Photoshop CS6 go slow when i move more elements together.
I tried to move with any method (mouse or Shift+ctrl+an arrow buton).
I optimized photoshop after tutorial.
I use windows 10 and my laptop is Dell Inspiron 15 5000 2-in-1 if it was necessary to know.
Can i solve this?
Which model Dell Inspiron 15 5000?
Model is Inspirion 15 5578 -> Buy Dell Inspiron 15 5578 Signature Edition 2 in 1 PC - Microsoft Store
Display | 15.6 in Full HD IPS TrueLife LED-backlit touchscreen (1920 x 1080), 10-finger multi-touch support |
Processor | Intel Core i7-7500U 2.70 GHz with Turbo Boost Technology up to 3.50 GHz |
Memory | 8GB DDR4 2400 MHz |
Hard drive size | 1TB 5400 RPM HDD |
Operating system | Windows 10 Home, 64-bit |
PC type | 2 in 1 |
Optical drive | None |
Media drive | SD card reader |
Audio | Waves MaxxAudio Pro |
Video | Intel HD Graphics 620 with shared graphics memory |
Ports | 2 USB 3.0 • 1 USB 2.0 • 1 HDMI • Headphone output/Microphone input combo |
Battery | 3-cell 42WHr* |
Camera | Integrated webcam |
Wireless | 802.11ac (Miracast enabled) |
Bluetooth | Bluetooth 4.0 |
Dimensions | 15.04 x 9.96 x 0.80 in (381.90 x 253.10 x 20.20 mm) |
Weight | 4.40 lbs (1.99 kg) |
Color | Gray |
Other | Model number: Inspiron 15 5000 Series (5578) • Precision touchpad • TPM 2.0 • Touchpad dimensions: 107 x 82 mm • Security lock slot |
I would think that model would handle Photoshop well.
Make sure all Windows updates are installed and you have the latest Intel HD Device driver installed from the Intel site. That you have updated CS6 to version 13.0.1.3. CS6 is very buggy without its updates. Your ACR plug-in should be version ACR 9.1.1.
Use CS6 menu Help>System Info. Copy and paste that info here....
