Hi still have problems on www.filippocentenari.it
when loaded the message Missing Files comes up.
Always on Iphone- Chrome and Safari
On a Pc sometimes.
The web site is uploaded via Muse on the FTP.
Already changed the key in XML file appPrefs.xml
cannot update to new version of Muse because it will break my design completely !
PLEASE HELP
Here, the alert isnāt shown, when visiting your site. Maybe it is in fact a cache issue on your machine.
strange because on my Iphone 6 there is this warning
cache cleared...
Thanks for reporting.Please see if below links helps you in resolving the issue.
Some files on the server may be incorrect or missing
ALREADY SEEN THE PAGE YOU SUGGEST
I ALSO MODIFIED THE XML FILE
NO RESULT
Did you modify the xml file while Muse was closed? Because this file is a preference file, it will only be loaded, when Muse is launched.
sure!
the file has been modificed and Muse was closed
If you have any third party widgets, or external HTML code, can you try deleting them one by one to see if that helps?
Preran
