I have started shooting panoramas on my iPhone 7 and I am looking for advice on correcting the curvature of lines that should be straight. Part of the problem is that the "adaptive wide angle" filter doesn't seem to recognize an iPhone panorama as a true panorama (like a stitched together panorama). I have had some success using puppet warp but that is imprecise and time consuming.
What is the best way to re-straighten those curved lines?
Kevin
Post an example panorama let us see what your dealing with. Which of the Iphone 7 three cameras did you use.
Thanks for getting back to me. I am using the "pano" setting on the iPhone 7. Here is a sample pan below. I would like to straighten the roadway and especially the border at the front of the driveway which should be straight. I have had some success using puppet warp but I still have hopes for adaptive wide angle. The problem is that adaptive wide angle does not recognize this photo as a panorama (I think).
Kevin
The thing is power lines sag so the curve is not wrong IMO. However, thay are it very distracting in this image I would use an other approach.
Thank you for painting out the power line. The question remains - how do I straighten out a diagonal line which appears curved in an iPhone panorama?
Kevin
You could try warping the image some. I'm sure if you search the web you will find information on the subject of adjusting perspective in stitched panoramas
Hi, JJ
Yes I know about warping. I am wondering why you wanted to get involved with this in the first place. To be specific - where is the interface between an iPhone panorama with curvature and "adaptive wide angle?" Thanks
K
did you watch the video
That looks like a perfectly normal panorama to me. Horizontal lines become curved. If I had to, I would use Transform > Warp also:
but if there were, say, a car or person on the extreme right side, they would be distorted.
Yes I like warp better then adaptive wide angle in this case.
