Hi All,
I download In Design server 2017 trail version for testing but it not launch throw extended tool kit. Is there any configuration to run by extended tool kit
SD
I also face this many a times when trying to launch the application from Extendscript. If the trial activation is all done. I would suggest you to do the following
Hope this resolves it for you
-Manan
Did you activate the trial ?
Aide d’InDesign | InDesign CC Server 2015 - Notes de mise à jour
-Manan
Manan,
Thanks now i able to run throw extended tool kit
Now i am try to process the file throw LBQ but it show below error
executing request http://localhost:12345/com.adobe.clover.application/api/idsqueue/EnqueueJob?jobName=process&queueNam...
org.apache.http.client.HttpResponseException: Internal Server Error
Before run i had executed clover.cmd and startup-indesign-server-CORBA-4instances
start ^"InDesign Server - Port 12345 - IOR1^" cmd /C InDesignServer.com -port 12345 -pluginpath server\corba -iorfile %IORFolder1%\ior1.txt
when i manually copy past the url it open the page
I there some thing i missing in configuration
Subhendu Das
Did you ever find a solution to this issue? I am facing the same problem.
