There are a ton of threads complaining about this same issue. I have not found a solution in any of them, as far as I can read. I'm going blind reading them, so I'm now going to ask directly. I am so disappointed that with all the threads on this, Adobe has not solved it yet, and in fact, every time an Adobe person engages in the thread, they act as if it is the first time they ever heard of the issue. And so all consideration of it starts at the beginning, even though that doesn't seem to have solved the problem for anyone -- so cut to the chase, stop wasting people's time.
My Acrobat DC CC 2017, now at v. 17.009.20058, worked fine. Now it doesn't, it crashes every time I open it, crashing about 30 seconds after opening. It doesn't matter whether I even open anything in it, it crashes anyway, so its not a file that is causing it. Whether I try to do something or not, it crashes at about 30 seconds. It appears that something that goes on about 30 seconds after opening is the problem.
I first noticed this problem 2-3 weeks ago. I had not used Acrobat since running Adobe CC 2017 updates at about the turn of August or early August, and around the same time updating my OS from macOS 10.12.5 to 10.12.6. I don't know if the problem started before or after those updates. After that, I cloned my main partition over to a second partition -- and the problem is on that second partition too, so it happened at the updates or before that, not since. I only installed Acrobat in early or mid May, and that August updating was the first time I updated since updating after the installation. So, whatever happened happened between the installation and that updating at about Aug. 1. Unfortunately, I do not know when I had last used Acrobat before that early August updating.
I'm running macOS 10.12.16 on a Mac Mini (Late 2014) at 2.6 GHz Core i5 processor, 8 GB RAM, 1 TB HDD that tests as fine, passes SMART test.
I have sent in at least a half dozen crash reports. The crash report is 30 pages long. I have seen so many long crash reports posted in the threads on this, I don't see any point in posting one here. However, I noted toward the top of mine a section identifying a problem, I think it must be THE problem:
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0:
That is identifying a crashed Thread: 0. I don't even find com.apple.main-thread on my hard drive, I did a search, and I also looked in Library/Preferences and in User/(name)/Library/Preferences.
Deep down in that crash report, I found what must be the thread: 0 it is talking of, in Thread 16 -- none of the other threads through 16 show any issue:
Thread 16:
0 libsystem_pthread.dylib 0x00007fffaba9e070 start_wqthread + 0
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000600000867740 rcx: 0x0000000000000000 rdx: 0x0000000000000005
rdi: 0x0000000000000000 rsi: 0x00000001098b6f7d rbp: 0x00007fff580e40c0 rsp: 0x00007fff580e40c0
r8: 0x0000000000000000 r9: 0x0000000000000230 r10: 0x07534943226f0071 r11: 0x00007fd0a58097a0
r12: 0x07534943226f0071 r13: 0x00007fd0a45122f8 r14: 0x00007fd0a4496710 r15: 0x00006080008561d0
rip: 0x00007fffaba93e00 rfl: 0x0000000000010293 cr2: 0x0000000000000000
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Thread 16 at line 0 seems to be the Crashed Thread: 0 it is referring to.
I looked for libsystem_pthread.dylib. There doesn't seem to be any libsystem_pthread.dylib on my computer. It does have two libsystem_pthread.tbd files, but not of that name ending in .dylib.
So, those parts of my crash report should say where the problem is, what is causing it. And I am informing that Acrobat crashes about 30 seconds after opening. What does Acrobat do about 30 seconds after opening -- that is where the problem is?
I have already done pretty much all the troubleshooting you can tell me to do. Nothing solves this, nothing makes any difference.
I have taken the preferences out of the preferences folders, both the main one in Library/Preferences and the ones in User/(name)/Preferences/Adobe -- I took out the ones Adobe listed to take out and some more too.
I have done restarts.
I have started the computer in Safe Mode.
I have uninstalled and reinstalled Acrobat from a new download via the CC 2017 Adobe Creative Cloud desktop application. That took most of day, a huge download -- Adobe could at least let us download the installer to our desktop so we can have it going forward to do this instead of having to do four+ hours of downloading all the time.
I booted from another partition with a clone of my main partition, same problem.
I tried deleting cache files at:
Font caches:
/users/yoursessionname/Library/Application Support/Adobe/Acrobat/version number, eg DC/AdobeCMapFnt17.lst and AdobeSysFnt15.lst and AdobeSysFnt17.lst and UserCache64.bin
Application caches:
/users/yoursessionname/Library/Caches/Acrobat/version number, eg DC/AcroFnt17.lst
I have Validated all the fonts in Font Book categorized as "pdf fonts." I also found all the Adobe fonts I could, 5-6 of them, and Validated them -- there might be more, but they are not readily identifiable, ans I have more than 1,000 fonts.
I tried taking all my fonts A-K out of the Fonts folder, and tested. No difference. I put them back in and tried taking out L-Z, no difference. Yes, of course I restarted each time before testing.
I tried creating a new user account, and then booting into that account. No difference.
I went to my Time Machine backup and actually moved the oldest Acrobat application, from around July 20, from there to my main partition, and tested it. Same problem.
So, Adobe, what is the problem, how can I -- and a ton of other people here -- fix it? I have given you a lot of info here. So have people in other threads. You can't just keep selling Acrobat and not solve this issue -- that would be criminal. So, considering all the people having this issue, and for how long back in time I see people complaining about it, and all this time and all this info given to you -- I think you better make this a high priority to fix and pronto. That this does not have a solution yet is unconscionable.
Message was edited by: Mark Trujillo 9/7/17, to fix typos.
Hi Mark,
If Acrobat is crashing on launch without even opening any file then it seems to be a licensing issue to me. Acrobat tries to validate its license and may be crashing due to failure. You can provide the amt3.log file for further analysis.
