Hi Everyone,
I appreciate that this is an ancient thread, but I have just emerged from a very painful couple of days merging old help systems together, and I had a nightmare with dropdowns no longer working in my updated output.
I had a situation where in 75% of cases, the dropdowns were working fine, but in the remaining 25% - they just weren't working, and I could not for the life of me figure out why.
I've got round it now, and to be honest I don't really understand how this has fixed it, but it has.
So in case this is of use to someone else experiencing this issue, I thought it worth sharing.
BTW I found a reference to this issue in another forum that suggested RH sometimes gets the popup ids confused between the popup link and destination text - but mine were all all ok.
What eventually solved this for me was this:
Hopefully voila! - your dropdowns will be working nicely again.
I'd love to be able to explain what's going on here, but to be honest I can't be bothered to work it out + I don't have time. Hope this helps.
Cheers,
Andy
Didn't 'Update DHTML effects in topics' work? (In the tools menu?)
Greet,
Willam
Hi William,
Thanks for replying and apologies for taking so long to respond.
I did try that Update option. It made absolutely no difference - all I got was a warning saying that the dhtml effects would no longer be backwards compatible or something, and then a big process bar as it went away and did something.
But it did not fix this issue for me...
Cheers,
Andy
TA, you didn't note what version you are using, but RH10 has issues with DHTML. I reported a bug over two months ag0 (see: http://forums.adobe.com/message/4910475#4910475) that had been confirmed by others, but there has been no solution provided as yet. It would be helpful (maybe ) if you reported this issue, too.
Hi Flaven,
Thanks for that, and apologies for not mentioning the version of RH I'm using - it's RH10.
I have another gripe actually that may wwell be connected to your other post. So I'll do some more digging and report back etc.
Cheers,
Andy
