoshop
Dave
Participant ,
I tried this method is not come
Guide ,
Another option would be creating custom Brushes and using »Stroke Path …« and some Layer Masks and Layer Styles.
Guru ,
thats nice...
Aug 29, 2022 Aug 29, 2022
I want to know how to proceed with the method you told me.
Sep 01, 2022 Sep 01, 2022
This link shows how it's done from making the brush to putting it on a path and using styles. The video is old, the but it's still done the exact same way today.
https://www.youtube.com/watch?v=3uOCcbjgCWo&t=271s
Melissa Piccone | Adobe Trainer | Online Courses Author | Fine Artist
This photoshop tutorial shows you how to create your own brush and run it along a path for a stitched effect. Running a brush on a path is a valuable technique and the only way to make a dotted circle in Photoshop. This tutorial works for all versions of Photoshop. I also cover layer styles for a
Enthusiast ,
I have a short video on youtube for how to do this using a path.
How to Run a Brush on a Path in Photoshop - YouTube
Adobe Employee ,
Nov 23, 2021 Nov 23, 2021
Hi all,
Take a look at the following article to move designs between Photoshop and Illustrator for different workflow that suits your design objectives: https://helpx.adobe.com/photoshop/using/move-designs-between-photoshop-illustrator.html
Also, if you are looking to work with Illustrator design in Photoshop? See this: https://helpx.adobe.com/illustrator/using/use-illustrator-artwork-in-photoshop.html
Hope it helps.
Mohit
Apr 20, 2024 Apr 20, 2024
You can use photoshop plugin https://graphicriver.net/item/realistic-embroidery-photoshop-plugin/34168279?irgwc=1&clickid=wtC2GuS... to get embroidered look in photoshop. Know more [Link removed]
