Hi Guys, I just want to use face aware liquify but there is no option to do so after using Quixel, it just has mesh options.
- Graphics card is enabled in performance and has 8g Vram
What is Quixel?
Could you please post a screenshot to illustrate the issue?
Have you tried other »Advanced Settings« for the GPU?
Christoph, it is a 3D texturing tool: http://quixel.se
Yep, so I was previously using quixel, all good no problems, then I shut
down PS, open up a simple single layer 2D face and when I go to liquify
there is no face aware tool available. Basically its like the settings from
Quixel have overridden the PS defaults and not reset (see below this is
what I get). Note, even when I use quixel I don't use the liquify tool at
all. (I have also included shots of my graphics options) thanks for any help
On 12 September 2017 at 22:12, PECourtejoie <forums_noreply@adobe.com>
Hello, you need to use the forum interface, and now the email to insert images in your posts.
i used to use Quixel in texture design but if you want to edit the final shape of the texture you have to merge the layers you want to add liquefy filter on it then add your liquefy filter
