Locked
iOS 11 platform SDK
Contributor ,
Sep 13, 2017 Sep 13, 2017
When setting the -platformsdk argument to point to the iOS 11 platform SDK in the Xcode 9 GM seed, the build fails with this:
ld: library not found for -lgcc_s.1
I know this has happened before with XCode updates. I copied over the new ld64 file, installed the new commandline tools etc. Is this something that will have to be fixed with an AIR SDK update, or is there something else I can try? We're using a bunch of ANEs, maybe those need to be repackaged?
Any help is appreciated - Peter
Air beta
2.4K
Engaged , Sep 13, 2017 Sep 13, 2017
iOS sdk 11 doesn't have this lib.
You can copy from 10.3
Copy this tbd from here:
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk/usr/lib/libgcc_s.1.tbd
to here:
/Applications/Xcode-beta.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk/usr/lib/libgcc_s.1.tbd
Engaged ,
to here:
Engaged ,
After this. Please make sure you test on a device with iOS 11.
When I use any platformSDK - it breaks app rotation on iOS11 on my iPad Pro.
I have to omit this (so it uses the default 10.1 SDK included with AIR)
Here is the ticket. Is under known issues in the release notes.
https://tracker.adobe.com/#/view/AIR-4198406
Contributor ,
is the rotation issue only with iPad pro? I'm not seeing anything weird so far, but our app is locked in portrait mode so we actually don't want it to rotate at all.
Engaged ,
It was happening me on iPad mini also. Started happening after release 3 of Beta (There's been 10)
I think locking to portrait or land was OK for me.
I'm going to try GM seed shortly.
Contributor ,
thanks!
Sep 15, 2017 Sep 15, 2017
I'm also have this problem in Window. How do you copy the ios SDK to ADobe AIR? I cannot find the location of Ios SDK in Adobe AIR folder in Window.
Nov 01, 2017 Nov 01, 2017
iOS SDK works only on macOS
Jan 22, 2020 Jan 22, 2020
Ok as you I can do it same procedures like
to here:
Hope its solved my problem.
Likes
