Define Brush Preset Creates an non-centred (out of alignment) Brush
Sep 08, 2017 Sep 08, 2017
I started with an Illustrator file of mandala-esque shapes. The files were then saved as .pngs. (Around 2-3 layers per a single shape(some dotted lines, some straight lines)) What I would like to do is to have brushes of each individual layer of the shape but each time I attempt this and test the layers by clicking the same central spot or even looking at the brush preview (pressing caps lock) it is clear that the brushes are not aligned to the centre. At first I thought it might of been because their anchors weren't central prior to defining the brush preset but that didn't affect it at all.
As a backup I thought about making a brush from the whole shape and not from layers but that won't work if the centre of the shape isn't the centre point of the brush.
Any help assisting with fixing this problem would be greatly appreciated.
The image shows the brush preview before applying it to the canvas and as you can see, the centre point is not the centre of the brush.
The anchor point was central prior to defining the brush preset so I'm not sure why the alignment isn't correct.
745
Community Expert , Sep 09, 2017 Sep 09, 2017
Thanks.
Well, I am surprised – when I convert the image to 8bit »Define Brush Preset« apparently produces the expectedly centred brush tips, when done in 16bit they seem to be off-kilter for me, too.
If you need them in 16bit you could load the individual layer’s transparency as a selection, expand it by a few pixels and then define the Brush Preset.
Adobe
Please provide the file you used to Define the Brush Presets for testing.
How exactly did you define the presets? Did you make a Selection, were the elements pure black on pure white, could there be stray pixels, …?
I appreciate the quick response, thanks a lot.
File attached below,
No I didn't make a selection, after aligning the 3 layers, I turned two off and defined brush preset to one, turned that off and then turned the second layer on then defined brush preset etc..
It was a solid black shape on transparent BG.
I made sure there were no stray pixels.
PSD: Define Brush preset.psb - Google Drive
Thanks again,
Nicholas. M
Thanks.
Sep 10, 2017 Sep 10, 2017
Hello,
I'm going to try with the file set to 8-bit instead of 16,
The resolution was intentional but the colour mode set to 16 was not.
The purpose for the brushes is to turn vectors into high quality raster layers that can be used in a variety of different ways, Colour isolation along with subtracting selections to name a few. I'll let you know how I go after defining the brush preset on an 8-bit document.
Thanks again,
Nicholas. M
If you start out with vectors anyway you could also create custom Shapes that you can then use to create Shape Layers with the Custom Shape Tool (of of the secondaries of the Rectangle Tool).
Thanks for the feedback.
They all worked after changing the document to 8-bit.  I'll have a look into the custom shape option a little more.
Thanks for the help and suggestions,
Nicholas. M
And may I ask what your intentions are for the Brush Presets?
If your goal is creating instances of a color image (the »mandala« shapes in different colors) you could also look into Smart Objects.
That may bloat the file-size and therefore affect performance but offer better edibility in the long run.
Distributing Smart Object instances along a Path can be automated with a Script for example, but that may be »overkill« if the task is not a frequent one for you.
script for distributing smart object instances along path for testing
