I'm using an active X control to display PDF files. The firs few clicks the PDF fills the whole space, but after 3 or 4 clicks a menu showing export pdf, create pdf, edit pdf ,etc appears on the righ using most of the small window. I'm using a document called "Interapplication Communication API Reference" and commands that i'm using start in page 106. I have set setShowToolbar(false) and the toolbar doesn't show. How can i control the other menu?
In case anyone is interested, i think i have solved the issue. In the following link Remove or prevent sidebar from opening by default on Adobe Reader - Super User about the third answer down shows where acrobat sets up the default view for the viewer. I changed the file in question and now there are no side bars on my view.