Location of log files:
amt3.log and oobelib.log: /Users/<current user>/Library/Logs
PDapp.log: /Users/<current user>/Library/Logs
Meanwhile, try the steps below:
Delete all the files from following folders:
Library/Application Support/Adobe/SLStore
Library/Appl
...Copy link to clipboard
OK, for lack of any interest whatsoever from Adobe to this problem so far, here is my LATEST full crash report -- maybe you will respond to this. I note, it is bot the same as the one I previously excerpted from, Thread 16 is not showing anything special in this one. So, the issue might be variable. This issue has been in the threads for years now. This is unconscionable:
Process: | AdobeAcrobat [2065] |
Path: | /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat |
Identifier: | com.adobe.Acrobat.Pro |
Version: | 17.009.20058 (17.009.20058) |
Code Type: | X86-64 (Native) |
Parent Process: | ??? [1] |
Responsible: | AdobeAcrobat [2065] |
User ID: | 502 |
Date/Time: | 2017-09-09 14:12:49.754 -0700 |
OS Version: | Mac OS X 10.12.6 (16G29) |
Report Version: | 12 |
Anonymous UUID: | 513B18A7-E1F6-4E5F-8406-52C0042CE596 |
Sleep/Wake UUID: | 9B8C19BB-9351-4FE8-8DBF-E2AE4AF3D843 |
Time Awake Since Boot: 9500 seconds
Time Since Wake: | 3000 seconds |
Crashed Thread: | 0 Dispatch queue: com.apple.main-thread |
Exception Type: | EXC_BAD_ACCESS (SIGSEGV) |
Exception Codes: | KERN_INVALID_ADDRESS at 0x0000000000000000 |
Exception Note: | EXC_CORPSE_NOTIFY |
Termination Signal: | Segmentation fault: 11 |
Termination Reason: | Namespace SIGNAL, Code 0xb |
VM Regions Near 0:
__TEXT | 0000000101c38000-0000000101c39000 [ | 4K] r-x/rwx SM=COW /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat |
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_platform.dylib | 0x00007fffa6492e00 _platform_strncmp + 320 | |
1 com.adobe.Acrobat.framework | 0x0000000102738668 0x101c3d000 + 11515496 | |
2 com.adobe.Acrobat.framework | 0x000000010271a945 0x101c3d000 + 11393349 | |
3 com.adobe.Acrobat.framework | 0x0000000102e22c99 0x101c3d000 + 18767001 | |
4 com.adobe.Acrobat.framework | 0x00000001035bcf29 0x101c3d000 + 26738473 | |
5 com.adobe.Acrobat.framework | 0x00000001035bc95e 0x101c3d000 + 26736990 | |
6 com.adobe.Acrobat.framework | 0x00000001035bcabc 0x101c3d000 + 26737340 | |
7 com.adobe.Acrobat.framework | 0x0000000102ed9aa8 0x101c3d000 + 19516072 | |
8 com.adobe.Acrobat.framework | 0x0000000102ed8b75 0x101c3d000 + 19512181 | |
9 com.adobe.Acrobat.framework | 0x0000000101db2e51 0x101c3d000 + 1531473 | |
10 com.apple.Foundation | 0x00007fff9256652a __NSThreadPerformPerform + 326 | |
11 com.apple.CoreFoundation | 0x00007fff90b24321 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17 | |
12 com.apple.CoreFoundation | 0x00007fff90b0521d __CFRunLoopDoSources0 + 557 | |
13 com.apple.CoreFoundation | 0x00007fff90b04716 __CFRunLoopRun + 934 | |
14 com.apple.CoreFoundation | 0x00007fff90b04114 CFRunLoopRunSpecific + 420 | |
15 com.apple.HIToolbox | 0x00007fff90064ebc RunCurrentEventLoopInMode + 240 | |
16 com.apple.HIToolbox | 0x00007fff90064cf1 ReceiveNextEventCommon + 432 | |
17 com.apple.HIToolbox | 0x00007fff90064b26 _BlockUntilNextEventMatchingListInModeWithFilter + 71 | |
18 com.apple.AppKit | 0x00007fff8e5fda54 _DPSNextEvent + 1120 | |
19 com.apple.AppKit | 0x00007fff8ed797ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 | |
20 com.apple.AppKit | 0x00007fff8e5f23db -[NSApplication run] + 926 | |
21 com.adobe.Acrobat.framework | 0x0000000101c45f6d 0x101c3d000 + 36717 | |
22 com.adobe.Acrobat.framework | 0x0000000101c448fe RunAcrobat + 246 | |
23 com.adobe.Acrobat.Pro | 0x0000000101c38f47 main + 86 | |
24 libdyld.dylib | 0x00007fffa6284235 start + 1 |
Thread 1:: Dispatch queue: NSOperationQueue 0x60000023b4e0 :: NSOperation 0x60000023b500 (QOS: USER_INTERACTIVE)
0 libsystem_kernel.dylib | 0x00007fffa63b2f46 __semwait_signal + 10 | |
1 libsystem_c.dylib | 0x00007fffa6339b72 nanosleep + 199 | |
2 com.apple.Foundation | 0x00007fff925d1a1b +[NSThread sleepForTimeInterval:] + 156 | |
3 com.adobe.Acrobat.framework | 0x0000000102ca034e 0x101c3d000 + 17183566 | |
4 com.apple.Foundation | 0x00007fff92537324 -[__NSOperationInternal _start:] + 672 | |
5 com.apple.Foundation | 0x00007fff925331db __NSOQSchedule_f + 201 | |
6 libdispatch.dylib | 0x00007fffa624e8fc _dispatch_client_callout + 8 | |
7 libdispatch.dylib | 0x00007fffa62649a0 _dispatch_queue_serial_drain + 896 | |
8 libdispatch.dylib | 0x00007fffa6257306 _dispatch_queue_invoke + 1046 | |
9 libdispatch.dylib | 0x00007fffa62506b5 _dispatch_root_queue_drain + 476 | |
10 libdispatch.dylib | 0x00007fffa625048c _dispatch_worker_thread3 + 99 | |
11 libsystem_pthread.dylib | 0x00007fffa649d5a2 _pthread_wqthread + 1299 | |
12 libsystem_pthread.dylib | 0x00007fffa649d07d start_wqthread + 13 |
Thread 2:
0 libsystem_kernel.dylib | 0x00007fffa63b344e __workq_kernreturn + 10 | |
1 libsystem_pthread.dylib | 0x00007fffa649d621 _pthread_wqthread + 1426 | |
Thread 3:
Thread 4:
0 libsystem_kernel.dylib | 0x00007fffa63b2bf2 __psynch_cvwait + 10 | |
1 libsystem_pthread.dylib | 0x00007fffa649e7fa _pthread_cond_wait + 712 | |
2 com.adobe.AGM | 0x000000010443d030 0x104430000 + 53296 | |
3 com.adobe.AGM | 0x000000010443cf6d 0x104430000 + 53101 | |
4 com.adobe.AGM | 0x00000001047ca265 0x104430000 + 3777125 | |
5 libsystem_pthread.dylib | 0x00007fffa649d93b _pthread_body + 180 | |
6 libsystem_pthread.dylib | 0x00007fffa649d887 _pthread_start + 286 | |
7 libsystem_pthread.dylib | 0x00007fffa649d08d thread_start + 13 |
Thread 5:
Thread 6:
Thread 7:
2 com.adobe.Acrobat.framework | 0x00000001020a507b 0x101c3d000 + 4620411 | |
3 com.adobe.Acrobat.framework | 0x0000000102095a11 0x101c3d000 + 4557329 | |
4 com.adobe.Acrobat.framework | 0x0000000102d54241 0x101c3d000 + 17920577 | |
5 com.adobe.Acrobat.framework | 0x0000000102091412 0x101c3d000 + 4539410 | |
6 com.adobe.Acrobat.framework | 0x000000010209fab4 0x101c3d000 + 4598452 | |
7 libsystem_pthread.dylib | 0x00007fffa649d93b _pthread_body + 180 | |
8 libsystem_pthread.dylib | 0x00007fffa649d887 _pthread_start + 286 | |
9 libsystem_pthread.dylib | 0x00007fffa649d08d thread_start + 13 |
Thread 8:: com.apple.NSEventThread
0 libsystem_kernel.dylib | 0x00007fffa63ab34a mach_msg_trap + 10 | |
1 libsystem_kernel.dylib | 0x00007fffa63aa797 mach_msg + 55 | |
2 com.apple.CoreFoundation | 0x00007fff90b05434 __CFRunLoopServiceMachPort + 212 | |
3 com.apple.CoreFoundation | 0x00007fff90b048c1 __CFRunLoopRun + 1361 | |
5 com.apple.AppKit | 0x00007fff8e74af02 _NSEventThread + 205 | |
6 libsystem_pthread.dylib | 0x00007fffa649d93b _pthread_body + 180 | |
7 libsystem_pthread.dylib | 0x00007fffa649d887 _pthread_start + 286 | |
