Hi all,
I have been creating a 3d scan effect in after effects following from surface studios tutorial and I ran into a problem. From my Grid effect composition sitting in the main comp you can see a white outline even the the layer is deselected. These 2 photos show the grid comp and the main comp. See how you can see outlines when the layer is deselected. Please help me find a solution
Check your composition dispaly settings in the relevant flyout menu and the global preferences (show bounding box and al lthat stuff)
Mylenium
Sorry I dont quite know where those settings options are. Could you please send a screenshot of the location those settings are.
Comp settings: cmd-k (mac) / ctl-k (win).
Preferences: Edit > Preferences.
Removing the bounding box got rid of the lines outside the frame but the random white light are still rendering in the final comp.
Hi HeathC,
Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
Kevin
