Hello,
On image I used Quick selection tool to selected and add Mask so image has transparent background.
Save for PNG then on file I really can not tell the different but some image has Black Backgroung....I don't what I did but some has White and other Black.
I have to open the file then I see which one has Transparent bg or I didn't work on it.
thank you for reading,
James
Hi All,
We have released a new update of Adobe Bridge (CC 2018) on 16 July 2018. The new version build number is 8.1.0.383. This version is available to install via Adobe Creative Cloud application.
This Bridge update contains support for SVG and PNG files, with transparency grid. Please also check the "Libraries" workspace after installing new version of Bridge CC.
You may need to update the Creative Cloud application and restart your computer to see the updated installer.
Deepak Gupta
The transparant parts of an image have a grey and white blocks pattern. Did you delete the background of the image?
yes,
how can you tell ? After you saved, I have to open the image then I see that image has Transparent BG.
Unfortunately, You can't tell right now. This request to allow Bridge to show transparency on file thumbnails has been submitted to Adobe. Not sure if they will act on it, but there are a lot of people urging Adobe to proceed with this request.
You mean I could tell by using Bridge?
From Photoshop, some image has Black Background and some images doesn't.
Do you know why?
thank you
No, you can't use Bridge at this point. We're trying to get Adobe to make it so you can. I'm not sure why you're seeing different bg colors. Normally you will see white, in Bridge or a browser if there is transparency.
You see here some has Black Background and white......It doesn't matter just wondering.
thank you
If you need thumbnails for your PSD files, sagethumbs can provide those at no extra cost.
Make sure "Show Transparency Grid" is checked on in Bridge Preferences, and you will see the familiar transparency checkerboard in Bridge's thumbnails and Previews. As mentioned before, only SVG and PNG file transparency. TIFF, PSD, etc... not yet.
Only if you are saving files as PNG-24 while you kept the foreground color as black, it will show you black in preview. (see the following image please. I did with a screenshot image)
Hi All,
Deepak Gupta