8 libsystem_pthread.dylib | 0x00007fffa649d08d thread_start + 13 |
Thread 9:
1 libsystem_pthread.dylib | 0x00007fffa649d48e _pthread_wqthread + 1023 | |
Thread 10:
0 libsystem_kernel.dylib | 0x00007fffa63b4246 read + 10 | |
1 com.adobe.Acrobat.framework | 0x0000000102093db7 0x101c3d000 + 4550071 | |
2 com.adobe.Acrobat.framework | 0x00000001020921fe 0x101c3d000 + 4542974 | |
3 com.adobe.Acrobat.framework | 0x000000010209c266 0x101c3d000 + 4584038 | |
4 com.adobe.Acrobat.framework | 0x0000000102091412 0x101c3d000 + 4539410 | |
5 com.adobe.Acrobat.framework | 0x000000010209fab4 0x101c3d000 + 4598452 | |
Thread 11:
0 libsystem_kernel.dylib | 0x00007fffa63b3d96 kevent + 10 | |
1 com.adobe.Acrobat.framework | 0x00000001035c8784 0x101c3d000 + 26785668 | |
2 com.adobe.Acrobat.framework | 0x00000001034f7c64 0x101c3d000 + 25930852 | |
3 libsystem_pthread.dylib | 0x00007fffa649d93b _pthread_body + 180 | |
4 libsystem_pthread.dylib | 0x00007fffa649d887 _pthread_start + 286 | |
5 libsystem_pthread.dylib | 0x00007fffa649d08d thread_start + 13 |
Thread 12:
5 com.adobe.AcrobatPlugin.EFS | 0x000000010c5d89af 0x10c5bf000 + 104879 | |
6 com.apple.Foundation | 0x00007fff925278ad __NSThread__start__ + 1243 | |
Thread 13:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork | 0x00007fff8fc41734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 | |
Thread 14:
2 com.adobe.Acrobat.framework | 0x00000001035bd8a8 0x101c3d000 + 26740904 | |
3 com.adobe.Acrobat.framework | 0x00000001035bd2ec 0x101c3d000 + 26739436 | |
4 com.adobe.Acrobat.framework | 0x00000001035bb337 0x101c3d000 + 26731319 | |
Thread 15:
0 libsystem_kernel.dylib | 0x00007fffa63b2eb6 __select + 10 |
1 com.adobe.AcrobatPlugin.Comments 0x000000010ca30fa8 0x10c6a2000 + 3731368
2 com.adobe.AcrobatPlugin.Comments 0x000000010ca31475 0x10c6a2000 + 3732597
3 com.adobe.AcrobatPlugin.Comments 0x000000010ca3185b 0x10c6a2000 + 3733595
4 com.adobe.AcrobatPlugin.Comments 0x000000010c9b22f5 0x10c6a2000 + 3212021
5 com.adobe.AcrobatPlugin.Comments 0x000000010cbcc29d 0x10c6a2000 + 5415581
Thread 16:
Thread 17:
rax: 0x0000000000000000 rbx: 0x000060000086aa00 rcx: 0x0000000000000000 rdx: 0x0000000000000005
rdi: 0x0000000000000000 rsi: 0x00000001039d3f7d rbp: 0x00007fff5dfc60c0 rsp: 0x00007fff5dfc60c0
r8: 0x0000000000000000 r9: 0x00000000000001e8 r10: 0xe9ba60750c9f0048 r11: 0x00007f8a2abcfba0
r12: 0xe9ba60750c9f0048 r13: 0x00007f8a29c91508 r14: 0x00007f8a29cef560 r15: 0x0000608000a46990
rip: 0x00007fffa6492e00 rfl: 0x0000000000010293 cr2: 0x0000000000000000
Logical CPU: | 2 |
Error Code: | 0x00000004 |
Trap Number: | 14 |
Binary Images:
0x101c38000 - | 0x101c38fff +com.adobe.Acrobat.Pro (17.009.20058 - 17.009.20058) <89FD27AE-19C1-32AC-AD60-56BF734C7A87> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat | |
0x101c3d000 - | 0x103f4dff7 +com.adobe.Acrobat.framework (17.009.20058 - 17.009.20058) <BEFA9703-203A-30C3-B28D-A235E4CF2A4C> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat | |
0x1042cf000 - | 0x104414ff7 +com.adobe.ACE (AdobeACE 2.20.02.37824 - 2.20.02.37824) <2A4A6267-20BC-325C-931C-E227220B7650> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE | |
0x104430000 - | 0x104978ffb +com.adobe.AGM (AdobeAGM 4.30.69.1 - 4.30.69.1) <41AB0A45-A247-3A5E-AF7B-E838BC92E7FD> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM | |
0x104a2d000 - | 0x104a49ffb +com.adobe.BIB (AdobeBIB 1.2.03.37824 - 1.2.03.37824) <63152A89-179C-3DE0-94B8-2ED83DA0CC8C> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB | |
0x104a55000 - | 0x104d46ff7 +com.adobe.CoolType (AdobeCoolType 5.14.05.37990 - 5.14.05.37990) <67877A6B-82A9-3931-9D53-9A95ACACBF4D> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType | |
0x104d94000 - | 0x104ecafff +com.adobe.AIDE (1.5.0 - 1.5.0.34124) <CE69D37F-2D03-3B1D-8E63-C04CCC3FC37A> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE | |
0x104f3e000 - | 0x104f41fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter | |
0x10a041000 - | 0x10a062fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.9.0.37990 - 3.9.0.37990) <E37A46A9-6654-3135-AE2E-61FDE4CC4D49> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat | |
0x10a8c2000 - | 0x10aa68fff GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine | |
0x10aaa7000 - | 0x10b002ff7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.25.17 - 10.2.5) <37814D97-7FB0-3378-BF1E-375CE00043ED> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver | |
0x10b21a000 - | 0x10b244fff GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat | |
0x10b24e000 - | 0x10b2c6ff7 com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.25.17 - 10.2.5) <256C1732-C04F-3952-9630-9AE95BDCB245> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver | |
0x10b603000 - | 0x10b94cff7 +com.adobe.AcrobatPlugin.EScript (17.009.20044 - 17.009.20044) <9729D67A-983F-3560-B074-48B28B4712C7> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Plugins/EScript.acroplugin/Contents/MacOS/EScript | |
0x10bac0000 - | 0x10bc0bfef +IMSLib.dylib (10.0.0.19 - 10.0.0.19) <32EDDC00-4237-3F41-8B49-8B8010FAA72B> /Applications/Utilities/Adobe Application Manager/*/IMSLib.dylib | |
0x10bc2c000 - | 0x10bc99fff +com.adobe.AcroSQLite (AcroSQLite - 1.0.0) <C5EDF3B4-FBED-3A2F-A83C-BFCBF0BD90C9> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite | |
0x10c4b6000 - | 0x10c4dafff +com.adobe.AcrobatPlugin.Updater (17.009.20044 - 17.009.20044) <DAF0EC42-E56C-3AED-A1C2-09BAA09B467A> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Plugins/Updater.acroplugin/Contents/MacOS/Updater | |
0x10c51b000 - | 0x10c51ffff +AcrobatUpdateHelperLib.dylib (1) <A8384547-A9BA-3F85-BCA4-4DDE1BD48369> /Library/Application Support/Adobe/*/AcrobatUpdateHelperLib.dylib | |
0x10c5bf000 - | 0x10c5e1fff +com.adobe.AcrobatPlugin.EFS (17.009.20044 - 17.009.20044) <D536C9E5-A5B6-38AC-8715-8226CC39A127> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Plugins/EFS.acroplugin/Contents/MacOS/EFS | |
0x10c5ec000 - | 0x10c665fff com.apple.xquery (1.3.1 - 30) <031D5366-8C48-3124-93EC-3AB4A5758460> /System/Library/PrivateFrameworks/XQuery.framework/XQuery | |
0x10c6a2000 - | 0x10ce07ffb +com.adobe.AcrobatPlugin.Comments (17.009.20044 - 17.009.20044) <1A20F000-9A0F-352C-9159-5F91DBA30B59> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Plugins/Comments.acroplugin/Contents/MacOS/Comments | |
0x10cfe5000 - | 0x10cfffff7 com.apple.security.csparser (3.0 - 57740.60.18) <119893A8-D878-3AF2-BA3C-F70D5C6E6950> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser | |
0x10d5fb000 - | 0x10d6e2fe7 +com.adobe.amtlib (amtlib 6.2.0.42 - 6.2.0.42) <1EC10EEE-A265-89C3-E1E0-46AE6B541674> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/amtlib.framework/amtlib | |
