I m trying to set up indesign server cc 2015 with mulitple session.
So that concurrent users can execute the extended javascripts.
I have already configured using default settings and for a single user all work good.
Accessing indesign server using SAOP.
Does Indesign server cc 2015 with mulitple sessions ?
If Yes, please get some samples to refer.
Moving to InDesign Server Developers forum
I suppose by multiple session you mean multiple instances of InDesign Server, if this is so then you can launch multiple instances exactly as you did with one instances. Open a new command prompt and type in the command to launch IDS for SOAP requests on a new port. Now you would have two instances of IDS running and you can direct your scripts to these instances using the sampleclient application
For ex
1st Command Window
indesignserver -port 34567
2nd Command Window
indesignserver -port 14567
Refer the URL below for examples and more details
-Manan
Just for reference, he was not meaning multi-instances but multi-session
There is a mechanism which let you open multiple session in a single instance of IDS introduced in CC version.
His problem is more detailed here :
