My issue, as you can guess, is two fold.
History:
I was tasked with rewriting an existing help file for a
company. However, they didn't have any sources, just the CHM. Using
RH6, I extracted the CHM so I could update the file. Unfortunately,
the document's styling is hideous. I'm trying to fix this.
First question:
I started by trying to switch the stylesheets used in each of
the pages to a default.css which I had created for use in other
help files for the same company. With the page open I went to
Format > Styles and tried to change the style sheet being used.
Unfortunately, I couldn't actually tell this page to use
default.css. Instead, I could only click New Sheet and create a new
sheet based on the default.css style. I went ahead and did this,
calling it default1.css.
I then moved to another page and tried the same thing.
Figuring I could just create a new style sheet and call it the same
thing, figuring I could just copy the styles from default.css, call
the new one default1.css again, and now both of the old sheets
would be using default1.css. Unfortunately, this didn't work and
the new default1.css became default1~.css, so now I have 3 CSS
files: default.css, default1.css and default1~.css.
So the first question is how do I get html pages to use the
same style sheet?
Second question:
Since I couldn't have the pages use the same CSS file, I
thought maybe I could create a new page, which uses the new CSS,
and simply have all the links going to the nonCSS page to the CSS
page.
My question is then how can I repoint all the links that go
to File A to File B without having to go into every page and
manually repoint the file? Also, is there any way to rename HTM
files so that all the links pointing to that file are updated?
Thank you
