Hi All,
i have found the below script for text increment in illustrator this is working fine, but i need the increment value to be variable
If the starting number is 7 and the increment value is 7 and number of steps is 5 then our requirement would be 7,14, 21,28,35.
#target illustrator
var selectedItems;
// if a document is open
if(documents.length >0)
var idoc = app.activeDocument;
// if textframes exist in the document
if(activeDocument.textFrames.length > 0)
// check to make sure something is selected.
selectedItems = selection
if (selectedItems.length > 0)
var itemFound = false;
for(var i=0; i<selectedItems.length; i++)
if(selectedItems.typename == "TextFrame")
itemFound = true;
alert ("The following text item is selected: >" + selectedItems.contents + "<")
var startNum = prompt ("Enter a starting number");
var incY = prompt ("Enter a Y offset in points (72 points = 1 inch)", "72", "Y Offset");
var steps = prompt ("How many steps?");
var increment = prompt ("count?"); //Added new
selectedItems.contents = startNum;
var myGroup = app.activeDocument.groupItems.add();
selectedItems.move( myGroup , ElementPlacement.PLACEATEND);
selectedItems.position = [0,0];
for(var a=0; a<steps; a++)
selectedItems.duplicate ();
var newNumber = parseFloat(startNum) + (a+1);
selectedItems.contents = newNumber;
var newY = incY / 72;
selectedItems.position = [0, -((a+1)*incY)];
if(itemFound == false) alert("No text items are selected.");
else
alert("Nothing is selected, select a text item(s) or a text range.");
else
alert("Open a document and select 1 or more text items or a text range.");
else
Vinoth
Try to change this line,
var newNumber = parseFloat(startNum) + (a+1) ;
to
var newNumber = parseFloat(startNum) + (a+1) * increment;
to
Thanks for the update, its working.
Instead of [0,0]; position the text has to be retained in the same position where the text is selected, it that is possible.
Vinoth
Any further updates for the above.
You can reference selected objects position, duplicate it and move it. reference below
var pos = selectedItems.position;
for(.....){
SelectedItems.position = [pos[0], pos[1]-((a+1)*incY)]
Thanks for update Ten,
I am not so good in scripting, could you please update this for me.
Vinoth
Try it
#target illustrator
var selectedItems, pos;
itemFound = true;
//selectedItems.position = [0,0]; //ignore this line.
pos = selectedItems.position; //get original objects position(x,y cordinates) in Array.
selectedItems.position = [pos[0], pos[1]-((a+1)*incY)]; //
else
else
else
However, I recommend you to learn around Scripting. Actually, We don't have enough time to write for someone and you don't always get it.
Thanks a lot. surely i am in the learning process.
In the decimal value for example 0.5 , 1.0 , 1.5 , 2.0. etc the value are found as 0.5 , 1 , 1.5 , 2. the value of 0 is missing after round value.
You can use toFix method like below.
var pai = 3.1415926535897932;
var fixedValue = pai.toFix(1);
Great i solved this issue, Thanks
