I can do para return, shift par return but not move copy to new column. It'a driving me potty. Don't want text boxes full of returns, Do I need to make 3 text boxes for 3 columns rather than using a shortcut in one box????
The number pad Enter key inserts a column/frame break. If you don't have a num-pad Enter key, choose Edit > Keyboard Shortcuts > Type Menu > Insert Break Character: Column Break and assign a key combination...
Fantastic - thanks a million.
Almost a year later, your tip is still paying off. Thanks lots
2016 and your answer is the gift that keeps on keeping on... Thanks!
Almost four years later and it's helpful!
2021 and you're still helping people (me) out
On many current short keyboard laptops (Windows) Fn Return no longer works. Which Shortcut combination is most widely used for a column break (so student/employees can use them consistenly in different settings/computers)?
THANK YOU! 🙂
Glory and praise to the design gods! THANK YOU FOR THIS ANSWER! Was driving me "potty" as well since I don't have a full keyboard.
I hate to be daft, but if I have a frame that is 2 columns and I press the Num Enter key, it breaks to a new page, not to the other column. What am I missing?
What am I missing?
Well, you may be missing something, but it's hard to tell from here.
If you're not, then it's a malfunction, the kind that often clears up with a reset of preferences.
Troubleshooting 101: Replace, or "trash" your InDesign preferences
How this thing should work:
Numpad Enter breaks to next column (or next frame if there’s no next column in that frame, or next page if there’s no next frame on that same page)
Shift+Enter breaks to next frame
Ctrl+Enter breaks to next page
If you’re on a notebook with the main keyboard only (no numpad), try to include Fn key in a combination, using 'main' Enter/Return key.
Right on!
I spoke too soon! The text I did have in the 2nd column disappeared after hitting the #pad enter key while in column 1. Where did it go?
It is overset. Look at Edit > Edit in Story Editor. Also, you will see a red plus sign in the outport of the textframe (the lower-right corner)
Running CS6 and to my great frustration, I could not assign a shortcut key combination. I followed instrux up til the assign & then nothing I came up with would satisfy.
The Column Break window even gave "Delete" as the default...
I tried a variety of options, but NOTHING jumped the type to the next column. Any guesses, or suggestions for a key combination????
Sounds like corrupt preferences. Reset: Troubleshooting 101: Replace, or "trash" your InDesign preferences then try again.
I hesitate to suggest a key combination, having no idea what program defaults you might or might not consider expendable. I tend to explore the Function keys (e.g., F8) with modifiers, perhaps just because I find them easy to remember.
Will try- but exactly what kind of modifiers with the F keysI don't
really use these much anyway, so no problem there. Are modifiers letters?
Opt/Control/Shift etc?
On Tue, Sep 12, 2017 at 2:09 PM John Mensinger <forums_noreply@adobe.com>
Thx. REplaced Prefs & it got rid of the 'Delete' under Default.
Tried using Fn key + Return, but without moving manually to the next
column, the next line doesn't jump.
On Tue, Sep 12, 2017 at 2:08 PM, John Mensinger <forums_noreply@adobe.com>
Well, why you need a custom key comb, when there is one already?
You don't have numpad, and what's about Fn key?
Did you try Fn+Return? It's documented as a workaround for those without numpad keys.
I reset the Preferences and the 'Default delete' disappeared. One down.
But the Fn key + Return isn't a stand-alone single command to change columns. I still have to MOVE the carat to the next column....
I would so much appreciate ANY suggested keyboard shortcut, e.g., F8 with modifier [not sure what this might be]
Kinda late to the party, but if you work on a short keyboard, column break is fn + return, frame break is fn + shift + return.
By @sjacob128
Unfortunately, not on a Dell laptop - Inspiron 7559 - or because I have a "full" keyboard?