0x110aff000 - | 0x110b3cdc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld | |
0x7fff8b72e000 - | 0x7fff8ba73ff7 com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera | |
0x7fff8d2aa000 - | 0x7fff8d46bfff com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation | |
0x7fff8d46c000 - | 0x7fff8d50eff7 com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio | |
0x7fff8d5d9000 - | 0x7fff8d5d9fff com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate | |
0x7fff8d5da000 - | 0x7fff8d5f1ffb libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib | |
0x7fff8d5f2000 - | 0x7fff8db0bfeb com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage | |
0x7fff8db0c000 - | 0x7fff8dc7dff3 libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib | |
0x7fff8dc7e000 - | 0x7fff8dc92ffb libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib | |
0x7fff8dc93000 - | 0x7fff8e089fef libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib | |
0x7fff8e08a000 - | 0x7fff8e0a0fff libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib | |
0x7fff8e0a1000 - | 0x7fff8e0a7fff libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib | |
0x7fff8e0a8000 - | 0x7fff8e0bcff7 libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib | |
0x7fff8e0bd000 - | 0x7fff8e244fe7 libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib | |
0x7fff8e245000 - | 0x7fff8e2f7fff libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib | |
0x7fff8e2f8000 - | 0x7fff8e2f8fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib | |
0x7fff8e5b7000 - | 0x7fff8f390ff3 com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit | |
0x7fff8f3a2000 - | 0x7fff8f3a2fff com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices | |
0x7fff8f3a3000 - | 0x7fff8f411ff7 com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS | |
0x7fff8f4ab000 - | 0x7fff8f5daff7 libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib | |
0x7fff8f5db000 - | 0x7fff8f625fff libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib | |
0x7fff8f682000 - | 0x7fff8f6b5fff libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib | |
0x7fff8f722000 - | 0x7fff8f7ccff7 com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync | |
0x7fff8f7cd000 - | 0x7fff8f81efff com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices | |
0x7fff8f81f000 - | 0x7fff8f82eff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis | |
0x7fff8f82f000 - | 0x7fff8f87cfff com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore | |
0x7fff8f87d000 - | 0x7fff8f8b8fff com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD | |
0x7fff8f8b9000 - | 0x7fff8f8c4fff com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis | |
0x7fff8f8c5000 - | 0x7fff8fad1ff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox | |
0x7fff8fad2000 - | 0x7fff8fad2fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit | |
0x7fff8fc3b000 - | 0x7fff90015fff com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork | |
0x7fff9002f000 - | 0x7fff9002ffff com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon | |
0x7fff90030000 - | 0x7fff90033fff com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels | |
0x7fff90034000 - | 0x7fff9033dfff com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox | |
0x7fff9033e000 - | 0x7fff90341ff7 com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help | |
0x7fff90342000 - | 0x7fff90347fff com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture | |
0x7fff90348000 - | 0x7fff903dfff3 com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink | |
0x7fff903e0000 - | 0x7fff903fafff com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting | |
0x7fff903fb000 - | 0x7fff903fcff3 com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print | |
0x7fff903fd000 - | 0x7fff903ffff7 com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI | |
0x7fff90400000 - | 0x7fff90406ff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition | |
0x7fff90407000 - | 0x7fff904e6ffb com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit | |
0x7fff904e7000 - | 0x7fff904e7fff com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa | |
0x7fff90631000 - | 0x7fff906befff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio | |
0x7fff906bf000 - | 0x7fff906d2fff com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth | |
0x7fff906d3000 - | 0x7fff909cefff com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData | |
0x7fff909cf000 - | 0x7fff90a7cff7 com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay | |
0x7fff90a7d000 - | 0x7fff90f16ff7 com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation | |
0x7fff90f17000 - | 0x7fff91599fff com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics | |
0x7fff9159a000 - | 0x7fff917ddffb com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage | |
0x7fff917de000 - | 0x7fff91843ff7 com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation | |
0x7fff91844000 - | 0x7fff918f5fff com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia | |
0x7fff918f6000 - | 0x7fff91941ff7 com.apple.CoreMediaIO (805.0 - 4932) <03F2B863-BF99-36DF-9A14-1DB534A289F3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO | |
0x7fff91942000 - | 0x7fff91942fff com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices | |
0x7fff91943000 - | 0x7fff91994fff com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE | |
0x7fff91995000 - | 0x7fff91c70ff7 com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore | |
0x7fff91c71000 - | 0x7fff91ca4fff com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices | |
0x7fff91ca5000 - | 0x7fff91cadff3 com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents | |
0x7fff91cae000 - | 0x7fff91e1aff7 com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices | |
0x7fff91e1b000 - | 0x7fff91ecbffb com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata | |
0x7fff91ecc000 - | 0x7fff91f2bfff com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices | |
0x7fff91f2c000 - | 0x7fff91f9cfff com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit | |
0x7fff91f9d000 - | 0x7fff91fe2ff7 com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList | |
0x7fff9206b000 - | 0x7fff921b8ffb com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText | |
0x7fff921b9000 - | 0x7fff921eeff3 com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo | |
0x7fff921ef000 - | 0x7fff92260ffb com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN | |
0x7fff9235e000 - | 0x7fff92363fff com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration | |
0x7fff924f5000 - | 0x7fff9289bfff com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation | |
