I think I have similar issue as to what JCT360 brought up in this old post if I understand JCT's posts. I publish to a defined path on the server, but to then view the actual help website on our intranet, what would the URL be for users to view the site?
For example, I'm using RH8 publishing to WebHelp using File System. Destination Path is: \\servername\wwwroot
Now once I publish there, what would be the URL I could email to someone so they could view the site on our intranet? They should be able to access via an http:// address, right?
Looking at the folder on the server, can see the default topic, "Home.htm". Should URL I can use for users to vew the site be http://servername/wwwroot/Home.htm? If I try this link though, get page not found.
Hope that makes sense. I'm working on a new site. I had the http:// address to acccess the help site in my browser history. I cleared my history and now can't seem to figure out what the URL to the help site is.
UPDATE: I realized, I don't need the wwwroot in the path. Also, while my default home page is Home.htm, the actual URL for my help site is based on the name of my project. So correct URL is in this format: http://servername/Project_Name.htm
Message was edited by: hughbetcha
Hughbetcha
The start page name can be changed in the first page of the wizard. If you change it to index.htm and get your IT people to create a sharename, your users could type just the sharename and the help would open.
