Hello guys. It has to be smthng obvious but I cannot figure it out. I have a character standing with arms down. When I want to wave his hand and say Hi the wrist/hand has to flip horizontally when the arm is up. But it is not changing automatically. Changing atttach style for arm doesn't change it either.
Maybe the solution doesn't exist still in the last version of the program?
Can you advice me what to do?
Thanks a lot for help.
Hi there, the best solution is for you to draw another version of the hand in the second position, on another layer. You can then assign a trigger key to activate it. Make sure to check the box that says Hide other layers in Group when setting up the trigger. This will switch hands when you need to. Just hit the trigger key while recording the arm animation.
Hope this helps
Hope this helps
It works great. Thank you!
