hi guys
i know its been asked before but no concrete solution has been found and its quite maddening that this wont go away, the project manager window and even eye dropper tool menus are getting stuck behind the playback window on second monitor and nothing can be done but force quitting the program and shutting it off and then back on, is there any solution that doesn't require binning preferences as im in a big post house with several workspaces and custom settings i cant delete
I'm not quite certain what you're asking. Can you take a screenshot of the issue?
no sorry thats kinda the point is you cant see it, windows open up automatically behind the playback monitor and then all the options in the top bar are greyed out so you are stuck, you cant get to the window to move it and you cant turn off the playback monitor to get to the window behind it
Can you go to Window - Workspaces - Reset to Saved Layout? Or can you grab the playback monitor window and move it out of the way so you can grab the tools and attach them elsewhere?
