Is it only in website made by Adobe applications that you can embed Indesign dokuments?
Try searching for something like "wordpress editor changes html code". There are plugins out there that deal with the Visual editor problem.
You're going to have be more detailed. You cannot embed an InDesign document but you can add a PDF or even an iframe version of Publish Online document.
You can have a link on your website to a Publish Online document, which would be hosted on Adobe Servers. You can include a facility in your Publish Online document that allows users to download a PDF version. Obviously if you have things like animations in your Publish Online document they won't be included in the PDF version.
Hope that helps!
-AM
This is fantastic 🙂
But,
now I have added the iFrame code and a title, but when you enter the site, only the code is showing up. Is it not possible that the post itself can be displayed?
You are adding HTML code to the page, so in the WordPress backend post page make sure you are pasting the iframe code in the text tab and not the visual tab.
Can you post the URL link to your Publish Online document
This wouldn't work because I'm in Visual mode:
But this does:
I have added the link in the text mode.
But what i see now is tha the link do not start with <iframe....
shouldent it do that?
Mine looks like this
https://indd.adobe.com/view/5c04ba52-9f0e-4619-b72b-5ed9aca549c9
- even I added this :<iframe style="border: 1px solid #777;" src="https://indd.adobe.com/embed/2c9dbf13-a83a-4cc7-b337-6b2ee63fe615?startpage=1&allowFullscreen=true" width="525px" height="371px" frameborder="0" allowfullscreen=""></iframe>
nilleg57851248 wrote
- even I added this :<iframe style="border: 1px solid #777;" src="https://indd.adobe.com/embed/2c9dbf13-a83a-4cc7-b337-6b2ee63fe615?startpage=1&allowFullscr een=true" width="525px" height="371px" frameborder="0" allowfullscreen=""></iframe>
You have to be in the HTML or Text tab (not the Visual tab). For an iFrame to work all of the code has to be included, not just the URL.
Try selecting all and pasting this into the HTML tab
<iframe style="border: 1px solid #777;" src="https://indd.adobe.com/embed/5c04ba52-9f0e-4619-b72b-5ed9aca549c9?startpage=1&allowFullscreen=true" width="100%" height="700px" frameborder="0" allowfullscreen=""></iframe>
this is wierd 😮
now I copy your and pasted it into the wp site at text tab, but it keeps showing up wrong
When I add the <iframe... in the text tap it stays. Then I took a look at the visual tab (before updating) and my Indesign shows perfect,- with read...
It is when I update the code changes to http/...
You need the iFrame tags. Try pasting the iFrame code in the Text tab and don't switch to Visual before you publish the post
Bit I think that is what I have done all the time? :
This is the code for embedding:
<iframe style="border: 1px solid #777;" src="https://indd.adobe.com/embed/fd3ea38b-db6b-417e-ae00-e3c664cb6d05?startpage=1&allowFullscreen=true" width="525px" height="371px" frameborder="0" allowfullscreen=""></iframe>
This is how the code looks in the text tab after publishing:
<a href="https://indd.adobe.com/embed/fd3ea38b-db6b-417e-ae00-e3c664cb6d05?startpage=1&allowFullscreen=true">https://indd.adobe.com/embed/fd3ea38b-db6b-417e-ae00-e3c664cb6d05?startpage=1&allowFullscreen=true</a>
I wonder if this mysterium have something to do with the smal coding tags in the meny bar?
I would really like to sort this out. The function (when it works) will be brilliant and very timesaving!
I'm very grateful for this forum and for all you help 🙂
Is your Wordpress site self hosted or with Wordpress? Do you have the latest version installed 4.8.1?
It it hosted with WP and is the latest version.
My teacher suggested tha the theme I use do not support iframes. - I used Twentyfifteen.
So now I try to find a theme that does ....
Wow that's frustrating. Hrm. I don't know the answer. Might be a limitation of your theme, that you can't do iframes?
I know for sure it works in Wordpress, I have a number of clients who use it. Here's an example of one in a post on InDesignSecrets (scroll down) which is a Wordpress site: https://indesignsecrets.com/publish-online-supports-embedding-indesign-documents.php