0x7fff928c7000 - | 0x7fff928f8ff7 com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS | |
0x7fff929b8000 - | 0x7fff92a5bfff com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth | |
0x7fff92a5c000 - | 0x7fff92af2ff7 com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit | |
0x7fff92af3000 - | 0x7fff92af9ffb com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface | |
0x7fff92afa000 - | 0x7fff92b4bff7 com.apple.ImageCaptureCore (7.0 - 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore | |
0x7fff92b4c000 - | 0x7fff92cacfef com.apple.ImageIO.framework (3.3.0 - 1599.12) <E54ADBF0-6001-3DEB-AEB0-3F857A781E06> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO | |
0x7fff92cad000 - | 0x7fff92cb1fff libGIF.dylib (1599.12) <A0836C44-9566-32A3-ACCF-82A5BAF2E521> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib | |
0x7fff92cb2000 - | 0x7fff92da2ff7 libJP2.dylib (1599.12) <0DB4F152-B36D-365C-97B1-34F1C114982B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib | |
0x7fff92da3000 - | 0x7fff92dc6ffb libJPEG.dylib (1599.12) <2F66BA16-D569-35AD-A4BB-7A1909F1BF11> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib | |
0x7fff92dc7000 - | 0x7fff92deeff7 libPng.dylib (1599.12) <A068239E-7DB3-33AD-BEA9-499D8DEF771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib | |
0x7fff92def000 - | 0x7fff92df1ff3 libRadiance.dylib (1599.12) <D26D6FC9-1175-38AB-ACAA-0CA073FD3978> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib | |
0x7fff92df2000 - | 0x7fff92e40ffb libTIFF.dylib (1599.12) <5D161E6A-D279-37A0-9F5F-A71A4C13BB09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib | |
0x7fff92f9e000 - | 0x7fff93ba8fff com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore | |
0x7fff93ba9000 - | 0x7fff93bc2ff7 com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos | |
0x7fff93e4c000 - | 0x7fff93e52fff com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility | |
0x7fff93e68000 - | 0x7fff943a1ff7 com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox | |
0x7fff943a2000 - | 0x7fff943fdfff com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal | |
0x7fff94ce6000 - | 0x7fff94ceefff com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS | |
0x7fff94ec5000 - | 0x7fff94ecdff7 libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib | |
0x7fff94ece000 - | 0x7fff94f1cff3 com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL | |
0x7fff94f1d000 - | 0x7fff94f36ffb com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory | |
0x7fff94f37000 - | 0x7fff94f42ff7 com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory | |
0x7fff94f43000 - | 0x7fff94f45fff libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib | |
0x7fff94f46000 - | 0x7fff94f49ff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib | |
0x7fff94f4a000 - | 0x7fff94f4efff libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib | |
0x7fff94f4f000 - | 0x7fff94f58ff7 libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib | |
0x7fff94f59000 - | 0x7fff94f64fff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib | |
0x7fff94f65000 - | 0x7fff94fa1ff7 libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib | |
0x7fff94fa2000 - | 0x7fff95118ff3 libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib | |
0x7fff95119000 - | 0x7fff9515aff7 libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib | |
0x7fff95ac2000 - | 0x7fff95ad0fff com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL | |
0x7fff95b6d000 - | 0x7fff95cb4fff com.apple.QTKit (7.7.3 - 2978.7) <49F88771-52FE-3989-AAB7-10A7494C4419> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit | |
0x7fff95cb5000 - | 0x7fff95f1fff7 com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit | |
0x7fff95f20000 - | 0x7fff95fe7fff com.apple.PDFKit (1.0 - 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit | |
0x7fff95fe8000 - | 0x7fff9650eff7 com.apple.QuartzComposer (5.1 - 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer | |
0x7fff9650f000 - | 0x7fff96532ffb com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters | |
0x7fff96533000 - | 0x7fff96620fff com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI | |
0x7fff96621000 - | 0x7fff96621fff com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz | |
0x7fff96622000 - | 0x7fff96822fff com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore | |
0x7fff96823000 - | 0x7fff96878fff com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook | |
0x7fff96879000 - | 0x7fff9688efff com.apple.SafariServices.framework (12603 - 12603.3.8) <966BF0C8-B94B-3BDF-AFE1-0F99DAAE6D99> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices | |
0x7fff96d71000 - | 0x7fff96d88ff7 com.apple.ScriptingBridge (1.3.3 - 69) <F51B85CD-9C80-317E-B594-4A03612EAF52> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge | |
0x7fff96d89000 - | 0x7fff9708bff7 com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security | |
0x7fff9708c000 - | 0x7fff97101fff com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation | |
0x7fff9712c000 - | 0x7fff9712fff3 com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement | |
0x7fff974b6000 - | 0x7fff97525ff7 com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration | |
0x7fff97526000 - | 0x7fff978d4fff com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox | |
0x7fff978d5000 - | 0x7fff98c5cff3 com.apple.WebCore (12603 - 12603.3.8) <FE0B8503-5E89-3D55-BF48-1370FE81910A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore | |
0x7fff98c5d000 - | 0x7fff98e49ff3 com.apple.WebKitLegacy (12603 - 12603.3.8) <8C2FFEAA-1E05-3756-8EA7-DF406C866191> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy | |
0x7fff98e4a000 - | 0x7fff991f5fff com.apple.WebKit (12603 - 12603.3.8) <C28C5735-5B6B-3434-8054-FDBC57B4E2DE> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit | |
0x7fff99d7c000 - | 0x7fff99d97ff3 com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer | |
0x7fff99d98000 - | 0x7fff99da5ff3 com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox | |
0x7fff99da6000 - | 0x7fff99dc8ffb com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 | |
0x7fff99dc9000 - | 0x7fff99dd8feb com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression | |
0x7fff99ec6000 - | 0x7fff99f5197f com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG | |
0x7fff99f8a000 - | 0x7fff99f8dff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo | |
0x7fff99f8e000 - | 0x7fff99fe0fff com.apple.AppleVAFramework (5.0.36 - 5.0.36) <7352078D-C230-397C-81A5-57A48CF218C0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA | |
0x7fff99fea000 - | 0x7fff99ff1ff7 com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices | |
