10
P: How to fix Photoshop Scratch Disks Full Error?
Jan 19, 2018 Jan 19, 2018
I am running Photoshop CC on my MacBook Air with macOS Sierra. Every time I attempt to open Photoshop through any means, the following message appears: "Could not initialize Photoshop because the scratch disks are full", and Photoshop does not open. I tried clearing space from my Mac in general including several GB worth of apps and removing several cache files, but nothing seems to work. I also tried holding down the command and option keys to reveal the Scratch Disk Preferences, and it lets me select the Startup and MacIntosh HD. Again, nothing worked. Anyone know how to fix this message, and/or clear scratch disk space?Screen Shot 2018-01-19 at 8.36.51 PM.png
{Moderator note: Edited the thread title PS-65057}
macOS , Windows
415.9K
correct answers 2 Correct answers
New Here , Dec 02, 2017 Dec 02, 2017
This is super late, but for anyone else who runs into this issue...Similar thing happened to me. Do you make new files by pixel size or by inches? I usually go by pixels (ex: 2500x3000 or something like that), but I apparently I had accidentally switched to inches and it would only let me max the numbers to 1000. Went back to pixels and it all worked out!
Adobe Employee , May 05, 2021 May 05, 2021
Hi all,
We're sorry for the scratch disk issue. Take a look at the following troubleshooting article which can help you to resolve the "Scratch disk is full" error: Troubleshoot scratch disk full errors in Photoshop
Please have a look and let us know if that helps.
Mohit
Adobe
replies 330 Replies 330
Sep 26, 2020 Sep 26, 2020
What doesn't work? Please be detailed.
Engaged ,
Sep 25, 2020 Sep 25, 2020
Photoshop won't start because my scratch disc is full. It says I can change the scratch disc by pressing Command-Option while launching it. But that doesn't work. Photoshop sees no other scratch discs even though I have an 8Tb disc nearly empty and ready to go.
Now I can't use Photoshop. Any help?
Jan 15, 2021 Jan 15, 2021
THANK YOU!!!!
Mentor ,
Jul 29, 2016 Jul 29, 2016
Hi
What OS are you using ? Mac or Windows
Is the external drive formatted for the right OS you are using ?
Pierre
Hey,
It should be I can read and write on it. I am using Mac OS.
In preferences , there is a Tab for Scratch disk,  Drive " I " in the shot below is my external Hard drive
Mar 02, 2020 Mar 02, 2020
I have the problem of the external SSD not showing as an option. I have reset PS preferences, the HD is formatted to ExFAT and it still wont show as an option.
Mar 03, 2020 Mar 03, 2020
I too am having the same issue.  I used to be able to choose my External Hard drive for my Scratch Disk - but it no longer allows me.  *Yes I know I only have 6.02GB of free space left.
I'm running a Mac Book Pro using Creative Cloud.  Photoshop Version 20.0.6
Any ideas appreciated.  🙂
Apr 16, 2020 Apr 16, 2020
This is exactly what is happening to me as well. Did you find an answer to this?
Apr 17, 2020 Apr 17, 2020
yesenial, you use Disk Utility to format disks in macOS. ALL INFO ON THE DISK WILL BE LOST FOREVER.
lmrw, why did you format as exFAT?
Neil, how is your disk formatted?
Jul 18, 2020 Jul 18, 2020
You are HEAVEN sent. Thank you!
Jul 27, 2020 Jul 27, 2020
Open Photoshop as administrator.
Aug 21, 2017 Aug 21, 2017
I cannot open photoshop because it says scratch disk full. I know of the shortcut (ctrl+alt) and have used it before to set my scratch disk to almost empty drives. I've tried the same thing again as photoshop is starting up but it does nothing and i still get the "scratch disks full" error message. It has opened in the past so I don't know what happened. I need this to work for school in a couple of weeks so any help is appreciated!
Try resetting your Photoshop preferences. Start Photoshop immediately press and hold Shift+Alt+Ctrl. If done in time Photoshop should pop up a dialog asking if you want to delete your preferences. Reply yes delete them.  Photoshop should then open using an new set of Adobe default preferences. If your system startup disk is full Photoshop may no start for there need to be free space on the drive tor Temp files and scratch space,  You system performance  will be poor not what it should be.  Your OS new to use temp space too.
JJMack
Aug 22, 2017 Aug 22, 2017
It worked! Thank you!
Contributor ,
Sep 07, 2017 Sep 07, 2017
I have the same problem. Suddenly PS won't launch and gives me a series of scratch disk errors but my disks aren't full. (LR and other programs run fine)
So before I delete my preferences where are they so I can make a copy of them. The idea of having to recreate all my settings is not that appealing.
Try holding down Ctrl+ALT and keep them held down and start Photoshop.  You should be able to  then change Photoshop's scratch disk configuration.
JJMack
Contributor ,
Thank you I was able to launch it
Contributor ,
Yeah except when I did Ctrl + ALT I now realize I lost all my prefs, keyboard shortcuts and customization etc. hence my question to where that was located to make a copy.
That should not have happened.  It sounds like you reset your preferences. Did you get this popup starting Photoshop while holding Alt+Ctrl? I changed mine fron C:\ to F:\ still has all my settings.
JJMack
If you have a system bbackup you user Id Photoshop preferences are stored in the following file system tree. Normally a hidden folder.
Use you ID not mine
JJMack
Contributor ,
Yes that's what I got but somehow it affected my prefs
Jan 18, 2019 Jan 18, 2019
CTRL + ALT worked for me thx.
Oct 29, 2019 Oct 29, 2019
I tried the Shift+Alt+Ctrl and it didnt work, the other way didnt work either, I tried it many times, the scratch disk message just keep popping up.
