XmlValidate() - Content is not allowed in prolog
Guest
Nov 11, 2008 Nov 11, 2008
I posted in another thread but I believe the issue described there is resolved so I am starting a new thread with this new issue.
XmlValidate always returns "Content is not allowed in prolog" I searched this forum and google and I did see where this problem was resolved for some. It appears that the most common cause was a hidden character (BOP I believe) in the file. However, I have verified that my xml does not have that in it.
I am at a loos as to how to proceed. I am hoping someone out there has seen this and fixed it. I need some serious help.
Advanced techniques
1.4K
Deleted User
Nov 12, 2008 Nov 12, 2008
quote:
Originally posted by: Newsgroup User
How did you verify this?
I ran some very helpful code from Ben Nadel at http://www.bennadel.com/index.cfm?dax=blog:1206.view that basically gets the first few characters of the parsed xml and outputs them with Asc(). After running that code I had no extra characters in there.
I did sort out this issue though. I had quotes around the first parameter:
<CFSET errorStructure = XmlValidate("xmlObject", " http://www.myserver.com/MyXsd.xsd")>. When ...
> It
Adam
Guest
<CFSET errorStructure = XmlValidate("xmlObject", " http://www.myserver.com/MyXsd.xsd")>. When I removed the quotes the "Content is not allowed in prolog" error went away but I came back to the original problem I reported about in another thread. Namely, the code would run for about 30 seconds and then a JRun Servlet Error is returned with "500 null" on the page.
It turns out THAT issue was because I had <xs:include schemaLocation="DocumentCommon.xsd"/> in the xsd file being called in XmlValidate. Once I copied and pasted the code in DocumentCommon.xsd into the called xsd, replacing the <xs:include schemaLocation>, it worked.
Very frustrating.
This is a good case in point as to why it's always good to post the code
that's giving the problem, when raising an issue here ;-)
That would have been a quick one to spot with a second pair of eyes.
Adam
Guest
You are 100% correct Adam. I made the mistake of starting another thread. I should have kept the one as the code was posted in the first thread.
I muddied my own waters and that ain't pretty!
That sound *sooo* wrong.
Adam
Documentation