0x7fff9a384000 - | 0x7fff9a402ff7 com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup | |
0x7fff9b08d000 - | 0x7fff9b0b4ff3 com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary | |
0x7fff9b0b5000 - | 0x7fff9b141ff7 com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs | |
0x7fff9b9d9000 - | 0x7fff9b9e2ffb com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth | |
0x7fff9bb67000 - | 0x7fff9bf46ff7 com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC | |
0x7fff9bf47000 - | 0x7fff9bf77fff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD | |
0x7fff9c12b000 - | 0x7fff9c13bfff com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji | |
0x7fff9c200000 - | 0x7fff9c216ff3 com.apple.CoreMediaAuthoring (2.2 - 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring | |
0x7fff9c21d000 - | 0x7fff9c2adffb com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF | |
0x7fff9c476000 - | 0x7fff9c4a6ff3 com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal | |
0x7fff9c737000 - | 0x7fff9c7c6ff7 com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication | |
0x7fff9c7c7000 - | 0x7fff9c906fe7 com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI | |
0x7fff9c907000 - | 0x7fff9c9d7ff3 com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils | |
0x7fff9ca27000 - | 0x7fff9ca8cff3 com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi | |
0x7fff9ca8d000 - | 0x7fff9ca9bff7 com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport | |
0x7fff9cb0d000 - | 0x7fff9cb17ffb com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation | |
0x7fff9cb18000 - | 0x7fff9cb1cff3 com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay | |
0x7fff9cb52000 - | 0x7fff9cbc7ffb com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore | |
0x7fff9cc03000 - | 0x7fff9cc42fff com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols | |
0x7fff9cc43000 - | 0x7fff9cd54fff com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv | |
0x7fff9ce97000 - | 0x7fff9cea2fff com.apple.DisplayServicesFW (3.1 - 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices | |
0x7fff9d03c000 - | 0x7fff9d46dff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore | |
0x7fff9e7c4000 - | 0x7fff9e7c4fff libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib | |
0x7fff9e7d1000 - | 0x7fff9e7dcff3 libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib | |
0x7fff9ea95000 - | 0x7fff9eab1fff com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage | |
0x7fff9eaca000 - | 0x7fff9f17cfff com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices | |
0x7fff9f1c2000 - | 0x7fff9f238ff3 com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal | |
0x7fff9f239000 - | 0x7fff9f24afff com.apple.HelpData (2.1.12 - 100.1) <EEB8CC44-9AFF-3005-A25D-18FE46574FD5> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData | |
0x7fff9f853000 - | 0x7fff9f85affb com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator | |
0x7fff9f85c000 - | 0x7fff9f870ff7 com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment | |
0x7fff9f871000 - | 0x7fff9f893fff com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices | |
0x7fff9f92f000 - | 0x7fff9f93fff3 com.apple.IntlPreferences (2.0 - 216) <77C9C2E7-EF9F-34BB-A5E3-B8BEA4226B5F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences | |
0x7fff9f97a000 - | 0x7fff9fb31fff com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling | |
0x7fff9fc2d000 - | 0x7fff9fcefff3 com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS | |
0x7fffa01a1000 - | 0x7fffa01a4fff com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove | |
0x7fffa0452000 - | 0x7fffa04cbff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders | |
0x7fffa0627000 - | 0x7fffa0635fff com.apple.MobileKeyBag (2.0 - 1.0) <D0983DB7-EF9D-3E19-A084-21319ECE5846> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag | |
0x7fffa0646000 - | 0x7fffa066eff7 com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport | |
0x7fffa0720000 - | 0x7fffa072bfff com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth | |
0x7fffa1003000 - | 0x7fffa1044ff3 com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis | |
0x7fffa16f1000 - | 0x7fffa172bffb com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage | |
0x7fffa172c000 - | 0x7fffa1746fff com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer | |
0x7fffa1747000 - | 0x7fffa1756ff7 com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing | |
0x7fffa175f000 - | 0x7fffa1782ff3 com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices | |
0x7fffa244c000 - | 0x7fffa244ffff com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper | |
0x7fffa24de000 - | 0x7fffa256bfff com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing | |
0x7fffa256c000 - | 0x7fffa258bff7 com.apple.shortcut (2.16 - 98) <6C0435B1-83DD-3254-B0D3-3B86C6CE606A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut | |
0x7fffa258c000 - | 0x7fffa27f2feb com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight | |
0x7fffa29d1000 - | 0x7fffa29ddff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore | |
0x7fffa30c9000 - | 0x7fffa313dfdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication | |
0x7fffa357c000 - | 0x7fffa3582ff7 com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC | |
0x7fffa360e000 - | 0x7fffa36d4ff7 com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO | |
0x7fffa3748000 - | 0x7fffa3749fff com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent | |
0x7fffa374a000 - | 0x7fffa38daff3 com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation | |
0x7fffa43a9000 - | 0x7fffa4469fff com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge | |
0x7fffa48b4000 - | 0x7fffa48bafff com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService | |
0x7fffa498b000 - | 0x7fffa498dffb com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport | |
0x7fffa49e2000 - | 0x7fffa49fdff7 libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib | |
0x7fffa49fe000 - | 0x7fffa4a09fff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib | |
0x7fffa4a9b000 - | 0x7fffa4a9cff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib | |
0x7fffa4a9d000 - | 0x7fffa4cb0fff libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib | |
0x7fffa4ccc000 - | 0x7fffa4cd3fff libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib | |
0x7fffa4cd4000 - | 0x7fffa4cd4fff libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib | |
0x7fffa4cd5000 - | 0x7fffa4cd9ffb libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib | |
0x7fffa4cda000 - | 0x7fffa4cdbffb libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib | |
0x7fffa4d47000 - | 0x7fffa4d72ff3 libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib | |
