I knew that I can change Wet parameter by pressing digit at keyboard (1 - 10%, 2 - 20% and so on, as changing opacity for regular brush).
I discovered that pressing shift+digit - changes Flow parameter, and alt+shift+digit - changes Mix parameter (an pixel layer must be selected).
Does anyone have guess how we can change Load parameter? It's just curiosity
(off course i tried Ctrl+Alt+digit and Ctrl+Alt+Shift +digit- it makes some selections (from 1 to 5), Ctrl+Shift+ digit (2-5) - show channels).
You may be able to create tool presets for the different Load setting you want and cycle through them using a shortcut key. However all setting you record in the tool Presets will be set for the tool. Not just your load setting.
Re: Cycle through Tool Presets with shortcut?
Yes, I use presets a lot and yesterday I found this thread with your script and copied it and tried a little to change it for me, but I postponed it for some days, when I'll have more free time. Thank You!
But sometimes it's easier and faster to change params with shortcuts, tool presets are too many to cycle through them. I show presets only for active tool, and the list is too big yet. Yesterday I deleted a half of them for mixer brush .
I use MagicSquire plugin with brush groups which allows to have presets sorted in folders with different colors so you can have different brushes with different parameters stored in folders that you can easily hide and show the ones that you don't need. So the list never gets big.
It also has a feature to store only size of the brush as a preset.
