Scaling the object without distorting it
Engaged ,
Sep 14, 2017 Sep 14, 2017
Hi!
I have an object with rounded corners at left top and right bottom. the whole thing is "bent" to right with 25%. It´s the background for short texts. Sometimes the text needs two lines, sometimes only one. The width is different as well.
Is it possible to change the width OR the hight of an object (created by me) without distorting it? And I am not meaning, with the "direct selection"-tool (white arrow) by marking each point I want to move.
hopfully my explanation is clear enough...
thanx
11.5K
Community Expert , Sep 14, 2017 Sep 14, 2017
Maybe this image will help. The 9-slice will really only work with the horizontal scaling here, so you'll have to decide how you want vertical scaling to look. You could just proportionally scale it, but I don't think that's what you want. I think what you're looking for might be if you cut the bubble from the triangle and proportionally scale it. Before you scale, move the pivot point to the right corner where the triangle and bubble meet.
Also here's a video on 9-slice scaling Using 9-slice scaling options with symbols
Adobe
Guide ,
If it is a Vector image, select it all, Expand it and then use the Scale tool to scale it by however many times are necessary. If it has a stroke applied you may want to select the Scale Strokes option before doing so.
hope this helps
Engaged ,
Hi theangietaylor
it is a vector. Maybe I was not that clear: I change only one parameter. Either the width or the height. The angle and the radius must stay the same!
here some exemples:
two lines (correct shape)
two lines (wrong shape)
one line (correct shape)
one line (wrong shape)
Are the rounded corners created with the round corners widget?
Because then they wouldn't be such a pain.
But it would still be impossible to make it longer in this tilted direction without using the sirect selection tool.
You might want to show us before and after and provide a sample file, so that not everyone has to rebuild the thing.
Engaged ,
... in InDesign it´s no problem.
Not quite.
The sheared rectangle with rounded corners is no problem. But as soon as this triangle is added to the shape, you will get a problem.
Guide ,
I'd be tempted to separate he triangle at the bottom from the main "balloon" so that they are two distinct objects grouped together. Then to scale the balloon, double click to go into Isolation mode where it can be scaled without affecting the "triangle"?
Engaged ,
you´re right, there ARE two objects. Otherwise it would be inpossible.
The pointing shape ("triangle") never changing.
Convert it to a symbol (F8) and select Enable Guides for 9-Slice Scaling. Then adjust the guides. What is outside the guides won't change when you scale the symbol.
Engaged ,
It´s an interresting feature. Thanks Myra!
Unfurtunately I didn´t found out yet how to use it for solving my problem...
But I´m not giving up.
Engaged ,
Sep 15, 2017 Sep 15, 2017
Ok. thank you Myra.
The solution would be: two forms. One for simple and one for double lines. Both variable in width.
Guide ,
And try my suggestion of using isolation mode for the scaling, it may be the easiest way to achieve the resizing of the individual object from the group.
hope this helps 🙂
Engaged ,
I will! thanks