0x7fffa4d73000 - | 0x7fffa4deffc7 libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib | |
0x7fffa4df3000 - | 0x7fffa4df3ff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib | |
0x7fffa4df4000 - | 0x7fffa4e04ff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib | |
0x7fffa4e05000 - | 0x7fffa4e13ff7 libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib | |
0x7fffa4e14000 - | 0x7fffa4e6aff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib | |
0x7fffa4e6b000 - | 0x7fffa4e94ff7 libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib | |
0x7fffa4e95000 - | 0x7fffa4ea5ffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib | |
0x7fffa4ea6000 - | 0x7fffa4ebcfcf libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib | |
0x7fffa4ebd000 - | 0x7fffa4ebdff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib | |
0x7fffa4ebe000 - | 0x7fffa4ebfff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib | |
0x7fffa4f79000 - | 0x7fffa505eff7 libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib | |
0x7fffa51fc000 - | 0x7fffa524fff7 libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib | |
0x7fffa52a3000 - | 0x7fffa52aaff3 libdscsym.dylib (148.3) <EF99B991-18D9-3A73-BE88-4DC55F036DEF> /usr/lib/libdscsym.dylib | |
0x7fffa52cc000 - | 0x7fffa52ccfff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib | |
0x7fffa52da000 - | 0x7fffa52dbfff libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib | |
0x7fffa52dc000 - | 0x7fffa52e1ff7 libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib | |
0x7fffa52e2000 - | 0x7fffa53d4ff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib | |
0x7fffa53d5000 - | 0x7fffa55faffb libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib | |
0x7fffa5600000 - | 0x7fffa5601fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib | |
0x7fffa5602000 - | 0x7fffa561bffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib | |
0x7fffa561c000 - | 0x7fffa5632ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib | |
0x7fffa5633000 - | 0x7fffa58dbff7 libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib | |
0x7fffa590e000 - | 0x7fffa5988ff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib | |
0x7fffa5989000 - | 0x7fffa5d5b047 libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib | |
0x7fffa5d5e000 - | 0x7fffa5d62fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib | |
0x7fffa5d63000 - | 0x7fffa5d94fff libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib | |
0x7fffa5db1000 - | 0x7fffa5dcdffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib | |
0x7fffa5dce000 - | 0x7fffa5e07fff libsandbox.1.dylib (592.70.1) <9C428C49-9D9A-3F9F-9573-BF5202D1F933> /usr/lib/libsandbox.1.dylib | |
0x7fffa5e1b000 - | 0x7fffa5e1cff3 libspindump.dylib (231.3) <C7CEEB64-06F4-3ACA-AAC1-30ECA909501A> /usr/lib/libspindump.dylib | |
0x7fffa5e1d000 - | 0x7fffa5f6bff7 libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib | |
0x7fffa5fc7000 - | 0x7fffa6017fff libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib | |
0x7fffa6060000 - | 0x7fffa606dfff libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib | |
0x7fffa606e000 - | 0x7fffa615dfff libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib | |
0x7fffa615e000 - | 0x7fffa6187fff libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib | |
0x7fffa6188000 - | 0x7fffa6199ff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib | |
0x7fffa61a8000 - | 0x7fffa61acff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib | |
0x7fffa61ad000 - | 0x7fffa61b7fff libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib | |
0x7fffa61b8000 - | 0x7fffa61bffff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib | |
0x7fffa61c0000 - | 0x7fffa61c8fff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib | |
0x7fffa61c9000 - | 0x7fffa624cfdf libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib | |
0x7fffa624d000 - | 0x7fffa627efff libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib | |
0x7fffa627f000 - | 0x7fffa6284ffb libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib | |
0x7fffa6285000 - | 0x7fffa6285ffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib | |
0x7fffa6286000 - | 0x7fffa6292fff libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib | |
0x7fffa6293000 - | 0x7fffa6293fff liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib | |
0x7fffa6294000 - | 0x7fffa6299ff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib | |
0x7fffa629a000 - | 0x7fffa629cff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib | |
0x7fffa629d000 - | 0x7fffa629effb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib | |
0x7fffa629f000 - | 0x7fffa62b7ff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib | |
0x7fffa62b8000 - | 0x7fffa62b8ff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib | |
0x7fffa62b9000 - | 0x7fffa6346fef libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib | |
0x7fffa6347000 - | 0x7fffa634affb libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib | |
0x7fffa634b000 - | 0x7fffa634efff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib | |
0x7fffa634f000 - | 0x7fffa6367fff libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib | |
0x7fffa6368000 - | 0x7fffa636efff libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib | |
0x7fffa636f000 - | 0x7fffa6398ff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib | |
0x7fffa6399000 - | 0x7fffa63bbff7 libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib | |
0x7fffa63bc000 - | 0x7fffa6403fe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib | |
0x7fffa6404000 - | 0x7fffa6422ff7 libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib | |
0x7fffa6423000 - | 0x7fffa647cffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib | |
0x7fffa647d000 - | 0x7fffa6486ff3 libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib | |
0x7fffa6487000 - | 0x7fffa6490ff3 libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib | |
0x7fffa6491000 - | 0x7fffa6499fe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib | |
0x7fffa649a000 - | 0x7fffa64a4ff7 libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib | |
0x7fffa64a5000 - | 0x7fffa64a8ff7 libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib | |
0x7fffa64a9000 - | 0x7fffa64aaff3 libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib | |
0x7fffa64ab000 - | 0x7fffa64b2ffb libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib | |
0x7fffa64b3000 - | 0x7fffa64c6ff7 libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib | |
0x7fffa64c7000 - | 0x7fffa64ccffb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib | |
