Hello! I was wondering on how I can fix this? It's not solid and I want it to be a solid color and not the spots?
Any one know how to? In an easy way
Thanks in advance
Your 2nd screenshot confirms this is vector.
IF you get this result
Then Ctrl 8 to make a compound path (like knocking a hole out of a doughnut) (or Smultringer if you are from Northern Europe)
Depends on what we are dealing with, cannot help much without better information
Select the item and go to appearance panel to tell you what you have selected
Paths or group - use hollow arrow tool, option click to elect and delete the inner noise
Live Type - Often the fonts have a companion that is not distressed so change font. Otherwise you need to outline type and do step as for paths
Image - unembed and open in photoshop and pain in the distressed noise.
Try switching to CPU Preview: Ctrl E (Win) or Cmd E (Mac) or turn it off in the Preferences > GPU Performance
That is the font, so not really a mistake. More of a "grunge"variation of an existing type face. What is the name given to this font? How many characters do you have to deal with? If it is not too many, you might try, on a copy, outlining the fonts > then using the Pathfinder tools, try merge or unit ( or minus front ). Worse case, on the outlined fonts, manually remove the Whites .
need more information:
1. is it Vector?
2. What font? is it Grunge font that his this look?
Best practices is to use the appearance panel:
Add new Fill
and select a solid Color.
select the previous fill and choose none.
And you will get a solid type.
But if the font is a grunge font you can create outline ad fill the white spots.
Hope this helps
If those are the only letters you need to fill in, you could use the Blob brush (otherwise I wouldn't recommend it--it'd be too tedious). If you want to clean up the edges, you could use Object > Path > Simplify...
Thank you guys for all the replies. I do not think is a font its draw from scratch i think.
It's paths. So select what you want with the group selection tool then inverse the selection and delete. My step 2.
If there are more than just those 3 letters, you could try and:
Release the group
Release the compound path
Select all , then deselect all punches (inner shape of a and o and the like)
in the pathfinder panel click on "Unite" (top left button)
Then select all and make compound path again.
I am assuming it is a raster image and not vector. So here are the steps.
1. Trace then expand the trace. (If you have a raster selected then you will have the option to use Image Trace in the Control panel) You can get rid of most of the extra paths by making the noise a larger number. (I left the noise to delete it a different way though I was able to rid almost all of the extra paths by making the noise 100) I also made sure I ignored the white so I would not have a path for the white area.
2. I used my Group Selection tool to select the three paths I wanted to keep. (highlighted in yellow) I used the shift key to add to my selection. Then I used Select>Inverse to select the opposite. (the small paths) Then I delete the selected items. (the paths you do not want)
3. Done. If you want to clean up the remaining paths just use Object>Path>Simplify...
