I was originally a CC user but moved to the photographer only (PS & LR) for a period, while I wasn't doing any video. I moved back to CC several months ago and am frustrated because PS tells me it's the trial version and I have to login with my Adode ID every single time. It is only PS, all other apps can be accessed without login.
In my Adobe account everything looks active, there is a current payment method that is being used and I have updated PS a couple of times.
Any experience of this and suggestions for fixing it?
David.
Well, after an hour and a half on the support line, they finally got round to trying removal of the Desktop Application Manager and deleting all the associated caches (also closing out all relevant apps in the activity monitor). They reinstalled it from a fresh download from Adobe and, after an initial sign-in, it has worked. It seems a couple of files for both PS and AI were corrupted and deleting and reinstalling has rebuilt them, resulting in both apps working without the need to license the
...Copy link to clipboard
Check your Adobe account you login with the Adobe Creative Cloud Desktop application has your full CC plan. If it does sign out from the desktop application and then sign back in using the Adobe Creative cloud desktop application that should activate your PS install.
Thanks for the advice JJMack. I've tired to log out and back in over the last few months (and I've just what you suggested now). I still get the same popup but it is only for PS (AI,AE,PR, CH, AU, BR etc all work without the request).
If I choose the 'License This Software', I get the option to use my account name and it tells me it's now registered but next time I need to start it up, same message.
Did you login at Adobe.com and manage your Acount plans to make sure your account you sign in with has your plan associated with it?
Yes - everything looks normal to me. Just to reiterate though - everything else on CC is working normally. It is only the PS app that is telling me it's a trial version and need to license it. Although I've checked everything, I would also assume that all of the other apps would be telling me they're trial version if the account set wasn't correct.
Even if I uninstall PS and reinstall it, I get the same issue.
This is after I've registered (every time)
I've had the same AdobeID since I first registered for CC about three years ago. When I opt for License This Software, it auto selects my AdobeID, so it knows it's me. Everything but PS seems to be registered and working correctly.
David did you sign out using the Adobe creative Cloud Desktop application then sign back in? That Application is what activates your installed applications.
I think you mean this (below) then yes, otherwise I don't have another app for management and I've only ever used this.
Looking around the Launchpad, there are no other management apps for Adobe.
Yes - that was what you suggested I do in the initial response and I've been signed out there a number of times in the last few months but nothing has changed in terms of PS. Here are the shots...
Signed out
2 step verification challenge
Signed back in
Me opening PS
I have never see that code thing happen You may need to contact Adobe Customet support, This I what I see. I just sign in and I can see my APPS. Did you get that Phone call and enter the code phoned to you? I do not want the Phone thing what if your away frome home without a cell phone. I do not have a mobile Phone.
Earlier this week I was trying to help someone in the Lightroom forum who is having the same problem. I provided all the same advice to him that JJMack provided for you. I don't think they ever resolved their sign in problem.
You may want to try removing everything with the Adobe Cleaner Tool Use the Creative Cloud Cleaner Tool to solve installation problems and then start over with the installs. If that doesn't work you'll probably have to contact Adobe Customer Care contact-bumper.
If you solve the problem please let us know how it was fixed.
I think you need to contact Adobe Customer support. I do not know how Creative cloud work on Macs. Adobe has a big cloud around their phone support a very circular flight for sure consistant and sure. Use google to find the number in you country. Most likely it will ring in a foreign country...
Well, after an hour and a half on the support line, they finally got round to trying removal of the Desktop Application Manager and deleting all the associated caches (also closing out all relevant apps in the activity monitor). They reinstalled it from a fresh download from Adobe and, after an initial sign-in, it has worked. It seems a couple of files for both PS and AI were corrupted and deleting and reinstalling has rebuilt them, resulting in both apps working without the need to license the software every time.
I thought that may be the case. Its a hard pill to swallow when I tell user to remove all Adobe software use Adobe cleaner and re-install all.
Adobe Customer support is good at fixing installation problems. Bug support not good at all IMO.
David, Thank you for following up and letting us know what was done to fix this problem.
