Legacy anchor points in client supplied file
Participant ,
Sep 12, 2017 Sep 12, 2017
Hi first up I just wanted to say how invaluable this forum has been to me over the years.  The moderators and forum users have always been so helpful and also very prompt in answering my questions, so THANKS
A client recently supplied a file to me that I would like to clean up if the job is not too time consuming.  Please see supplied screenshot.  I would like to delete the anchor points to the left of the image as when the file is exported it leaves white space on the left hand side.  I know I can just crop it in photoshop but in a recent job, it would have been so much easier to use the ai file instead of the png.
I am assuming if I could close off the line at the point where the small arrow is, I could just delete the rest of the anchor points but I am unsure how to do close it off.  Thanks for any help.
880
Community Expert , Sep 14, 2017 Sep 14, 2017
I don't know where you put the extra anchor points, but I think you need a point on the selected path at this position:
Adobe
Is this shape made with one path? This is what I would do.
I would use the pathfinder command:
I would make a rectangle over the area I want to delete:
Then select all of the shapes:
Go to Window>Pathfinder>Minus Front:
You should end up with this:
If there are any stray anchor points, they shouldn't be connected to the other shape and you should be able to delete them with the direct select or regular selection tool.
Participant ,
Sep 13, 2017 Sep 13, 2017
Thanks for your help but that didnt work.  I think its a bit of a mess, see screenshot of overall logoScreen Shot 2017-09-13 at 5.12.24 pm.png
Guide ,
Grab the Eraser tool and make it really big. Erase the points you don't need by dragging it over them. The path should automatically close after you have done this.
Hope this helps
Participant ,
Hi Angie,
Thanks for the suggestion.  I tried this and it does get rid of some of it but as some of the anchor point are really close to the edge, if I get too close it removes the existing edge.  Hope that makes sense.
Guide ,
If you zoom in really close and make the Eraser smaller to get rid of the additional annoying points perhaps?
First create some additional new points on the edge you want to keep. Then use the lasso tool or the direct selection tool to select all the points that need to be deleted. Delete them and then close the path.
Participant ,
Thanks Monika,
I tried what you suggested but lost some of the white artwork.  I probably did it wrong.  Can I elaborate to make sure?  Please see screenshot.
Direct Selection tool
After deleting, I lose the white part.
THANKS
try the eraser tool. It is all depends how someone drew it. If the path is connected with a certain way it will change the look of the path.
Participant ,
Thanks I guess this is good enough
Try selecting it, then select the Shape Builder Tool (Shift + M) and hold down the Alt key to subtract the extra part.
Participant ,
Thanks all good now
