Hello, I need some help. I am trying to render a short 1080 sequence (5 minutes) on which I have added a logo as watermark. To do so I have used one of the presets in the new graphic panel (Logo Bug), in which I have inserted my own logo,which is in .png format.
Rendering the sequence without the watermark takes about 5 minutes. With the watermark it seems that it will take several hours and the performances of the computer are critically reduced. (I have interrupted the rendering as I could not use any other program, nor control my mouse). I also tried to add the watermark with the old titles method, by importing the logo in a title, but the result is the same.
I tried to export directly without rendering via Media encoder, but Media Encoder will crash my computer.
Here is the information on my settings
Any help you could provide would be most welcome.
In your export media window, click on effects - image overlay
What type of graphics card (GPU) are you using?
Hi, thanks for looking into my problem. I have 2 Nvidia GeForce GTX 780
How big is this PNG?
The PNG is 45Ko
Hi everyone, I finally managed to export the sequence with the logo as watermark. It took +/-5 hours.. I think this is not normal. Any help would be welcome.
Are you adding a watermark in the render options or are you adding the PNG to a new layer on top of everything else? Can you try whichever option you are not using and see if you still get the long render time?
What are the dimensions of the watermark graphic, in pixels? I'd go to Photoshop and make a new image to match the Sequence size in Premiere, for instance 1920x1080 or whatever you are working with. Size and place the watermark graphic within that frame exactly where you want it, and add transparency if desired. Now save as .png or .psd with alpha.
Drop that into Premiere timeline. Export. As Premiere does not have to do any scaling or anything to the image, should not add appreciable render time to a timeline that did not have that overlay. The 5-hour thing makes no sense at all.
Jeff
I see your point. I should not scale the graphic in Première. The watermark Graphic in photoshop is 410x426 px and the format is png.
I want it to be very small on the top corner of the Première sequence which is 1920x1080 px. So far I have inserted the graphic in a layer created with essential graphics and changed the scale of the logo it in there. I have no idea which size to make it in Photoshop to avoid having to adjust it a little in Première. I'll try reducing it by half in photoshop. But I may still have to adjust it. Première is supposed to handle scaled graphics in the titles, maybe the problem is elsewhere.
1920x1080. Just make several versions with your logo various sizes in the upper corner. Then drop it in the top video layer in Premiere. No resizing
HI, I am adding the PNG in a new layer above the whole sequence. I don't know about the option of adding the watermark to the render options. How do you do that?
I will do as you say tomorrow ( here in France it is late now) and will let you know how it went. Thanks a million for your help.
Hi Jeff,
I rendered as you advised and it worked better. It took 1 hour versus 5 hours the first time (but in VBR 2 passes while first time it was VBR 1 pass).
Although I still find this time very long. Do you think such duration is normal? The output file is 266 Mo (I encoded with H264 using an Ipad/Apple TV 1080p25 preconfiguration).The sources files are all 4 K, some encoded with GoPro Cineform, edited on a 1080 timeline.
Thank you again for your help.
In Premiere, look under File > Project Settings > General and see what the Renderer is set to. It will be either GPU or Software only. You want this to be GPU, so that your graphics card can accelerate the processing, specifically the scaling from 4k to HD. Your processor and GPU are about 4 years old, but still quite viable for HD editing. When using 4k footage, that will put a much greater load on the system.
Newer releases of Premiere have started dropping support for some older GPUs. I don't think the GTX 780 was dropped, but you should check that to see if it is being used.
Jeff
Hi Jeff, I checked that render is set to GPU and that my graphic cards are still supported.
Maybe I have inadvertedly erased some system file when I cleaned up my computer by erasing Temp files with cc clean. This is when problems began. Or maybe my system is getting too old. I have to start looking for a new one, as I will have soon to edit a big 52' project with 4K source footage. Any tips in terms of where I can find the ideal configuration?
again many thanks for your help.
