I think I've killed my project
Participant ,
Nov 05, 2008 Nov 05, 2008
I created a new folder within the Topic Files folder in Project Manager and as soon as I entered the name and clicked out, it acted as though I'd asked it do something huge and went into a flickering hourglass thing. I left it for a while then tried to close RH and found it was Program not Responding. Now when I open it, the cursor is an hourglass and I can't do anything in it.
Any ideas about what I should do? I would leave it work through whatever it is doing but the Program not Responding message in the title suggests that it isn't actually doing anything.
826
LEGEND , Nov 05, 2008 Nov 05, 2008
Perhaps try closing your project and squashing the .CPD file. Then open the project using the .XPJ (The .CPD should be rebuilt for you automagickally)
Hi Authorgirl
Where is your project? I'm suspecting you will return to say it's on a network resource. I suspect this because it's a common occurrence where one attempts to create a folder and things go wonky with RoboHelp if you are working that way.
Assuming my hunch is correct, you need to copy the project to your local C drive and proceed from there.
Cheers... Rick
Participant ,
Hi Rick
No, the project is on my C drive.
I have just found a post by Jon A on 9/30/08 saying he had this exact same problem and he fixed it by editing the root.fpj file and removing the reference to the new folder.
So I bravely ventured into my root.fpj file (having copied it first) and did the same but it hasn't made any difference. The project still opens slowly then the cursor flickers between pointer and hourglass.
There is a folder in that file called !Language!
Is this supposed to be in there - it isn't anything I have created?
BTW, I am using RH7.02
Participant ,
Rick, you are a star!
That worked.
Thank you sooo much.
Helen
Participant ,
Nov 13, 2008 Nov 13, 2008
Back to the original problem though - does anyone know why RH 7.02.001 crashes when I create a new folder in the Project Manager? I assume it is a bug.
Is there another way of doing it? I do need a new folder.
Helen
Hi Helen
Where is the project? If it's on a network drive, that could easily explain it. Other than that, maybe odd characters being used in the folder name?
Cheers... Rick
Ugh... up way too late and not enough caffeine. I see you answered that earlier.
Sorry... Rick
Participant ,
The folder name is normal - the problem happens even if I create the folder and click outside it whilst retaining the default 'New Folder' name.
Participant ,
The problem also occurs if I try to rename a folder.
Participant ,
Nov 14, 2008 Nov 14, 2008
Solution: I established that it was happening on all projects and so re-installed RH.
I can now add/rename folders although it does take a good couple of minutes to do it in my large project.
Helen
Nov 17, 2008 Nov 17, 2008
I am having the same problem. It is causing me major issues. It does this multiple times a day any time I try to add, delete or rename a folder. I am losing a lot of my work every time this happens and I'm starting to get really frustrated.
I took Rick's advise and deleted the CPD file and now my project seems to be running ok but very slowly. I guess slow is better then not working at all 😕
RoboHelp Documentation
Download Adobe RoboHelp