0x7fffa64cd000 - | 0x7fffa64f6ff7 libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib |
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0 | |
thread_create: 0 | |
thread_set_state: 0 |
Calls made by this process:
task_for_pid: 0 | |
Calls made by all processes on this machine:
task_for_pid: 3548 | |
VM Region Summary:
ReadOnly portion of Libraries: Total=392.8M resident=0K(0%) swapped_out_or_unallocated=392.8M(100%)
Writable regions: Total=165.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=165.7M(100%)
VIRTUAL REGION | ||
REGION TYPE | SIZE | COUNT (non-coalesced) |
Accelerate framework | 384K | 4 |
Activity Tracing | 256K | 2 |
CG backing stores | 5616K | 5 |
CG image | 644K | 24 |
CoreAnimation | 56K | 9 |
CoreUI image data | 1260K | 15 |
CoreUI image file | 184K | 5 |
Foundation | 4K | 2 |
Image IO | 76K | 4 |
Kernel Alloc Once | 8K | 2 |
MALLOC | 120.9M | 81 |
MALLOC guard page | 48K | 10 |
Memory Tag 242 | 12K | 2 |
Memory Tag 251 | 16K | 2 |
SQLite page cache | 64K | 2 |
STACK GUARD | 56.1M | 19 |
Stack | 17.6M | 20 |
VM_ALLOCATE | 2540K | 29 |
__DATA | 36.1M | 294 |
__GLSLBUILTINS | 2588K | 2 |
__IMAGE | 528K | 2 |
__LINKEDIT | 117.9M | 26 |
__TEXT | 274.9M | 286 |
__UNICODE | 556K | 2 |
mapped file | 58.3M | 23 |
shared memory | 18.4M | 18 |
TOTAL | 714.6M | 864 |
Model: Macmini7,1, BootROM MM71.0220.B29, 2 processors, Intel Core i5, 2.6 GHz, 8 GB, SMC 2.24f32
Graphics: Intel Iris, Intel Iris, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5444
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5444
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x13B), Broadcom BCM43xx 1.0 (7.21.171.130.1a1)
Bluetooth: Version 5.0.5f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS541010A9E662, 1 TB
USB Device: USB 3.0 Bus
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: CanoScan
USB Device: Keyboard Hub
USB Device: CDRW55292EXT3-B
USB Device: Apple Keyboard
Thunderbolt Bus: Mac mini, Apple Inc., 26.1
Hi Mark,
If Acrobat is crashing on launch without even opening any file then it seems to be a licensing issue to me. Acrobat tries to validate its license and may be crashing due to failure. You can provide the amt3.log file for further analysis.
Location of log files:
amt3.log and oobelib.log: /Users/<current user>/Library/Logs
PDapp.log: /Users/<current user>/Library/Logs
Meanwhile, try the steps below:
Delete all the files from following folders:
Library/Application Support/Adobe/SLStore
Library/Application Support/Adobe/SLCache
And, delete all files from following folder except cache.db
Library/Application Support/Adobe/Adobe PCD
Launch Acrobat, activate when prompted and check.
Rave
Hello Rave,
I just tried deleting those files you said to delete. I then tested, it did not crash at 30 seconds, was still open well after a minute. I closed it. I then restarted my computer, and tested again. Again, it stayed open well past a minute. I then closed, and opened Acrobat once more -- and it stayed open, no crashing, for 10 minutes or more, and then I closed it.
That appears to have solved the issue -- maybe. I will be testing and watching for the next couple days before I decide that fix is final.
Thank you for that. What are those files? I presume they simply got corrupted? I did earlier try an uninstall with the uninstaller and reinstalled. Should I have cleared those files manually too?
How could it be that simple to fix, when the other thread has been out there for years with no fix -- in fact, I don't think I saw anywhere in it to try this.
Hi Mark,
When Acrobat launches it also validates the license information periodically that is saved in the files you deleted. In case of corrupt files or any event that causes the licensing to break, the program shuts down due to license failure.
Improper permissions to the aforementioned folders also lead to licensing failure as Acrobat will not be able to access the folders to write or read the information.
I assumed that might be the situation here and suggested the steps. Deleting these files are recommended only as a last resort because it could lead to licensing failure of other installed Adobe applications on your machine.You will then have to launch and relicense the respective applications.
I am glad that the steps worked for you.
Rave
Well, this fix has failed, it has not passed the test of time. Two days later, and Acrobat has started crashing again about 30 seconds after opening. In fact, the way I found out was that I a crash report popped up this morning even though I hadn't opened Acrobat -- how could that happen? And ever since that, all I get is the crashing.
I tried eliminating those files again -- but there were none in those folders now.
What process goes on about 30 second after opening, every time? That is where the problem is.
Should I delete certain preference files? I just went in and deleted some named for Acrobat from Users/(me)/Preferences. But then int testing, it still crashed.
This is like I saw some people saying in another thread here, that they had tried a solution that was offered, it worked, but then it stopped working a couple-few days later. Doesn't that crash report I posted tell you something -- if not, what is the point of crash reports?
Hi Mark,
Sorry for the delay in response.
As mentioned in my response# 2, could you please provide me the log files.
You can email me directly at trkumar@adobe.com
Also provide me the following information:
1. Exact version of Acrobat.
2. The Adobe ID used to activate the license.
3. Check if you have Read/ Write permissions to SLSTORE, SLCACHE and Adobe PCD folders.
4. Check the steps mentioned in the KB: Resolve connection errors with Adobe Creative Cloud and Creative Suite applications
5. When was the last time that Acrobat worked fine. Did any update or software install break the workflow?
6. Check in Safe mode or a different admin user account if Acrobat launches fine.
Rave
I have the exact same problem that Mark has or had, I have Mac Sierra and Adobe DC Pro was working fine until a couple of weeks ago, in all my computers (all Mac, same OS), I have lost count of how many reports I have sent already.
Reading Mark's and your posts Rave, what I can tell you is that my Adobe crashes only when I open a file, and only if the file comes from the adobe creative cloud, if I open a file from my hard drive there is no problem. I checked this carefully after reading your posts. The crash report says the same as Mark's report, the only difference is the version of acrobat,
I am not as savvy with computers as Mark, so, would you explain to me how to fix this as if you were talking to your mom or dad, if they know something about computers, I mean, I know something.
